#define | BSP_HAS_FRAME_BUFFER 1 |
#define | BSP_NE2000_NETWORK_DRIVER_NAME "ne1" |
#define | BSP_NE2000_NETWORK_DRIVER_ATTACH rtems_ne_driver_attach |
#define | BSP_WD8003_NETWORK_DRIVER_NAME "wd1" |
#define | BSP_WD8003_NETWORK_DRIVER_ATTACH rtems_wd_driver_attach |
#define | BSP_DEC21140_NETWORK_DRIVER_NAME "dc1" |
#define | BSP_DEC21140_NETWORK_DRIVER_ATTACH rtems_dec21140_driver_attach |
#define | BSP_3C509_NETWORK_DRIVER_NAME "3c1" |
#define | BSP_3C509_NETWORK_DRIVER_ATTACH rtems_3c509_driver_attach |
#define | RTEMS_BSP_NETWORK_DRIVER_NAME BSP_DEC21140_NETWORK_DRIVER_NAME |
#define | RTEMS_BSP_NETWORK_DRIVER_ATTACH BSP_DEC21140_NETWORK_DRIVER_ATTACH |
#define | IO_TIMER1 0x40 |
#define | TIMER_CNTR0 (IO_TIMER1 + 0) /* timer 0 counter port */ |
#define | TIMER_CNTR1 (IO_TIMER1 + 1) /* timer 1 counter port */ |
#define | TIMER_CNTR2 (IO_TIMER1 + 2) /* timer 2 counter port */ |
#define | TIMER_MODE (IO_TIMER1 + 3) /* timer mode port */ |
#define | TIMER_SEL0 0x00 /* select counter 0 */ |
#define | TIMER_SEL1 0x40 /* select counter 1 */ |
#define | TIMER_SEL2 0x80 /* select counter 2 */ |
#define | TIMER_INTTC 0x00 /* mode 0, intr on terminal cnt */ |
#define | TIMER_ONESHOT 0x02 /* mode 1, one shot */ |
#define | TIMER_RATEGEN 0x04 /* mode 2, rate generator */ |
#define | TIMER_SQWAVE 0x06 /* mode 3, square wave */ |
#define | TIMER_SWSTROBE 0x08 /* mode 4, s/w triggered strobe */ |
#define | TIMER_HWSTROBE 0x0a /* mode 5, h/w triggered strobe */ |
#define | TIMER_LATCH 0x00 /* latch counter for reading */ |
#define | TIMER_LSB 0x10 /* r/w counter LSB */ |
#define | TIMER_MSB 0x20 /* r/w counter MSB */ |
#define | TIMER_16BIT 0x30 /* r/w counter 16 bits, LSB first */ |
#define | TIMER_BCD 0x01 /* count in BCD */ |
#define | TIMER_RD_BACK 0xc0 /* Read Back Command */ |
#define | RB_NOT_COUNT 0x40 /* Don't select counter latch */ |
#define | RB_NOT_STATUS 0x20 /* Don't select status latch */ |
#define | RB_COUNT_0 0x02 /* Counter 0 latch */ |
#define | RB_COUNT_1 0x04 /* Counter 1 latch */ |
#define | RB_COUNT_2 0x08 /* Counter 2 latch */ |
#define | RB_OUTPUT 0x80 /* Output of the counter is 1 */ |
#define | TIMER_TICK 1193182 /* The internal tick rate in ticks per second */ |
#define | BSP_CONSOLE_VGA 0 |
#define | BSP_CONSOLE_COM1 1 |
#define | BSP_CONSOLE_COM2 2 |
#define | US_TO_TICK(us) (((us)*105+44)/88) |
#define | TICK_TO_US(tk) (((tk)*88+52)/105) |
#define | BSP_IDLE_TASK_BODY bsp_idle_thread |
#define | BSP_CONSOLE_PORT_CONSOLE (-1) |
#define | BSP_CONSOLE_PORT_COM1 (BSP_UART_COM1) |
#define | BSP_CONSOLE_PORT_COM2 (BSP_UART_COM2) |
