RTEMS  5.1
arm-pl011-regs.h
1
9 /*
10  * Copyright (c) 2013 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Dornierstr. 4
14  * 82178 Puchheim
15  * Germany
16  * <info@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef LIBBSP_ARM_SHARED_ARM_PL011_REGS_H
24 #define LIBBSP_ARM_SHARED_ARM_PL011_REGS_H
25
26 #include <bsp/utility.h>
27
28 typedef struct {
29  uint32_t uartdr;
30 #define PL011_UARTDR_OE BSP_BIT32(11)
31 #define PL011_UARTDR_BE BSP_BIT32(10)
32 #define PL011_UARTDR_PE BSP_BIT32(9)
33 #define PL011_UARTDR_FE BSP_BIT32(8)
34 #define PL011_UARTDR_DATA(val) BSP_FLD32(val, 0, 7)
35 #define PL011_UARTDR_DATA_GET(reg) BSP_FLD32GET(reg, 0, 7)
36 #define PL011_UARTDR_DATA_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
37  uint32_t uartrsr_uartecr;
38 #define PL011_UARTRSR_UARTECR_OE BSP_BIT32(3)
39 #define PL011_UARTRSR_UARTECR_BE BSP_BIT32(2)
40 #define PL011_UARTRSR_UARTECR_PE BSP_BIT32(1)
41 #define PL011_UARTRSR_UARTECR_FE BSP_BIT32(0)
42  uint32_t reserved_08[4];
43  uint32_t uartfr;
44 #define PL011_UARTFR_RI BSP_BIT32(8)
45 #define PL011_UARTFR_TXFE BSP_BIT32(7)
46 #define PL011_UARTFR_RXFF BSP_BIT32(6)
47 #define PL011_UARTFR_TXFF BSP_BIT32(5)
48 #define PL011_UARTFR_RXFE BSP_BIT32(4)
49 #define PL011_UARTFR_BUSY BSP_BIT32(3)
50 #define PL011_UARTFR_DCD BSP_BIT32(2)
51 #define PL011_UARTFR_DSR BSP_BIT32(1)
52 #define PL011_UARTFR_CTS BSP_BIT32(0)
53  uint32_t reserved_1c;
54  uint32_t uartilpr;
55 #define PL011_UARTILPR_ILPDVSR(val) BSP_FLD32(val, 0, 7)
56 #define PL011_UARTILPR_ILPDVSR_GET(reg) BSP_FLD32GET(reg, 0, 7)
57 #define PL011_UARTILPR_ILPDVSR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
58  uint32_t uartibrd;
59 #define PL011_UARTIBRD_BAUD_DIVINT(val) BSP_FLD32(val, 0, 15)
60 #define PL011_UARTIBRD_BAUD_DIVINT_GET(reg) BSP_FLD32GET(reg, 0, 15)
61 #define PL011_UARTIBRD_BAUD_DIVINT_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
62  uint32_t uartfbrd;
63 #define PL011_UARTFBRD_BAUD_DIVFRAC(val) BSP_FLD32(val, 0, 5)
64 #define PL011_UARTFBRD_BAUD_DIVFRAC_GET(reg) BSP_FLD32GET(reg, 0, 5)
65 #define PL011_UARTFBRD_BAUD_DIVFRAC_SET(reg, val) BSP_FLD32SET(reg, val, 0, 5)
66  uint32_t uartlcr_h;
67 #define PL011_UARTLCR_H_SPS BSP_BIT32(7)
68 #define PL011_UARTLCR_H_WLEN(val) BSP_FLD32(val, 5, 6)
69 #define PL011_UARTLCR_H_WLEN_GET(reg) BSP_FLD32GET(reg, 5, 6)
70 #define PL011_UARTLCR_H_WLEN_SET(reg, val) BSP_FLD32SET(reg, val, 5, 6)
71 #define PL011_UARTLCR_H_WLEN_5 0x00U
72 #define PL011_UARTLCR_H_WLEN_6 0x01U
73 #define PL011_UARTLCR_H_WLEN_7 0x02U
74 #define PL011_UARTLCR_H_WLEN_8 0x03U
75 #define PL011_UARTLCR_H_FEN BSP_BIT32(4)
76 #define PL011_UARTLCR_H_STP2 BSP_BIT32(3)
77 #define PL011_UARTLCR_H_EPS BSP_BIT32(2)
78 #define PL011_UARTLCR_H_PEN BSP_BIT32(1)
79 #define PL011_UARTLCR_H_BRK BSP_BIT32(0)
80  uint32_t uartcr;
81 #define PL011_UARTCR_CTSEN BSP_BIT32(15)
82 #define PL011_UARTCR_RTSEN BSP_BIT32(14)
83 #define PL011_UARTCR_OUT2 BSP_BIT32(13)
84 #define PL011_UARTCR_OUT1 BSP_BIT32(12)
85 #define PL011_UARTCR_RTS BSP_BIT32(11)
86 #define PL011_UARTCR_DTR BSP_BIT32(10)
87 #define PL011_UARTCR_RXE BSP_BIT32(9)
88 #define PL011_UARTCR_TXE BSP_BIT32(8)
89 #define PL011_UARTCR_LBE BSP_BIT32(7)
90 #define PL011_UARTCR_SIRLP BSP_BIT32(3)
91 #define PL011_UARTCR_SIREN BSP_BIT32(2)
92 #define PL011_UARTCR_UARTEN BSP_BIT32(1)
93  uint32_t uartifls;
94 #define PL011_UARTIFLS_RXIFLSEL(val) BSP_FLD32(val, 3, 5)
95 #define PL011_UARTIFLS_RXIFLSEL_GET(reg) BSP_FLD32GET(reg, 3, 5)
96 #define PL011_UARTIFLS_RXIFLSEL_SET(reg, val) BSP_FLD32SET(reg, val, 3, 5)
97 #define PL011_UARTIFLS_TXIFLSEL(val) BSP_FLD32(val, 0, 2)
98 #define PL011_UARTIFLS_TXIFLSEL_GET(reg) BSP_FLD32GET(reg, 0, 2)
99 #define PL011_UARTIFLS_TXIFLSEL_SET(reg, val) BSP_FLD32SET(reg, val, 0, 2)
100  uint32_t uartimsc;
101  uint32_t uartris;
102  uint32_t uartmis;
103  uint32_t uarticr;
104 #define PL011_UARTI_OEI BSP_BIT32(10)
105 #define PL011_UARTI_BEI BSP_BIT32(9)
106 #define PL011_UARTI_PEI BSP_BIT32(8)
107 #define PL011_UARTI_FEI BSP_BIT32(7)
108 #define PL011_UARTI_RTI BSP_BIT32(6)
109 #define PL011_UARTI_TXI BSP_BIT32(5)
110 #define PL011_UARTI_RXI BSP_BIT32(4)
111 #define PL011_UARTI_DSRMI BSP_BIT32(3)
112 #define PL011_UARTI_DCDMI BSP_BIT32(2)
113 #define PL011_UARTI_CTSMI BSP_BIT32(1)
114 #define PL011_UARTI_RIMI BSP_BIT32(0)
115  uint32_t uartdmacr;
116 #define PL011_UARTDMACR_DMAONERR BSP_BIT32(2)
117 #define PL011_UARTDMACR_TXDMAE BSP_BIT32(1)
118 #define PL011_UARTDMACR_RXDMAE BSP_BIT32(0)
119  uint32_t reserved_4c[997];
120  uint32_t uartperiphid0;
121  uint32_t uartperiphid1;
122  uint32_t uartperiphid2;
123  uint32_t uartperiphid3;
124  uint32_t uartpcellid0;
125  uint32_t uartpcellid1;
126  uint32_t uartpcellid2;
127  uint32_t uartpcellid3;
128 } pl011;
129
130 #endif /* LIBBSP_ARM_SHARED_ARM_PL011_REGS_H */
Utility macros.
Definition: arm-pl011-regs.h:28
