RTEMS  5.1
bsp.h
1
9 /*
10  * Copyright (c) 2012 Claas Ziemke. All rights reserved.
11  *
12  * Claas Ziemke
13  * Kernerstrasse 11
14  * 70182 Stuttgart
15  * Germany
16  * <claas.ziemke@gmx.net>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  *
22  * Modified by Ben Gras <beng@shrike-systems.com> to add lots
23  * of beagleboard/beaglebone definitions, delete lpc32xx specific
24  * ones, and merge with some other header files.
25  */
26
27 #ifndef LIBBSP_ARM_BEAGLE_BSP_H
28 #define LIBBSP_ARM_BEAGLE_BSP_H
29
40 #include <bspopts.h>
41 #include <stdint.h>
42 #include <bsp/start.h>
44 #include <bsp/beagleboneblack.h>
45
46 #include <rtems.h>
47 #include <rtems/irq-extension.h>
48
49 #include <libcpu/omap3.h>
50 #include <libcpu/am335x.h>
51
52 #define BSP_FEATURE_IRQ_EXTENSION
53
54 /* UART base clock frequency */
55 #define UART_CLOCK 48000000
56
57 /* Access memory-mapped I/O devices */
58 #define mmio_read(a) (*(volatile uint32_t *)(a))
59 #define mmio_write(a,v) (*(volatile uint32_t *)(a) = (v))
60 #define mmio_set(a,v) mmio_write((a), mmio_read((a)) | (v))
61 #define mmio_clear(a,v) mmio_write((a), mmio_read((a)) & ~(v))
62
63 #define REG16(x)(*((volatile uint16_t *)(x)))
64 #define REG(x)(*((volatile uint32_t *)(x)))
65 #define BIT(x)(0x1 << (x))
66 // Start and End included
67 #define BITS(Start, End) (((1 << (End+1)) - 1) & ~((1 << (Start)) - 1))
68
69 #define udelay(u) rtems_task_wake_after(1 + ((u)/rtems_configuration_get_microseconds_per_tick()))
70
71 /* Write a uint32_t value to a memory address. */
72 static inline void
73 write32(uint32_t address, uint32_t value)
74 {
75  REG(address) = value;
76 }
77
78 /* Read an uint32_t from a memory address */
79 static inline uint32_t
80 read32(uint32_t address)
81 {
82  return REG(address);
83 }
84
85 /* Set a 32 bits value depending on a mask */
86 static inline void
87 set32(uint32_t address, uint32_t mask, uint32_t value)
88 {
89  uint32_t val;
90  val = read32(address);
91  /* clear the bits */
92  val &= ~(mask);
93  /* apply the value using the mask */
94  val |= (value & mask);
95  write32(address, val);
96 }
97
98 /* Write a uint16_t value to a memory address. */
99 static inline void
100 write16(uint32_t address, uint16_t value)
101 {
102  REG16(address) = value;
103 }
104
105 /* Read an uint16_t from a memory address */
106 static inline uint16_t
107 read16(uint32_t address)
108 {
109  return REG16(address);
110 }
111
112 /* Data synchronization barrier */
113 static inline void dsb(void)
114 {
115  asm volatile("dsb" : : : "memory");
116 }
117
118 /* Instruction synchronization barrier */
119 static inline void isb(void)
120 {
121  asm volatile("isb" : : : "memory");
122 }
123
124 /* flush data cache */
125 static inline void flush_data_cache(void)
126 {
127  asm volatile(
128  "mov r0, #0\n"
129  "mcr p15, #0, r0, c7, c10, #4\n"
130  : /* No outputs */
131  : /* No inputs */
132  : "r0","memory"
133  );
134 }
135
136 #define __arch_getb(a) (*(volatile unsigned char *)(a))
137 #define __arch_getw(a) (*(volatile unsigned short *)(a))
138 #define __arch_getl(a) (*(volatile unsigned int *)(a))
139
140 #define __arch_putb(v,a) (*(volatile unsigned char *)(a) = (v))
141 #define __arch_putw(v,a) (*(volatile unsigned short *)(a) = (v))
142 #define __arch_putl(v,a) (*(volatile unsigned int *)(a) = (v))
143
144 #define writeb(v,c) ({ unsigned char __v = v; __arch_putb(__v,c); __v; })
145 #define writew(v,c) ({ unsigned short __v = v; __arch_putw(__v,c); __v; })
146 #define writel(v,c) ({ unsigned int __v = v; __arch_putl(__v,c); __v; })
147
148 #define readb(c) ({ unsigned char __v = __arch_getb(c); __v; })
149 #define readw(c) ({ unsigned short __v = __arch_getw(c); __v; })
150 #define readl(c) ({ unsigned int __v = __arch_getl(c); __v; })
151
152 #define SYSTEM_CLOCK_12 12000000
153 #define SYSTEM_CLOCK_13 13000000
154 #define SYSTEM_CLOCK_192 19200000
155 #define SYSTEM_CLOCK_96 96000000
156
157 #if !defined(IS_DM3730) && !defined(IS_AM335X)
158 #error Unrecognized BSP configured.
159 #endif
160
161 #if IS_DM3730
162 #define BSP_DEVICEMEM_START 0x48000000
163 #define BSP_DEVICEMEM_END 0x5F000000
164 #endif
165
166 #if IS_AM335X
167 #define BSP_DEVICEMEM_START 0x44000000
168 #define BSP_DEVICEMEM_END 0x57000000
169 #endif
170
171 /* per-target uart config */
172 #if IS_AM335X
173 #define BSP_CONSOLE_UART 1
174 #define BSP_CONSOLE_UART_BASE BEAGLE_BASE_UART_1
175 #define BSP_CONSOLE_UART_IRQ OMAP3_UART1_IRQ
176 #define BEAGLE_BASE_UART_1 0x44E09000
177 #define BEAGLE_BASE_UART_2 0x48022000
178 #define BEAGLE_BASE_UART_3 0x48024000
179 #endif
180
181 /* per-target uart config */
182 #if IS_DM3730
183 #define BSP_CONSOLE_UART 3
184 #define BSP_CONSOLE_UART_BASE BEAGLE_BASE_UART_3
185 #define BSP_CONSOLE_UART_IRQ OMAP3_UART3_IRQ
186 #define BEAGLE_BASE_UART_1 0x4806A000
187 #define BEAGLE_BASE_UART_2 0x4806C000
188 #define BEAGLE_BASE_UART_3 0x49020000
189 #endif
190
191 /* GPIO pin config */
192 #if IS_AM335X
193 #define BSP_GPIO_PIN_COUNT 128
194 #define BSP_GPIO_PINS_PER_BANK 32
195 #endif
196
197 #if IS_DM3730
198 #define BSP_GPIO_PIN_COUNT 192
199 #define BSP_GPIO_PINS_PER_BANK 32
200 #endif
201
202 #if BSP_START_COPY_FDT_FROM_U_BOOT
203 #define BSP_FDT_IS_SUPPORTED
204 #endif
205
206 /* i2c stuff */
207 typedef struct {
208  uint32_t rx_or_tx;
209  uint32_t stat;
210  uint32_t ctrl;
211  uint32_t clk_hi;
212  uint32_t clk_lo;
213  uint32_t adr;
214  uint32_t rxfl;
215  uint32_t txfl;
216  uint32_t rxb;
217  uint32_t txb;
218  uint32_t s_tx;
219  uint32_t s_txfl;
220 } beagle_i2c;
221
222 /* sctlr */
223 /* Read System Control Register */
224 static inline uint32_t read_sctlr(void)
225 {
226  uint32_t ctl;
227
228  asm volatile("mrc p15, 0, %[ctl], c1, c0, 0 @ Read SCTLR\n\t"
229  : [ctl] "=r" (ctl));
230  return ctl;
231 }
232
233 /* Write System Control Register */
234 static inline void write_sctlr(uint32_t ctl)
235 {
236  asm volatile("mcr p15, 0, %[ctl], c1, c0, 0 @ Write SCTLR\n\t"
237  : : [ctl] "r" (ctl));
238  isb();
239 }
240
241 /* Read Auxiliary Control Register */
242 static inline uint32_t read_actlr(void)
243 {
244  uint32_t ctl;
245
246  asm volatile("mrc p15, 0, %[ctl], c1, c0, 1 @ Read ACTLR\n\t"
247  : [ctl] "=r" (ctl));
248  return ctl;
249 }
250
251 /* Write Auxiliary Control Register */
252 static inline void write_actlr(uint32_t ctl)
253 {
254  asm volatile("mcr p15, 0, %[ctl], c1, c0, 1 @ Write ACTLR\n\t"
255  : : [ctl] "r" (ctl));
256  isb();
257 }
258
259 /* Write Translation Table Base Control Register */
260 static inline void write_ttbcr(uint32_t bcr)
261 {
262  asm volatile("mcr p15, 0, %[bcr], c2, c0, 2 @ Write TTBCR\n\t"
263  : : [bcr] "r" (bcr));
264
265  isb();
266 }
267
268 /* Read Domain Access Control Register */
269 static inline uint32_t read_dacr(void)
270 {
271  uint32_t dacr;
272
273  asm volatile("mrc p15, 0, %[dacr], c3, c0, 0 @ Read DACR\n\t"
274  : [dacr] "=r" (dacr));
275
276  return dacr;
277 }
278
279
280 /* Write Domain Access Control Register */
281 static inline void write_dacr(uint32_t dacr)
282 {
283  asm volatile("mcr p15, 0, %[dacr], c3, c0, 0 @ Write DACR\n\t"
284  : : [dacr] "r" (dacr));
285
286  isb();
287 }
288
289 static inline void refresh_tlb(void)
290 {
291  dsb();
292
293  /* Invalidate entire unified TLB */
294  asm volatile("mcr p15, 0, %[zero], c8, c7, 0 @ TLBIALL\n\t"
295  : : [zero] "r" (0));
296
297  /* Invalidate all instruction caches to PoU.
298  * Also flushes branch target cache. */
299  asm volatile("mcr p15, 0, %[zero], c7, c5, 0"
300  : : [zero] "r" (0));
301
302  /* Invalidate entire branch predictor array */
303  asm volatile("mcr p15, 0, %[zero], c7, c5, 6"
304  : : [zero] "r" (0)); /* flush BTB */
305
306  dsb();
307  isb();
308 }
309
310 /* Read Translation Table Base Register 0 */
311 static inline uint32_t read_ttbr0(void)
312 {
313  uint32_t bar;
314
315  asm volatile("mrc p15, 0, %[bar], c2, c0, 0 @ Read TTBR0\n\t"
316  : [bar] "=r" (bar));
317
318  return bar & ARM_TTBR_ADDR_MASK;
319 }
320
321
322 /* Read Translation Table Base Register 0 */
323 static inline uint32_t read_ttbr0_unmasked(void)
324 {
325  uint32_t bar;
326
327  asm volatile("mrc p15, 0, %[bar], c2, c0, 0 @ Read TTBR0\n\t"
328  : [bar] "=r" (bar));
329
330  return bar;
331 }
332
333 /* Write Translation Table Base Register 0 */
334 static inline void write_ttbr0(uint32_t bar)
335 {
336  dsb();
337  isb();
338  /* In our setup TTBR contains the base address *and* the flags
339  but other pieces of the kernel code expect ttbr to be the
340  base address of the l1 page table. We therefore add the
341  flags here and remove them in the read_ttbr0 */
342  uint32_t v = (bar & ARM_TTBR_ADDR_MASK ) | ARM_TTBR_FLAGS_CACHED;
343  asm volatile("mcr p15, 0, %[bar], c2, c0, 0 @ Write TTBR0\n\t"
344  : : [bar] "r" (v));
345
346  refresh_tlb();
347 }
348
349 /* Behaviour on fatal error; default: test-friendly.
350  * set breakpoint to bsp_fatal_extension.
351  */
352 /* Enabling BSP_PRESS_KEY_FOR_RESET prevents noninteractive testing */
353 /*#define BSP_PRESS_KEY_FOR_RESET 1 */
354 #define BSP_PRINT_EXCEPTION_CONTEXT 1
355  /* human-readable exception info */
356 #define BSP_RESET_BOARD_AT_EXIT 1
357  /* causes qemu to exit, signaling end of test */
358
364 BSP_START_TEXT_SECTION void beagle_setup_mmu_and_cache(void);
365
366 /* @} */
367
368 #endif /* LIBBSP_ARM_BEAGLE_BSP_H */
DEFAULT_INITIAL_EXTENSION Support.
BeagleBone Black BSP definitions.
Header file for the Interrupt Manager Extension.
Beagleboard specific set up of the MMU.
Definition: bspstartmmu.c:41
Definition: bsp.h:207
unsigned v
Definition: tte.h:73
