RTEMS  5.1
bsp.h
1
9 /* bsp.h
10  *
11  * This include file contains all MVME147 board IO definitions.
12  *
13  * COPYRIGHT (c) 1989-1999.
14  * On-Line Applications Research Corporation (OAR).
15  *
16  * The license and distribution terms for this file may be
17  * found in the file LICENSE in this distribution or at
18  * http://www.rtems.org/license/LICENSE.
19  *
20  * MVME147 port for TNI - Telecom Bretagne
21  * by Dominique LE CAMPION (Dominique.LECAMPION@enst-bretagne.fr)
22  * May 1996
23  */
24
25 #ifndef LIBBSP_M68K_MVME147_BSP_H
26 #define LIBBSP_M68K_MVME147_BSP_H
27
38 #include <bspopts.h>
40
41 #include <rtems.h>
42
43 #ifdef __cplusplus
44 extern "C" {
45 #endif
46
47 /* Constants */
48
49 #define RAM_START 0x00005000
50 #define RAM_END 0x00400000
51
52  /* MVME 147 Peripheral controller chip
53  see MVME147/D1, 3.4 */
54
55 struct pcc_map {
56  /* 32 bit registers */
57  uint32_t dma_table_address; /* 0xfffe1000 */
58  uint32_t dma_data_address; /* 0xfffe1004 */
59  uint32_t dma_bytecount; /* 0xfffe1008 */
60  uint32_t dma_data_holding; /* 0xfffe100c */
61
62  /* 16 bit registers */
63  uint16_t timer1_preload; /* 0xfffe1010 */
64  uint16_t timer1_count; /* 0xfffe1012 */
65  uint16_t timer2_preload; /* 0xfffe1014 */
66  uint16_t timer2_count; /* 0xfffe1016 */
67
68  /* 8 bit registers */
69  uint8_t timer1_int_control; /* 0xfffe1018 */
70  uint8_t timer1_control; /* 0xfffe1019 */
71  uint8_t timer2_int_control; /* 0xfffe101a */
72  uint8_t timer2_control; /* 0xfffe101b */
73
74  uint8_t acfail_int_control; /* 0xfffe101c */
75  uint8_t watchdog_control; /* 0xfffe101d */
76
77  uint8_t printer_int_control; /* 0xfffe101e */
78  uint8_t printer_control; /* 0xfffe102f */
79
80  uint8_t dma_int_control; /* 0xfffe1020 */
81  uint8_t dma_control; /* 0xfffe1021 */
82  uint8_t bus_error_int_control; /* 0xfffe1022 */
83  uint8_t dma_status; /* 0xfffe1023 */
84  uint8_t abort_int_control; /* 0xfffe1024 */
85  uint8_t table_address_function_code; /* 0xfffe1025 */
86  uint8_t serial_port_int_control; /* 0xfffe1026 */
87  uint8_t general_purpose_control; /* 0xfffe1027 */
88  uint8_t lan_int_control; /* 0xfffe1028 */
89  uint8_t general_purpose_status; /* 0xfffe1029 */
90  uint8_t scsi_port_int_control; /* 0xfffe102a */
91  uint8_t slave_base_address; /* 0xfffe102b */
92  uint8_t software_int_1_control; /* 0xfffe102c */
93  uint8_t int_base_vector; /* 0xfffe102d */
94  uint8_t software_int_2_control; /* 0xfffe102e */
95  uint8_t revision_level; /* 0xfffe102f */
96 };
97
98 #define pcc ((volatile struct pcc_map * const) 0xfffe1000)
99
100 #define z8530 0xfffe3001
101
102 /* interrupt vectors - see MVME146/D1 4.14 */
103 #define PCC_BASE_VECTOR 0x40 /* First user int */
104 #define SCC_VECTOR PCC_BASE_VECTOR+3
105 #define TIMER_1_VECTOR PCC_BASE_VECTOR+8
106 #define TIMER_2_VECTOR PCC_BASE_VECTOR+9
107 #define SOFT_1_VECTOR PCC_BASE_VECTOR+10
108 #define SOFT_2_VECTOR PCC_BASE_VECTOR+11
109
110 #define USE_CHANNEL_A 1 /* 1 = use channel A for console */
111 #define USE_CHANNEL_B 0 /* 1 = use channel B for console */
112
113 #if (USE_CHANNEL_A == 1)
114 #define CONSOLE_CONTROL 0xfffe3002
115 #define CONSOLE_DATA 0xfffe3003
116 #elif (USE_CHANNEL_B == 1)
117 #define CONSOLE_CONTROL 0xfffe3000
118 #define CONSOLE_DATA 0xfffe3001
119 #endif
120
121 extern rtems_isr_entry M68Kvec[]; /* vector table address */
122
123 /* functions */
124
125 rtems_isr_entry set_vector(
126  rtems_isr_entry handler,
127  rtems_vector_number vector,
128  int type
129 );
130
131 #ifdef __cplusplus
132 }
133 #endif
134
137 #endif
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Definition: bsp.h:55
