RTEMS  5.1
uart.h File Reference
UART Support. More...
#include <rtems/bspIo.h>
#define BSP_UART_INTR_CTRL_DISABLE   (0)
#define BSP_UART_INTR_CTRL_GDB   (0xaa) /* RX only */
#define BSP_UART_INTR_CTRL_ENABLE   (0xbb) /* Normal operations */
#define BSP_UART_INTR_CTRL_TERMIOS   (0xcc) /* RX & line status */
#define BSP_UART_STATUS_ERROR   (-1) /* No character */
#define BSP_UART_STATUS_NOCHAR   (0) /* No character */
#define BSP_UART_STATUS_CHAR   (1) /* Character present */
#define BSP_UART_STATUS_BREAK   (2) /* Break point is detected */
#define BSP_UART_COM1   (0)
#define BSP_UART_COM2   (1)
#define COM1_BASE_IO   0x3F8
#define COM2_BASE_IO   0x2F8
#define RBR   RSRBR /* Rx Buffer Register (read) */
#define THR   RSTHR /* Tx Buffer Register (write) */
#define IER   RSIER /* Interrupt Enable Register */
#define IIR   RSIIR /* Interrupt Ident Register (read) */
#define FCR   RSFCR /* FIFO Control Register (write) */
#define LCR   RSLCR /* Line Control Register */
#define LSR   RSLSR /* Line Status Register */
#define DLL   RSDLL /* Divisor Latch, LSB */
#define DLM   RSDLH /* Divisor Latch, MSB */
#define CNT   RSCNT /* General Control register */
#define UART_ENABLE   1
#define PAD_ENABLE   2
#define NO_MORE_INTR   1
#define TRANSMITTER_HODING_REGISTER_EMPTY   2
#define RECEIVER_DATA_AVAIL   4
#define RECEIVER_ERROR   6
#define CHARACTER_TIMEOUT_INDICATION   12
#define RECEIVE_ENABLE   0x1
#define TRANSMIT_ENABLE   0x2
#define RECEIVER_LINE_ST_ENABLE   0x4
#define INTERRUPT_DISABLE   0x0
#define DR   0x01 /* Data Ready */
#define OE   0x02 /* Overrun Error */
#define PE   0x04 /* Parity Error */
#define FE   0x08 /* Framing Error */
#define BI   0x10 /* Break Interrupt */
#define THRE   0x20 /* Transmitter Holding Register Empty */
#define TEMT   0x40 /* Transmitter Empty */
#define ERFIFO   0x80 /* Error receive Fifo */
#define CHR_5_BITS   0
#define CHR_6_BITS   1
#define CHR_7_BITS   2
#define CHR_8_BITS   3
#define WL   0x03 /* Word length mask */
#define STB   0x04 /* 1 Stop Bit, otherwise 2 Stop Bits */
#define PEN   0x08 /* Parity Enabled */
#define EPS   0x10 /* Even Parity Select, otherwise Odd */
#define SP   0x20 /* Stick Parity */
#define BCB   0x40 /* Break Control Bit */
#define DLAB   0x80 /* Enable Divisor Latch Access */
#define FIFO_CTRL   0x01 /* Set to 1 permit access to other bits */
#define FIFO_EN   0x01 /* Enable the FIFO */
#define XMIT_RESET   0x04 /* Transmit FIFO Reset */
#define RCV_RESET   0x02 /* Receive FIFO Reset */
#define FCR3   0x08 /* do not understand manual! */
#define RECEIVE_FIFO_TRIGGER1   0x0 /* trigger recieve interrupt after 1 byte */
#define RECEIVE_FIFO_TRIGGER4   0x40 /* trigger recieve interrupt after 4 byte */
#define RECEIVE_FIFO_TRIGGER8   0x80 /* trigger recieve interrupt after 8 byte */
#define RECEIVE_FIFO_TRIGGER12   0xc0 /* trigger recieve interrupt after 14 byte */
#define TRIG_LEVEL   0xc0 /* Mask for the trigger level */
void BSP_uart_init (int uart, int baud, int hwFlow)
void BSP_uart_set_baud (int aurt, int baud)
void BSP_uart_intr_ctrl (int uart, int cmd)
void BSP_uart_throttle (int uart)
void BSP_uart_unthrottle (int uart)
int BSP_uart_polled_status (int uart)
void BSP_uart_polled_write (int uart, int val)
int BSP_uart_polled_read (int uart)
void BSP_uart_termios_set (int uart, void *ttyp)
int BSP_uart_termios_write_com1 (int minor, const char *buf, int len)
int BSP_uart_termios_write_com2 (int minor, const char *buf, int len)
void BSP_uart_termios_isr_com1 (void)
void BSP_uart_termios_isr_com2 (void)
void BSP_uart_dbgisr_com1 (void)
void BSP_uart_dbgisr_com2 (void)
unsigned BSP_poll_char_via_serial (void)
void BSP_output_char_via_serial (int val)
int BSPConsolePort
int BSPBaseBaud
UART Support.
