RTEMS  5.1
arm-gic-tm27.h
1
9 /*
10  * Copyright (c) 2013-2014 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Dornierstr. 4
14  * 82178 Puchheim
15  * Germany
16  * <info@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef _RTEMS_TMTEST27
24 #error "This is an RTEMS internal file you must not include directly."
25 #endif
26
27 #ifndef LIBBSP_ARM_SHARED_ARM_GIC_TM27_H
28 #define LIBBSP_ARM_SHARED_ARM_GIC_TM27_H
29
30 #include <assert.h>
31
32 #include <bsp.h>
33 #include <bsp/irq.h>
34
35 #define MUST_WAIT_FOR_INTERRUPT 1
36
37 #define ARM_GIC_TM27_IRQ_LOW ARM_GIC_IRQ_SGI_12
38
39 #define ARM_GIC_TM27_IRQ_HIGH ARM_GIC_IRQ_SGI_13
40
41 #define ARM_GIC_TM27_PRIO_LOW 0x80
42
43 #define ARM_GIC_TM27_PRIO_HIGH 0x00
44
45 static inline void Install_tm27_vector(void (*handler)(rtems_vector_number))
46 {
48  ARM_GIC_TM27_IRQ_LOW,
49  "tm27 low",
51  (rtems_interrupt_handler) handler,
52  NULL
53  );
54  assert(sc == RTEMS_SUCCESSFUL);
55
56  sc = arm_gic_irq_set_priority(
57  ARM_GIC_TM27_IRQ_LOW,
58  ARM_GIC_TM27_PRIO_LOW
59  );
60  assert(sc == RTEMS_SUCCESSFUL);
61
63  ARM_GIC_TM27_IRQ_HIGH,
64  "tm27 high",
66  (rtems_interrupt_handler) handler,
67  NULL
68  );
69  assert(sc == RTEMS_SUCCESSFUL);
70
71  sc = arm_gic_irq_set_priority(
72  ARM_GIC_TM27_IRQ_HIGH,
73  ARM_GIC_TM27_PRIO_HIGH
74  );
75  assert(sc == RTEMS_SUCCESSFUL);
76 }
77
78 static inline void Cause_tm27_intr(void)
79 {
80  rtems_status_code sc = arm_gic_irq_generate_software_irq(
81  ARM_GIC_TM27_IRQ_LOW,
82  ARM_GIC_IRQ_SOFTWARE_IRQ_TO_SELF,
83  0
84  );
85  assert(sc == RTEMS_SUCCESSFUL);
86 }
87
88 static inline void Clear_tm27_intr(void)
89 {
90  /* Nothing to do */
91 }
92
93 static inline void Lower_tm27_intr(void)
94 {
95  rtems_status_code sc = arm_gic_irq_generate_software_irq(
96  ARM_GIC_TM27_IRQ_HIGH,
97  ARM_GIC_IRQ_SOFTWARE_IRQ_TO_SELF,
98  0
99  );
100  assert(sc == RTEMS_SUCCESSFUL);
101 }
102
103 #endif /* LIBBSP_ARM_SHARED_ARM_GIC_TM27_H */
Definition: status.h:47
rtems_status_code rtems_interrupt_handler_install(rtems_vector_number vector, const char *info, rtems_option options, rtems_interrupt_handler handler, void *arg)
Installs the interrupt handler routine handler for the interrupt vector with number vector.
Definition: irq.c:127
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Information for the Assert Handler.
rtems_status_code
Classic API Status.
Definition: status.h:43
#define RTEMS_INTERRUPT_UNIQUE
Makes the interrupt handler unique. Prevents other handler from using the same interrupt vector.
Definition: irq-extension.h:44
void(* rtems_interrupt_handler)(void *)
Interrupt handler routine type.
Definition: irq-extension.h:79
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
