RTEMS  5.1
io.h
1
7 /*
8  * Copyright (c) 2012 Sebastian Huber. All rights reserved.
9  *
10  * embedded brains GmbH
11  * Obere Lagerstr. 30
12  * 82178 Puchheim
13  * Germany
14  * <rtems@embedded-brains.de>
15  *
16  * The license and distribution terms for this file may be
17  * found in the file LICENSE in this distribution or at
18  * http://www.rtems.org/license/LICENSE.
19  */
20
21 #ifndef LIBBSP_ARM_STM32F4_IO_H
22 #define LIBBSP_ARM_STM32F4_IO_H
23
24 #include <stdbool.h>
25 #include <stdint.h>
26 #include <bspopts.h>
27
28 #ifdef __cplusplus
29 extern "C" {
30 #endif /* __cplusplus */
31
39 #define STM32F4_GPIO_PIN(port, index) ((((port) << 4) | (index)) & 0xff)
40
41 #define STM32F4_GPIO_PORT_OF_PIN(pin) (((pin) >> 4) & 0xf)
42
43 #define STM32F4_GPIO_INDEX_OF_PIN(pin) ((pin) & 0xf)
44
45 #ifdef STM32F4_FAMILY_F4XXXX
46
52 typedef enum {
53  STM32F4_GPIO_MODE_INPUT,
54  STM32F4_GPIO_MODE_OUTPUT,
55  STM32F4_GPIO_MODE_AF,
56  STM32F4_GPIO_MODE_ANALOG
57 } stm32f4_gpio_mode;
58
59 typedef enum {
60  STM32F4_GPIO_OTYPE_PUSH_PULL,
61  STM32F4_GPIO_OTYPE_OPEN_DRAIN
62 } stm32f4_gpio_otype;
63
64 typedef enum {
65  STM32F4_GPIO_OSPEED_2_MHZ,
66  STM32F4_GPIO_OSPEED_25_MHZ,
67  STM32F4_GPIO_OSPEED_50_MHZ,
68  STM32F4_GPIO_OSPEED_100_MHZ
69 } stm32f4_gpio_ospeed;
70
71 typedef enum {
72  STM32F4_GPIO_NO_PULL,
73  STM32F4_GPIO_PULL_UP,
74  STM32F4_GPIO_PULL_DOWN
75 } stm32f4_gpio_pull;
76
77 typedef enum {
78  STM32F4_GPIO_AF_SYSTEM = 0,
79  STM32F4_GPIO_AF_TIM1 = 1,
80  STM32F4_GPIO_AF_TIM2 = 1,
81  STM32F4_GPIO_AF_TIM3 = 2,
82  STM32F4_GPIO_AF_TIM4 = 2,
83  STM32F4_GPIO_AF_TIM5 = 2,
84  STM32F4_GPIO_AF_TIM8 = 3,
85  STM32F4_GPIO_AF_TIM9 = 3,
86  STM32F4_GPIO_AF_TIM10 = 3,
87  STM32F4_GPIO_AF_TIM11 = 3,
88  STM32F4_GPIO_AF_I2C1 = 4,
89  STM32F4_GPIO_AF_I2C2 = 4,
90  STM32F4_GPIO_AF_I2C3 = 4,
91  STM32F4_GPIO_AF_SPI1 = 5,
92  STM32F4_GPIO_AF_SPI2 = 5,
93  STM32F4_GPIO_AF_SPI3 = 6,
94  STM32F4_GPIO_AF_USART1 = 7,
95  STM32F4_GPIO_AF_USART2 = 7,
96  STM32F4_GPIO_AF_USART3 = 7,
97  STM32F4_GPIO_AF_UART4 = 8,
98  STM32F4_GPIO_AF_UART5 = 8,
99  STM32F4_GPIO_AF_USART6 = 8,
100  STM32F4_GPIO_AF_CAN1 = 9,
101  STM32F4_GPIO_AF_CAN2 = 9,
102  STM32F4_GPIO_AF_TIM12 = 9,
103  STM32F4_GPIO_AF_TIM13 = 9,
104  STM32F4_GPIO_AF_TIM14 = 9,
105  STM32F4_GPIO_AF_OTG_FS = 10,
106  STM32F4_GPIO_AF_OTG_HS = 10,
107  STM32F4_GPIO_AF_ETH = 11,
108  STM32F4_GPIO_AF_FSMC = 12,
109  STM32F4_GPIO_AF_OTG_HS_FS = 12,
110  STM32F4_GPIO_AF_SDIO = 12,
111  STM32F4_GPIO_AF_DCMI = 13,
112  STM32F4_GPIO_AF_EVENTOUT = 15
113 } stm32f4_gpio_af;
114
115 typedef union {
116  struct {
117  uint32_t pin_first : 8;
118  uint32_t pin_last : 8;
119  uint32_t mode : 2;
120  uint32_t otype : 1;
121  uint32_t ospeed : 2;
122  uint32_t pupd : 2;
123  uint32_t output : 1;
124  uint32_t af : 4;
125  uint32_t reserved : 4;
126  } fields;
127
128  uint32_t value;
129 } stm32f4_gpio_config;
130
131 #define STM32F4_GPIO_CONFIG_TERMINAL \
132  { { 0xff, 0xff, 0x3, 0x1, 0x3, 0x3, 0x1, 0xf, 0xf } }
133
136 #endif /* STM32F4_FAMILY_F4XXXX */
137 #ifdef STM32F4_FAMILY_F10XXX
138
144 typedef enum {
145  STM32F4_GPIO_MODE_INPUT,
146  STM32F4_GPIO_MODE_OUTPUT_10MHz,
147  STM32F4_GPIO_MODE_OUTPUT_2MHz,
148  STM32F4_GPIO_MODE_OUTPUT_50MHz
149 } stm32f4_gpio_mode;
150
151 typedef enum {
152  STM32F4_GPIO_CNF_IN_ANALOG = 0,
153  STM32F4_GPIO_CNF_IN_FLOATING = 1,
154  STM32F4_GPIO_CNF_IN_PULL_UPDOWN = 2,
155
156  STM32F4_GPIO_CNF_OUT_GPIO_PP = 0,
157  STM32F4_GPIO_CNF_OUT_GPIO_OD = 1,
158  STM32F4_GPIO_CNF_OUT_AF_PP = 2,
159  STM32F4_GPIO_CNF_OUT_AF_OD = 3,
160 } stm32f4_gpio_cnf;
161
162 typedef enum {
163  STM32F4_GPIO_REMAP_DONT_CHANGE,
164  STM32F4_GPIO_REMAP_SPI1_0,
165  STM32F4_GPIO_REMAP_SPI1_1,
166  STM32F4_GPIO_REMAP_I2C1_0,
167  STM32F4_GPIO_REMAP_I2C1_1,
168  STM32F4_GPIO_REMAP_USART1_0,
169  STM32F4_GPIO_REMAP_USART1_1,
170  STM32F4_GPIO_REMAP_USART2_0,
171  STM32F4_GPIO_REMAP_USART2_1,
172  STM32F4_GPIO_REMAP_USART3_0,
173  STM32F4_GPIO_REMAP_USART3_1,
174  STM32F4_GPIO_REMAP_USART3_3,
175  STM32F4_GPIO_REMAP_TIM1_0,
176  STM32F4_GPIO_REMAP_TIM1_1,
177  STM32F4_GPIO_REMAP_TIM1_3,
178  STM32F4_GPIO_REMAP_TIM2_0,
179  STM32F4_GPIO_REMAP_TIM2_1,
180  STM32F4_GPIO_REMAP_TIM2_2,
181  STM32F4_GPIO_REMAP_TIM2_3,
182  STM32F4_GPIO_REMAP_TIM3_0,
183  STM32F4_GPIO_REMAP_TIM3_2,
184  STM32F4_GPIO_REMAP_TIM3_3,
185  STM32F4_GPIO_REMAP_TIM4_0,
186  STM32F4_GPIO_REMAP_TIM4_1,
187  STM32F4_GPIO_REMAP_CAN1_0,
188  STM32F4_GPIO_REMAP_CAN1_2,
189  STM32F4_GPIO_REMAP_CAN1_3,
190  STM32F4_GPIO_REMAP_PD01_0,
191  STM32F4_GPIO_REMAP_PD01_1,
192  STM32F4_GPIO_REMAP_TIM5CH4_0,
193  STM32F4_GPIO_REMAP_TIM5CH4_1,
194  STM32F4_GPIO_REMAP_ADC1_ETRGINJ_0,
195  STM32F4_GPIO_REMAP_ADC1_ETRGINJ_1,
196  STM32F4_GPIO_REMAP_ADC1_ETRGREG_0,
197  STM32F4_GPIO_REMAP_ADC1_ETRGREG_1,
198  STM32F4_GPIO_REMAP_ADC2_ETRGINJ_0,
199  STM32F4_GPIO_REMAP_ADC2_ETRGINJ_1,
200  STM32F4_GPIO_REMAP_ADC2_ETRGREG_0,
201  STM32F4_GPIO_REMAP_ADC2_ETRGREG_1,
202  STM32F4_GPIO_REMAP_ETH_0,
203  STM32F4_GPIO_REMAP_ETH_1,
204  STM32F4_GPIO_REMAP_CAN2_0,
205  STM32F4_GPIO_REMAP_CAN2_1,
206  STM32F4_GPIO_REMAP_MII_RMII_0,
207  STM32F4_GPIO_REMAP_MII_RMII_1,
208  STM32F4_GPIO_REMAP_SWJ_0,
209  STM32F4_GPIO_REMAP_SWJ_1,
210  STM32F4_GPIO_REMAP_SWJ_2,
211  STM32F4_GPIO_REMAP_SWJ_4,
212  STM32F4_GPIO_REMAP_SPI3_0,
213  STM32F4_GPIO_REMAP_SPI3_1,
214  STM32F4_GPIO_REMAP_TIM2ITR1_0,
215  STM32F4_GPIO_REMAP_TIM2ITR1_1,
216  STM32F4_GPIO_REMAP_PTP_PPS_0,
217  STM32F4_GPIO_REMAP_PTP_PPS_1,
218  STM32F4_GPIO_REMAP_TIM15_0,
219  STM32F4_GPIO_REMAP_TIM15_1,
220  STM32F4_GPIO_REMAP_TIM16_0,
221  STM32F4_GPIO_REMAP_TIM16_1,
222  STM32F4_GPIO_REMAP_TIM17_0,
223  STM32F4_GPIO_REMAP_TIM17_1,
224  STM32F4_GPIO_REMAP_CEC_0,
225  STM32F4_GPIO_REMAP_CEC_1,
226  STM32F4_GPIO_REMAP_TIM1_DMA_0,
227  STM32F4_GPIO_REMAP_TIM1_DMA_1,
228  STM32F4_GPIO_REMAP_TIM9_0,
229  STM32F4_GPIO_REMAP_TIM9_1,
230  STM32F4_GPIO_REMAP_TIM10_0,
231  STM32F4_GPIO_REMAP_TIM10_1,
232  STM32F4_GPIO_REMAP_TIM11_0,
233  STM32F4_GPIO_REMAP_TIM11_1,
234  STM32F4_GPIO_REMAP_TIM13_0,
235  STM32F4_GPIO_REMAP_TIM13_1,
236  STM32F4_GPIO_REMAP_TIM14_0,
237  STM32F4_GPIO_REMAP_TIM14_1,
238  STM32F4_GPIO_REMAP_FSMC_0,
239  STM32F4_GPIO_REMAP_FSMC_1,
240  STM32F4_GPIO_REMAP_TIM67_DAC_DMA_0,
241  STM32F4_GPIO_REMAP_TIM67_DAC_DMA_1,
242  STM32F4_GPIO_REMAP_TIM12_0,
243  STM32F4_GPIO_REMAP_TIM12_1,
244  STM32F4_GPIO_REMAP_MISC_0,
245  STM32F4_GPIO_REMAP_MISC_1,
246 } stm32f4_gpio_remap;
247
248 typedef union {
249  struct {
250  uint32_t pin_first : 8;
251  uint32_t pin_last : 8;
252  uint32_t mode : 2;
253  uint32_t cnf : 2;
254  uint32_t output : 1;
255  uint32_t remap : 8;
256  uint32_t reserved : 3;
257  } fields;
258
259  uint32_t value;
260 } stm32f4_gpio_config;
261
262 #define STM32F4_GPIO_CONFIG_TERMINAL \
263  { { 0xff, 0xff, 0x3, 0x3, 0x1, 0xff, 0x7 } }
264
267 #endif /* STM32F4_FAMILY_F10XXX */
268
269 extern const stm32f4_gpio_config stm32f4_start_config_gpio [];
270
271 void stm32f4_gpio_set_clock(int pin, bool set);
272
273 void stm32f4_gpio_set_config(const stm32f4_gpio_config *config);
274
279 void stm32f4_gpio_set_config_array(const stm32f4_gpio_config *configs);
280
281 void stm32f4_gpio_set_output(int pin, bool set);
282
283 bool stm32f4_gpio_get_input(int pin);
284
285 #ifdef STM32F4_FAMILY_F4XXXX
286
292 #define STM32F4_PIN_USART(port, idx, altfunc) \
293  { \
294  { \
295  .pin_first = STM32F4_GPIO_PIN(port, idx), \
296  .pin_last = STM32F4_GPIO_PIN(port, idx), \
297  .mode = STM32F4_GPIO_MODE_AF, \
298  .otype = STM32F4_GPIO_OTYPE_PUSH_PULL, \
299  .ospeed = STM32F4_GPIO_OSPEED_2_MHZ, \
300  .pupd = STM32F4_GPIO_PULL_UP, \
301  .af = altfunc \
302  } \
303  }
304
305 #define STM32F4_PIN_USART1_TX_PA9 STM32F4_PIN_USART(0, 9, STM32F4_GPIO_AF_USART1)
306 #define STM32F4_PIN_USART1_TX_PB6 STM32F4_PIN_USART(1, 6, STM32F4_GPIO_AF_USART1)
307 #define STM32F4_PIN_USART1_RX_PA10 STM32F4_PIN_USART(0, 10, STM32F4_GPIO_AF_USART1)
308 #define STM32F4_PIN_USART1_RX_PB7 STM32F4_PIN_USART(1, 7, STM32F4_GPIO_AF_USART1)
309
310 #define STM32F4_PIN_USART2_TX_PA2 STM32F4_PIN_USART(0, 2, STM32F4_GPIO_AF_USART2)
311 #define STM32F4_PIN_USART2_TX_PD5 STM32F4_PIN_USART(3, 5, STM32F4_GPIO_AF_USART2)
312 #define STM32F4_PIN_USART2_RX_PA3 STM32F4_PIN_USART(0, 3, STM32F4_GPIO_AF_USART2)
313 #define STM32F4_PIN_USART2_RX_PD6 STM32F4_PIN_USART(3, 6, STM32F4_GPIO_AF_USART2)
314
315 #define STM32F4_PIN_USART3_TX_PC10 STM32F4_PIN_USART(2, 10, STM32F4_GPIO_AF_USART3)
316 #define STM32F4_PIN_USART3_TX_PD8 STM32F4_PIN_USART(3, 8, STM32F4_GPIO_AF_USART3)
317 #define STM32F4_PIN_USART3_RX_PC11 STM32F4_PIN_USART(2, 11, STM32F4_GPIO_AF_USART3)
318 #define STM32F4_PIN_USART3_RX_PD9 STM32F4_PIN_USART(3, 9, STM32F4_GPIO_AF_USART3)
319
320 #define STM32F4_PIN_UART4_TX_PA0 STM32F4_PIN_USART(0, 0, STM32F4_GPIO_AF_UART4)
321 #define STM32F4_PIN_UART4_TX_PC10 STM32F4_PIN_USART(2, 10, STM32F4_GPIO_AF_UART4)
322 #define STM32F4_PIN_UART4_RX_PA1 STM32F4_PIN_USART(0, 1, STM32F4_GPIO_AF_UART4)
323 #define STM32F4_PIN_UART4_RX_PC11 STM32F4_PIN_USART(2, 11, STM32F4_GPIO_AF_UART4)
324
325 #define STM32F4_PIN_UART5_TX_PC12 STM32F4_PIN_USART(2, 12, STM32F4_GPIO_AF_UART5)
326 #define STM32F4_PIN_UART5_RX_PD2 STM32F4_PIN_USART(3, 2, STM32F4_GPIO_AF_UART5)
327
328 #define STM32F4_PIN_USART6_TX_PC6 STM32F4_PIN_USART(2, 6, STM32F4_GPIO_AF_USART6)
329 #define STM32F4_PIN_USART6_RX_PC7 STM32F4_PIN_USART(2, 7, STM32F4_GPIO_AF_USART6)
330
333 #endif /* STM32F4_FAMILY_F4XXXX */
334 #ifdef STM32F4_FAMILY_F10XXX
335
341 #define STM32F4_PIN_USART_TX(port, idx, remapvalue) \
342  { \
343  { \
344  .pin_first = STM32F4_GPIO_PIN(port, idx), \
345  .pin_last = STM32F4_GPIO_PIN(port, idx), \
346  .mode = STM32F4_GPIO_MODE_OUTPUT_2MHz, \
347  .cnf = STM32F4_GPIO_CNF_OUT_AF_PP, \
348  .output = 0, \
349  .remap = remapvalue \
350  } \
351  }
352
353 #define STM32F4_PIN_USART_RX(port, idx, remapvalue) \
354  { \
355  { \
356  .pin_first = STM32F4_GPIO_PIN(port, idx), \
357  .pin_last = STM32F4_GPIO_PIN(port, idx), \
358  .mode = STM32F4_GPIO_MODE_INPUT, \
359  .cnf = STM32F4_GPIO_CNF_IN_FLOATING, \
360  .output = 0, \
361  .remap = remapvalue \
362  } \
363  }
364
365 #define STM32F4_PIN_USART1_TX_MAP_0 STM32F4_PIN_USART_TX(0, 9, STM32F4_GPIO_REMAP_USART1_0)
366 #define STM32F4_PIN_USART1_RX_MAP_0 STM32F4_PIN_USART_RX(0, 10, STM32F4_GPIO_REMAP_USART1_0)
367 #define STM32F4_PIN_USART1_TX_MAP_1 STM32F4_PIN_USART_TX(1, 6, STM32F4_GPIO_REMAP_USART1_1)
368 #define STM32F4_PIN_USART1_RX_MAP_1 STM32F4_PIN_USART_RX(1, 7, STM32F4_GPIO_REMAP_USART1_1)
369
370 #define STM32F4_PIN_USART2_TX_MAP_0 STM32F4_PIN_USART_TX(0, 2, STM32F4_GPIO_REMAP_USART2_0)
371 #define STM32F4_PIN_USART2_RX_MAP_0 STM32F4_PIN_USART_RX(0, 3, STM32F4_GPIO_REMAP_USART2_0)
372 #define STM32F4_PIN_USART2_TX_MAP_1 STM32F4_PIN_USART_TX(3, 5, STM32F4_GPIO_REMAP_USART2_1)
373 #define STM32F4_PIN_USART2_RX_MAP_1 STM32F4_PIN_USART_RX(3, 6, STM32F4_GPIO_REMAP_USART2_1)
374
375 #define STM32F4_PIN_USART3_TX_MAP_0 STM32F4_PIN_USART_TX(1, 10, STM32F4_GPIO_REMAP_USART3_0)
376 #define STM32F4_PIN_USART3_RX_MAP_0 STM32F4_PIN_USART_RX(1, 11, STM32F4_GPIO_REMAP_USART3_0)
377 #define STM32F4_PIN_USART3_TX_MAP_1 STM32F4_PIN_USART_TX(2, 10, STM32F4_GPIO_REMAP_USART3_1)
378 #define STM32F4_PIN_USART3_RX_MAP_1 STM32F4_PIN_USART_RX(2, 11, STM32F4_GPIO_REMAP_USART3_1)
379 #define STM32F4_PIN_USART3_TX_MAP_3 STM32F4_PIN_USART_TX(3, 8, STM32F4_GPIO_REMAP_USART3_3)
380 #define STM32F4_PIN_USART3_RX_MAP_3 STM32F4_PIN_USART_RX(3, 9, STM32F4_GPIO_REMAP_USART3_3)
381
382 #define STM32F4_PIN_UART4_TX STM32F4_PIN_USART_TX(2, 10, STM32F4_GPIO_REMAP_DONT_CHANGE)
383 #define STM32F4_PIN_UART4_RX STM32F4_PIN_USART_RX(2, 11, STM32F4_GPIO_REMAP_DONT_CHANGE)
384
385 #define STM32F4_PIN_UART5_TX STM32F4_PIN_USART_TX(2, 12, STM32F4_GPIO_REMAP_DONT_CHANGE)
386 #define STM32F4_PIN_UART5_RX STM32F4_PIN_USART_RX(3, 2, STM32F4_GPIO_REMAP_DONT_CHANGE)
387
388 #define STM32F4_PIN_I2C(port, idx, remapvalue) \
389  { \
390  { \
391  .pin_first = STM32F4_GPIO_PIN(port, idx), \
392  .pin_last = STM32F4_GPIO_PIN(port, idx), \
393  .mode = STM32F4_GPIO_MODE_OUTPUT_2MHz, \
394  .cnf = STM32F4_GPIO_CNF_OUT_AF_OD, \
395  .output = 0, \
396  .remap = remapvalue \
397  } \
398  }
399
400 #define STM32F4_PIN_I2C1_SCL_MAP0 STM32F4_PIN_I2C(1, 6, STM32F4_GPIO_REMAP_I2C1_0)
401 #define STM32F4_PIN_I2C1_SDA_MAP0 STM32F4_PIN_I2C(1, 7, STM32F4_GPIO_REMAP_I2C1_0)
402 #define STM32F4_PIN_I2C1_SCL_MAP1 STM32F4_PIN_I2C(1, 8, STM32F4_GPIO_REMAP_I2C1_1)
403 #define STM32F4_PIN_I2C1_SDA_MAP1 STM32F4_PIN_I2C(1, 9, STM32F4_GPIO_REMAP_I2C1_1)
404
405 #define STM32F4_PIN_I2C2_SCL STM32F4_PIN_I2C(1, 10, STM32F4_GPIO_REMAP_DONT_CHANGE)
406 #define STM32F4_PIN_I2C2_SDA STM32F4_PIN_I2C(1, 11, STM32F4_GPIO_REMAP_DONT_CHANGE)
407
410 #endif /* STM32F4_FAMILY_F10XXX */
411
412 #ifdef __cplusplus
413 }
414 #endif /* __cplusplus */
415
416 #endif /* LIBBSP_ARM_STM32F4_IO_H */
Definition: deflate.c:115
Sets the GPIO configuration of an array terminated by STM32F4_GPIO_CONFIG_TERMINAL.
Definition: io.c:222
