RTEMS  5.1
bsp.h
1
9 /*
10  * Board Support Package for `Generic' Motorola MC68340
11  *
12  * Based on the `gen68360' board support package, and covered by the
13  * original distribution terms.
14  */
15
16 /* bsp.h
17  *
18  * COPYRIGHT (c) 1989-1999.
19  * On-Line Applications Research Corporation (OAR).
20  *
21  * The license and distribution terms for this file may be
22  * found in the file LICENSE in this distribution or at
23  * http://www.rtems.org/license/LICENSE.
24  */
25
26 #ifndef LIBBSP_M68K_GEN68340_BSP_H
27 #define LIBBSP_M68K_GEN68340_BSP_H
28
39 #ifndef ASM
40
41 #include <bspopts.h>
43
44 #include <rtems.h>
45
46 #ifdef __cplusplus
47 extern "C" {
48 #endif
49
50 /* Constants */
51
52 /* Structures */
53
54 extern rtems_isr_entry M68Kvec[]; /* vector table address */
55
56 /* functions */
57
58 rtems_isr_entry set_vector(
59  rtems_isr_entry handler,
60  rtems_vector_number vector,
61  int type
62 );
63
64 /*
65  * Methods used across files inside the BSP
66  */
67 int dbug_in_char( int minor );
68 void dbug_out_char( int minor, int ch );
69 int dbug_char_present( int minor );
70 void _dbug_dumpanic(void);
71
72 /*
73  * Only called from .S but prototyped here to capture the dependecy.
74  */
75 void _Init68340 (void);
76
77 #ifdef __cplusplus
78 }
79 #endif
80
81 #endif /* !ASM */
82
85 #endif
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
