RTEMS
5.1
Atmel AT91RM9200 Register Definitions. More...
#include "bits.h"
#define | AIC_SMR_BASE 0xFFFFF000 |
#define | AIC_SMR_REG(_x_) *(vulong *)(AIC_SMR_BASE + (_x_ & 0x7c)) |
#define | AIC_SVR_BASE 0xFFFFF080 |
#define | AIC_SVR_REG(_x_) *(vulong *)(AIC_SVR_BASE + (_x_ & 0x7c)) |
#define | AIC_CTL_BASE 0xFFFFF100 |
#define | AIC_CTL_REG(_x_) *(vulong *)(AIC_CTL_BASE + (_x_ & 0x7f)) |
#define | AIC_SMR_FIQ 0x00 /* Advanced Interrupt Controller FIQ */ |
#define | AIC_SMR_SYSIRQ 0x04 /* Advanced Interrupt Controller SYSIRQ */ |
#define | AIC_SMR_PIOA 0x08 /* Parallel I/O Controller A */ |
#define | AIC_SMR_PIOB 0x0c /* Parallel I/O Controller B */ |
#define | AIC_SMR_PIOC 0x10 /* Parallel I/O Controller C */ |
#define | AIC_SMR_PIOD 0x14 /* Parallel I/O Controller D */ |
#define | AIC_SMR_US0 0x18 /* USART 0 */ |
#define | AIC_SMR_US1 0x1c /* USART 1 */ |
#define | AIC_SMR_US2 0x20 /* USART 2 */ |
#define | AIC_SMR_US3 0x24 /* USART 3 */ |
#define | AIC_SMR_MCI 0x28 /* Multimedia Card Interface */ |
#define | AIC_SMR_UDP 0x2c /* USB Device Port */ |
#define | AIC_SMR_TWI 0x30 /* Two-wire Interface */ |
#define | AIC_SMR_SPI 0x34 /* Serial Peripheral Interface */ |
#define | AIC_SMR_SSC0 0x38 /* Synchronous Serial Controller 0 */ |
#define | AIC_SMR_SSC1 0x3c /* Synchronous Serial Controller 1 */ |
#define | AIC_SMR_SSC2 0x40 /* Synchronous Serial Controller 2 */ |
#define | AIC_SMR_TC0 0x44 /* Timer/Counter 0 */ |
#define | AIC_SMR_TC1 0x48 /* Timer/Counter 1 */ |
#define | AIC_SMR_TC2 0x4c /* Timer/Counter 2 */ |
#define | AIC_SMR_TC3 0x50 /* Timer/Counter 3 */ |
#define | AIC_SMR_TC4 0x54 /* Timer/Counter 4 */ |
#define | AIC_SMR_TC5 0x58 /* Timer/Counter 5 */ |
#define | AIC_SMR_UHP 0x5c /* USB Host Port */ |
#define | AIC_SMR_EMAC 0x60 /* Ethernet MAC */ |
#define | AIC_SMR_IRQ0 0x64 /* Advanced Interrupt Controller IRQ0 */ |
#define | AIC_SMR_IRQ1 0x68 /* Advanced Interrupt Controller IRQ1 */ |
#define | AIC_SMR_IRQ2 0x6c /* Advanced Interrupt Controller IRQ2 */ |
#define | AIC_SMR_IRQ3 0x70 /* Advanced Interrupt Controller IRQ3 */ |
#define | AIC_SMR_IRQ4 0x74 /* Advanced Interrupt Controller IRQ4 */ |
#define | AIC_SMR_IRQ5 0x78 /* Advanced Interrupt Controller IRQ5 */ |
#define | AIC_SMR_IRQ6 0x7c /* Advanced Interrupt Controller IRQ6 */ |
#define | AIC_IVR 0x00 /* IRQ Vector Register */ |
#define | AIC_FVR 0x04 /* FIQ Vector Register */ |
#define | AIC_ISR 0x08 /* Interrupt Status Register */ |
#define | AIC_IPR 0x0C /* Interrupt Pending Register */ |
#define | AIC_IMR 0x10 /* Interrupt Mask Register */ |
#define | AIC_CISR 0x14 /* Core Interrupt Status Register */ |
#define | AIC_IECR 0x20 /* Interrupt Enable Command Register */ |
#define | AIC_IDCR 0x24 /* Interrupt Disable Command Register */ |
#define | AIC_ICCR 0x28 /* Interrupt Clear Command Register */ |
#define | AIC_ISCR 0x2C /* Interrupt Set Command Register */ |
#define | AIC_EOICR 0x30 /* End of Interrupt Command Register */ |
#define | AIC_SPU 0x34 /* Spurious Vector Register */ |
#define | AIC_DCR 0x38 /* Debug Control Register (Protect) */ |
#define | AIC_FFER 0x40 /* Fast Forcing Enable Register */ |
#define | AIC_FFDR 0x44 /* Fast Forcing Disable Register */ |
#define | AIC_FFSR 0x48 /* Fast Forcing Status Register */ |
#define | AIC_ISR_IRQID_MASK 0x1f /* current interrupt ID */ |
#define | AIC_CISR_IRQ BIT1 /* 1 = Core IRQ is active */ |
#define | AIC_CISR_FIQ BIT0 /* 1 = Core FIQ is active */ |
#define | AIC_DCR_GMSK BIT1 /* 0 = AIC controls IRQ and FIQ */ |
#define | AIC_DCR_PROT BIT0 /* 1 = enable protection mode */ |
#define | AIC_SMR_PRIOR(_x_) ((_x_ & 0x07) << 0) |
#define | AIC_SMR_SRC_LVL_LOW (0 << 5) /* Are these right? docs don't say which is high/low */ |
#define | AIC_SMR_SRC_EDGE_LOW (1 << 5) |
#define | AIC_SMR_SRC_LVL_HI (2 << 5) |
#define | AIC_SMR_SRC_EDGE_HI (3 << 5) |
#define | DBGU_BASE 0xFFFFF200 |
#define | DBGU_REG(_x_) *(vulong *)(DBGU_BASE + _x_) |
#define | DBGU_CR 0x00 /* Control Register */ |
#define | DBGU_MR 0x04 /* Mode Register */ |
#define | DBGU_IER 0x08 /* Interrupt Enable Register */ |
#define | DBGU_IDR 0x0C /* Interrupt Disable Register */ |
#define | DBGU_IMR 0x10 /* Interrupt Mask Register */ |
#define | DBGU_CSR 0x14 /* Channel Status Register */ |
#define | DBGU_RHR 0x18 /* Receiver Holding Register */ |
#define | DBGU_THR 0x1C /* Transmitter Holding Register */ |
#define | DBGU_BRGR 0x20 /* Baud Rate Generator Register */ |
#define | DBGU_C1R 0x40 /* Chip ID1 Register */ |
#define | DBGU_C2R 0x44 /* Chip ID2 Register */ |
#define | DBGU_FNTR 0x48 /* Force NTRST Register */ |
#define | USART0_BASE 0xFFFC0000 |
#define | USART1_BASE 0xFFFC4000 |
#define | USART2_BASE 0xFFFC8000 |
#define | USART3_BASE 0xFFFCC000 |
#define | ST_BASE 0xFFFFFD00 |
#define | ST_REG(_x_) *(vulong *)(ST_BASE + _x_) |
#define | ST_CR 0x00 /* Control Register */ |
#define | ST_PIMR 0x04 /* Period Interval Mode Register */ |
#define | ST_WDMR 0x08 /* Watchdog Mode Register */ |
#define | ST_RTMR 0x0C /* Real-time Mode Register */ |
#define | ST_SR 0x10 /* Status Register */ |
#define | ST_IER 0x14 /* Interrupt Enable Register */ |
#define | ST_IDR 0x18 /* Interrupt Disable Register */ |
#define | ST_IMR 0x1C /* Interrupt Mask Register */ |
#define | ST_RTAR 0x20 /* Real-time Alarm Register */ |
#define | ST_CRTR 0x24 /* Current Real-time Register */ |
#define | ST_CR_WDRST BIT0 /* write 1 to reload WD counter */ |
#define | ST_PIMR_PIV_MASK 0x0000ffff |
#define | ST_WDMR_EXTEN BIT17 /* WDOVF is not implemented on AT91RM9200 */ |
#define | ST_WDMR_RSTEN BIT16 /* 1 = reset the AT91RM9200 when WD overflows */ |
#define | ST_WDMR_WDV_MASK 0x0000ffff /* WD counter is in the lower 16-bits */ |
#define | ST_RTMR_RTPRES_MASK 0x0000ffff /* Real-Time Prescaler */ |
#define | ST_SR_ALMS BIT3 |
#define | ST_SR_RTTINC BIT2 |
#define | ST_SR_WDOVF BIT1 |
#define | ST_SR_PITS BIT0 |
#define | ST_RTAR_ALMV_MASK 0x000fffff |
#define | ST_CRTR_CRTV_MASK 0x000fffff |
#define | PDC_RPR 0x100 /* Receive Pointer Register */ |
#define | PDC_RCR 0x104 /* Receive Counter Register */ |
#define | PDC_TPR 0x108 /* Transmit Pointer Register */ |
#define | PDC_TCR 0x10c /* Transmit Counter Register */ |
#define | PDC_RNPR 0x110 /* Receive Next Pointer Register */ |
#define | PDC_RNCR 0x114 /* Receive Next Counter Register */ |
#define | PDC_TNPR 0x118 /* Transmit Next Pointer Register */ |
#define | PDC_TNCR 0x11c /* Transmit Next Counter Register */ |
#define | PDC_PTCR 0x120 /* PDC Transfer Control Register */ |
#define | PDC_PTSR 0x124 /* PDC Transfer Status Register */ |
#define | PIOA_BASE 0xFFFFF400 |
#define | PIOA_REG(_x_) *(vulong *)(PIOA_BASE + _x_) |
#define | PIOB_BASE 0xFFFFF600 |
#define | PIOB_REG(_x_) *(vulong *)(PIOB_BASE + _x_) |
#define | PIOC_BASE 0xFFFFF800 |
#define | PIOC_REG(_x_) *(vulong *)(PIOC_BASE + _x_) |
#define | PIOD_BASE 0xFFFFFA00 |
#define | PIOD_REG(_x_) *(vulong *)(PIOD_BASE + _x_) |
#define | PMC_BASE 0xFFFFFC00 |
#define | PMC_REG(_x_) *(vulong *)(PMC_BASE + _x_) |
#define | EMAC_BASE 0xFFFBC000 |
#define | EMAC_REG(_x_) *(vulong *)(EMAC_BASE + _x_) |
#define | TC_BASE 0xFFFA0000 |
#define | TC_REG(_x_) *(vulong *)(TC_BASE + 0x00 + _x_) |
#define | TC_TC0_REG(_x_) *(vulong *)(TC_BASE + 0x00 + _x_) |
#define | TC_TC1_REG(_x_) *(vulong *)(TC_BASE + 0x40 + _x_) |
#define | TC_TC2_REG(_x_) *(vulong *)(TC_BASE + 0x80 + _x_) |
#define | TC_CCR 0x00 /* Channel Control Register */ |
#define | TC_CMR 0x04 /* Channel Mode Register */ |
#define | TC_CV 0x10 /* Counter Value */ |
#define | TC_RA 0x14 /* Register A */ |
#define | TC_RB 0x18 /* Register B */ |
#define | TC_RC 0x1C /* Register C */ |
#define | TC_SR 0x20 /* Status Register */ |
#define | TC_IER 0x24 /* Interrupt Enable Register */ |
#define | TC_IDR 0x28 /* Interrupt Disable Register */ |
#define | TC_IMR 0x2C /* Interrupt Mask Register */ |
#define | TC_BCR 0xc0 /* Channel Control Register */ |
#define | TC_BMR 0xc4 /* Channel Control Register */ |
#define | TC_BCR_SYNC BIT1 /* Set to syncronize channels */ |
#define | TC_BMR_TC0(_x_) ((_x_ & 0x3) << 0) /* TC0 clock source */ |
#define | TC_BMR_TC1(_x_) ((_x_ & 0x3) << 2) /* TC1 clock source */ |
#define | TC_BMR_TC2(_x_) ((_x_ & 0x3) << 4) /* TC2 clock source */ |
#define | TC_CCR_CLKEN BIT0 /* Enable clock */ |
#define | TC_CCR_CLKDIS BIT1 /* Disable clock */ |
#define | TC_CCR_SWTRG BIT2 /* Software trigger command */ |
#define | TC_CMR_TCCLKS(_x_) ((_x_ & 0x7) << 0) /* Clock source */ |
#define | TC_CMR_CLKI BIT3 /* Clock invert */ |
#define | TC_BURST(_x_) ((_x_ & 0x3 << 4) /* Burst signal selection */ |
#define | TC_WAVE BIT15 /* 0 for catpure, 1 for wave */ |
#define | TC_CMR_LDBSTOP BIT6 /* Set to stop clock when RB loads */ |
#define | TC_CMR_LDBDIS BIT7 /* Set to disable clock when RB loads */ |
#define | TC_CMR_ETRGEDG(_x_) ((_x_ & 0x3) << 8) /* Select edge triggering mode */ |
#define | TC_CMR_ABETRG BIT10 /* Select ext trigger source */ |
#define | TC_CMR_CPCTRG BIT14 /* RC Compare trigger enable */ |
#define | TC_CMR_LDRA(_x_) ((_x_ & 0x3) << 16) /* RA loading selection */ |
#define | TC_CMR_LDRB(_x_) ((_x_ & 0x3) << 18) /* RB loading selection */ |
#define | TC_CMR_CPCSTOP BIT6 /* Clock stopped w/ RC compare */ |
#define | TC_CMR_CPCDIS BIT7 /* Clock disabled w/ RC compare */ |
#define | TC_CMR_EEVTEDG(_x_) ((_x_ & 0x3) << 8) /* Ext event edge selection */ |
#define | TC_CMR_EEVT(_x_) ((_x_ & 0x3) << 10) /* Ext event selection */ |
#define | TC_CMR_ENETRG BIT12 /* Ext event trigger enable */ |
#define | TC_CMR_WAVESEL(_x_) ((_x_ & 0x3) << 13) /* Waveform selection */ |
#define | TC_CMR_ACPA(_x_) ((_x_ & 0x3) << 16) /* RA compare effect on TIOA */ |
#define | TC_CMR_ACPC(_x_) ((_x_ & 0x3) << 18) /* RC compare effect on TIOA */ |
#define | TC_CMR_AEEVT(_x_) ((_x_ & 0x3) << 20) /* Ext event effect on TIOA */ |
#define | TC_CMR_ASWTRG(_x_) ((_x_ & 0x3) << 22) /* SW trigger effect on TIOA */ |
#define | TC_CMR_BCPB(_x_) ((_x_ & 0x3) << 24) /* RB compare effect on TIOB */ |
#define | TC_CMR_BCPC(_x_) ((_x_ & 0x3) << 26) /* RC compare effect on TIOB */ |
#define | TC_CMR_BEEVT(_x_) ((_x_ & 0x3) << 28) /* Ext event effect on TIOB */ |
#define | TC_CMR_BSWTRG(_x_) ((_x_ & 0x3) << 30) /* SW trigger effect on TIOB */ |
#define | TC_CV_MASK 0xffff /* Timer counter mask */ |
#define | TC_SR_COVFS BIT0 /* Counter overflow status */ |
#define | TC_SR_LOVRS BIT1 /* Load overrun status */ |
#define | TC_SR_CPAS BIT2 /* RA compare status */ |
#define | TC_SR_CPBS BIT3 /* RB compare status */ |
#define | TC_SR_CPCS BIT4 /* RC compare status */ |
#define | TC_SR_LDRAS BIT5 /* RA loading status */ |
#define | TC_SR_LDRBS BIT6 /* RB loading status */ |
#define | TC_SR_ETRGS BIT7 /* External trigger status */ |
#define | TC_SR_CLKSTA BIT16 /* Clock enabling status */ |
#define | TC_SR_MTIOA BIT17 /* TIOA Mirror */ |
#define | TC_SR_MTIOB BIT18 /* TIOB Mirror */ |
#define | EBI_BASE 0xFFFFFF60 |
#define | EBI_REG(_x_) *(vulong *)(EBI_BASE + _x_) |
#define | SMC_REG(_x_) *(vulong *)(EBI_BASE + 0x10 + _x_) |
#define | SDRC_REG(_x_) *(vulong *)(EBI_BASE + 0x30 + _x_) |
Typedefs | |
typedef volatile unsigned long | vulong |
