RTEMS  5.1
bsp.h
1
9 /*
10  * COPYRIGHT (c) 1989-1999.
11  * On-Line Applications Research Corporation (OAR).
12  *
13  * The license and distribution terms for this file may be
14  * found in the file LICENSE in this distribution or at
15  * http://www.rtems.org/license/LICENSE.
16  *
17  * Jukka Pietarinen <jukka.pietarinen@mrf.fi>, 2008,
18  * Micro-Research Finland Oy
19  */
20
21 #ifndef LIBBSP_LM32_LM32_EVR_BSP_H
22 #define LIBBSP_LM32_LM32_EVR_BSP_H
23
33 #include <stdint.h>
34 #include <bspopts.h>
36
37 #include <rtems.h>
38
39 #ifdef __cplusplus
40 extern "C" {
41 #endif
42
43 /*
44  * lm32 requires certain aligment of mbuf because unaligned uint32_t
45  * accesses are not handled properly.
46  */
47
48 #define CPU_U32_FIX
49
50 #if defined(RTEMS_NETWORKING)
51 struct rtems_bsdnet_ifconfig;
52
53 extern int rtems_tsmac_driver_attach(struct rtems_bsdnet_ifconfig *config,
54  int attaching);
55
56 #define RTEMS_BSP_NETWORK_DRIVER_NAME "TSMAC0"
57 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_tsmac_driver_attach
58
59  /*
60  * Due to a hardware design error (RJ45 connector with 10baseT magnetics)
61  * we are forced to use 10baseT mode.
62  */
63
64 #define TSMAC_FORCE_10BASET
65 #endif
66
67 /* functions */
68 rtems_isr_entry set_vector( /* returns old vector */
69  rtems_isr_entry handler, /* isr routine */
70  rtems_vector_number vector, /* vector number */
71  int type /* RTEMS or RAW intr */
72 );
73
74 /*
75  * Prototypes for BSP methods that cross file boundaries
76  */
77 void BSP_uart_polled_write(char ch);
78 int BSP_uart_polled_read( void );
79 char BSP_uart_is_character_ready(char *ch);
80
81 #ifdef __cplusplus
82 }
83 #endif
84
87 #endif
88 /* end of include file */
Definition: deflate.c:115
rtems_isr_entry set_vector(rtems_isr_entry handler, rtems_vector_number vector, int type)
Install an interrupt handler.
Definition: setvec.c:28
DEFAULT_INITIAL_EXTENSION Support.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
