RTEMS  5.1
bmp.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
38 #ifndef BMP_H
39 #define BMP_H
40
42 #define BMP_TYPE 0x4D42
43
45 #define BITMAPINFOHEADER 40
46
47 /*------------------------------------------------------------------------------
48  * Exported types
49  *------------------------------------------------------------------------------*/
50
51 #pragma pack(1)
52
54 typedef struct _BMPHeader {
55  /* signature, must be 4D42 hex */
56  uint16_t type;
57  /* size of BMP file in bytes (unreliable) */
58  uint32_t fileSize;
59  /* reserved, must be zero */
60  uint16_t reserved1;
61  /* reserved, must be zero */
62  uint16_t reserved2;
63  /* offset to start of image data in bytes */
64  uint32_t offset;
65  /* size of BITMAPINFOHEADER structure, must be 40 */
66  uint32_t headerSize;
67  /* image width in pixels */
68  uint32_t width;
69  /* image height in pixels */
70  uint32_t height;
71  /* number of planes in the image, must be 1 */
72  uint16_t planes;
73  /* number of bits per pixel (1, 4, 8, 16, 24, 32) */
74  uint16_t bits;
75  /* compression type (0=none, 1=RLE-8, 2=RLE-4) */
76  uint32_t compression;
77  /* size of image data in bytes (including padding) */
78  uint32_t imageSize;
79  /* horizontal resolution in pixels per meter (unreliable) */
80  uint32_t xresolution;
81  /* vertical resolution in pixels per meter (unreliable) */
82  uint32_t yresolution;
83  /* number of colors in image, or zero */
84  uint32_t ncolours;
85  /* number of important colors, or zero */
86  uint32_t importantcolours;
87 } BMPHeader;
88
89 #pragma pack()
90
91 /*------------------------------------------------------------------------------
92  * Exported functions
93  *------------------------------------------------------------------------------*/
94 extern uint8_t BMP_IsValid(void *file);
95 extern uint32_t BMP_GetFileSize(void *file);
96
97 extern uint8_t BMP_Decode(
98  void *file,
99  uint8_t *buffer,
100  uint32_t width,
101  uint32_t height,
102  uint8_t bpp);
103
104 extern void WriteBMPheader(
105  uint32_t *pAddressHeader,
106  uint32_t bmpHSize,
107  uint32_t bmpVSize,
108  uint8_t nbByte_Pixels);
109
110 extern void BMP_displayHeader(uint32_t *pAddressHeader);
111 extern void RGB565toBGR555(
112  uint8_t *fileSource,
113  uint8_t *fileDestination,
114  uint32_t width,
115  uint32_t height,
116  uint8_t bpp);
117
118 #endif //#ifndef BMP_H
119
Definition: bmp.h:54
struct _BMPHeader BMPHeader
Definition: mongoose.c:442
