RTEMS
5.1
Atmel AT91RM9200 EMAC Register definitions. More...
#include <bits.h>
#define | EMAC_CTL 0x00 /* Network Control Register */ |
#define | EMAC_CFG 0x04 /* Network Configuration Register */ |
#define | EMAC_SR 0x08 /* Network Status Register */ |
#define | EMAC_TAR 0x0C /* Transmit Address Register */ |
#define | EMAC_TCR 0x10 /* Transmit Control Register */ |
#define | EMAC_TSR 0x14 /* Transmit Status Register */ |
#define | EMAC_RBQP 0x18 /* Receive Buffer Queue Pointer */ |
#define | EMAC_RSR 0x20 /* Receive Status Register */ |
#define | EMAC_ISR 0x24 /* Interrupt Enable Register */ |
#define | EMAC_IER 0x28 /* Interrupt Enable Register */ |
#define | EMAC_IDR 0x2C /* Interrupt Disable Register */ |
#define | EMAC_IMR 0x30 /* Interrupt Mask Register */ |
#define | EMAC_MAN 0x34 /* PHY Maintenance Register */ |
#define | EMAC_FRA 0x40 /* Frames Transmitted OK Register */ |
#define | EMAC_SCOL 0x44 /* Single Collision Frame Register */ |
#define | EMAC_MCOL 0x48 /* Multiple Collision Frame Register */ |
#define | EMAC_OK 0x4C /* Frames Received OK Register */ |
#define | EMAC_SEQE 0x50 /* Frame Check Sequence Error Register */ |
#define | EMAC_ALE 0x54 /* Alignment Error Register */ |
#define | EMAC_DTE 0x58 /* Deferred Transmission Frame Register */ |
#define | EMAC_LCOL 0x5C /* Late Collision Register */ |
#define | EMAC_ECOL 0x60 /* Excessive Collision Register */ |
#define | EMAC_CSE 0x64 /* Carrier Sense Error Register */ |
#define | EMAC_TUE 0x68 /* Transmit Underrun Error Register */ |
#define | EMAC_CDE 0x6C /* Code Error Register */ |
#define | EMAC_ELR 0x70 /* Excessive Length Error Register */ |
#define | EMAC_RJB 0x74 /* Receive Jabber Register */ |
#define | EMAC_USF 0x78 /* Undersize Frame Register */ |
#define | EMAC_SQEE 0x7C /* SQE Test Error Register */ |
#define | EMAC_DRFC 0x80 /* Discarded RX Frame Register */ |
#define | EMAC_HSH 0x90 /* Hash Address High[63:32] */ |
#define | EMAC_HSL 0x94 /* Hash Address Low[31:0] */ |
#define | EMAC_SA1L 0x98 /* Specific Addr 1 Low, First 4 bytes */ |
#define | EMAC_SA1H 0x9C /* Specific Addr 1 High, Last 2 bytes */ |
#define | EMAC_SA2L 0xA0 /* Specific Addr 2 Low, First 4 bytes */ |
#define | EMAC_SA2H 0xA4 /* Specific Addr 2 High, Last 2 bytes */ |
#define | EMAC_SA3L 0xA8 /* Specific Addr 3 Low, First 4 bytes */ |
#define | EMAC_SA3H 0xAC /* Specific Addr 3 High, Last 2 bytes */ |
#define | EMAC_SA4L 0xB0 /* Specific Addr 4 Low, First 4 bytes */ |
#define | EMAC_SA4H 0xB4 /* Specific Addr 4 High, Last 2 bytesr */ |
#define | EMAC_CTL_LB BIT0 /* 1 = Set Loopback output signal */ |
#define | EMAC_CTL_LBL BIT1 /* 1 = Loopback local. */ |
#define | EMAC_CTL_RE BIT2 /* 1 = Receive enable. */ |
#define | EMAC_CTL_TE BIT3 /* 1 = Transmit enable. */ |
#define | EMAC_CTL_MPE BIT4 /* 1 = Management port enable. */ |
#define | EMAC_CTL_CSR BIT5 /* Write 1 to clear stats registers. */ |
#define | EMAC_CTL_ISR BIT6 /* Write to increment stats registers */ |
#define | EMAC_CTL_WES BIT7 /* 1 = Enable writing to stats regs */ |
#define | EMAC_CTL_BP BIT8 /* 1 = Force collision on all RX frames */ |
#define | EMAC_CFG_SPD BIT0 /* 1 = 10/100 Speed (not functional?) */ |
#define | EMAC_CFG_FD BIT1 /* 1 = Full duplex. */ |
#define | EMAC_CFG_BR BIT2 /* write 0 */ |
#define | EMAC_CFG_CAF BIT4 /* 1 = accept all frames */ |
#define | EMAC_CFG_NBC BIT5 /* 1 = disable reception of bcast frms */ |
#define | EMAC_CFG_MTI BIT6 /* 1 = Multicast hash enable */ |
#define | EMAC_CFG_UNI BIT7 /* 1 = Unicast hash enable. */ |
#define | EMAC_CFG_BIG BIT8 /* 1 = enable reception 1522 byte frms */ |
#define | EMAC_CFG_EAE BIT9 /* write 0 */ |
#define | EMAC_CFG_CLK_8 (0 << 10) /* MII Clock = HCLK divided by 8 */ |
#define | EMAC_CFG_CLK_16 (1 << 10) /* MII Clock = HCLK divided by 16 */ |
#define | EMAC_CFG_CLK_32 (2 << 10) /* MII Clock = HCLK divided by 32 */ |
#define | EMAC_CFG_CLK_64 (3 << 10) /* MII Clock = HCLK divided by 64 */ |
#define | EMAC_CFG_CLK_MASK (3 << 10) /* MII Clock mask */ |
#define | EMAC_CFG_RTY BIT12 /* Retry Test Mode - Must be 0 */ |
#define | EMAC_CFG_RMII BIT13 /* Reduced MII Mode Enable */ |
#define | EMAC_LINK BIT0 /* Link pin */ |
#define | EMAC_MDIO BIT1 /* Real Time state of MDIO pin */ |
#define | EMAC_IDLE BIT2 /* 0 = PHY Logic is idle */ |
#define | EMAC_TCR_LEN(_x_) ((_x_ & 0x7FF) << 0) /* Tx frame len minus CRC */ |
#define | EMAC_TCR_NCRC BIT15 /* Do'nt append CRC on Tx */ |
#define | EMAC_TSR_OVR BIT0 /* 1 = Transmit buffer overrun */ |
#define | EMAC_TSR_COL BIT1 /* 1 = Collision occured */ |
#define | EMAC_TSR_RLE BIT2 /* 1 = Retry lmimt exceeded */ |
#define | EMAC_TSR_TXIDLE BIT3 /* 1 = Transmitter is idle */ |
#define | EMAC_TSR_BNQ BIT4 /* 1 = Transmit buffer not queued */ |
#define | EMAC_TSR_COMP BIT5 /* 1 = Transmit complete */ |
#define | EMAC_TSR_UND BIT6 /* 1 = Transmit underrun */ |
#define | EMAC_RSR_BNA BIT0 /* 1 = Buffer not available */ |
#define | EMAC_RSR_REC BIT1 /* 1 = Frame received */ |
#define | EMAC_RSR_OVR BIT2 /* 1 = Receive overrun */ |
#define | EMAC_INT_DONE BIT0 /* Phy management done */ |
#define | EMAC_INT_RCOM BIT1 /* Receive complete */ |
#define | EMAC_INT_RBNA BIT2 /* Receive buffer not available */ |
#define | EMAC_INT_TOVR BIT3 /* Transmit buffer overrun */ |
#define | EMAC_INT_TUND BIT4 /* Transmit buffer underrun */ |
#define | EMAC_INT_RTRY BIT5 /* Transmit Retry limt */ |
#define | EMAC_INT_TBRE BIT6 /* Transmit buffer register empty */ |
#define | EMAC_INT_TCOM BIT7 /* Transmit complete */ |
#define | EMAC_INT_TIDLE BIT8 /* Transmit idle */ |
#define | EMAC_INT_LINK BIT9 /* Link pin changed value */ |
#define | EMAC_INT_ROVR BIT10 /* Receive overrun */ |
#define | EMAC_INT_ABT BIT11 /* Abort on DMA transfer */ |
#define | EMAC_MAN_DATA(_x_) ((_x_ & 0xFFFF) << 0)/* PHY data register */ |
#define | EMAC_MAN_CODE (0x2 << 16) /* IEEE Code */ |
#define | EMAC_MAN_REGA(_x_) ((_x_ & 0x1F) << 18) /* PHY register address */ |
#define | EMAC_MAN_PHYA(_x_) ((_x_ & 0x1F) << 23) /* PHY address */ |
#define | EMAC_MAN_WRITE (0x1 << 28) /* Transfer is a write */ |
#define | EMAC_MAN_READ (0x2 << 28) /* Transfer is a read */ |
#define | EMAC_MAN_HIGH BIT30 /* Must be set */ |
#define | EMAC_MAN_LOW BIT31 |
#define | RXBUF_ADD_BASE_MASK 0xfffffffc /* Base addr of the rx buf */ |
#define | RXBUF_ADD_WRAP BIT1 /* set indicates last buf */ |
#define | RXBUF_ADD_OWNED BIT0 /* 1 = SW owns the pointer */ |
#define | RXBUF_STAT_BCAST BIT31 /* Global bcast addr detected */ |
#define | RXBUF_STAT_MULTI BIT30 /* Multicast hash match */ |
#define | RXBUF_STAT_UNI BIT29 /* Unicast hash match */ |
#define | RXBUF_STAT_EXT BIT28 /* External address (optional) */ |
#define | RXBUF_STAT_UNK BIT27 /* Unknown source address */ |
#define | RXBUF_STAT_LOC1 BIT26 /* Local address 1 match */ |
#define | RXBUF_STAT_LOC2 BIT25 /* Local address 2 match */ |
#define | RXBUF_STAT_LOC3 BIT24 /* Local address 3 match */ |
#define | RXBUF_STAT_LOC4 BIT23 /* Local address 4 match */ |
#define | RXBUF_STAT_LEN_MASK 0x7ff /* Len of frame including FCS */ |
