RTEMS  5.1
twi.h
1 /* not yet implemented */
2
3 /*
4  * RTEMS driver for Blackfin TWI (I2C)
5  *
6  * COPYRIGHT (c) 2008 Kallisti Labs, Los Gatos, CA, USA
7  * written by Allan Hessenflow <allanh@kallisti.com>
8  *
9  * The license and distribution terms for this file may be
10  * found in the file LICENSE in this distribution or at
11  * http://www.rtems.org/license/LICENSE.
12  */
13
14 #ifndef _twi_h_
15 #define _twi_h_
16
17
18 #ifdef __cplusplus
19 extern "C" {
20 #endif
21
22
23 typedef struct {
24  uint32_t sclk;
25  void *base;
26  bool fast;
27  int8_t slave_address;
29
30 typedef struct bfin_twi_request_s {
31  bool write;
32  int count;
33  void *data;
34  /* Chained requests are done with repeated start conditions in between.
35  These are useful for atomic address write/data read transactions
36  (which can be important in multi-master configurations), and for
37  doing 10-bit addressing. */
38  struct bfin_twi_request_s *next;
40
41 typedef rtems_status_code (*bfin_twi_callback_t)(int channel,
42  void *arg,
43  bool general_call,
44  bool write,
45  bool done,
46  int read_count,
47  uint8_t *data);
48
49
50 rtems_status_code bfin_twi_init(int channel, bfin_twi_config_t *config);
51
52 rtems_status_code bfin_twi_register_callback(int channel,
53  bfin_twi_callback_t callback,
54  void *arg);
55
56 void bfin_twi_isr(int source);
57
58 rtems_status_code bfin_twi_request(int channel, uint8_t address,
59  bfin_twi_request_t *request,
60  rtems_interval timeout);
61
62
63 #ifdef __cplusplus
64 }
65 #endif
66
67 #endif /* _twi_h_ */
68
Definition: twi.h:23
Definition: deflate.c:115
Watchdog_Interval rtems_interval
Used to manage and manipulate intervals specified by clock ticks.
Definition: types.h:127
ssize_t write(int fd, const void *buffer, size_t count)
Definition: write.c:30
rtems_status_code
Classic API Status.
Definition: status.h:43
Definition: twi.h:30
