RTEMS
5.1
bsps
arm
raspberrypi
include
bsp
spi.h
1
9
10
* Copyright (c) 2014-2015 Andre Marques <andre.lousa.marques at gmail.com>
11
12
* The license and distribution terms for this file may be
13
* found in the file LICENSE in this distribution or at
14
* http://www.rtems.org/license/LICENSE.
15
16
17
#ifndef LIBBSP_ARM_RASPBERRYPI_SPI_H
18
#define LIBBSP_ARM_RASPBERRYPI_SPI_H
19
20
rtems/libi2c.h
21
22
#ifdef __cplusplus
23
extern
"C"
24
#endif
/* __cplusplus */
25
39
/* TODO: It would be nice if this value could be probed at startup, probably
40
* using the Mailbox interface since the usual way of setting this on
41
* the hardware is through a "config.txt" text file on the SD card.
42
* Having this setup on the configure.ac script would require changing
43
* the same setting on two different places. */
44
#define GPU_CORE_CLOCK_RATE 250000000
45
69
extern
int
rpi_spi_init
bool
bidirectional_mode);
70
73
#ifdef __cplusplus
74
75
#endif
/* __cplusplus */
76
77
#endif
/* LIBBSP_ARM_RASPBERRYPI_SPI_H */
libi2c.h
Legacy I2C Library.
rpi_spi_init
int rpi_spi_init(bool bidirectional_mode)
Setups the Raspberry Pi SPI bus (located on the GPIO header) on the "/dev/spi" device file,...
Definition:
spi.c:640
