RTEMS  5.1
arm-release-id.h
1
9 /*
10  * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Dornierstr. 4
14  * 82178 Puchheim
15  * Germany
16  * <rtems@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef ARM_RELEASE_ID_H_
24 #define ARM_RELEASE_ID_H_
25
26 #ifdef __cplusplus
27 extern "C" {
28 #endif /* __cplusplus */
29
30 /* #define the IDs which identify a release. This must be done
31  * prior to #including bsp.h */
32 #define ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( release_no, patch_level ) \
33  ( ( ( ( release_no ) & 0xFFFF ) << 16 ) + ( ( patch_level ) & 0xFFFF ) )
34
35 typedef enum {
36  ARM_RELEASE_ID_R0_P0 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 0 ),
37  ARM_RELEASE_ID_R0_P1 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 1 ),
38  ARM_RELEASE_ID_R0_P2 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 2 ),
39  ARM_RELEASE_ID_R0_P3 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 3 ),
40  ARM_RELEASE_ID_R0_P4 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 4 ),
41  ARM_RELEASE_ID_R0_P5 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 5 ),
42  ARM_RELEASE_ID_R0_P6 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 6 ),
43  ARM_RELEASE_ID_R0_P7 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 7 ),
44  ARM_RELEASE_ID_R0_P8 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 8 ),
45  ARM_RELEASE_ID_R0_P9 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 9 ),
46  ARM_RELEASE_ID_R0_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 0, 10 ),
47  ARM_RELEASE_ID_R1_P0 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 0 ),
48  ARM_RELEASE_ID_R1_P1 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 1 ),
49  ARM_RELEASE_ID_R1_P2 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 2 ),
50  ARM_RELEASE_ID_R1_P3 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 3 ),
51  ARM_RELEASE_ID_R1_P4 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 4 ),
52  ARM_RELEASE_ID_R1_P5 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 5 ),
53  ARM_RELEASE_ID_R1_P6 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 6 ),
54  ARM_RELEASE_ID_R1_P7 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 7 ),
55  ARM_RELEASE_ID_R1_P8 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 8 ),
56  ARM_RELEASE_ID_R1_P9 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 9 ),
57  ARM_RELEASE_ID_R1_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 1, 10 ),
58  ARM_RELEASE_ID_R2_P0 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 0 ),
59  ARM_RELEASE_ID_R2_P1 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 1 ),
60  ARM_RELEASE_ID_R2_P2 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 2 ),
61  ARM_RELEASE_ID_R2_P3 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 3 ),
62  ARM_RELEASE_ID_R2_P4 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 4 ),
63  ARM_RELEASE_ID_R2_P5 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 5 ),
64  ARM_RELEASE_ID_R2_P6 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 6 ),
65  ARM_RELEASE_ID_R2_P7 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 7 ),
66  ARM_RELEASE_ID_R2_P8 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 8 ),
67  ARM_RELEASE_ID_R2_P9 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 9 ),
68  ARM_RELEASE_ID_R2_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 2, 10 ),
69  ARM_RELEASE_ID_R3_P0 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 0 ),
70  ARM_RELEASE_ID_R3_P1 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 1 ),
71  ARM_RELEASE_ID_R3_P2 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 2 ),
72  ARM_RELEASE_ID_R3_P3 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 3 ),
73  ARM_RELEASE_ID_R3_P4 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 4 ),
74  ARM_RELEASE_ID_R3_P5 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 5 ),
75  ARM_RELEASE_ID_R3_P6 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 6 ),
76  ARM_RELEASE_ID_R3_P7 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 7 ),
77  ARM_RELEASE_ID_R3_P8 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 8 ),
78  ARM_RELEASE_ID_R3_P9 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 9 ),
79  ARM_RELEASE_ID_R3_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 3, 10 ),
80  ARM_RELEASE_ID_R4_P0 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 0 ),
81  ARM_RELEASE_ID_R4_P1 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 1 ),
82  ARM_RELEASE_ID_R4_P2 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 2 ),
83  ARM_RELEASE_ID_R4_P3 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 3 ),
84  ARM_RELEASE_ID_R4_P4 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 4 ),
85  ARM_RELEASE_ID_R4_P5 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 5 ),
86  ARM_RELEASE_ID_R4_P6 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 6 ),
87  ARM_RELEASE_ID_R4_P7 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 7 ),
88  ARM_RELEASE_ID_R4_P8 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 8 ),
89  ARM_RELEASE_ID_R4_P9 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 9 ),
90  ARM_RELEASE_ID_R4_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 4, 10 ),
91  ARM_RELEASE_ID_R5_P0 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 0 ),
92  ARM_RELEASE_ID_R5_P1 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 1 ),
93  ARM_RELEASE_ID_R5_P2 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 2 ),
94  ARM_RELEASE_ID_R5_P3 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 3 ),
95  ARM_RELEASE_ID_R5_P4 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 4 ),
96  ARM_RELEASE_ID_R5_P5 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 5 ),
97  ARM_RELEASE_ID_R5_P6 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 6 ),
98  ARM_RELEASE_ID_R5_P7 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 7 ),
99  ARM_RELEASE_ID_R5_P8 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 8 ),
100  ARM_RELEASE_ID_R5_P9 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 9 ),
101  ARM_RELEASE_ID_R5_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 5, 10 ),
102  ARM_RELEASE_ID_R6_P0 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 0 ),
103  ARM_RELEASE_ID_R6_P1 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 1 ),
104  ARM_RELEASE_ID_R6_P2 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 2 ),
105  ARM_RELEASE_ID_R6_P3 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 3 ),
106  ARM_RELEASE_ID_R6_P4 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 4 ),
107  ARM_RELEASE_ID_R6_P5 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 5 ),
108  ARM_RELEASE_ID_R6_P6 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 6 ),
109  ARM_RELEASE_ID_R6_P7 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 7 ),
110  ARM_RELEASE_ID_R6_P8 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 8 ),
111  ARM_RELEASE_ID_R6_P9 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 9 ),
112  ARM_RELEASE_ID_R6_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 6, 10 ),
113  ARM_RELEASE_ID_R7_P0 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 0 ),
114  ARM_RELEASE_ID_R7_P1 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 1 ),
115  ARM_RELEASE_ID_R7_P2 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 2 ),
116  ARM_RELEASE_ID_R7_P3 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 3 ),
117  ARM_RELEASE_ID_R7_P4 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 4 ),
118  ARM_RELEASE_ID_R7_P5 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 5 ),
119  ARM_RELEASE_ID_R7_P6 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 6 ),
120  ARM_RELEASE_ID_R7_P7 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 7 ),
121  ARM_RELEASE_ID_R7_P8 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 8 ),
122  ARM_RELEASE_ID_R7_P9 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 9 ),
123  ARM_RELEASE_ID_R7_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 7, 10 ),
124  ARM_RELEASE_ID_R8_P0 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 0 ),
125  ARM_RELEASE_ID_R8_P1 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 1 ),
126  ARM_RELEASE_ID_R8_P2 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 2 ),
127  ARM_RELEASE_ID_R8_P3 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 3 ),
128  ARM_RELEASE_ID_R8_P4 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 4 ),
129  ARM_RELEASE_ID_R8_P5 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 5 ),
130  ARM_RELEASE_ID_R8_P6 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 6 ),
131  ARM_RELEASE_ID_R8_P7 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 7 ),
132  ARM_RELEASE_ID_R8_P8 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 8 ),
133  ARM_RELEASE_ID_R8_P9 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 9 ),
134  ARM_RELEASE_ID_R8_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 8, 10 ),
135  ARM_RELEASE_ID_R9_P0 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 0 ),
136  ARM_RELEASE_ID_R9_P1 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 1 ),
137  ARM_RELEASE_ID_R9_P2 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 2 ),
138  ARM_RELEASE_ID_R9_P3 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 3 ),
139  ARM_RELEASE_ID_R9_P4 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 4 ),
140  ARM_RELEASE_ID_R9_P5 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 5 ),
141  ARM_RELEASE_ID_R9_P6 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 6 ),
142  ARM_RELEASE_ID_R9_P7 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 7 ),
143  ARM_RELEASE_ID_R9_P8 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 8 ),
144  ARM_RELEASE_ID_R9_P9 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 9 ),
145  ARM_RELEASE_ID_R9_P10 = ARM_RELEASE_ID_FROM_NUMBER_AND_PATCH_LEVEL( 9, 10 )
146 } arm_release_id;
147
148 #ifdef __cplusplus
149 }
150 #endif /* __cplusplus */
151
152 #endif /* ARM_RELEASE_ID_H_ */
