RTEMS  5.1
boot.h
1
9 /*
10  * Copyright (c) 2010
11  * embedded brains GmbH
12  * Obere Lagerstr. 30
13  * D-82178 Puchheim
14  * Germany
15  * <rtems@embedded-brains.de>
16  *
17  * The license and distribution terms for this file may be
18  * found in the file LICENSE in this distribution or at
19  * http://www.rtems.org/license/LICENSE.
20  */
21
22 #ifndef LIBBSP_ARM_LPC32XX_BOOT_H
23 #define LIBBSP_ARM_LPC32XX_BOOT_H
24
25 #include <stdint.h>
26
27 #include <bsp/nand-mlc.h>
28
29 #ifdef __cplusplus
30 extern "C" {
31 #endif /* __cplusplus */
32
58 #define LPC32XX_BOOT_BLOCK_0 0
59 #define LPC32XX_BOOT_BLOCK_1 1
60
61 #define LPC32XX_BOOT_ICR_SP_3AC_8IF 0xf0
62 #define LPC32XX_BOOT_ICR_SP_4AC_8IF 0xd2
63 #define LPC32XX_BOOT_ICR_LP_4AC_8IF 0xb4
64 #define LPC32XX_BOOT_ICR_LP_5AC_8IF 0x96
65
66 typedef union {
67  struct {
68  uint8_t d0;
69  uint8_t reserved_0 [3];
70  uint8_t d1;
71  uint8_t reserved_1 [3];
72  uint8_t d2;
73  uint8_t reserved_2 [3];
74  uint8_t d3;
75  uint8_t reserved_3 [3];
76  uint8_t d4;
77  uint8_t reserved_4 [3];
78  uint8_t d5;
79  uint8_t reserved_5 [3];
80  uint8_t d6;
81  uint8_t reserved_6 [3];
82  uint8_t d7;
83  uint8_t reserved_7 [3];
84  uint8_t d8;
85  uint8_t reserved_8 [3];
86  uint8_t d9;
87  uint8_t reserved_9 [3];
88  uint8_t d10;
89  uint8_t reserved_10 [3];
90  uint8_t d11;
91  uint8_t reserved_11 [3];
92  uint8_t d12;
93  uint8_t reserved_12 [463];
94  } field;
95  uint32_t data [MLC_SMALL_DATA_WORD_COUNT];
97
98 void lpc32xx_setup_boot_block(
99  lpc32xx_boot_block *boot_block,
100  uint8_t icr,
101  uint8_t page_count
102 );
103
104 void lpc32xx_set_boot_block_bad(
105  lpc32xx_boot_block *boot_block
106 );
107
110 #ifdef __cplusplus
111 }
112 #endif /* __cplusplus */
113
114 #endif /* LIBBSP_ARM_LPC32XX_BOOT_H */
Definition: boot.h:66
NAND MLC controller API.
