RTEMS  5.1
arm-pl111-regs.h
1
9 /*
10  * Copyright (c) 2013 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Dornierstr. 4
14  * 82178 Puchheim
15  * Germany
16  * <info@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef LIBBSP_ARM_SHARED_ARM_PL111_REGS_H
24 #define LIBBSP_ARM_SHARED_ARM_PL111_REGS_H
25
26 #include <bsp/utility.h>
27
28 typedef struct {
29  uint32_t timing0;
30 #define PL111_LCD_TIMING0_PPL(val) BSP_FLD32(val, 2, 7)
31 #define PL111_LCD_TIMING0_PPL_GET(reg) BSP_FLD32GET(reg, 2, 7)
32 #define PL111_LCD_TIMING0_PPL_SET(reg, val) BSP_FLD32SET(reg, val, 2, 7)
33 #define PL111_LCD_TIMING0_HSW(val) BSP_FLD32(val, 8, 15)
34 #define PL111_LCD_TIMING0_HSW_GET(reg) BSP_FLD32GET(reg, 8, 15)
35 #define PL111_LCD_TIMING0_HSW_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
36 #define PL111_LCD_TIMING0_HFP(val) BSP_FLD32(val, 16, 23)
37 #define PL111_LCD_TIMING0_HFP_GET(reg) BSP_FLD32GET(reg, 16, 23)
38 #define PL111_LCD_TIMING0_HFP_SET(reg, val) BSP_FLD32SET(reg, val, 16, 23)
39 #define PL111_LCD_TIMING0_HBP(val) BSP_FLD32(val, 24, 31)
40 #define PL111_LCD_TIMING0_HBP_GET(reg) BSP_FLD32GET(reg, 24, 31)
41 #define PL111_LCD_TIMING0_HBP_SET(reg, val) BSP_FLD32SET(reg, val, 24, 31)
42  uint32_t timing1;
43 #define PL111_LCD_TIMING1_LPP(val) BSP_FLD32(val, 0, 9)
44 #define PL111_LCD_TIMING1_LPP_GET(reg) BSP_FLD32GET(reg, 0, 9)
45 #define PL111_LCD_TIMING1_LPP_SET(reg, val) BSP_FLD32SET(reg, val, 0, 9)
46 #define PL111_LCD_TIMING1_VSW(val) BSP_FLD32(val, 10, 15)
47 #define PL111_LCD_TIMING1_VSW_GET(reg) BSP_FLD32GET(reg, 10, 15)
48 #define PL111_LCD_TIMING1_VSW_SET(reg, val) BSP_FLD32SET(reg, val, 10, 15)
49 #define PL111_LCD_TIMING1_VFP(val) BSP_FLD32(val, 16, 23)
50 #define PL111_LCD_TIMING1_VFP_GET(reg) BSP_FLD32GET(reg, 16, 23)
51 #define PL111_LCD_TIMING1_VFP_SET(reg, val) BSP_FLD32SET(reg, val, 16, 23)
52 #define PL111_LCD_TIMING1_VBP(val) BSP_FLD32(val, 24, 31)
53 #define PL111_LCD_TIMING1_VBP_GET(reg) BSP_FLD32GET(reg, 24, 31)
54 #define PL111_LCD_TIMING1_VBP_SET(reg, val) BSP_FLD32SET(reg, val, 24, 31)
55  uint32_t timing2;
56 #define PL111_LCD_TIMING2_PCD_LO(val) BSP_FLD32(val, 0, 4)
57 #define PL111_LCD_TIMING2_PCD_LO_GET(reg) BSP_FLD32GET(reg, 0, 4)
58 #define PL111_LCD_TIMING2_PCD_LO_SET(reg, val) BSP_FLD32SET(reg, val, 0, 4)
59 #define PL111_LCD_TIMING2_CLKSEL BSP_BIT32(5)
60 #define PL111_LCD_TIMING2_ACB(val) BSP_FLD32(val, 6, 10)
61 #define PL111_LCD_TIMING2_ACB_GET(reg) BSP_FLD32GET(reg, 6, 10)
62 #define PL111_LCD_TIMING2_ACB_SET(reg, val) BSP_FLD32SET(reg, val, 6, 10)
63 #define PL111_LCD_TIMING2_IVS BSP_BIT32(11)
64 #define PL111_LCD_TIMING2_IHS BSP_BIT32(12)
65 #define PL111_LCD_TIMING2_IPC BSP_BIT32(13)
66 #define PL111_LCD_TIMING2_IOE BSP_BIT32(14)
67 #define PL111_LCD_TIMING2_CPL(val) BSP_FLD32(val, 16, 25)
68 #define PL111_LCD_TIMING2_CPL_GET(reg) BSP_FLD32GET(reg, 16, 25)
69 #define PL111_LCD_TIMING2_CPL_SET(reg, val) BSP_FLD32SET(reg, val, 16, 25)
70 #define PL111_LCD_TIMING2_BCD BSP_BIT32(26)
71 #define PL111_LCD_TIMING2_PCD_HI(val) BSP_FLD32(val, 27, 31)
72 #define PL111_LCD_TIMING2_PCD_HI_GET(reg) BSP_FLD32GET(reg, 27, 31)
73 #define PL111_LCD_TIMING2_PCD_HI_SET(reg, val) BSP_FLD32SET(reg, val, 27, 31)
74  uint32_t timing3;
75 #define PL111_LCD_TIMING3_LED(val) BSP_FLD32(val, 0, 6)
76 #define PL111_LCD_TIMING3_LED_GET(reg) BSP_FLD32GET(reg, 0, 6)
77 #define PL111_LCD_TIMING3_LED_SET(reg, val) BSP_FLD32SET(reg, val, 0, 6)
78 #define PL111_LCD_TIMING3_LEE BSP_BIT32(16)
79  uint32_t upbase;
80  uint32_t lpbase;
81  uint32_t control;
82 #define PL111_LCD_CONTROL_LCD_EN BSP_BIT32(0)
83 #define PL111_LCD_CONTROL_LCD_BPP(val) BSP_FLD32(val, 1, 3)
84 #define PL111_LCD_CONTROL_LCD_BPP_GET(reg) BSP_FLD32GET(reg, 1, 3)
85 #define PL111_LCD_CONTROL_LCD_BPP_SET(reg, val) BSP_FLD32SET(reg, val, 1, 3)
86 #define PL111_LCD_CONTROL_LCD_BPP_1 0x00U
87 #define PL111_LCD_CONTROL_LCD_BPP_2 0x01U
88 #define PL111_LCD_CONTROL_LCD_BPP_4 0x02U
89 #define PL111_LCD_CONTROL_LCD_BPP_8 0x03U
90 #define PL111_LCD_CONTROL_LCD_BPP_16 0x04U
91 #define PL111_LCD_CONTROL_LCD_BPP_24 0x05U
92 #define PL111_LCD_CONTROL_LCD_BPP_16_5_6_5 0x06U
93 #define PL111_LCD_CONTROL_LCD_BPP_12 0x07U
94 #define PL111_LCD_CONTROL_LCD_BW BSP_BIT32(4)
95 #define PL111_LCD_CONTROL_LCD_TFT BSP_BIT32(5)
96 #define PL111_LCD_CONTROL_LCD_MONO8 BSP_BIT32(6)
97 #define PL111_LCD_CONTROL_LCD_DUAL BSP_BIT32(7)
98 #define PL111_LCD_CONTROL_BGR BSP_BIT32(8)
99 #define PL111_LCD_CONTROL_BEBO BSP_BIT32(9)
100 #define PL111_LCD_CONTROL_BEPO BSP_BIT32(10)
101 #define PL111_LCD_CONTROL_LCD_PWR BSP_BIT32(11)
102 #define PL111_LCD_CONTROL_LCD_V_COMP(val) BSP_FLD32(val, 12, 13)
103 #define PL111_LCD_CONTROL_LCD_V_COMP_GET(reg) BSP_FLD32GET(reg, 12, 13)
104 #define PL111_LCD_CONTROL_LCD_V_COMP_SET(reg, val) BSP_FLD32SET(reg, val, 12, 13)
105 #define PL111_LCD_CONTROL_WATERMARK BSP_BIT32(16)
106  uint32_t imsc;
107  uint32_t ris;
108  uint32_t mis;
109  uint32_t icr;
110 #define PL111_LCD_I_FUF BSP_BIT32(1)
111 #define PL111_LCD_I_LNBU BSP_BIT32(2)
112 #define PL111_LCD_I_VCOMP BSP_BIT32(3)
113 #define PL111_LCD_I_MBERROR BSP_BIT32(4)
114  uint32_t upcurr;
115  uint32_t lpcurr;
116  uint32_t reserved_34[115];
117  uint16_t pal[256];
118 #define PL111_LCD_PAL_R(val) BSP_FLD16(val, 0, 4)
119 #define PL111_LCD_PAL_R_GET(reg) BSP_FLD16GET(reg, 0, 4)
120 #define PL111_LCD_PAL_R_SET(reg, val) BSP_FLD16SET(reg, val, 0, 4)
121 #define PL111_LCD_PAL_G(val) BSP_FLD16(val, 5, 9)
122 #define PL111_LCD_PAL_G_GET(reg) BSP_FLD16GET(reg, 5, 9)
123 #define PL111_LCD_PAL_G_SET(reg, val) BSP_FLD16SET(reg, val, 5, 9)
124 #define PL111_LCD_PAL_B(val) BSP_FLD16(val, 10, 14)
125 #define PL111_LCD_PAL_B_GET(reg) BSP_FLD16GET(reg, 10, 14)
126 #define PL111_LCD_PAL_B_SET(reg, val) BSP_FLD16SET(reg, val, 10, 14)
127 #define PL111_LCD_PAL_I BSP_BIT16(15)
128 } pl111_lcd;
129
130 typedef struct {
131  uint8_t image[1024];
132  uint32_t ctrl;
133 #define PL111_CRSR_CTRL_ON BSP_BIT32(0)
134 #define PL111_CRSR_CTRL_NUMBER(val) BSP_FLD32(val, 4, 5)
135 #define PL111_CRSR_CTRL_NUMBER_GET(reg) BSP_FLD32GET(reg, 4, 5)
136 #define PL111_CRSR_CTRL_NUMBER_SET(reg, val) BSP_FLD32SET(reg, val, 4, 5)
137  uint32_t config;
138 #define PL111_CRSR_CONFIG_SIZE BSP_BIT32(0)
139 #define PL111_CRSR_CONFIG_FRAME_SYNC BSP_BIT32(1)
140  uint32_t palette0;
141  uint32_t palette1;
142 #define PL111_CRSR_PALETTE_RED(val) BSP_FLD32(val, 0, 7)
143 #define PL111_CRSR_PALETTE_RED_GET(reg) BSP_FLD32GET(reg, 0, 7)
144 #define PL111_CRSR_PALETTE_RED_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
145 #define PL111_CRSR_PALETTE_GREEN(val) BSP_FLD32(val, 8, 15)
146 #define PL111_CRSR_PALETTE_GREEN_GET(reg) BSP_FLD32GET(reg, 8, 15)
147 #define PL111_CRSR_PALETTE_GREEN_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
148 #define PL111_CRSR_PALETTE_BLUE(val) BSP_FLD32(val, 16, 23)
149 #define PL111_CRSR_PALETTE_BLUE_GET(reg) BSP_FLD32GET(reg, 16, 23)
150 #define PL111_CRSR_PALETTE_BLUE_SET(reg, val) BSP_FLD32SET(reg, val, 16, 23)
151  uint32_t xy;
152 #define PL111_CRSR_XY_X(val) BSP_FLD32(val, 0, 9)
153 #define PL111_CRSR_XY_X_GET(reg) BSP_FLD32GET(reg, 0, 9)
154 #define PL111_CRSR_XY_X_SET(reg, val) BSP_FLD32SET(reg, val, 0, 9)
155 #define PL111_CRSR_XY_X_EXP(val) BSP_FLD32(val, 10, 11)
156 #define PL111_CRSR_XY_X_EXP_GET(reg) BSP_FLD32GET(reg, 10, 11)
157 #define PL111_CRSR_XY_X_EXP_SET(reg, val) BSP_FLD32SET(reg, val, 10, 11)
158 #define PL111_CRSR_XY_Y(val) BSP_FLD32(val, 16, 25)
159 #define PL111_CRSR_XY_Y_GET(reg) BSP_FLD32GET(reg, 16, 25)
160 #define PL111_CRSR_XY_Y_SET(reg, val) BSP_FLD32SET(reg, val, 16, 25)
161 #define PL111_CRSR_XY_Y_EXP(val) BSP_FLD32(val, 25, 27)
162 #define PL111_CRSR_XY_Y_EXP_GET(reg) BSP_FLD32GET(reg, 25, 27)
163 #define PL111_CRSR_XY_Y_EXP_SET(reg, val) BSP_FLD32SET(reg, val, 25, 27)
164  uint32_t clip;
165 #define PL111_CRSR_CLIP_X(val) BSP_FLD32(val, 0, 5)
166 #define PL111_CRSR_CLIP_X_GET(reg) BSP_FLD32GET(reg, 0, 5)
167 #define PL111_CRSR_CLIP_X_SET(reg, val) BSP_FLD32SET(reg, val, 0, 5)
168 #define PL111_CRSR_CLIP_Y(val) BSP_FLD32(val, 8, 13)
169 #define PL111_CRSR_CLIP_Y_GET(reg) BSP_FLD32GET(reg, 8, 13)
170 #define PL111_CRSR_CLIP_Y_SET(reg, val) BSP_FLD32SET(reg, val, 8, 13)
171  uint32_t imsc;
172  uint32_t icr;
173  uint32_t ris;
174  uint32_t mis;
175 #define PL111_CRSR_I_CRSR BSP_BIT32(0)
176 } pl111_crsr;
177
178 typedef struct {
179  pl111_lcd lcd;
180  uint32_t reserved_400[256];
181  pl111_crsr crsr;
182 } pl111;
183
184 #endif /* LIBBSP_ARM_SHARED_ARM_PL111_REGS_H */
Definition: deflate.c:115
Utility macros.
Definition: arm-pl111-regs.h:130
Definition: arm-pl111-regs.h:28
Definition: intercom.c:74
Definition: 8xx_immap.h:201
Definition: arm-pl111-regs.h:178
