RTEMS
5.1
Data Structure Index
Class Hierarchy
z
z
z
z
Pages
bsps
bfin
include
libcpu
mmu.h
1
/* Blackfin MMU Support
2
3
* Copyright (c) 2008 Kallisti Labs, Los Gatos, CA, USA
4
* written by Allan Hessenflow <allanh@kallisti.com>
5
6
* The license and distribution terms for this file may be
7
* found in the file LICENSE in this distribution or at
8
* http://www.rtems.org/license/LICENSE.
9
10
11
12
/* NOTE: this currently only implements a static table. It should be made
13
to handle more regions than fit in the CPLBs, with an exception handler
14
to do replacements as needed. This would of course require great care
15
to insure any storage required by the exception handler, including any
16
stack space, the exception handler itself, and the region descriptors
17
it needs to update the CPLBs, are in regions that will never be
18
replaced. */
19
20
#ifndef _mmu_h_
21
#define _mmu_h_
22
23
#include <libcpu/mmuRegs.h>
24
25
26
#define INSTR_NOCACHE (ICPLB_DATA_CPLB_USER_RD | \
27
ICPLB_DATA_CPLB_VALID)
28
29
#define INSTR_CACHEABLE (ICPLB_DATA_CPLB_L1_CHBL | \
30
31
32
33
#define DATA_NOCACHE (DCPLB_DATA_CPLB_DIRTY | \
34
DCPLB_DATA_CPLB_SUPV_WR | \
35
DCPLB_DATA_CPLB_USER_WR | \
36
DCPLB_DATA_CPLB_USER_RD | \
37
DCPLB_DATA_CPLB_VALID)
38
39
#define DATA_WRITEBACK (DCPLB_DATA_CPLB_L1_AOW | \
40
DCPLB_DATA_CPLB_L1_CHBL | \
41
42
43
44
45
46
47
48
#ifdef __cplusplus
49
extern
"C"
50
#endif
51
52
53
typedef
struct
54
struct
55
void
*address;
56
uint32_t flags;
57
} instruction[ICPLB_COUNT];
58
struct
59
void
*address;
60
uint32_t flags;
61
} data[DCPLB_COUNT];
62
bfin_mmu_config_t
63
64
65
void
bfin_mmu_init(
bfin_mmu_config_t
config
66
67
68
#ifdef __cplusplus
69
70
#endif
71
72
#endif
/* _mmu_h_ */
73
config_s
Definition:
deflate.c:115
bfin_mmu_config_t
Definition:
mmu.h:53
