RTEMS  5.1
bsp.h
1
9 /* bsp.h
10  *
11  * This include file contains all MVME147 board IO definitions.
12  *
13  * COPYRIGHT (c) 1989-1999.
14  * On-Line Applications Research Corporation (OAR).
15  *
16  * The license and distribution terms for this file may be
17  * found in the file LICENSE in this distribution or at
18  * http://www.rtems.org/license/LICENSE.
19  *
20  * MVME147 port for TNI - Telecom Bretagne
21  * by Dominique LE CAMPION (Dominique.LECAMPION@enst-bretagne.fr)
22  * May 1996
23  */
24
25 #ifndef LIBBSP_M68K_MVME147S_BSP_H
26 #define LIBBSP_M68K_MVME147S_BSP_H
27
38 #include <bspopts.h>
40
41 #include <rtems.h>
42
43 #ifdef __cplusplus
44 extern "C" {
45 #endif
46
47 /* Constants */
48
49 #define RAM_START 0x00007000
50 #define RAM_END 0x003e0000
51 #define DRAM_END 0x00400000
52  /* We leave 128k for the shared memory */
53
54  /* MVME 147 Peripheral controller chip
55  see MVME147/D1, 3.4 */
56
57 struct pcc_map {
58  /* 32 bit registers */
59  uint32_t dma_table_address; /* 0xfffe1000 */
60  uint32_t dma_data_address; /* 0xfffe1004 */
61  uint32_t dma_bytecount; /* 0xfffe1008 */
62  uint32_t dma_data_holding; /* 0xfffe100c */
63
64  /* 16 bit registers */
65  uint16_t timer1_preload; /* 0xfffe1010 */
66  uint16_t timer1_count; /* 0xfffe1012 */
67  uint16_t timer2_preload; /* 0xfffe1014 */
68  uint16_t timer2_count; /* 0xfffe1016 */
69
70  /* 8 bit registers */
71  uint8_t timer1_int_control; /* 0xfffe1018 */
72  uint8_t timer1_control; /* 0xfffe1019 */
73  uint8_t timer2_int_control; /* 0xfffe101a */
74  uint8_t timer2_control; /* 0xfffe101b */
75
76  uint8_t acfail_int_control; /* 0xfffe101c */
77  uint8_t watchdog_control; /* 0xfffe101d */
78
79  uint8_t printer_int_control; /* 0xfffe101e */
80  uint8_t printer_control; /* 0xfffe102f */
81
82  uint8_t dma_int_control; /* 0xfffe1020 */
83  uint8_t dma_control; /* 0xfffe1021 */
84  uint8_t bus_error_int_control; /* 0xfffe1022 */
85  uint8_t dma_status; /* 0xfffe1023 */
86  uint8_t abort_int_control; /* 0xfffe1024 */
87  uint8_t table_address_function_code; /* 0xfffe1025 */
88  uint8_t serial_port_int_control; /* 0xfffe1026 */
89  uint8_t general_purpose_control; /* 0xfffe1027 */
90  uint8_t lan_int_control; /* 0xfffe1028 */
91  uint8_t general_purpose_status; /* 0xfffe1029 */
92  uint8_t scsi_port_int_control; /* 0xfffe102a */
93  uint8_t slave_base_address; /* 0xfffe102b */
94  uint8_t software_int_1_control; /* 0xfffe102c */
95  uint8_t int_base_vector; /* 0xfffe102d */
96  uint8_t software_int_2_control; /* 0xfffe102e */
97  uint8_t revision_level; /* 0xfffe102f */
98 };
99
100 #define pcc ((volatile struct pcc_map * const) 0xfffe1000)
101
102 /* VME chip configuration registers */
103
104 struct vme_lcsr_map {
105  uint8_t unused_1;
106  uint8_t system_controller; /* 0xfffe2001 */
107  uint8_t unused_2;
108  uint8_t vme_bus_requester; /* 0xfffe2003 */
109  uint8_t unused_3;
110  uint8_t master_configuration; /* 0xfffe2005 */
111  uint8_t unused_4;
112  uint8_t slave_configuration; /* 0xfffe2007 */
113  uint8_t unused_5;
114  uint8_t timer_configuration; /* 0xfffe2009 */
115  uint8_t unused_6;
116  uint8_t slave_address_modifier; /* 0xfffe200b */
117  uint8_t unused_7;
118  uint8_t master_address_modifier; /* 0xfffe200d */
119  uint8_t unused_8;
120  uint8_t interrupt_handler_mask; /* 0xfffe200f */
121  uint8_t unused_9;
122  uint8_t utility_interrupt_mask; /* 0xfffe2011 */
123  uint8_t unused_10;
124  uint8_t utility_interrupt_vector; /* 0xfffe2013 */
125  uint8_t unused_11;
126  uint8_t interrupt_request; /* 0xfffe2015 */
127  uint8_t unused_12;
128  uint8_t vme_bus_status_id; /* 0xfffe2017 */
129  uint8_t unused_13;
130  uint8_t bus_error_status; /* 0xfffe2019 */
131  uint8_t unused_14;
132  uint8_t gcsr_base_address; /* 0xfffe201b */
133 };
134
135 #define vme_lcsr ((volatile struct vme_lcsr_map * const) 0xfffe2000)
136
137 struct vme_gcsr_map {
138  uint8_t unused_1;
139  uint8_t global_0; /* 0xfffe2021 */
140  uint8_t unused_2;
141  uint8_t global_1; /* 0xfffe2023 */
142  uint8_t unused_3;
143  uint8_t board_identification; /* 0xfffe2025 */
144  uint8_t unused_4;
145  uint8_t general_purpose_0; /* 0xfffe2027 */
146  uint8_t unused_5;
147  uint8_t general_purpose_1; /* 0xfffe2029 */
148  uint8_t unused_6;
149  uint8_t general_purpose_2; /* 0xfffe202b */
150  uint8_t unused_7;
151  uint8_t general_purpose_3; /* 0xfffe202d */
152  uint8_t unused_8;
153  uint8_t general_purpose_4; /* 0xfffe202f */
154 };
155
156 #define vme_gcsr ((volatile struct vme_gcsr_map * const) 0xfffe2020)
157
158 #define z8530 0xfffe3001
159
160 /* interrupt vectors - see MVME147/D1 4.14 */
161 #define PCC_BASE_VECTOR 0x40 /* First user int */
162 #define SCC_VECTOR PCC_BASE_VECTOR+3
163 #define TIMER_1_VECTOR PCC_BASE_VECTOR+8
164 #define TIMER_2_VECTOR PCC_BASE_VECTOR+9
165 #define SOFT_1_VECTOR PCC_BASE_VECTOR+10
166 #define SOFT_2_VECTOR PCC_BASE_VECTOR+11
167
168 #define VME_BASE_VECTOR 0x50
169 #define VME_SIGLP_VECTOR VME_BASE_VECTOR+1
170
171 #define USE_CHANNEL_A 1 /* 1 = use channel A for console */
172 #define USE_CHANNEL_B 0 /* 1 = use channel B for console */
173
174 #if (USE_CHANNEL_A == 1)
175 #define CONSOLE_CONTROL 0xfffe3002
176 #define CONSOLE_DATA 0xfffe3003
177 #elif (USE_CHANNEL_B == 1)
178 #define CONSOLE_CONTROL 0xfffe3000
179 #define CONSOLE_DATA 0xfffe3001
180 #endif
181
182 #define FOREVER 1 /* infinite loop */
183
184 #ifdef M147_INIT
185 #undef EXTERN
186 #define EXTERN
187 #else
188 #undef EXTERN
189 #define EXTERN extern
190 #endif
191
192 extern rtems_isr_entry M68Kvec[]; /* vector table address */
193
194 /*
195  * NOTE: Use the standard Clock driver entry
196  */
197
198 /* functions */
199
200 rtems_isr_entry set_vector(
201  rtems_isr_entry handler,
202  rtems_vector_number vector,
203  int type
204 );
205
206 #ifdef __cplusplus
207 }
208 #endif
209
212 #endif
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Definition: bsp.h:104
Definition: bsp.h:137
Definition: bsp.h:55
