RTEMS  5.1
ofw_tree.h
1 /*
2  * Copyright (c) 2006 Jakub Jermar
3  * All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  *
9  * - Redistributions of source code must retain the above copyright
10  * notice, this list of conditions and the following disclaimer.
11  * - Redistributions in binary form must reproduce the above copyright
12  * notice, this list of conditions and the following disclaimer in the
13  * documentation and/or other materials provided with the distribution.
14  * - The name of the author may not be used to endorse or promote products
15  * derived from this software without specific prior written permission.
16  *
17  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
18  * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
19  * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
20  * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
21  * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
22  * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
23  * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
24  * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
25  * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
26  * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
27  */
28
29 #ifndef BOOT_OFW_TREE_H_
30 #define BOOT_OFW_TREE_H_
31
32 #include <boot/types.h>
33 #include <boot/ofw.h>
34
35
37 typedef struct {
38  char name[OFW_TREE_PROPERTY_MAX_NAMELEN];
39  size_t size;
40  void *value;
42
44 typedef struct ofw_tree_node {
45  struct ofw_tree_node *parent;
46  struct ofw_tree_node *peer;
47  struct ofw_tree_node *child;
48
49  uint32_t node_handle;
51  char *da_name;
53  unsigned int properties;
54  ofw_tree_property_t *property;
55
56  void *device;
58
59 extern ofw_tree_node_t *ofw_tree_build(void);
60
61 #endif
Definition: ofw_tree.h:44
Definition: ofw_tree.h:53
char * da_name
Definition: ofw_tree.h:51
Definition: ofw_tree.h:37
void * device
Definition: ofw_tree.h:56
Definition: ofw_tree.h:49
unsigned size
Definition: tte.h:74
