RTEMS  5.1
arm-gic-regs.h
1
9 /*
10  * Copyright (c) 2013, 2019 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Dornierstr. 4
14  * 82178 Puchheim
15  * Germany
16  * <info@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef LIBBSP_ARM_SHARED_ARM_GIC_REGS_H
24 #define LIBBSP_ARM_SHARED_ARM_GIC_REGS_H
25
26 #include <bsp/utility.h>
27
28 typedef struct {
29  uint32_t iccicr;
30 #define GIC_CPUIF_ICCICR_CBPR BSP_BIT32(4)
31 #define GIC_CPUIF_ICCICR_FIQ_EN BSP_BIT32(3)
32 #define GIC_CPUIF_ICCICR_ACK_CTL BSP_BIT32(2)
33 #define GIC_CPUIF_ICCICR_ENABLE_GRP_1 BSP_BIT32(1)
34 #define GIC_CPUIF_ICCICR_ENABLE BSP_BIT32(0)
35  uint32_t iccpmr;
36 #define GIC_CPUIF_ICCPMR_PRIORITY(val) BSP_FLD32(val, 0, 7)
37 #define GIC_CPUIF_ICCPMR_PRIORITY_GET(reg) BSP_FLD32GET(reg, 0, 7)
38 #define GIC_CPUIF_ICCPMR_PRIORITY_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
39  uint32_t iccbpr;
40 #define GIC_CPUIF_ICCBPR_BINARY_POINT(val) BSP_FLD32(val, 0, 2)
41 #define GIC_CPUIF_ICCBPR_BINARY_POINT_GET(reg) BSP_FLD32GET(reg, 0, 2)
42 #define GIC_CPUIF_ICCBPR_BINARY_POINT_SET(reg, val) BSP_FLD32SET(reg, val, 0, 2)
43  uint32_t icciar;
44 #define GIC_CPUIF_ICCIAR_CPUID(val) BSP_FLD32(val, 10, 12)
45 #define GIC_CPUIF_ICCIAR_CPUID_GET(reg) BSP_FLD32GET(reg, 10, 12)
46 #define GIC_CPUIF_ICCIAR_CPUID_SET(reg, val) BSP_FLD32SET(reg, val, 10, 12)
47 #define GIC_CPUIF_ICCIAR_ACKINTID(val) BSP_FLD32(val, 0, 9)
48 #define GIC_CPUIF_ICCIAR_ACKINTID_GET(reg) BSP_FLD32GET(reg, 0, 9)
49 #define GIC_CPUIF_ICCIAR_ACKINTID_SET(reg, val) BSP_FLD32SET(reg, val, 0, 9)
50  uint32_t icceoir;
51 #define GIC_CPUIF_ICCEOIR_CPUID(val) BSP_FLD32(val, 10, 12)
52 #define GIC_CPUIF_ICCEOIR_CPUID_GET(reg) BSP_FLD32GET(reg, 10, 12)
53 #define GIC_CPUIF_ICCEOIR_CPUID_SET(reg, val) BSP_FLD32SET(reg, val, 10, 12)
54 #define GIC_CPUIF_ICCEOIR_EOIINTID(val) BSP_FLD32(val, 0, 9)
55 #define GIC_CPUIF_ICCEOIR_EOIINTID_GET(reg) BSP_FLD32GET(reg, 0, 9)
56 #define GIC_CPUIF_ICCEOIR_EOIINTID_SET(reg, val) BSP_FLD32SET(reg, val, 0, 9)
57  uint32_t iccrpr;
58 #define GIC_CPUIF_ICCRPR_PRIORITY(val) BSP_FLD32(val, 0, 7)
59 #define GIC_CPUIF_ICCRPR_PRIORITY_GET(reg) BSP_FLD32GET(reg, 0, 7)
60 #define GIC_CPUIF_ICCRPR_PRIORITY_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
61  uint32_t icchpir;
62 #define GIC_CPUIF_ICCHPIR_CPUID(val) BSP_FLD32(val, 10, 12)
63 #define GIC_CPUIF_ICCHPIR_CPUID_GET(reg) BSP_FLD32GET(reg, 10, 12)
64 #define GIC_CPUIF_ICCHPIR_CPUID_SET(reg, val) BSP_FLD32SET(reg, val, 10, 12)
65 #define GIC_CPUIF_ICCHPIR_PENDINTID(val) BSP_FLD32(val, 0, 9)
66 #define GIC_CPUIF_ICCHPIR_PENDINTID_GET(reg) BSP_FLD32GET(reg, 0, 9)
67 #define GIC_CPUIF_ICCHPIR_PENDINTID_SET(reg, val) BSP_FLD32SET(reg, val, 0, 9)
68  uint32_t iccabpr;
69 #define GIC_CPUIF_ICCABPR_BINARY_POINT(val) BSP_FLD32(val, 0, 2)
70 #define GIC_CPUIF_ICCABPR_BINARY_POINT_GET(reg) BSP_FLD32GET(reg, 0, 2)
71 #define GIC_CPUIF_ICCABPR_BINARY_POINT_SET(reg, val) BSP_FLD32SET(reg, val, 0, 2)
72  uint32_t reserved_20[55];
73  uint32_t icciidr;
74 #define GIC_CPUIF_ICCIIDR_PRODUCT_ID(val) BSP_FLD32(val, 24, 31)
75 #define GIC_CPUIF_ICCIIDR_PRODUCT_ID_GET(reg) BSP_FLD32GET(reg, 24, 31)
76 #define GIC_CPUIF_ICCIIDR_PRODUCT_ID_SET(reg, val) BSP_FLD32SET(reg, val, 24, 31)
77 #define GIC_CPUIF_ICCIIDR_ARCH_VERSION(val) BSP_FLD32(val, 16, 19)
78 #define GIC_CPUIF_ICCIIDR_ARCH_VERSION_GET(reg) BSP_FLD32GET(reg, 16, 19)
79 #define GIC_CPUIF_ICCIIDR_ARCH_VERSION_SET(reg, val) BSP_FLD32SET(reg, val, 16, 19)
80 #define GIC_CPUIF_ICCIIDR_REVISION(val) BSP_FLD32(val, 12, 15)
81 #define GIC_CPUIF_ICCIIDR_REVISION_GET(reg) BSP_FLD32GET(reg, 12, 15)
82 #define GIC_CPUIF_ICCIIDR_REVISION_SET(reg, val) BSP_FLD32SET(reg, val, 12, 15)
83 #define GIC_CPUIF_ICCIIDR_IMPLEMENTER(val) BSP_FLD32(val, 0, 11)
84 #define GIC_CPUIF_ICCIIDR_IMPLEMENTER_GET(reg) BSP_FLD32GET(reg, 0, 11)
85 #define GIC_CPUIF_ICCIIDR_IMPLEMENTER_SET(reg, val) BSP_FLD32SET(reg, val, 0, 11)
86 } gic_cpuif;
87
88 typedef struct {
89  /* GICD_CTLR */
90  uint32_t icddcr;
91 /* GICv3 only */
92 #define GIC_DIST_ICDDCR_RWP BSP_BIT32(31)
93 #define GIC_DIST_ICDDCR_E1NWF BSP_BIT32(7)
94 #define GIC_DIST_ICDDCR_DS BSP_BIT32(6)
95 #define GIC_DIST_ICDDCR_ARE_NS BSP_BIT32(5)
96 #define GIC_DIST_ICDDCR_ARE_S BSP_BIT32(4)
97 #define GIC_DIST_ICDDCR_ENABLE_GRP1S BSP_BIT32(2)
98 #define GIC_DIST_ICDDCR_ENABLE_GRP1NS BSP_BIT32(1)
99 #define GIC_DIST_ICDDCR_ENABLE_GRP0 BSP_BIT32(0)
100 /* GICv1/GICv2 */
101 #define GIC_DIST_ICDDCR_ENABLE_GRP_1 BSP_BIT32(1)
102 #define GIC_DIST_ICDDCR_ENABLE BSP_BIT32(0)
103  uint32_t icdictr;
104 #define GIC_DIST_ICDICTR_LSPI(val) BSP_FLD32(val, 11, 15)
105 #define GIC_DIST_ICDICTR_LSPI_GET(reg) BSP_FLD32GET(reg, 11, 15)
106 #define GIC_DIST_ICDICTR_LSPI_SET(reg, val) BSP_FLD32SET(reg, val, 11, 15)
107 #define GIC_DIST_ICDICTR_SECURITY_EXTN BSP_BIT32(10)
108 #define GIC_DIST_ICDICTR_CPU_NUMBER(val) BSP_FLD32(val, 5, 7)
109 #define GIC_DIST_ICDICTR_CPU_NUMBER_GET(reg) BSP_FLD32GET(reg, 5, 7)
110 #define GIC_DIST_ICDICTR_CPU_NUMBER_SET(reg, val) BSP_FLD32SET(reg, val, 5, 7)
111 #define GIC_DIST_ICDICTR_IT_LINES_NUMBER(val) BSP_FLD32(val, 0, 4)
112 #define GIC_DIST_ICDICTR_IT_LINES_NUMBER_GET(reg) BSP_FLD32GET(reg, 0, 4)
113 #define GIC_DIST_ICDICTR_IT_LINES_NUMBER_SET(reg, val) BSP_FLD32SET(reg, val, 0, 4)
114  uint32_t icdiidr;
115 #define GIC_DIST_ICDIIDR_PRODUCT_ID(val) BSP_FLD32(val, 24, 31)
116 #define GIC_DIST_ICDIIDR_PRODUCT_ID_GET(reg) BSP_FLD32GET(reg, 24, 31)
117 #define GIC_DIST_ICDIIDR_PRODUCT_ID_SET(reg, val) BSP_FLD32SET(reg, val, 24, 31)
118 #define GIC_DIST_ICDIIDR_VARIANT(val) BSP_FLD32(val, 16, 19)
119 #define GIC_DIST_ICDIIDR_VARIANT_GET(reg) BSP_FLD32GET(reg, 16, 19)
120 #define GIC_DIST_ICDIIDR_VARIANT_SET(reg, val) BSP_FLD32SET(reg, val, 16, 19)
121 #define GIC_DIST_ICDIIDR_REVISION(val) BSP_FLD32(val, 12, 15)
122 #define GIC_DIST_ICDIIDR_REVISION_GET(reg) BSP_FLD32GET(reg, 12, 15)
123 #define GIC_DIST_ICDIIDR_REVISION_SET(reg, val) BSP_FLD32SET(reg, val, 12, 15)
124 #define GIC_DIST_ICDIIDR_IMPLEMENTER(val) BSP_FLD32(val, 0, 11)
125 #define GIC_DIST_ICDIIDR_IMPLEMENTER_GET(reg) BSP_FLD32GET(reg, 0, 11)
126 #define GIC_DIST_ICDIIDR_IMPLEMENTER_SET(reg, val) BSP_FLD32SET(reg, val, 0, 11)
127  uint32_t reserved_0c[29];
128  uint32_t icdigr[32];
129  uint32_t icdiser[32];
130  uint32_t icdicer[32];
131  uint32_t icdispr[32];
132  uint32_t icdicpr[32];
133  uint32_t icdabr[32];
134  uint32_t reserved_380[32];
135  uint8_t icdipr[256];
136  uint32_t reserved_500[192];
137  uint8_t icdiptr[256];
138  uint32_t reserved_900[192];
139  uint32_t icdicfr[64];
140  /* GICD_IGRPMODR GICv3 only, reserved in GICv1/GICv2 */
141  uint32_t icdigmr[32];
142  uint32_t reserved_d80[96];
143  uint32_t icdsgir;
144 #define GIC_DIST_ICDSGIR_TARGET_LIST_FILTER(val) BSP_FLD32(val, 24, 25)
145 #define GIC_DIST_ICDSGIR_TARGET_LIST_FILTER_GET(reg) BSP_FLD32GET(reg, 24, 25)
146 #define GIC_DIST_ICDSGIR_TARGET_LIST_FILTER_SET(reg, val) BSP_FLD32SET(reg, val, 24, 25)
147 #define GIC_DIST_ICDSGIR_CPU_TARGET_LIST(val) BSP_FLD32(val, 16, 23)
148 #define GIC_DIST_ICDSGIR_CPU_TARGET_LIST_GET(reg) BSP_FLD32GET(reg, 16, 23)
149 #define GIC_DIST_ICDSGIR_CPU_TARGET_LIST_SET(reg, val) BSP_FLD32SET(reg, val, 16, 23)
150 #define GIC_DIST_ICDSGIR_NSATT BSP_BIT32(15)
151 #define GIC_DIST_ICDSGIR_SGIINTID(val) BSP_FLD32(val, 0, 3)
152 #define GIC_DIST_ICDSGIR_SGIINTID_GET(reg) BSP_FLD32GET(reg, 0, 3)
153 #define GIC_DIST_ICDSGIR_SGIINTID_SET(reg, val) BSP_FLD32SET(reg, val, 0, 3)
154 } gic_dist;
155
156 /* GICv3 only */
157 typedef struct {
158  /* GICR_CTLR */
159  uint32_t icrrcr;
160 #define GIC_REDIST_ICRRCR_UWP BSP_BIT32(31)
161 #define GIC_REDIST_ICRRCR_DPG1S BSP_BIT32(26)
162 #define GIC_REDIST_ICRRCR_DPG1NS BSP_BIT32(25)
163 #define GIC_REDIST_ICRRCR_DPG0 BSP_BIT32(24)
164 #define GIC_REDIST_ICRRCR_RWP BSP_BIT32(4)
165 #define GIC_REDIST_ICRRCR_ENABLE_LPI BSP_BIT32(0)
166  uint32_t icriidr;
167  uint64_t icrtyper;
168 #define GIC_REDIST_ICRTYPER_AFFINITY_VALUE(val) BSP_FLD64(val, 32, 63)
169 #define GIC_REDIST_ICRTYPER_AFFINITY_VALUE_GET(reg) BSP_FLD64GET(reg, 32, 63)
170 #define GIC_REDIST_ICRTYPER_AFFINITY_VALUE_SET(reg, val) BSP_FLD64SET(reg, val, 32, 63)
171 #define GIC_REDIST_ICRTYPER_COMMON_LPI_AFFINITY(val) BSP_FLD64(val, 24, 25)
172 #define GIC_REDIST_ICRTYPER_COMMON_LPI_AFFINITY_GET(reg) BSP_FLD64GET(reg, 24, 25)
173 #define GIC_REDIST_ICRTYPER_COMMON_LPI_AFFINITY_SET(reg, val) BSP_FLD64SET(reg, val, 24, 25)
174 #define GIC_REDIST_ICRTYPER_CPU_NUMBER(val) BSP_FLD64(val, 8, 23)
175 #define GIC_REDIST_ICRTYPER_CPU_NUMBER_GET(reg) BSP_FLD64GET(reg, 8, 23)
176 #define GIC_REDIST_ICRTYPER_CPU_NUMBER_SET(reg, val) BSP_FLD64SET(reg, val, 8, 23)
177 #define GIC_REDIST_ICRTYPER_DPGS BSP_BIT64(5)
178 #define GIC_REDIST_ICRTYPER_LAST BSP_BIT64(4)
179 #define GIC_REDIST_ICRTYPER_DIRECT_LPI BSP_BIT64(3)
180 #define GIC_REDIST_ICRTYPER_VLPIS BSP_BIT64(1)
181 #define GIC_REDIST_ICRTYPER_PLPIS BSP_BIT64(0)
182  uint32_t unused_10;
183  uint32_t icrwaker;
184 #define GIC_REDIST_ICRWAKER_CHILDREN_ASLEEP BSP_BIT32(2)
185 #define GIC_REDIST_ICRWAKER_PROCESSOR_SLEEP BSP_BIT32(1)
186 } gic_redist;
187
188 /* GICv3 only */
189 typedef struct {
190  uint32_t reserved_0_80[32];
191  /* GICR_IGROUPR0 */
192  uint32_t icspigrpr[32];
193  /* GICR_ISENABLER0 */
194  uint32_t icspiser[32];
195  /* GICR_ICENABLER0 */
196  uint32_t icspicer[32];
197  /* GICR_ISPENDR0 */
198  uint32_t icspispendr[32];
199  /* GICR_ICPENDR0 */
200  uint32_t icspicpendr[32];
201  /* GICR_ISACTIVER0 */
202  uint32_t icspisar[32];
203  /* GICR_ICACTIVER0 */
204  uint32_t icspicar[32];
205  /* GICR_IPRIORITYR */
206  uint8_t icspiprior[32];
207  uint32_t reserved_420_bfc[504];
208  /* GICR_ICFGR0 */
209  uint32_t icspicfgr0;
210  /* GICR_ICFGR1 */
211  uint32_t icspicfgr1;
212  uint32_t reserved_c08_cfc[62];
213  /* GICR_IGRPMODR0 */
214  uint32_t icspigrpmodr[64];
215 } gic_sgi_ppi;
216
217 #endif /* LIBBSP_ARM_SHARED_ARM_GIC_REGS_H */
Definition: arm-gic-regs.h:28
Definition: arm-gic-regs.h:88
Utility macros.
Definition: arm-gic-regs.h:157
Definition: arm-gic-regs.h:189
