RTEMS  5.1
bsp_bsdnet_attach.h
1 #ifndef BSP_BSDNET_ATTACH_INFO_H
2 #define BSP_BSDNET_ATTACH_INFO_H
3
4 /* Author: Till Straumann, 2005; see ../../LICENSE */
5
6 /* Rationale: traditionally, BSPs only supported a single networking interface
7  * the BSP defined RTEMS_NETWORK_DRIVER_NAME & friends macros
8  * for applications to use.
9  * If more than one interface is present, this simple approach is
10  * not enough.
11  * Hence, this BSP exports a routine declaring all available interfaces
12  * so the application can make a choice.
13  */
14
15 #ifdef __cplusplus
16  extern "C" {
17 #endif
18
19 /* Fwd. decl just in case */
20 struct rtems_bsdnet_ifconfig;
21
22 typedef struct {
23  /* name of the interface */
24  const char *name;
25  /* optional description (to be used by chooser 'help' function etc.) */
26  const char *description;
27  /* driver 'attach' function */
28  int (*attach_fn)(struct rtems_bsdnet_ifconfig*, int);
30
31 /* Return a pointer to the (static) list of network interface descriptions
32  * of this board.
33  *
34  * NOTES: A NULL value is returned if e.g., the board type cannot be determined
35  * or for other reasons.
36  * The 'description' field is optional, i.e., may be NULL.
37  * The list is terminated by an element with a NULL name field.
38  * The interfaces are listed in the order they are labelled.
39  */
40
42 BSP_availableNetIFs(void);
43
44 /* Define this macro so applications can conditionally compile this API */
45 #define BSP_HAS_MULTIPLE_NETIFS(x) BSP_availableNetIFs()
46
47 /* Legacy macro; applications should use BSP_Available_NetIfs() to choose
48  * an interface and attach function.
49  */
50 extern char BSP_auto_network_driver_name[20];
51 #define RTEMS_BSP_NETWORK_DRIVER_NAME BSP_auto_network_driver_name
52
53 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH BSP_auto_enet_attach
54
55 /* This routine checks the name field passed in the 'ifconfig'.
56  * If the name is NULL or points to the BSP_auto_network_driver_name
57  * array, the routine checks all interfaces for an active link and
58  * attaches the first alive one.
59  * It also updates 'ifconfig' to reflect the chosen interface's name
60  * and attach function.
61  *
62  * If another name is passed in, the routine scans
63  * the available interfaces for that name and uses it, if found.
64  * Eventually, a default interface is chosen (provided that
65  * the board type is successfully detected).
66  *
67  * Note that only ONE interface chained into rtems_bsdnet_config
68  * may use the "auto" name.
69  *
70  */
71
72 int
73 BSP_auto_enet_attach(struct rtems_bsdnet_ifconfig *ifconfig, int attaching);
74
75 #ifdef __cplusplus
76  }
77 #endif
78
79 #endif
Definition: bsp_bsdnet_attach.h:22
