RTEMS  5.1
alt_qspi_private.h
1
7 /******************************************************************************
8  *
9  * Copyright 2013 Altera Corporation. All Rights Reserved.
10  *
11  * Redistribution and use in source and binary forms, with or without
12  * modification, are permitted provided that the following conditions are met:
13  *
14  * 1. Redistributions of source code must retain the above copyright notice,
15  * this list of conditions and the following disclaimer.
16  *
17  * 2. Redistributions in binary form must reproduce the above copyright notice,
18  * this list of conditions and the following disclaimer in the documentation
19  * and/or other materials provided with the distribution.
20  *
21  * 3. The name of the author may not be used to endorse or promote products
22  * derived from this software without specific prior written permission.
23  *
24  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR
25  * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
26  * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO
27  * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
28  * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
29  * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
32  * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
33  * OF SUCH DAMAGE.
34  *
35  ******************************************************************************/
36
41 #ifndef __ALT_QSPI_PRIVATE_H__
42 #define __ALT_QSPI_PRIVATE_H__
43
44 #include "socal/socal.h"
45
46 //
47 // This section provisions support for various flash devices.
48 //
49
50 #define ALT_QSPI_PROVISION_MICRON_N25Q_SUPPORT 1
51
53
54 #define ALT_QSPI_PAGE_ADDR_MSK 0xFFFFFF00
55 #define ALT_QSPI_PAGE_SIZE 0x00000100 // 256 B
56 #define ALT_QSPI_SUBSECTOR_ADDR_MSK 0xFFFFF000
57 #define ALT_QSPI_SUBSECTOR_SIZE 0x00001000 // 4096 B
58 #define ALT_QSPI_SECTOR_ADDR_MSK 0xFFFF0000
59 #define ALT_QSPI_SECTOR_SIZE 0x00010000 // 64 KiB
60 #define ALT_QSPI_BANK_ADDR_MSK 0xFF000000
61 #define ALT_QSPI_BANK_SIZE 0x01000000 // 16 MiB
62
63 #if ALT_QSPI_PROVISION_MICRON_N25Q_SUPPORT
64 #define ALT_QSPI_N25Q_DIE_ADDR_MSK 0xFE000000
65 #define ALT_QSPI_N25Q_DIE_SIZE 0x02000000 // 32 MiB
66 #endif
67
69
70 // Default delay timing (in ns) for N25Q.
71 // These values are from the N25Q handbook. The timing correctness is difficult
72 // to test because the test setup does not feature mutliple chips.
73 #define ALT_QSPI_TSHSL_NS_DEF (50)
74 #define ALT_QSPI_TSD2D_NS_DEF (0)
75 #define ALT_QSPI_TCHSH_NS_DEF (4)
76 #define ALT_QSPI_TSLCH_NS_DEF (4)
77
78 /*
79 // Default delay timing (in ns)
80 #define ALT_QSPI_TSHSL_NS_DEF (200)
81 #define ALT_QSPI_TSD2D_NS_DEF (255)
82 #define ALT_QSPI_TCHSH_NS_DEF (20)
83 #define ALT_QSPI_TSLCH_NS_DEF (20)
84 */
85
86 // Flash commands
87 #define ALT_QSPI_STIG_OPCODE_READ (0x03)
88 #define ALT_QSPI_STIG_OPCODE_4BYTE_READ (0x13)
89 #define ALT_QSPI_STIG_OPCODE_FASTREAD (0x0B)
90 #define ALT_QSPI_STIG_OPCODE_FASTREAD_DUAL_OUTPUT (0x3B)
91 #define ALT_QSPI_STIG_OPCODE_FASTREAD_QUAD_OUTPUT (0x6B)
92 #define ALT_QSPI_STIG_OPCODE_FASTREAD_DUAL_IO (0xBB)
93 #define ALT_QSPI_STIG_OPCODE_FASTREAD_QUAD_IO (0xEB)
94 #define ALT_QSPI_STIG_OPCODE_PP (0x02)
95 #define ALT_QSPI_STIG_OPCODE_DUAL_PP (0xA2)
96 #define ALT_QSPI_STIG_OPCODE_QUAD_PP (0x32)
97 #define ALT_QSPI_STIG_OPCODE_RDID (0x9F)
98 #define ALT_QSPI_STIG_OPCODE_WREN (0x06)
99 #define ALT_QSPI_STIG_OPCODE_WRDIS (0x04)
100 #define ALT_QSPI_STIG_OPCODE_RDSR (0x05)
101 #define ALT_QSPI_STIG_OPCODE_WRSR (0x01)
102 #define ALT_QSPI_STIG_OPCODE_SUBSEC_ERASE (0x20)
103 #define ALT_QSPI_STIG_OPCODE_SEC_ERASE (0xD8)
104 #define ALT_QSPI_STIG_OPCODE_BULK_ERASE (0xC7)
105 #define ALT_QSPI_STIG_OPCODE_DIE_ERASE (0xC4)
106 #define ALT_QSPI_STIG_OPCODE_CHIP_ERASE (0x60)
107 #define ALT_QSPI_STIG_OPCODE_RD_EXT_REG (0xC8)
108 #define ALT_QSPI_STIG_OPCODE_WR_EXT_REG (0xC5)
109 #define ALT_QSPI_STIG_OPCODE_RD_STAT_REG (0x05)
110 #define ALT_QSPI_STIG_OPCODE_WR_STAT_REG (0x01)
111 #define ALT_QSPI_STIG_OPCODE_ENTER_4BYTE_MODE (0xB7)
112 #define ALT_QSPI_STIG_OPCODE_EXIT_4BYTE_MODE (0xE9)
113
114 // Micron commands, for 512 Mib, 1 Gib (64 MiB, 128 MiB) parts.
115 #if ALT_QSPI_PROVISION_MICRON_N25Q_SUPPORT
116 #define ALT_QSPI_STIG_OPCODE_RESET_EN (0x66)
117 #define ALT_QSPI_STIG_OPCODE_RESET_MEM (0x99)
118 #define ALT_QSPI_STIG_OPCODE_RDFLGSR (0x70)
119 #define ALT_QSPI_STIG_OPCODE_CLRFLGSR (0x50)
120 #define ALT_QSPI_STIG_OPCODE_DISCVR_PARAM (0x5A)
121 #endif
122
123 // Spansion commands
124 // #define OPCODE_ECRM (0xFF) // Exit continuous read mode
125
126 #define QSPI_READ_CLK_MHZ (50)
127 #define QSPI_FASTREAD_CLK_MHZ (100)
128
129 // Manufacturer ID
130 #define ALT_QSPI_STIG_RDID_JEDECID_MICRON (0x20)
131 #define ALT_QSPI_STIG_RDID_JEDECID_NUMONYX (0x20) // Same as Micron
132 #define ALT_QSPI_STIG_RDID_JEDECID_SPANSION (0xEF)
133 #define ALT_QSPI_STIG_RDID_JEDECID_WINBOND (0xEF) // Same as Spansion
134 #define ALT_QSPI_STIG_RDID_JEDECID_MACRONIC (0xC2)
135 #define ALT_QSPI_STIG_RDID_JEDECID_ATMEL (0x1F)
136
137 #define ALT_QSPI_STIG_RDID_JEDECID_GET(value) ((value >> 0) & 0xff)
138 #define ALT_QSPI_STIG_RDID_CAPACITYID_GET(value) ((value >> 16) & 0xff)
139
140 #define ALT_QSPI_STIG_FLAGSR_ERASEPROGRAMREADY_GET(value) ((value >> 7) & 0x1)
141 #define ALT_QSPI_STIG_FLAGSR_ERASEREADY_GET(value) ((value >> 7) & 0x1)
142 #define ALT_QSPI_STIG_FLAGSR_PROGRAMREADY_GET(value) ((value >> 7) & 0x1)
143 #define ALT_QSPI_STIG_FLAGSR_ERASEERROR_GET(value) ((value >> 5) & 0x1)
144 #define ALT_QSPI_STIG_FLAGSR_PROGRAMERROR_GET(value) ((value >> 4) & 0x1)
145 #define ALT_QSPI_STIG_FLAGSR_ADDRESSINGMODE_GET(value) ((value >> 1) & 0x1)
146 #define ALT_QSPI_STIG_FLAGSR_PROTECTIONERROR_GET(value) ((value >> 0) & 0x1)
147
148 #define ALT_QSPI_STIG_SR_BUSY_GET(value) ((value >> 0) & 0x1)
149
151
152 #define ALT_QSPI_TIMEOUT_INFINITE (0xffffffff)
153
154 ALT_STATUS_CODE alt_qspi_replace(uint32_t dst, const void * src, size_t size);
155
156 ALT_STATUS_CODE alt_qspi_stig_cmd(uint32_t opcode, uint32_t dummy, uint32_t timeout);
157 ALT_STATUS_CODE alt_qspi_stig_rd_cmd(uint8_t opcode, uint32_t dummy,
158  uint32_t num_bytes, uint32_t * output,
159  uint32_t timeout);
160 ALT_STATUS_CODE alt_qspi_stig_wr_cmd(uint8_t opcode, uint32_t dummy,
161  uint32_t num_bytes, const uint32_t * input,
162  uint32_t timeout);
163 ALT_STATUS_CODE alt_qspi_stig_addr_cmd(uint8_t opcode, uint32_t dummy,
164  uint32_t address,
165  uint32_t timeout);
166
167 ALT_STATUS_CODE alt_qspi_device_wren(void);
168 ALT_STATUS_CODE alt_qspi_device_wrdis(void);
169 ALT_STATUS_CODE alt_qspi_device_rdid(uint32_t * rdid);
170 ALT_STATUS_CODE alt_qspi_discovery_parameter(uint32_t * param);
171 ALT_STATUS_CODE alt_qspi_device_bank_select(uint32_t bank);
172
173 #endif // __ALT_PRIVATE_QSPI_H__
int32_t ALT_STATUS_CODE
Definition: hwlib.h:60
unsigned size
Definition: tte.h:74
