RTEMS  5.1
b1553rt.h
1 /* B1553RT driver interface
2  *
3  * COPYRIGHT (c) 2009.
4  * Aeroflex Gaisler AB
5  *
6  * The license and distribution terms for this file may be
7  * found in the file LICENSE in this distribution or at
8  * http://www.rtems.org/license/LICENSE.
9  */
10
11 #ifndef __B1553RT_H__
12 #define __B1553RT_H__
13
14 #include <drvmgr/drvmgr.h>
15
16 #ifdef __cplusplus
17 extern "C" {
18 #endif
19
20 struct rt_reg {
21  volatile unsigned int stat; /* 0x00 */
22  volatile unsigned int ctrl; /* 0x04 */
23  volatile unsigned int vword; /* 0x08 */
24  volatile unsigned int irq; /* 0x0C */
25  volatile unsigned int addr; /* 0x10 */
26  volatile unsigned int ipm; /* 0x14 */
27 };
28
29
30 struct rt_msg {
31  unsigned short miw;
32  unsigned short time;
33  unsigned short data[32];
34  unsigned short desc;
35 };
36
37 #define RT_FREQ_12MHZ 0
38 #define RT_FREQ_16MHZ 1
39 #define RT_FREQ_20MHZ 2
40 #define RT_FREQ_24MHZ 3
41 #define RT_FREQ_MASK 0x3
42
43 /* IOCTLs */
44 #define RT_SET_ADDR 3
45 #define RT_SET_BCE 5
46 #define RT_RX_BLOCK 8
47 #define RT_CLR_STATUS 12
48 #define RT_GET_STATUS 13
49 #define RT_SET_EVENTID 14
50
51 #define RT_SET_VECTORW 32
52 #define RT_SET_EXTMDATA 33
53
54 #define RT_ILLCMD_IRQ 128
55 #define RT_MERR_IRQ 2048
56 #define RT_DMAF_IRQ 32768 /* DMA Fail irq */
57
58 #define RT_TSW_OK (1<<14)
59 #define RT_TSW_BUS (1<<13)
60 #define RT_TSW_BC (1<<12)
61 #define RT_TSW_LPBKERRB (1<<11)
62 #define RT_TSW_LPBKERRA (1<<10)
63 #define RT_TSW_ILL (1<<9)
64 #define RT_TSW_MEM (1<<8)
65 #define RT_TSW_MAN (1<<7)
66 #define RT_TSW_PAR (1<<6)
67 #define RT_TSW_WC (1<<5)
68
69 void b1553rt_print_dev(struct drvmgr_dev *dev, int options);
70 void b1553rt_print(int options);
71
72 void b1553rt_register_drv(void);
73
74 #ifdef __cplusplus
75 }
76 #endif
77
78 #endif /* __RT_H__ */
79
Definition: b1553brm.h:71
Definition: b1553rt.h:20
Definition: drvmgr.h:275
