RTEMS
5.1
1 #ifndef __TASK_API_BESTCOMM_CNTRL_H 2 #define __TASK_API_BESTCOMM_CNTRL_H 1 33 #define SDMA_INT_BIT_DBG 31 34 #define SDMA_INT_BIT_TEA 28 35 #define SDMA_INT_BIT_TEA_TASK 24 36 #define SDMA_INT_BIT_IMPL 0x9000FFFF 38 #define SDMA_PTDCTRL_BIT_TEA 14 40 #define SDMA_TCR_BIT_AUTO 15 41 #define SDMA_TCR_BIT_HOLD 5 43 #define SDMA_STAT_BIT_ALARM 17 44 #define SDMA_FIFO_ALARM_MASK 0x0020000 46 #define SDMA_DRD_BIT_TFD 27 47 #define SDMA_DRD_BIT_INT 26 48 #define SDMA_DRD_BIT_INIT 21 49 #define SDMA_DRD_MASK_FLAGS 0x0C000000 50 #define SDMA_DRD_MASK_LENGTH 0x03FFFFFF 51 #define SDMA_BD_BIT_READY 30 53 #define SDMA_BD_MASK_READY constant(1<<SDMA_BD_BIT_READY) 55 #define SDMA_BD_MASK_READY (1<<SDMA_BD_BIT_READY) 57 #define SDMA_BD_MASK_SIGN 0x7FFFFFFF 59 #define SDMA_PRAGMA_BIT_RSV 7 60 #define SDMA_PRAGMA_BIT_PRECISE_INC 6 61 #define SDMA_PRAGMA_BIT_RST_ERROR_NO 5 62 #define SDMA_PRAGMA_BIT_PACK 4 63 #define SDMA_PRAGMA_BIT_INTEGER 3 64 #define SDMA_PRAGMA_BIT_SPECREAD 2 65 #define SDMA_PRAGMA_BIT_CW 1 66 #define SDMA_PRAGMA_BIT_RL 0 68 #define SDMA_TASK_ENTRY_BYTES 32 69 #define SDMA_TASK_GROUP_NUM 16 70 #define SDMA_TASK_GROUP_BYTES (SDMA_TASK_ENTRY_BYTES*SDMA_TASK_GROUP_NUM) 76 #define SDMA_TASKNUM_EXT(OldTaskNum) (OldTaskNum%16) 78 #define SDMA_TASKBAR_CHANGE(sdma, OldTaskNum) { \ 79 sdma->taskBar += (((int)(OldTaskNum/SDMA_TASK_GROUP_NUM))*SDMA_TASK_GROUP_BYTES); \ 82 #define SDMA_TASKBAR_RESTORE(sdma, OldTaskNum) { \ 83 sdma->taskBar -= (((int)(OldTaskNum/SDMA_TASK_GROUP_NUM))*SDMA_TASK_GROUP_BYTES); \ 90 #define SDMA_TASK_CFG(RegAddr, TaskNum, AutoStart, AutoStartNum) { \ 91 *(((volatile uint16 *)RegAddr)+TaskNum) = (uint16)(0x0000 | \ 92 ((AutoStart!=0)<<7) | \ 93 (AutoStartNum&0xF) ); \ 96 #define SDMA_TASK_AUTO_START(RegAddr, TaskNum, AutoStart, AutoStartNum) { \ 97 *(((volatile uint16 *)RegAddr)+TaskNum) = (uint16)((*(((volatile uint16 *)RegAddr)+TaskNum) & \ 98 (uint16) 0xff30) | ((uint16)(0x0000 | \ 99 ((AutoStart!=0)<<7) | \ 100 (AutoStartNum&0xF)) )); \ 103 #define SDMA_TASK_ENABLE(RegAddr, TaskNum) { \ 104 *(((volatile uint16 *)RegAddr)+TaskNum) |= (uint16)0x8000; \ 107 #define SDMA_TASK_DISABLE(RegAddr, TaskNum) { \ 108 *(((volatile uint16 *)RegAddr)+TaskNum) &= ~(uint16)0x8000; \ 111 #define SDMA_TASK_STATUS(RegAddr, TaskNum) \ 112 *(((volatile uint16 *)RegAddr)+TaskNum) 118 #define SDMA_INT_ENABLE(RegAddr, Bit) \ 120 rtems_interrupt_level level; \ 121 rtems_interrupt_disable(level); \ 122 *((volatile uint32 *) RegAddr) &= ~((uint32) (1 << Bit)); \ 123 rtems_interrupt_enable(level); \ 126 #define SDMA_INT_DISABLE(RegAddr, Bit) \ 128 rtems_interrupt_level level; \ 129 rtems_interrupt_disable(level); \ 130 *((volatile uint32 *) (RegAddr)) |= ((uint32)(1 << Bit)); \ 131 rtems_interrupt_enable(level); \ 134 #define SDMA_INT_SOURCE(RegPend, RegMask) \ 135 (*((volatile uint32 *)(RegPend)) & (~*((volatile uint32 *)(RegMask))) & (uint32)SDMA_INT_BIT_IMPL) 137 #define SDMA_INT_PENDING(RegPend, RegMask) \ 138 (*((volatile uint32 *)(RegPend)) & (~*((volatile uint32 *)(RegMask)))) 140 #define SDMA_INT_TEST(IntSource, Bit) \ 141 (((uint32)IntSource) & ((uint32)(1<<Bit))) 149 #define SDMA_CLEAR_IEVENT(RegAddr, Bit) { \ 150 *((volatile uint32 *)RegAddr) = ((uint32)(1<<Bit)); \ 153 #define SDMA_GET_PENDINGBIT(sdma, Bit) \ 154 (sdma->IntPend & (uint32)(1<<Bit)) 156 #define SDMA_GET_MASKBIT(sdma, Bit) \ 157 (sdma->IntMask & (uint32)(1<<Bit)) 168 #define SDMA_TEA_ENABLE(sdma) { \ 169 SDMA_INT_ENABLE(sdma, SDMA_INT_BIT_TEA); \ 170 sdma->PtdCntrl &= ~((uint32)(1<<SDMA_PTDCTRL_BIT_TEA)); \ 174 #define SDMA_TEA_DISABLE(sdma) { \ 175 SDMA_INT_DISABLE(sdma, SDMA_INT_BIT_TEA); \ 176 sdma->PtdCntrl |= ((uint32)(1<<SDMA_PTDCTRL_BIT_TEA)); \ 180 #define SDMA_TEA_CLEAR(sdma) { \ 181 sdma->IntPend = ((uint32)(0x1F<<SDMA_INT_BIT_TEA_TASK)); \ 185 #define SDMA_TEA_SOURCE(RegPend) \ 186 (uint32)(((*(volatile uint32 *)RegPend)>>SDMA_INT_BIT_TEA_TASK) & 0xF) 194 #define SDMA_DBG_ENABLE(sdma) { \ 195 SDMA_INT_ENABLE(sdma, SDMA_INT_BIT_DBG); \ 198 #define SDMA_DBG_DISABLE(sdma) { \ 199 SDMA_INT_DISABLE(sdma, SDMA_INT_BIT_DBG); \ 203 #define SDMA_DBG_CLEAR(sdma) { \ 204 SDMA_CLEAR_IEVENT(sdma, SDMA_INT_BIT_DBG); \ 207 #define SDMA_DBG_MDE(dst, sdma, addr) { \ 208 sdma->MDEDebug = addr; \ 209 dst = sdma->MDEDebug; \ 212 #define SDMA_DBG_ADS(dst, sdma, addr) { \ 213 sdma->ADSDebug = addr; \ 214 dst = sdma->ADSDebug; \ 217 #define SDMA_DBG_PTD(dst, sdma, addr) { \ 218 sdma->PTDDebug = addr; \ 219 dst = sdma->PTDDebug; \ 231 #define SDMA_SET_SIZE(RegAddr, TaskNum, SrcSize, DstSize) \ 232 *(((volatile uint8 *)RegAddr)+((uint32)(TaskNum/2))) = \ 233 (uint8)((*(((volatile uint8 *)RegAddr)+((uint32)(TaskNum/2))) & \ 234 ((TaskNum%2) ? 0xf0 : 0x0f)) | \ 235 ((uint8)(((SrcSize & 0x3)<<2) | \ 236 ( DstSize & 0x3 ) ) <<(4*((int)(1-(TaskNum%2)))))); 240 #define SDMA_SET_INIT(RegAddr, TaskNum, Initiator) \ 242 *(((volatile uint16 *)RegAddr)+TaskNum) &= (uint16)0xE0FF; \ 243 *(((volatile uint16 *)RegAddr)+TaskNum) |= (((0x01F & Initiator)<<8) | \ 244 (0<<SDMA_TCR_BIT_HOLD)); \ 248 #define SDMA_INIT_CHANGE(task, oldInitiator, newInitiator) { \ 250 for (i=0; i<task->NumDRD; i++) { \ 251 if (SDMA_INIT_READ(task->DRD[i]) == (uint32)oldInitiator) { \ 252 SDMA_INIT_WRITE(task->DRD[i],newInitiator); \ 258 #define SDMA_SET_INITIATOR_PRIORITY(sdma, initiator, priority) \ 259 *(((volatile uint8 *)&sdma->IPR0)+initiator) = priority; 263 #define SDMA_INIT_READ(PtrDRD) \ 264 (((*(volatile uint32 *)PtrDRD)>>SDMA_DRD_BIT_INIT) & (uint32)0x1F) 267 #define SDMA_INIT_WRITE(PtrDRD, Initiator) { \ 268 *(volatile uint32 *)PtrDRD = ((*(volatile uint32 *)PtrDRD) & 0xFC1FFFFF) | \ 269 (Initiator<<SDMA_DRD_BIT_INIT); \ 273 #define SDMA_INIT_CHANGE(task, oldInitiator, newInitiator) { \ 275 for (i=0; i<task->NumDRD; i++) { \ 276 if (SDMA_INIT_READ(task->DRD[i]) == (uint32)oldInitiator) { \ 277 SDMA_INIT_WRITE(task->DRD[i],newInitiator); \
