RTEMS  5.1
bsp.h
1
9 /*
10  * mcf5235 BSP header file
11  */
12
13 #ifndef LIBBSP_M68K_MCF5235_BSP_H
14 #define LIBBSP_M68K_MCF5235_BSP_H
15
26 #include <bspopts.h>
28 #include <rtems.h>
29 #include <rtems/bspIo.h>
30
31 /***************************************************************************/
33 #include <mcf5235/mcf5235.h> /* internal MCF5235 modules */
34
35 #ifdef __cplusplus
36 extern "C" {
37 #endif
38
39 /***************************************************************************/
41 struct rtems_bsdnet_ifconfig;
42 extern int rtems_fec_driver_attach (struct rtems_bsdnet_ifconfig *config, int attaching );
43 #define RTEMS_BSP_NETWORK_DRIVER_NAME "fec0"
44 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_fec_driver_attach
45
46 /***************************************************************************/
49 /* define which port the console should use - all other ports are then defined as general purpose */
50 #define CONSOLE_PORT 0
51
52 /* functions */
53
54 uint32_t get_CPU_clock_speed(void);
55 rtems_isr_entry set_vector(
56  rtems_isr_entry handler,
57  rtems_vector_number vector,
58  int type
59 );
60
61 /*
62  * Interrupt assignments
63  * Highest-priority listed first
64  */
65 #define FEC_IRQ_LEVEL 4
66 #define FEC_IRQ_RX_PRIORITY 7
67 #define FEC_IRQ_TX_PRIORITY 6
68
69 #define PIT3_IRQ_LEVEL 4
70 #define PIT3_IRQ_PRIORITY 0
71
72 #define UART0_IRQ_LEVEL 3
73 #define UART0_IRQ_PRIORITY 7
74 #define UART1_IRQ_LEVEL 3
75 #define UART1_IRQ_PRIORITY 6
76 #define UART2_IRQ_LEVEL 3
77 #define UART2_IRQ_PRIORITY 5
78
79 /*
80  * Prototypes for BSP methods which cross file boundaries
81  */
82 void Init5235(void);
83
84 #ifdef __cplusplus
85 }
86 #endif
87
90 #endif
Definition: deflate.c:115
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Interface to Kernel Print Methods.
