RTEMS
5.1
bsps
i386
include
bsp
irq.h
1
7
/* irq.h
8
9
* This include file describe the data structure and the functions implemented
10
* by rtems to write interrupt handlers.
11
12
* CopyRight (C) 1998 valette@crf.canon.fr
13
14
* This code is heavilly inspired by the public specification of STREAM V2
15
* that can be found at :
16
17
* <http://www.chorus.com/Documentation/index.html> by following
18
* the STREAM API Specification Document link.
19
20
* The license and distribution terms for this file may be
21
* found in the file LICENSE in this distribution or at
22
* http://www.rtems.org/license/LICENSE.
23
24
32
#ifndef _IRQ_H_
33
#define _IRQ_H_
34
35
#ifdef __cplusplus
36
extern
"C"
37
#endif
38
43
bsp/irq_asm.h
44
rtems.h
45
#define BSP_SHARED_HANDLER_SUPPORT 1
46
rtems/irq.h
47
rtems/irq-extension.h
48
49
50
| Constants
51
52
54
#define BSP_IRQ_VECTOR_BASE BSP_ASM_IRQ_VECTOR_BASE
55
#define BSP_IRQ_LINES_NUMBER 16
56
#define BSP_IRQ_MAX_ON_i8259A (BSP_IRQ_LINES_NUMBER - 1)
57
58
59
* Define the number of valid vectors. This is different to the number of IRQ
60
* signals supported. Use this value to allocation vector data or range check.
61
62
#define BSP_IRQ_VECTOR_NUMBER 17
63
#define BSP_IRQ_VECTOR_LOWEST_OFFSET 0
64
#define BSP_IRQ_VECTOR_MAX_OFFSET (BSP_IRQ_VECTOR_NUMBER - 1)
65
72
#define BSP_PERIODIC_TIMER 0
/* fixed on all builds of PC */
73
#define BSP_KEYBOARD 1
74
#define BSP_UART_COM2_IRQ 3
/* fixed for ISA bus */
75
#define BSP_UART_COM1_IRQ 4
76
#define BSP_UART_COM3_IRQ 5
77
#define BSP_UART_COM4_IRQ 6
78
#define BSP_RT_TIMER1 8
79
#define BSP_RT_TIMER3 10
80
#define BSP_SMP_IPI 16
/* not part of the ATPIC */
81
82
#define BSP_INTERRUPT_VECTOR_MIN BSP_IRQ_VECTOR_LOWEST_OFFSET
83
#define BSP_INTERRUPT_VECTOR_MAX BSP_IRQ_VECTOR_MAX_OFFSET
84
88
typedef
unsigned
short
rtems_i8259_masks
89
92
#ifdef __cplusplus
93
94
#endif
95
96
#endif
/* _IRQ_H_ */
rtems_i8259_masks
unsigned short rtems_i8259_masks
Type definition for RTEMS managed interrupts.
Definition:
irq.h:88
irq-extension.h
Header file for the Interrupt Manager Extension.
rtems.h
irq.h
irq_asm.h
