RTEMS  5.1
alt_acpidmap.h
1
7 /*******************************************************************************
8 * *
9 * Copyright 2013 Altera Corporation. All Rights Reserved. *
10 * *
11 * Redistribution and use in source and binary forms, with or without *
12 * modification, are permitted provided that the following conditions are met: *
13 * *
14 * 1. Redistributions of source code must retain the above copyright notice, *
15 * this list of conditions and the following disclaimer. *
16 * *
17 * 2. Redistributions in binary form must reproduce the above copyright notice, *
18 * this list of conditions and the following disclaimer in the documentation *
19 * and/or other materials provided with the distribution. *
20 * *
21 * 3. The name of the author may not be used to endorse or promote products *
22 * derived from this software without specific prior written permission. *
23 * *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR *
25 * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF *
26 * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO *
27 * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, *
28 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, *
29 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; *
30 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, *
31 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR *
32 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF *
33 * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. *
34 * *
35 *******************************************************************************/
36
37 /* Altera - ALT_ACPIDMAP */
38
39 #ifndef __ALTERA_ALT_ACPIDMAP_H__
40 #define __ALTERA_ALT_ACPIDMAP_H__
41
42 #ifdef __cplusplus
43 extern "C"
44 {
45 #endif /* __cplusplus */
46
47 /*
48  * Component : ACP ID Mapper Registers - ALT_ACPIDMAP
49  * ACP ID Mapper Registers
50  *
51  * Registers in the ACP ID Mapper module
52  *
53  */
54 /*
55  * Register : Read AXI Master Mapping Register for Fixed Virtual ID 2 - vid2rd
56  *
57  * The Read AXI Master Mapping Register contains the USER, ADDR page, and ID
58  * signals mapping values for particular transaction with 12-bit ID which locks the
59  * fixed 3-bit virtual ID.
60  *
61  * Register Layout
62  *
63  * Bits | Access | Reset | Description
64  * :--------|:-------|:------|:-----------------------------
65  * [3:0] | ??? | 0x0 | *UNDEFINED*
66  * [8:4] | RW | 0x1 | ARUSER value to SCU for ID=2
67  * [11:9] | ??? | 0x0 | *UNDEFINED*
68  * [13:12] | RW | 0x0 | ARADDR 1GB Page Decoder
69  * [15:14] | ??? | 0x0 | *UNDEFINED*
70  * [27:16] | RW | 0x4 | Remap Master ID = DAP ID
71  * [30:28] | ??? | 0x0 | *UNDEFINED*
72  * [31] | RW | 0x1 | Force Mapping for ID=2
73  *
74  */
75 /*
76  * Field : ARUSER value to SCU for ID=2 - user
77  *
78  * This value is propagated to SCU as ARUSERS.
79  *
80  * Field Access Macros:
81  *
82  */
83 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID2RD_USER register field. */
84 #define ALT_ACPIDMAP_VID2RD_USER_LSB 4
85 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID2RD_USER register field. */
86 #define ALT_ACPIDMAP_VID2RD_USER_MSB 8
87 /* The width in bits of the ALT_ACPIDMAP_VID2RD_USER register field. */
88 #define ALT_ACPIDMAP_VID2RD_USER_WIDTH 5
89 /* The mask used to set the ALT_ACPIDMAP_VID2RD_USER register field value. */
90 #define ALT_ACPIDMAP_VID2RD_USER_SET_MSK 0x000001f0
91 /* The mask used to clear the ALT_ACPIDMAP_VID2RD_USER register field value. */
92 #define ALT_ACPIDMAP_VID2RD_USER_CLR_MSK 0xfffffe0f
93 /* The reset value of the ALT_ACPIDMAP_VID2RD_USER register field. */
94 #define ALT_ACPIDMAP_VID2RD_USER_RESET 0x1
95 /* Extracts the ALT_ACPIDMAP_VID2RD_USER field value from a register. */
96 #define ALT_ACPIDMAP_VID2RD_USER_GET(value) (((value) & 0x000001f0) >> 4)
97 /* Produces a ALT_ACPIDMAP_VID2RD_USER register field value suitable for setting the register. */
98 #define ALT_ACPIDMAP_VID2RD_USER_SET(value) (((value) << 4) & 0x000001f0)
99
100 /*
101  * Field : ARADDR 1GB Page Decoder - page
102  *
103  * ARADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
104  *
105  * Field Access Macros:
106  *
107  */
108 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID2RD_PAGE register field. */
109 #define ALT_ACPIDMAP_VID2RD_PAGE_LSB 12
110 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID2RD_PAGE register field. */
111 #define ALT_ACPIDMAP_VID2RD_PAGE_MSB 13
112 /* The width in bits of the ALT_ACPIDMAP_VID2RD_PAGE register field. */
113 #define ALT_ACPIDMAP_VID2RD_PAGE_WIDTH 2
114 /* The mask used to set the ALT_ACPIDMAP_VID2RD_PAGE register field value. */
115 #define ALT_ACPIDMAP_VID2RD_PAGE_SET_MSK 0x00003000
116 /* The mask used to clear the ALT_ACPIDMAP_VID2RD_PAGE register field value. */
117 #define ALT_ACPIDMAP_VID2RD_PAGE_CLR_MSK 0xffffcfff
118 /* The reset value of the ALT_ACPIDMAP_VID2RD_PAGE register field. */
119 #define ALT_ACPIDMAP_VID2RD_PAGE_RESET 0x0
120 /* Extracts the ALT_ACPIDMAP_VID2RD_PAGE field value from a register. */
121 #define ALT_ACPIDMAP_VID2RD_PAGE_GET(value) (((value) & 0x00003000) >> 12)
122 /* Produces a ALT_ACPIDMAP_VID2RD_PAGE register field value suitable for setting the register. */
123 #define ALT_ACPIDMAP_VID2RD_PAGE_SET(value) (((value) << 12) & 0x00003000)
124
125 /*
126  * Field : Remap Master ID = DAP ID - mid
127  *
128  * The 12-bit ID of the master to remap to 3-bit virtual ID N, where N is the 3-bit
129  * ID to use.
130  *
131  * Field Access Macros:
132  *
133  */
134 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID2RD_MID register field. */
135 #define ALT_ACPIDMAP_VID2RD_MID_LSB 16
136 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID2RD_MID register field. */
137 #define ALT_ACPIDMAP_VID2RD_MID_MSB 27
138 /* The width in bits of the ALT_ACPIDMAP_VID2RD_MID register field. */
139 #define ALT_ACPIDMAP_VID2RD_MID_WIDTH 12
140 /* The mask used to set the ALT_ACPIDMAP_VID2RD_MID register field value. */
141 #define ALT_ACPIDMAP_VID2RD_MID_SET_MSK 0x0fff0000
142 /* The mask used to clear the ALT_ACPIDMAP_VID2RD_MID register field value. */
143 #define ALT_ACPIDMAP_VID2RD_MID_CLR_MSK 0xf000ffff
144 /* The reset value of the ALT_ACPIDMAP_VID2RD_MID register field. */
145 #define ALT_ACPIDMAP_VID2RD_MID_RESET 0x4
146 /* Extracts the ALT_ACPIDMAP_VID2RD_MID field value from a register. */
147 #define ALT_ACPIDMAP_VID2RD_MID_GET(value) (((value) & 0x0fff0000) >> 16)
148 /* Produces a ALT_ACPIDMAP_VID2RD_MID register field value suitable for setting the register. */
149 #define ALT_ACPIDMAP_VID2RD_MID_SET(value) (((value) << 16) & 0x0fff0000)
150
151 /*
152  * Field : Force Mapping for ID=2 - force
153  *
154  * Set to 1 to force the mapping between the 12-bit ID and 3-bit virtual ID N. Set
155  * to 0 to allow the 3-bit ID N to be dynamically allocated.
156  *
157  * Field Access Macros:
158  *
159  */
160 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID2RD_FORCE register field. */
161 #define ALT_ACPIDMAP_VID2RD_FORCE_LSB 31
162 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID2RD_FORCE register field. */
163 #define ALT_ACPIDMAP_VID2RD_FORCE_MSB 31
164 /* The width in bits of the ALT_ACPIDMAP_VID2RD_FORCE register field. */
165 #define ALT_ACPIDMAP_VID2RD_FORCE_WIDTH 1
166 /* The mask used to set the ALT_ACPIDMAP_VID2RD_FORCE register field value. */
167 #define ALT_ACPIDMAP_VID2RD_FORCE_SET_MSK 0x80000000
168 /* The mask used to clear the ALT_ACPIDMAP_VID2RD_FORCE register field value. */
169 #define ALT_ACPIDMAP_VID2RD_FORCE_CLR_MSK 0x7fffffff
170 /* The reset value of the ALT_ACPIDMAP_VID2RD_FORCE register field. */
171 #define ALT_ACPIDMAP_VID2RD_FORCE_RESET 0x1
172 /* Extracts the ALT_ACPIDMAP_VID2RD_FORCE field value from a register. */
173 #define ALT_ACPIDMAP_VID2RD_FORCE_GET(value) (((value) & 0x80000000) >> 31)
174 /* Produces a ALT_ACPIDMAP_VID2RD_FORCE register field value suitable for setting the register. */
175 #define ALT_ACPIDMAP_VID2RD_FORCE_SET(value) (((value) << 31) & 0x80000000)
176
177 #ifndef __ASSEMBLY__
178 /*
179  * WARNING: The C register and register group struct declarations are provided for
180  * convenience and illustrative purposes. They should, however, be used with
181  * caution as the C language standard provides no guarantees about the alignment or
182  * atomicity of device memory accesses. The recommended practice for writing
183  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
184  * alt_write_word() functions.
185  *
186  * The struct declaration for register ALT_ACPIDMAP_VID2RD.
187  */
189 {
190  uint32_t : 4; /* *UNDEFINED* */
191  uint32_t user : 5; /* ARUSER value to SCU for ID=2 */
192  uint32_t : 3; /* *UNDEFINED* */
193  uint32_t page : 2; /* ARADDR 1GB Page Decoder */
194  uint32_t : 2; /* *UNDEFINED* */
195  uint32_t mid : 12; /* Remap Master ID = DAP ID */
196  uint32_t : 3; /* *UNDEFINED* */
197  uint32_t force : 1; /* Force Mapping for ID=2 */
198 };
199
200 /* The typedef declaration for register ALT_ACPIDMAP_VID2RD. */
201 typedef volatile struct ALT_ACPIDMAP_VID2RD_s ALT_ACPIDMAP_VID2RD_t;
202 #endif /* __ASSEMBLY__ */
203
204 /* The byte offset of the ALT_ACPIDMAP_VID2RD register from the beginning of the component. */
205 #define ALT_ACPIDMAP_VID2RD_OFST 0x0
206
207 /*
208  * Register : Write AXI Master Mapping Register for Fixed Virtual ID 2 - vid2wr
209  *
210  * The Write AXI Master Mapping Register contains the USER, ADDR page, and ID
211  * signals mapping values for particular transaction with 12-bit ID which locks the
212  * fixed 3-bit virtual ID.
213  *
214  * Register Layout
215  *
216  * Bits | Access | Reset | Description
217  * :--------|:-------|:------|:-----------------------------
218  * [3:0] | ??? | 0x0 | *UNDEFINED*
219  * [8:4] | RW | 0x1 | AWUSER value to SCU for ID=2
220  * [11:9] | ??? | 0x0 | *UNDEFINED*
221  * [13:12] | RW | 0x0 | AWADDR 1GB Page Decoder
222  * [15:14] | ??? | 0x0 | *UNDEFINED*
223  * [27:16] | RW | 0x4 | Remap Master ID = DAP ID
224  * [30:28] | ??? | 0x0 | *UNDEFINED*
225  * [31] | RW | 0x1 | Force Mapping for ID=2
226  *
227  */
228 /*
229  * Field : AWUSER value to SCU for ID=2 - user
230  *
231  * This value is propagated to SCU as AWUSERS.
232  *
233  * Field Access Macros:
234  *
235  */
236 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID2WR_USER register field. */
237 #define ALT_ACPIDMAP_VID2WR_USER_LSB 4
238 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID2WR_USER register field. */
239 #define ALT_ACPIDMAP_VID2WR_USER_MSB 8
240 /* The width in bits of the ALT_ACPIDMAP_VID2WR_USER register field. */
241 #define ALT_ACPIDMAP_VID2WR_USER_WIDTH 5
242 /* The mask used to set the ALT_ACPIDMAP_VID2WR_USER register field value. */
243 #define ALT_ACPIDMAP_VID2WR_USER_SET_MSK 0x000001f0
244 /* The mask used to clear the ALT_ACPIDMAP_VID2WR_USER register field value. */
245 #define ALT_ACPIDMAP_VID2WR_USER_CLR_MSK 0xfffffe0f
246 /* The reset value of the ALT_ACPIDMAP_VID2WR_USER register field. */
247 #define ALT_ACPIDMAP_VID2WR_USER_RESET 0x1
248 /* Extracts the ALT_ACPIDMAP_VID2WR_USER field value from a register. */
249 #define ALT_ACPIDMAP_VID2WR_USER_GET(value) (((value) & 0x000001f0) >> 4)
250 /* Produces a ALT_ACPIDMAP_VID2WR_USER register field value suitable for setting the register. */
251 #define ALT_ACPIDMAP_VID2WR_USER_SET(value) (((value) << 4) & 0x000001f0)
252
253 /*
254  * Field : AWADDR 1GB Page Decoder - page
255  *
256  * AWADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
257  *
258  * Field Access Macros:
259  *
260  */
261 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID2WR_PAGE register field. */
262 #define ALT_ACPIDMAP_VID2WR_PAGE_LSB 12
263 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID2WR_PAGE register field. */
264 #define ALT_ACPIDMAP_VID2WR_PAGE_MSB 13
265 /* The width in bits of the ALT_ACPIDMAP_VID2WR_PAGE register field. */
266 #define ALT_ACPIDMAP_VID2WR_PAGE_WIDTH 2
267 /* The mask used to set the ALT_ACPIDMAP_VID2WR_PAGE register field value. */
268 #define ALT_ACPIDMAP_VID2WR_PAGE_SET_MSK 0x00003000
269 /* The mask used to clear the ALT_ACPIDMAP_VID2WR_PAGE register field value. */
270 #define ALT_ACPIDMAP_VID2WR_PAGE_CLR_MSK 0xffffcfff
271 /* The reset value of the ALT_ACPIDMAP_VID2WR_PAGE register field. */
272 #define ALT_ACPIDMAP_VID2WR_PAGE_RESET 0x0
273 /* Extracts the ALT_ACPIDMAP_VID2WR_PAGE field value from a register. */
274 #define ALT_ACPIDMAP_VID2WR_PAGE_GET(value) (((value) & 0x00003000) >> 12)
275 /* Produces a ALT_ACPIDMAP_VID2WR_PAGE register field value suitable for setting the register. */
276 #define ALT_ACPIDMAP_VID2WR_PAGE_SET(value) (((value) << 12) & 0x00003000)
277
278 /*
279  * Field : Remap Master ID = DAP ID - mid
280  *
281  * The 12-bit ID of the master to remap to 3-bit virtual ID N, where N is the 3-bit
282  * ID to use.
283  *
284  * Field Access Macros:
285  *
286  */
287 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID2WR_MID register field. */
288 #define ALT_ACPIDMAP_VID2WR_MID_LSB 16
289 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID2WR_MID register field. */
290 #define ALT_ACPIDMAP_VID2WR_MID_MSB 27
291 /* The width in bits of the ALT_ACPIDMAP_VID2WR_MID register field. */
292 #define ALT_ACPIDMAP_VID2WR_MID_WIDTH 12
293 /* The mask used to set the ALT_ACPIDMAP_VID2WR_MID register field value. */
294 #define ALT_ACPIDMAP_VID2WR_MID_SET_MSK 0x0fff0000
295 /* The mask used to clear the ALT_ACPIDMAP_VID2WR_MID register field value. */
296 #define ALT_ACPIDMAP_VID2WR_MID_CLR_MSK 0xf000ffff
297 /* The reset value of the ALT_ACPIDMAP_VID2WR_MID register field. */
298 #define ALT_ACPIDMAP_VID2WR_MID_RESET 0x4
299 /* Extracts the ALT_ACPIDMAP_VID2WR_MID field value from a register. */
300 #define ALT_ACPIDMAP_VID2WR_MID_GET(value) (((value) & 0x0fff0000) >> 16)
301 /* Produces a ALT_ACPIDMAP_VID2WR_MID register field value suitable for setting the register. */
302 #define ALT_ACPIDMAP_VID2WR_MID_SET(value) (((value) << 16) & 0x0fff0000)
303
304 /*
305  * Field : Force Mapping for ID=2 - force
306  *
307  * Set to 1 to force the mapping between the 12-bit ID and 3-bit virtual ID N. Set
308  * to 0 to allow the 3-bit ID N to be dynamically allocated.
309  *
310  * Field Access Macros:
311  *
312  */
313 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID2WR_FORCE register field. */
314 #define ALT_ACPIDMAP_VID2WR_FORCE_LSB 31
315 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID2WR_FORCE register field. */
316 #define ALT_ACPIDMAP_VID2WR_FORCE_MSB 31
317 /* The width in bits of the ALT_ACPIDMAP_VID2WR_FORCE register field. */
318 #define ALT_ACPIDMAP_VID2WR_FORCE_WIDTH 1
319 /* The mask used to set the ALT_ACPIDMAP_VID2WR_FORCE register field value. */
320 #define ALT_ACPIDMAP_VID2WR_FORCE_SET_MSK 0x80000000
321 /* The mask used to clear the ALT_ACPIDMAP_VID2WR_FORCE register field value. */
322 #define ALT_ACPIDMAP_VID2WR_FORCE_CLR_MSK 0x7fffffff
323 /* The reset value of the ALT_ACPIDMAP_VID2WR_FORCE register field. */
324 #define ALT_ACPIDMAP_VID2WR_FORCE_RESET 0x1
325 /* Extracts the ALT_ACPIDMAP_VID2WR_FORCE field value from a register. */
326 #define ALT_ACPIDMAP_VID2WR_FORCE_GET(value) (((value) & 0x80000000) >> 31)
327 /* Produces a ALT_ACPIDMAP_VID2WR_FORCE register field value suitable for setting the register. */
328 #define ALT_ACPIDMAP_VID2WR_FORCE_SET(value) (((value) << 31) & 0x80000000)
329
330 #ifndef __ASSEMBLY__
331 /*
332  * WARNING: The C register and register group struct declarations are provided for
333  * convenience and illustrative purposes. They should, however, be used with
334  * caution as the C language standard provides no guarantees about the alignment or
335  * atomicity of device memory accesses. The recommended practice for writing
336  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
337  * alt_write_word() functions.
338  *
339  * The struct declaration for register ALT_ACPIDMAP_VID2WR.
340  */
342 {
343  uint32_t : 4; /* *UNDEFINED* */
344  uint32_t user : 5; /* AWUSER value to SCU for ID=2 */
345  uint32_t : 3; /* *UNDEFINED* */
346  uint32_t page : 2; /* AWADDR 1GB Page Decoder */
347  uint32_t : 2; /* *UNDEFINED* */
348  uint32_t mid : 12; /* Remap Master ID = DAP ID */
349  uint32_t : 3; /* *UNDEFINED* */
350  uint32_t force : 1; /* Force Mapping for ID=2 */
351 };
352
353 /* The typedef declaration for register ALT_ACPIDMAP_VID2WR. */
354 typedef volatile struct ALT_ACPIDMAP_VID2WR_s ALT_ACPIDMAP_VID2WR_t;
355 #endif /* __ASSEMBLY__ */
356
357 /* The byte offset of the ALT_ACPIDMAP_VID2WR register from the beginning of the component. */
358 #define ALT_ACPIDMAP_VID2WR_OFST 0x4
359
360 /*
361  * Register : Read AXI Master Mapping Register for Fixed Virtual ID 3 - vid3rd
362  *
363  * The Read AXI Master Mapping Register contains the USER, ADDR page, and ID
364  * signals mapping values for particular transaction with 12-bit ID which locks the
365  * fixed 3-bit virtual ID.
366  *
367  * Register Layout
368  *
369  * Bits | Access | Reset | Description
370  * :--------|:-------|:------|:------------------------
371  * [3:0] | ??? | 0x0 | *UNDEFINED*
372  * [8:4] | RW | 0x0 | ARUSER value to SCU
373  * [11:9] | ??? | 0x0 | *UNDEFINED*
374  * [13:12] | RW | 0x0 | ARADDR 1GB Page Decoder
375  * [15:14] | ??? | 0x0 | *UNDEFINED*
376  * [27:16] | RW | 0x0 | Remap Master ID
377  * [30:28] | ??? | 0x0 | *UNDEFINED*
378  * [31] | RW | 0x0 | Force Mapping
379  *
380  */
381 /*
382  * Field : ARUSER value to SCU - user
383  *
384  * This value is propagated to SCU as ARUSERS.
385  *
386  * Field Access Macros:
387  *
388  */
389 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID3RD_USER register field. */
390 #define ALT_ACPIDMAP_VID3RD_USER_LSB 4
391 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID3RD_USER register field. */
392 #define ALT_ACPIDMAP_VID3RD_USER_MSB 8
393 /* The width in bits of the ALT_ACPIDMAP_VID3RD_USER register field. */
394 #define ALT_ACPIDMAP_VID3RD_USER_WIDTH 5
395 /* The mask used to set the ALT_ACPIDMAP_VID3RD_USER register field value. */
396 #define ALT_ACPIDMAP_VID3RD_USER_SET_MSK 0x000001f0
397 /* The mask used to clear the ALT_ACPIDMAP_VID3RD_USER register field value. */
398 #define ALT_ACPIDMAP_VID3RD_USER_CLR_MSK 0xfffffe0f
399 /* The reset value of the ALT_ACPIDMAP_VID3RD_USER register field. */
400 #define ALT_ACPIDMAP_VID3RD_USER_RESET 0x0
401 /* Extracts the ALT_ACPIDMAP_VID3RD_USER field value from a register. */
402 #define ALT_ACPIDMAP_VID3RD_USER_GET(value) (((value) & 0x000001f0) >> 4)
403 /* Produces a ALT_ACPIDMAP_VID3RD_USER register field value suitable for setting the register. */
404 #define ALT_ACPIDMAP_VID3RD_USER_SET(value) (((value) << 4) & 0x000001f0)
405
406 /*
407  * Field : ARADDR 1GB Page Decoder - page
408  *
409  * ARADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
410  *
411  * Field Access Macros:
412  *
413  */
414 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID3RD_PAGE register field. */
415 #define ALT_ACPIDMAP_VID3RD_PAGE_LSB 12
416 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID3RD_PAGE register field. */
417 #define ALT_ACPIDMAP_VID3RD_PAGE_MSB 13
418 /* The width in bits of the ALT_ACPIDMAP_VID3RD_PAGE register field. */
419 #define ALT_ACPIDMAP_VID3RD_PAGE_WIDTH 2
420 /* The mask used to set the ALT_ACPIDMAP_VID3RD_PAGE register field value. */
421 #define ALT_ACPIDMAP_VID3RD_PAGE_SET_MSK 0x00003000
422 /* The mask used to clear the ALT_ACPIDMAP_VID3RD_PAGE register field value. */
423 #define ALT_ACPIDMAP_VID3RD_PAGE_CLR_MSK 0xffffcfff
424 /* The reset value of the ALT_ACPIDMAP_VID3RD_PAGE register field. */
425 #define ALT_ACPIDMAP_VID3RD_PAGE_RESET 0x0
426 /* Extracts the ALT_ACPIDMAP_VID3RD_PAGE field value from a register. */
427 #define ALT_ACPIDMAP_VID3RD_PAGE_GET(value) (((value) & 0x00003000) >> 12)
428 /* Produces a ALT_ACPIDMAP_VID3RD_PAGE register field value suitable for setting the register. */
429 #define ALT_ACPIDMAP_VID3RD_PAGE_SET(value) (((value) << 12) & 0x00003000)
430
431 /*
432  * Field : Remap Master ID - mid
433  *
434  * The 12-bit ID of the master to remap to 3-bit virtual ID N, where N is the 3-bit
435  * ID to use.
436  *
437  * Field Access Macros:
438  *
439  */
440 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID3RD_MID register field. */
441 #define ALT_ACPIDMAP_VID3RD_MID_LSB 16
442 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID3RD_MID register field. */
443 #define ALT_ACPIDMAP_VID3RD_MID_MSB 27
444 /* The width in bits of the ALT_ACPIDMAP_VID3RD_MID register field. */
445 #define ALT_ACPIDMAP_VID3RD_MID_WIDTH 12
446 /* The mask used to set the ALT_ACPIDMAP_VID3RD_MID register field value. */
447 #define ALT_ACPIDMAP_VID3RD_MID_SET_MSK 0x0fff0000
448 /* The mask used to clear the ALT_ACPIDMAP_VID3RD_MID register field value. */
449 #define ALT_ACPIDMAP_VID3RD_MID_CLR_MSK 0xf000ffff
450 /* The reset value of the ALT_ACPIDMAP_VID3RD_MID register field. */
451 #define ALT_ACPIDMAP_VID3RD_MID_RESET 0x0
452 /* Extracts the ALT_ACPIDMAP_VID3RD_MID field value from a register. */
453 #define ALT_ACPIDMAP_VID3RD_MID_GET(value) (((value) & 0x0fff0000) >> 16)
454 /* Produces a ALT_ACPIDMAP_VID3RD_MID register field value suitable for setting the register. */
455 #define ALT_ACPIDMAP_VID3RD_MID_SET(value) (((value) << 16) & 0x0fff0000)
456
457 /*
458  * Field : Force Mapping - force
459  *
460  * Set to 1 to force the mapping between the 12-bit ID and 3-bit virtual ID N. Set
461  * to 0 to allow the 3-bit ID N to be dynamically allocated.
462  *
463  * Field Access Macros:
464  *
465  */
466 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID3RD_FORCE register field. */
467 #define ALT_ACPIDMAP_VID3RD_FORCE_LSB 31
468 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID3RD_FORCE register field. */
469 #define ALT_ACPIDMAP_VID3RD_FORCE_MSB 31
470 /* The width in bits of the ALT_ACPIDMAP_VID3RD_FORCE register field. */
471 #define ALT_ACPIDMAP_VID3RD_FORCE_WIDTH 1
472 /* The mask used to set the ALT_ACPIDMAP_VID3RD_FORCE register field value. */
473 #define ALT_ACPIDMAP_VID3RD_FORCE_SET_MSK 0x80000000
474 /* The mask used to clear the ALT_ACPIDMAP_VID3RD_FORCE register field value. */
475 #define ALT_ACPIDMAP_VID3RD_FORCE_CLR_MSK 0x7fffffff
476 /* The reset value of the ALT_ACPIDMAP_VID3RD_FORCE register field. */
477 #define ALT_ACPIDMAP_VID3RD_FORCE_RESET 0x0
478 /* Extracts the ALT_ACPIDMAP_VID3RD_FORCE field value from a register. */
479 #define ALT_ACPIDMAP_VID3RD_FORCE_GET(value) (((value) & 0x80000000) >> 31)
480 /* Produces a ALT_ACPIDMAP_VID3RD_FORCE register field value suitable for setting the register. */
481 #define ALT_ACPIDMAP_VID3RD_FORCE_SET(value) (((value) << 31) & 0x80000000)
482
483 #ifndef __ASSEMBLY__
484 /*
485  * WARNING: The C register and register group struct declarations are provided for
486  * convenience and illustrative purposes. They should, however, be used with
487  * caution as the C language standard provides no guarantees about the alignment or
488  * atomicity of device memory accesses. The recommended practice for writing
489  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
490  * alt_write_word() functions.
491  *
492  * The struct declaration for register ALT_ACPIDMAP_VID3RD.
493  */
495 {
496  uint32_t : 4; /* *UNDEFINED* */
497  uint32_t user : 5; /* ARUSER value to SCU */
498  uint32_t : 3; /* *UNDEFINED* */
499  uint32_t page : 2; /* ARADDR 1GB Page Decoder */
500  uint32_t : 2; /* *UNDEFINED* */
501  uint32_t mid : 12; /* Remap Master ID */
502  uint32_t : 3; /* *UNDEFINED* */
503  uint32_t force : 1; /* Force Mapping */
504 };
505
506 /* The typedef declaration for register ALT_ACPIDMAP_VID3RD. */
507 typedef volatile struct ALT_ACPIDMAP_VID3RD_s ALT_ACPIDMAP_VID3RD_t;
508 #endif /* __ASSEMBLY__ */
509
510 /* The byte offset of the ALT_ACPIDMAP_VID3RD register from the beginning of the component. */
511 #define ALT_ACPIDMAP_VID3RD_OFST 0x8
512
513 /*
514  * Register : Write AXI Master Mapping Register for Fixed Virtual ID 3 - vid3wr
515  *
516  * The Write AXI Master Mapping Register contains the USER, ADDR page, and ID
517  * signals mapping values for particular transaction with 12-bit ID which locks the
518  * fixed 3-bit virtual ID.
519  *
520  * Register Layout
521  *
522  * Bits | Access | Reset | Description
523  * :--------|:-------|:------|:------------------------
524  * [3:0] | ??? | 0x0 | *UNDEFINED*
525  * [8:4] | RW | 0x0 | AWUSER value to SCU
526  * [11:9] | ??? | 0x0 | *UNDEFINED*
527  * [13:12] | RW | 0x0 | AWADDR 1GB Page Decoder
528  * [15:14] | ??? | 0x0 | *UNDEFINED*
529  * [27:16] | RW | 0x0 | Remap Master ID
530  * [30:28] | ??? | 0x0 | *UNDEFINED*
531  * [31] | RW | 0x0 | Force Mapping
532  *
533  */
534 /*
535  * Field : AWUSER value to SCU - user
536  *
537  * This value is propagated to SCU as AWUSERS.
538  *
539  * Field Access Macros:
540  *
541  */
542 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID3WR_USER register field. */
543 #define ALT_ACPIDMAP_VID3WR_USER_LSB 4
544 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID3WR_USER register field. */
545 #define ALT_ACPIDMAP_VID3WR_USER_MSB 8
546 /* The width in bits of the ALT_ACPIDMAP_VID3WR_USER register field. */
547 #define ALT_ACPIDMAP_VID3WR_USER_WIDTH 5
548 /* The mask used to set the ALT_ACPIDMAP_VID3WR_USER register field value. */
549 #define ALT_ACPIDMAP_VID3WR_USER_SET_MSK 0x000001f0
550 /* The mask used to clear the ALT_ACPIDMAP_VID3WR_USER register field value. */
551 #define ALT_ACPIDMAP_VID3WR_USER_CLR_MSK 0xfffffe0f
552 /* The reset value of the ALT_ACPIDMAP_VID3WR_USER register field. */
553 #define ALT_ACPIDMAP_VID3WR_USER_RESET 0x0
554 /* Extracts the ALT_ACPIDMAP_VID3WR_USER field value from a register. */
555 #define ALT_ACPIDMAP_VID3WR_USER_GET(value) (((value) & 0x000001f0) >> 4)
556 /* Produces a ALT_ACPIDMAP_VID3WR_USER register field value suitable for setting the register. */
557 #define ALT_ACPIDMAP_VID3WR_USER_SET(value) (((value) << 4) & 0x000001f0)
558
559 /*
560  * Field : AWADDR 1GB Page Decoder - page
561  *
562  * AWADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
563  *
564  * Field Access Macros:
565  *
566  */
567 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID3WR_PAGE register field. */
568 #define ALT_ACPIDMAP_VID3WR_PAGE_LSB 12
569 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID3WR_PAGE register field. */
570 #define ALT_ACPIDMAP_VID3WR_PAGE_MSB 13
571 /* The width in bits of the ALT_ACPIDMAP_VID3WR_PAGE register field. */
572 #define ALT_ACPIDMAP_VID3WR_PAGE_WIDTH 2
573 /* The mask used to set the ALT_ACPIDMAP_VID3WR_PAGE register field value. */
574 #define ALT_ACPIDMAP_VID3WR_PAGE_SET_MSK 0x00003000
575 /* The mask used to clear the ALT_ACPIDMAP_VID3WR_PAGE register field value. */
576 #define ALT_ACPIDMAP_VID3WR_PAGE_CLR_MSK 0xffffcfff
577 /* The reset value of the ALT_ACPIDMAP_VID3WR_PAGE register field. */
578 #define ALT_ACPIDMAP_VID3WR_PAGE_RESET 0x0
579 /* Extracts the ALT_ACPIDMAP_VID3WR_PAGE field value from a register. */
580 #define ALT_ACPIDMAP_VID3WR_PAGE_GET(value) (((value) & 0x00003000) >> 12)
581 /* Produces a ALT_ACPIDMAP_VID3WR_PAGE register field value suitable for setting the register. */
582 #define ALT_ACPIDMAP_VID3WR_PAGE_SET(value) (((value) << 12) & 0x00003000)
583
584 /*
585  * Field : Remap Master ID - mid
586  *
587  * The 12-bit ID of the master to remap to 3-bit virtual ID N, where N is the 3-bit
588  * ID to use.
589  *
590  * Field Access Macros:
591  *
592  */
593 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID3WR_MID register field. */
594 #define ALT_ACPIDMAP_VID3WR_MID_LSB 16
595 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID3WR_MID register field. */
596 #define ALT_ACPIDMAP_VID3WR_MID_MSB 27
597 /* The width in bits of the ALT_ACPIDMAP_VID3WR_MID register field. */
598 #define ALT_ACPIDMAP_VID3WR_MID_WIDTH 12
599 /* The mask used to set the ALT_ACPIDMAP_VID3WR_MID register field value. */
600 #define ALT_ACPIDMAP_VID3WR_MID_SET_MSK 0x0fff0000
601 /* The mask used to clear the ALT_ACPIDMAP_VID3WR_MID register field value. */
602 #define ALT_ACPIDMAP_VID3WR_MID_CLR_MSK 0xf000ffff
603 /* The reset value of the ALT_ACPIDMAP_VID3WR_MID register field. */
604 #define ALT_ACPIDMAP_VID3WR_MID_RESET 0x0
605 /* Extracts the ALT_ACPIDMAP_VID3WR_MID field value from a register. */
606 #define ALT_ACPIDMAP_VID3WR_MID_GET(value) (((value) & 0x0fff0000) >> 16)
607 /* Produces a ALT_ACPIDMAP_VID3WR_MID register field value suitable for setting the register. */
608 #define ALT_ACPIDMAP_VID3WR_MID_SET(value) (((value) << 16) & 0x0fff0000)
609
610 /*
611  * Field : Force Mapping - force
612  *
613  * Set to 1 to force the mapping between the 12-bit ID and 3-bit virtual ID N. Set
614  * to 0 to allow the 3-bit ID N to be dynamically allocated.
615  *
616  * Field Access Macros:
617  *
618  */
619 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID3WR_FORCE register field. */
620 #define ALT_ACPIDMAP_VID3WR_FORCE_LSB 31
621 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID3WR_FORCE register field. */
622 #define ALT_ACPIDMAP_VID3WR_FORCE_MSB 31
623 /* The width in bits of the ALT_ACPIDMAP_VID3WR_FORCE register field. */
624 #define ALT_ACPIDMAP_VID3WR_FORCE_WIDTH 1
625 /* The mask used to set the ALT_ACPIDMAP_VID3WR_FORCE register field value. */
626 #define ALT_ACPIDMAP_VID3WR_FORCE_SET_MSK 0x80000000
627 /* The mask used to clear the ALT_ACPIDMAP_VID3WR_FORCE register field value. */
628 #define ALT_ACPIDMAP_VID3WR_FORCE_CLR_MSK 0x7fffffff
629 /* The reset value of the ALT_ACPIDMAP_VID3WR_FORCE register field. */
630 #define ALT_ACPIDMAP_VID3WR_FORCE_RESET 0x0
631 /* Extracts the ALT_ACPIDMAP_VID3WR_FORCE field value from a register. */
632 #define ALT_ACPIDMAP_VID3WR_FORCE_GET(value) (((value) & 0x80000000) >> 31)
633 /* Produces a ALT_ACPIDMAP_VID3WR_FORCE register field value suitable for setting the register. */
634 #define ALT_ACPIDMAP_VID3WR_FORCE_SET(value) (((value) << 31) & 0x80000000)
635
636 #ifndef __ASSEMBLY__
637 /*
638  * WARNING: The C register and register group struct declarations are provided for
639  * convenience and illustrative purposes. They should, however, be used with
640  * caution as the C language standard provides no guarantees about the alignment or
641  * atomicity of device memory accesses. The recommended practice for writing
642  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
643  * alt_write_word() functions.
644  *
645  * The struct declaration for register ALT_ACPIDMAP_VID3WR.
646  */
648 {
649  uint32_t : 4; /* *UNDEFINED* */
650  uint32_t user : 5; /* AWUSER value to SCU */
651  uint32_t : 3; /* *UNDEFINED* */
652  uint32_t page : 2; /* AWADDR 1GB Page Decoder */
653  uint32_t : 2; /* *UNDEFINED* */
654  uint32_t mid : 12; /* Remap Master ID */
655  uint32_t : 3; /* *UNDEFINED* */
656  uint32_t force : 1; /* Force Mapping */
657 };
658
659 /* The typedef declaration for register ALT_ACPIDMAP_VID3WR. */
660 typedef volatile struct ALT_ACPIDMAP_VID3WR_s ALT_ACPIDMAP_VID3WR_t;
661 #endif /* __ASSEMBLY__ */
662
663 /* The byte offset of the ALT_ACPIDMAP_VID3WR register from the beginning of the component. */
664 #define ALT_ACPIDMAP_VID3WR_OFST 0xc
665
666 /*
667  * Register : Read AXI Master Mapping Register for Fixed Virtual ID 4 - vid4rd
668  *
669  * The Read AXI Master Mapping Register contains the USER, ADDR page, and ID
670  * signals mapping values for particular transaction with 12-bit ID which locks the
671  * fixed 3-bit virtual ID.
672  *
673  * Register Layout
674  *
675  * Bits | Access | Reset | Description
676  * :--------|:-------|:------|:------------------------
677  * [3:0] | ??? | 0x0 | *UNDEFINED*
678  * [8:4] | RW | 0x0 | ARUSER value to SCU
679  * [11:9] | ??? | 0x0 | *UNDEFINED*
680  * [13:12] | RW | 0x0 | ARADDR 1GB Page Decoder
681  * [15:14] | ??? | 0x0 | *UNDEFINED*
682  * [27:16] | RW | 0x0 | Remap Master ID
683  * [30:28] | ??? | 0x0 | *UNDEFINED*
684  * [31] | RW | 0x0 | Force Mapping
685  *
686  */
687 /*
688  * Field : ARUSER value to SCU - user
689  *
690  * This value is propagated to SCU as ARUSERS.
691  *
692  * Field Access Macros:
693  *
694  */
695 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID4RD_USER register field. */
696 #define ALT_ACPIDMAP_VID4RD_USER_LSB 4
697 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID4RD_USER register field. */
698 #define ALT_ACPIDMAP_VID4RD_USER_MSB 8
699 /* The width in bits of the ALT_ACPIDMAP_VID4RD_USER register field. */
700 #define ALT_ACPIDMAP_VID4RD_USER_WIDTH 5
701 /* The mask used to set the ALT_ACPIDMAP_VID4RD_USER register field value. */
702 #define ALT_ACPIDMAP_VID4RD_USER_SET_MSK 0x000001f0
703 /* The mask used to clear the ALT_ACPIDMAP_VID4RD_USER register field value. */
704 #define ALT_ACPIDMAP_VID4RD_USER_CLR_MSK 0xfffffe0f
705 /* The reset value of the ALT_ACPIDMAP_VID4RD_USER register field. */
706 #define ALT_ACPIDMAP_VID4RD_USER_RESET 0x0
707 /* Extracts the ALT_ACPIDMAP_VID4RD_USER field value from a register. */
708 #define ALT_ACPIDMAP_VID4RD_USER_GET(value) (((value) & 0x000001f0) >> 4)
709 /* Produces a ALT_ACPIDMAP_VID4RD_USER register field value suitable for setting the register. */
710 #define ALT_ACPIDMAP_VID4RD_USER_SET(value) (((value) << 4) & 0x000001f0)
711
712 /*
713  * Field : ARADDR 1GB Page Decoder - page
714  *
715  * ARADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
716  *
717  * Field Access Macros:
718  *
719  */
720 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID4RD_PAGE register field. */
721 #define ALT_ACPIDMAP_VID4RD_PAGE_LSB 12
722 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID4RD_PAGE register field. */
723 #define ALT_ACPIDMAP_VID4RD_PAGE_MSB 13
724 /* The width in bits of the ALT_ACPIDMAP_VID4RD_PAGE register field. */
725 #define ALT_ACPIDMAP_VID4RD_PAGE_WIDTH 2
726 /* The mask used to set the ALT_ACPIDMAP_VID4RD_PAGE register field value. */
727 #define ALT_ACPIDMAP_VID4RD_PAGE_SET_MSK 0x00003000
728 /* The mask used to clear the ALT_ACPIDMAP_VID4RD_PAGE register field value. */
729 #define ALT_ACPIDMAP_VID4RD_PAGE_CLR_MSK 0xffffcfff
730 /* The reset value of the ALT_ACPIDMAP_VID4RD_PAGE register field. */
731 #define ALT_ACPIDMAP_VID4RD_PAGE_RESET 0x0
732 /* Extracts the ALT_ACPIDMAP_VID4RD_PAGE field value from a register. */
733 #define ALT_ACPIDMAP_VID4RD_PAGE_GET(value) (((value) & 0x00003000) >> 12)
734 /* Produces a ALT_ACPIDMAP_VID4RD_PAGE register field value suitable for setting the register. */
735 #define ALT_ACPIDMAP_VID4RD_PAGE_SET(value) (((value) << 12) & 0x00003000)
736
737 /*
738  * Field : Remap Master ID - mid
739  *
740  * The 12-bit ID of the master to remap to 3-bit virtual ID N, where N is the 3-bit
741  * ID to use.
742  *
743  * Field Access Macros:
744  *
745  */
746 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID4RD_MID register field. */
747 #define ALT_ACPIDMAP_VID4RD_MID_LSB 16
748 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID4RD_MID register field. */
749 #define ALT_ACPIDMAP_VID4RD_MID_MSB 27
750 /* The width in bits of the ALT_ACPIDMAP_VID4RD_MID register field. */
751 #define ALT_ACPIDMAP_VID4RD_MID_WIDTH 12
752 /* The mask used to set the ALT_ACPIDMAP_VID4RD_MID register field value. */
753 #define ALT_ACPIDMAP_VID4RD_MID_SET_MSK 0x0fff0000
754 /* The mask used to clear the ALT_ACPIDMAP_VID4RD_MID register field value. */
755 #define ALT_ACPIDMAP_VID4RD_MID_CLR_MSK 0xf000ffff
756 /* The reset value of the ALT_ACPIDMAP_VID4RD_MID register field. */
757 #define ALT_ACPIDMAP_VID4RD_MID_RESET 0x0
758 /* Extracts the ALT_ACPIDMAP_VID4RD_MID field value from a register. */
759 #define ALT_ACPIDMAP_VID4RD_MID_GET(value) (((value) & 0x0fff0000) >> 16)
760 /* Produces a ALT_ACPIDMAP_VID4RD_MID register field value suitable for setting the register. */
761 #define ALT_ACPIDMAP_VID4RD_MID_SET(value) (((value) << 16) & 0x0fff0000)
762
763 /*
764  * Field : Force Mapping - force
765  *
766  * Set to 1 to force the mapping between the 12-bit ID and 3-bit virtual ID N. Set
767  * to 0 to allow the 3-bit ID N to be dynamically allocated.
768  *
769  * Field Access Macros:
770  *
771  */
772 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID4RD_FORCE register field. */
773 #define ALT_ACPIDMAP_VID4RD_FORCE_LSB 31
774 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID4RD_FORCE register field. */
775 #define ALT_ACPIDMAP_VID4RD_FORCE_MSB 31
776 /* The width in bits of the ALT_ACPIDMAP_VID4RD_FORCE register field. */
777 #define ALT_ACPIDMAP_VID4RD_FORCE_WIDTH 1
778 /* The mask used to set the ALT_ACPIDMAP_VID4RD_FORCE register field value. */
779 #define ALT_ACPIDMAP_VID4RD_FORCE_SET_MSK 0x80000000
780 /* The mask used to clear the ALT_ACPIDMAP_VID4RD_FORCE register field value. */
781 #define ALT_ACPIDMAP_VID4RD_FORCE_CLR_MSK 0x7fffffff
782 /* The reset value of the ALT_ACPIDMAP_VID4RD_FORCE register field. */
783 #define ALT_ACPIDMAP_VID4RD_FORCE_RESET 0x0
784 /* Extracts the ALT_ACPIDMAP_VID4RD_FORCE field value from a register. */
785 #define ALT_ACPIDMAP_VID4RD_FORCE_GET(value) (((value) & 0x80000000) >> 31)
786 /* Produces a ALT_ACPIDMAP_VID4RD_FORCE register field value suitable for setting the register. */
787 #define ALT_ACPIDMAP_VID4RD_FORCE_SET(value) (((value) << 31) & 0x80000000)
788
789 #ifndef __ASSEMBLY__
790 /*
791  * WARNING: The C register and register group struct declarations are provided for
792  * convenience and illustrative purposes. They should, however, be used with
793  * caution as the C language standard provides no guarantees about the alignment or
794  * atomicity of device memory accesses. The recommended practice for writing
795  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
796  * alt_write_word() functions.
797  *
798  * The struct declaration for register ALT_ACPIDMAP_VID4RD.
799  */
801 {
802  uint32_t : 4; /* *UNDEFINED* */
803  uint32_t user : 5; /* ARUSER value to SCU */
804  uint32_t : 3; /* *UNDEFINED* */
805  uint32_t page : 2; /* ARADDR 1GB Page Decoder */
806  uint32_t : 2; /* *UNDEFINED* */
807  uint32_t mid : 12; /* Remap Master ID */
808  uint32_t : 3; /* *UNDEFINED* */
809  uint32_t force : 1; /* Force Mapping */
810 };
811
812 /* The typedef declaration for register ALT_ACPIDMAP_VID4RD. */
813 typedef volatile struct ALT_ACPIDMAP_VID4RD_s ALT_ACPIDMAP_VID4RD_t;
814 #endif /* __ASSEMBLY__ */
815
816 /* The byte offset of the ALT_ACPIDMAP_VID4RD register from the beginning of the component. */
817 #define ALT_ACPIDMAP_VID4RD_OFST 0x10
818
819 /*
820  * Register : Write AXI Master Mapping Register for Fixed Virtual ID 4 - vid4wr
821  *
822  * The Write AXI Master Mapping Register contains the USER, ADDR page, and ID
823  * signals mapping values for particular transaction with 12-bit ID which locks the
824  * fixed 3-bit virtual ID.
825  *
826  * Register Layout
827  *
828  * Bits | Access | Reset | Description
829  * :--------|:-------|:------|:------------------------
830  * [3:0] | ??? | 0x0 | *UNDEFINED*
831  * [8:4] | RW | 0x0 | AWUSER value to SCU
832  * [11:9] | ??? | 0x0 | *UNDEFINED*
833  * [13:12] | RW | 0x0 | AWADDR 1GB Page Decoder
834  * [15:14] | ??? | 0x0 | *UNDEFINED*
835  * [27:16] | RW | 0x0 | Remap Master ID
836  * [30:28] | ??? | 0x0 | *UNDEFINED*
837  * [31] | RW | 0x0 | Force Mapping
838  *
839  */
840 /*
841  * Field : AWUSER value to SCU - user
842  *
843  * This value is propagated to SCU as AWUSERS.
844  *
845  * Field Access Macros:
846  *
847  */
848 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID4WR_USER register field. */
849 #define ALT_ACPIDMAP_VID4WR_USER_LSB 4
850 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID4WR_USER register field. */
851 #define ALT_ACPIDMAP_VID4WR_USER_MSB 8
852 /* The width in bits of the ALT_ACPIDMAP_VID4WR_USER register field. */
853 #define ALT_ACPIDMAP_VID4WR_USER_WIDTH 5
854 /* The mask used to set the ALT_ACPIDMAP_VID4WR_USER register field value. */
855 #define ALT_ACPIDMAP_VID4WR_USER_SET_MSK 0x000001f0
856 /* The mask used to clear the ALT_ACPIDMAP_VID4WR_USER register field value. */
857 #define ALT_ACPIDMAP_VID4WR_USER_CLR_MSK 0xfffffe0f
858 /* The reset value of the ALT_ACPIDMAP_VID4WR_USER register field. */
859 #define ALT_ACPIDMAP_VID4WR_USER_RESET 0x0
860 /* Extracts the ALT_ACPIDMAP_VID4WR_USER field value from a register. */
861 #define ALT_ACPIDMAP_VID4WR_USER_GET(value) (((value) & 0x000001f0) >> 4)
862 /* Produces a ALT_ACPIDMAP_VID4WR_USER register field value suitable for setting the register. */
863 #define ALT_ACPIDMAP_VID4WR_USER_SET(value) (((value) << 4) & 0x000001f0)
864
865 /*
866  * Field : AWADDR 1GB Page Decoder - page
867  *
868  * AWADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
869  *
870  * Field Access Macros:
871  *
872  */
873 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID4WR_PAGE register field. */
874 #define ALT_ACPIDMAP_VID4WR_PAGE_LSB 12
875 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID4WR_PAGE register field. */
876 #define ALT_ACPIDMAP_VID4WR_PAGE_MSB 13
877 /* The width in bits of the ALT_ACPIDMAP_VID4WR_PAGE register field. */
878 #define ALT_ACPIDMAP_VID4WR_PAGE_WIDTH 2
879 /* The mask used to set the ALT_ACPIDMAP_VID4WR_PAGE register field value. */
880 #define ALT_ACPIDMAP_VID4WR_PAGE_SET_MSK 0x00003000
881 /* The mask used to clear the ALT_ACPIDMAP_VID4WR_PAGE register field value. */
882 #define ALT_ACPIDMAP_VID4WR_PAGE_CLR_MSK 0xffffcfff
883 /* The reset value of the ALT_ACPIDMAP_VID4WR_PAGE register field. */
884 #define ALT_ACPIDMAP_VID4WR_PAGE_RESET 0x0
885 /* Extracts the ALT_ACPIDMAP_VID4WR_PAGE field value from a register. */
886 #define ALT_ACPIDMAP_VID4WR_PAGE_GET(value) (((value) & 0x00003000) >> 12)
887 /* Produces a ALT_ACPIDMAP_VID4WR_PAGE register field value suitable for setting the register. */
888 #define ALT_ACPIDMAP_VID4WR_PAGE_SET(value) (((value) << 12) & 0x00003000)
889
890 /*
891  * Field : Remap Master ID - mid
892  *
893  * The 12-bit ID of the master to remap to 3-bit virtual ID N, where N is the 3-bit
894  * ID to use.
895  *
896  * Field Access Macros:
897  *
898  */
899 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID4WR_MID register field. */
900 #define ALT_ACPIDMAP_VID4WR_MID_LSB 16
901 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID4WR_MID register field. */
902 #define ALT_ACPIDMAP_VID4WR_MID_MSB 27
903 /* The width in bits of the ALT_ACPIDMAP_VID4WR_MID register field. */
904 #define ALT_ACPIDMAP_VID4WR_MID_WIDTH 12
905 /* The mask used to set the ALT_ACPIDMAP_VID4WR_MID register field value. */
906 #define ALT_ACPIDMAP_VID4WR_MID_SET_MSK 0x0fff0000
907 /* The mask used to clear the ALT_ACPIDMAP_VID4WR_MID register field value. */
908 #define ALT_ACPIDMAP_VID4WR_MID_CLR_MSK 0xf000ffff
909 /* The reset value of the ALT_ACPIDMAP_VID4WR_MID register field. */
910 #define ALT_ACPIDMAP_VID4WR_MID_RESET 0x0
911 /* Extracts the ALT_ACPIDMAP_VID4WR_MID field value from a register. */
912 #define ALT_ACPIDMAP_VID4WR_MID_GET(value) (((value) & 0x0fff0000) >> 16)
913 /* Produces a ALT_ACPIDMAP_VID4WR_MID register field value suitable for setting the register. */
914 #define ALT_ACPIDMAP_VID4WR_MID_SET(value) (((value) << 16) & 0x0fff0000)
915
916 /*
917  * Field : Force Mapping - force
918  *
919  * Set to 1 to force the mapping between the 12-bit ID and 3-bit virtual ID N. Set
920  * to 0 to allow the 3-bit ID N to be dynamically allocated.
921  *
922  * Field Access Macros:
923  *
924  */
925 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID4WR_FORCE register field. */
926 #define ALT_ACPIDMAP_VID4WR_FORCE_LSB 31
927 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID4WR_FORCE register field. */
928 #define ALT_ACPIDMAP_VID4WR_FORCE_MSB 31
929 /* The width in bits of the ALT_ACPIDMAP_VID4WR_FORCE register field. */
930 #define ALT_ACPIDMAP_VID4WR_FORCE_WIDTH 1
931 /* The mask used to set the ALT_ACPIDMAP_VID4WR_FORCE register field value. */
932 #define ALT_ACPIDMAP_VID4WR_FORCE_SET_MSK 0x80000000
933 /* The mask used to clear the ALT_ACPIDMAP_VID4WR_FORCE register field value. */
934 #define ALT_ACPIDMAP_VID4WR_FORCE_CLR_MSK 0x7fffffff
935 /* The reset value of the ALT_ACPIDMAP_VID4WR_FORCE register field. */
936 #define ALT_ACPIDMAP_VID4WR_FORCE_RESET 0x0
937 /* Extracts the ALT_ACPIDMAP_VID4WR_FORCE field value from a register. */
938 #define ALT_ACPIDMAP_VID4WR_FORCE_GET(value) (((value) & 0x80000000) >> 31)
939 /* Produces a ALT_ACPIDMAP_VID4WR_FORCE register field value suitable for setting the register. */
940 #define ALT_ACPIDMAP_VID4WR_FORCE_SET(value) (((value) << 31) & 0x80000000)
941
942 #ifndef __ASSEMBLY__
943 /*
944  * WARNING: The C register and register group struct declarations are provided for
945  * convenience and illustrative purposes. They should, however, be used with
946  * caution as the C language standard provides no guarantees about the alignment or
947  * atomicity of device memory accesses. The recommended practice for writing
948  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
949  * alt_write_word() functions.
950  *
951  * The struct declaration for register ALT_ACPIDMAP_VID4WR.
952  */
954 {
955  uint32_t : 4; /* *UNDEFINED* */
956  uint32_t user : 5; /* AWUSER value to SCU */
957  uint32_t : 3; /* *UNDEFINED* */
958  uint32_t page : 2; /* AWADDR 1GB Page Decoder */
959  uint32_t : 2; /* *UNDEFINED* */
960  uint32_t mid : 12; /* Remap Master ID */
961  uint32_t : 3; /* *UNDEFINED* */
962  uint32_t force : 1; /* Force Mapping */
963 };
964
965 /* The typedef declaration for register ALT_ACPIDMAP_VID4WR. */
966 typedef volatile struct ALT_ACPIDMAP_VID4WR_s ALT_ACPIDMAP_VID4WR_t;
967 #endif /* __ASSEMBLY__ */
968
969 /* The byte offset of the ALT_ACPIDMAP_VID4WR register from the beginning of the component. */
970 #define ALT_ACPIDMAP_VID4WR_OFST 0x14
971
972 /*
973  * Register : Read AXI Master Mapping Register for Fixed Virtual ID 5 - vid5rd
974  *
975  * The Read AXI Master Mapping Register contains the USER, ADDR page, and ID
976  * signals mapping values for particular transaction with 12-bit ID which locks the
977  * fixed 3-bit virtual ID.
978  *
979  * Register Layout
980  *
981  * Bits | Access | Reset | Description
982  * :--------|:-------|:------|:------------------------
983  * [3:0] | ??? | 0x0 | *UNDEFINED*
984  * [8:4] | RW | 0x0 | ARUSER value to SCU
985  * [11:9] | ??? | 0x0 | *UNDEFINED*
986  * [13:12] | RW | 0x0 | ARADDR 1GB Page Decoder
987  * [15:14] | ??? | 0x0 | *UNDEFINED*
988  * [27:16] | RW | 0x0 | Remap Master ID
989  * [30:28] | ??? | 0x0 | *UNDEFINED*
990  * [31] | RW | 0x0 | Force Mapping
991  *
992  */
993 /*
994  * Field : ARUSER value to SCU - user
995  *
996  * This value is propagated to SCU as ARUSERS.
997  *
998  * Field Access Macros:
999  *
1000  */
1001 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID5RD_USER register field. */
1002 #define ALT_ACPIDMAP_VID5RD_USER_LSB 4
1003 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID5RD_USER register field. */
1004 #define ALT_ACPIDMAP_VID5RD_USER_MSB 8
1005 /* The width in bits of the ALT_ACPIDMAP_VID5RD_USER register field. */
1006 #define ALT_ACPIDMAP_VID5RD_USER_WIDTH 5
1007 /* The mask used to set the ALT_ACPIDMAP_VID5RD_USER register field value. */
1008 #define ALT_ACPIDMAP_VID5RD_USER_SET_MSK 0x000001f0
1009 /* The mask used to clear the ALT_ACPIDMAP_VID5RD_USER register field value. */
1010 #define ALT_ACPIDMAP_VID5RD_USER_CLR_MSK 0xfffffe0f
1011 /* The reset value of the ALT_ACPIDMAP_VID5RD_USER register field. */
1012 #define ALT_ACPIDMAP_VID5RD_USER_RESET 0x0
1013 /* Extracts the ALT_ACPIDMAP_VID5RD_USER field value from a register. */
1014 #define ALT_ACPIDMAP_VID5RD_USER_GET(value) (((value) & 0x000001f0) >> 4)
1015 /* Produces a ALT_ACPIDMAP_VID5RD_USER register field value suitable for setting the register. */
1016 #define ALT_ACPIDMAP_VID5RD_USER_SET(value) (((value) << 4) & 0x000001f0)
1017
1018 /*
1019  * Field : ARADDR 1GB Page Decoder - page
1020  *
1021  * ARADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
1022  *
1023  * Field Access Macros:
1024  *
1025  */
1026 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID5RD_PAGE register field. */
1027 #define ALT_ACPIDMAP_VID5RD_PAGE_LSB 12
1028 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID5RD_PAGE register field. */
1029 #define ALT_ACPIDMAP_VID5RD_PAGE_MSB 13
1030 /* The width in bits of the ALT_ACPIDMAP_VID5RD_PAGE register field. */
1031 #define ALT_ACPIDMAP_VID5RD_PAGE_WIDTH 2
1032 /* The mask used to set the ALT_ACPIDMAP_VID5RD_PAGE register field value. */
1033 #define ALT_ACPIDMAP_VID5RD_PAGE_SET_MSK 0x00003000
1034 /* The mask used to clear the ALT_ACPIDMAP_VID5RD_PAGE register field value. */
1035 #define ALT_ACPIDMAP_VID5RD_PAGE_CLR_MSK 0xffffcfff
1036 /* The reset value of the ALT_ACPIDMAP_VID5RD_PAGE register field. */
1037 #define ALT_ACPIDMAP_VID5RD_PAGE_RESET 0x0
1038 /* Extracts the ALT_ACPIDMAP_VID5RD_PAGE field value from a register. */
1039 #define ALT_ACPIDMAP_VID5RD_PAGE_GET(value) (((value) & 0x00003000) >> 12)
1040 /* Produces a ALT_ACPIDMAP_VID5RD_PAGE register field value suitable for setting the register. */
1041 #define ALT_ACPIDMAP_VID5RD_PAGE_SET(value) (((value) << 12) & 0x00003000)
1042
1043 /*
1044  * Field : Remap Master ID - mid
1045  *
1046  * The 12-bit ID of the master to remap to 3-bit virtual ID N, where N is the 3-bit
1047  * ID to use.
1048  *
1049  * Field Access Macros:
1050  *
1051  */
1052 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID5RD_MID register field. */
1053 #define ALT_ACPIDMAP_VID5RD_MID_LSB 16
1054 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID5RD_MID register field. */
1055 #define ALT_ACPIDMAP_VID5RD_MID_MSB 27
1056 /* The width in bits of the ALT_ACPIDMAP_VID5RD_MID register field. */
1057 #define ALT_ACPIDMAP_VID5RD_MID_WIDTH 12
1058 /* The mask used to set the ALT_ACPIDMAP_VID5RD_MID register field value. */
1059 #define ALT_ACPIDMAP_VID5RD_MID_SET_MSK 0x0fff0000
1060 /* The mask used to clear the ALT_ACPIDMAP_VID5RD_MID register field value. */
1061 #define ALT_ACPIDMAP_VID5RD_MID_CLR_MSK 0xf000ffff
1062 /* The reset value of the ALT_ACPIDMAP_VID5RD_MID register field. */
1063 #define ALT_ACPIDMAP_VID5RD_MID_RESET 0x0
1064 /* Extracts the ALT_ACPIDMAP_VID5RD_MID field value from a register. */
1065 #define ALT_ACPIDMAP_VID5RD_MID_GET(value) (((value) & 0x0fff0000) >> 16)
1066 /* Produces a ALT_ACPIDMAP_VID5RD_MID register field value suitable for setting the register. */
1067 #define ALT_ACPIDMAP_VID5RD_MID_SET(value) (((value) << 16) & 0x0fff0000)
1068
1069 /*
1070  * Field : Force Mapping - force
1071  *
1072  * Set to 1 to force the mapping between the 12-bit ID and 3-bit virtual ID N. Set
1073  * to 0 to allow the 3-bit ID N to be dynamically allocated.
1074  *
1075  * Field Access Macros:
1076  *
1077  */
1078 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID5RD_FORCE register field. */
1079 #define ALT_ACPIDMAP_VID5RD_FORCE_LSB 31
1080 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID5RD_FORCE register field. */
1081 #define ALT_ACPIDMAP_VID5RD_FORCE_MSB 31
1082 /* The width in bits of the ALT_ACPIDMAP_VID5RD_FORCE register field. */
1083 #define ALT_ACPIDMAP_VID5RD_FORCE_WIDTH 1
1084 /* The mask used to set the ALT_ACPIDMAP_VID5RD_FORCE register field value. */
1085 #define ALT_ACPIDMAP_VID5RD_FORCE_SET_MSK 0x80000000
1086 /* The mask used to clear the ALT_ACPIDMAP_VID5RD_FORCE register field value. */
1087 #define ALT_ACPIDMAP_VID5RD_FORCE_CLR_MSK 0x7fffffff
1088 /* The reset value of the ALT_ACPIDMAP_VID5RD_FORCE register field. */
1089 #define ALT_ACPIDMAP_VID5RD_FORCE_RESET 0x0
1090 /* Extracts the ALT_ACPIDMAP_VID5RD_FORCE field value from a register. */
1091 #define ALT_ACPIDMAP_VID5RD_FORCE_GET(value) (((value) & 0x80000000) >> 31)
1092 /* Produces a ALT_ACPIDMAP_VID5RD_FORCE register field value suitable for setting the register. */
1093 #define ALT_ACPIDMAP_VID5RD_FORCE_SET(value) (((value) << 31) & 0x80000000)
1094
1095 #ifndef __ASSEMBLY__
1096 /*
1097  * WARNING: The C register and register group struct declarations are provided for
1098  * convenience and illustrative purposes. They should, however, be used with
1099  * caution as the C language standard provides no guarantees about the alignment or
1100  * atomicity of device memory accesses. The recommended practice for writing
1101  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1102  * alt_write_word() functions.
1103  *
1104  * The struct declaration for register ALT_ACPIDMAP_VID5RD.
1105  */
1107 {
1108  uint32_t : 4; /* *UNDEFINED* */
1109  uint32_t user : 5; /* ARUSER value to SCU */
1110  uint32_t : 3; /* *UNDEFINED* */
1111  uint32_t page : 2; /* ARADDR 1GB Page Decoder */
1112  uint32_t : 2; /* *UNDEFINED* */
1113  uint32_t mid : 12; /* Remap Master ID */
1114  uint32_t : 3; /* *UNDEFINED* */
1115  uint32_t force : 1; /* Force Mapping */
1116 };
1117
1118 /* The typedef declaration for register ALT_ACPIDMAP_VID5RD. */
1119 typedef volatile struct ALT_ACPIDMAP_VID5RD_s ALT_ACPIDMAP_VID5RD_t;
1120 #endif /* __ASSEMBLY__ */
1121
1122 /* The byte offset of the ALT_ACPIDMAP_VID5RD register from the beginning of the component. */
1123 #define ALT_ACPIDMAP_VID5RD_OFST 0x18
1124
1125 /*
1126  * Register : Write AXI Master Mapping Register for Fixed Virtual ID 5 - vid5wr
1127  *
1128  * The Write AXI Master Mapping Register contains the USER, ADDR page, and ID
1129  * signals mapping values for particular transaction with 12-bit ID which locks the
1130  * fixed 3-bit virtual ID.
1131  *
1132  * Register Layout
1133  *
1134  * Bits | Access | Reset | Description
1135  * :--------|:-------|:------|:------------------------
1136  * [3:0] | ??? | 0x0 | *UNDEFINED*
1137  * [8:4] | RW | 0x0 | AWUSER value to SCU
1138  * [11:9] | ??? | 0x0 | *UNDEFINED*
1139  * [13:12] | RW | 0x0 | AWADDR 1GB Page Decoder
1140  * [15:14] | ??? | 0x0 | *UNDEFINED*
1141  * [27:16] | RW | 0x0 | Remap Master ID
1142  * [30:28] | ??? | 0x0 | *UNDEFINED*
1143  * [31] | RW | 0x0 | Force Mapping
1144  *
1145  */
1146 /*
1147  * Field : AWUSER value to SCU - user
1148  *
1149  * This value is propagated to SCU as AWUSERS.
1150  *
1151  * Field Access Macros:
1152  *
1153  */
1154 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID5WR_USER register field. */
1155 #define ALT_ACPIDMAP_VID5WR_USER_LSB 4
1156 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID5WR_USER register field. */
1157 #define ALT_ACPIDMAP_VID5WR_USER_MSB 8
1158 /* The width in bits of the ALT_ACPIDMAP_VID5WR_USER register field. */
1159 #define ALT_ACPIDMAP_VID5WR_USER_WIDTH 5
1160 /* The mask used to set the ALT_ACPIDMAP_VID5WR_USER register field value. */
1161 #define ALT_ACPIDMAP_VID5WR_USER_SET_MSK 0x000001f0
1162 /* The mask used to clear the ALT_ACPIDMAP_VID5WR_USER register field value. */
1163 #define ALT_ACPIDMAP_VID5WR_USER_CLR_MSK 0xfffffe0f
1164 /* The reset value of the ALT_ACPIDMAP_VID5WR_USER register field. */
1165 #define ALT_ACPIDMAP_VID5WR_USER_RESET 0x0
1166 /* Extracts the ALT_ACPIDMAP_VID5WR_USER field value from a register. */
1167 #define ALT_ACPIDMAP_VID5WR_USER_GET(value) (((value) & 0x000001f0) >> 4)
1168 /* Produces a ALT_ACPIDMAP_VID5WR_USER register field value suitable for setting the register. */
1169 #define ALT_ACPIDMAP_VID5WR_USER_SET(value) (((value) << 4) & 0x000001f0)
1170
1171 /*
1172  * Field : AWADDR 1GB Page Decoder - page
1173  *
1174  * AWADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
1175  *
1176  * Field Access Macros:
1177  *
1178  */
1179 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID5WR_PAGE register field. */
1180 #define ALT_ACPIDMAP_VID5WR_PAGE_LSB 12
1181 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID5WR_PAGE register field. */
1182 #define ALT_ACPIDMAP_VID5WR_PAGE_MSB 13
1183 /* The width in bits of the ALT_ACPIDMAP_VID5WR_PAGE register field. */
1184 #define ALT_ACPIDMAP_VID5WR_PAGE_WIDTH 2
1185 /* The mask used to set the ALT_ACPIDMAP_VID5WR_PAGE register field value. */
1186 #define ALT_ACPIDMAP_VID5WR_PAGE_SET_MSK 0x00003000
1187 /* The mask used to clear the ALT_ACPIDMAP_VID5WR_PAGE register field value. */
1188 #define ALT_ACPIDMAP_VID5WR_PAGE_CLR_MSK 0xffffcfff
1189 /* The reset value of the ALT_ACPIDMAP_VID5WR_PAGE register field. */
1190 #define ALT_ACPIDMAP_VID5WR_PAGE_RESET 0x0
1191 /* Extracts the ALT_ACPIDMAP_VID5WR_PAGE field value from a register. */
1192 #define ALT_ACPIDMAP_VID5WR_PAGE_GET(value) (((value) & 0x00003000) >> 12)
1193 /* Produces a ALT_ACPIDMAP_VID5WR_PAGE register field value suitable for setting the register. */
1194 #define ALT_ACPIDMAP_VID5WR_PAGE_SET(value) (((value) << 12) & 0x00003000)
1195
1196 /*
1197  * Field : Remap Master ID - mid
1198  *
1199  * The 12-bit ID of the master to remap to 3-bit virtual ID N, where N is the 3-bit
1200  * ID to use.
1201  *
1202  * Field Access Macros:
1203  *
1204  */
1205 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID5WR_MID register field. */
1206 #define ALT_ACPIDMAP_VID5WR_MID_LSB 16
1207 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID5WR_MID register field. */
1208 #define ALT_ACPIDMAP_VID5WR_MID_MSB 27
1209 /* The width in bits of the ALT_ACPIDMAP_VID5WR_MID register field. */
1210 #define ALT_ACPIDMAP_VID5WR_MID_WIDTH 12
1211 /* The mask used to set the ALT_ACPIDMAP_VID5WR_MID register field value. */
1212 #define ALT_ACPIDMAP_VID5WR_MID_SET_MSK 0x0fff0000
1213 /* The mask used to clear the ALT_ACPIDMAP_VID5WR_MID register field value. */
1214 #define ALT_ACPIDMAP_VID5WR_MID_CLR_MSK 0xf000ffff
1215 /* The reset value of the ALT_ACPIDMAP_VID5WR_MID register field. */
1216 #define ALT_ACPIDMAP_VID5WR_MID_RESET 0x0
1217 /* Extracts the ALT_ACPIDMAP_VID5WR_MID field value from a register. */
1218 #define ALT_ACPIDMAP_VID5WR_MID_GET(value) (((value) & 0x0fff0000) >> 16)
1219 /* Produces a ALT_ACPIDMAP_VID5WR_MID register field value suitable for setting the register. */
1220 #define ALT_ACPIDMAP_VID5WR_MID_SET(value) (((value) << 16) & 0x0fff0000)
1221
1222 /*
1223  * Field : Force Mapping - force
1224  *
1225  * Set to 1 to force the mapping between the 12-bit ID and 3-bit virtual ID N. Set
1226  * to 0 to allow the 3-bit ID N to be dynamically allocated.
1227  *
1228  * Field Access Macros:
1229  *
1230  */
1231 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID5WR_FORCE register field. */
1232 #define ALT_ACPIDMAP_VID5WR_FORCE_LSB 31
1233 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID5WR_FORCE register field. */
1234 #define ALT_ACPIDMAP_VID5WR_FORCE_MSB 31
1235 /* The width in bits of the ALT_ACPIDMAP_VID5WR_FORCE register field. */
1236 #define ALT_ACPIDMAP_VID5WR_FORCE_WIDTH 1
1237 /* The mask used to set the ALT_ACPIDMAP_VID5WR_FORCE register field value. */
1238 #define ALT_ACPIDMAP_VID5WR_FORCE_SET_MSK 0x80000000
1239 /* The mask used to clear the ALT_ACPIDMAP_VID5WR_FORCE register field value. */
1240 #define ALT_ACPIDMAP_VID5WR_FORCE_CLR_MSK 0x7fffffff
1241 /* The reset value of the ALT_ACPIDMAP_VID5WR_FORCE register field. */
1242 #define ALT_ACPIDMAP_VID5WR_FORCE_RESET 0x0
1243 /* Extracts the ALT_ACPIDMAP_VID5WR_FORCE field value from a register. */
1244 #define ALT_ACPIDMAP_VID5WR_FORCE_GET(value) (((value) & 0x80000000) >> 31)
1245 /* Produces a ALT_ACPIDMAP_VID5WR_FORCE register field value suitable for setting the register. */
1246 #define ALT_ACPIDMAP_VID5WR_FORCE_SET(value) (((value) << 31) & 0x80000000)
1247
1248 #ifndef __ASSEMBLY__
1249 /*
1250  * WARNING: The C register and register group struct declarations are provided for
1251  * convenience and illustrative purposes. They should, however, be used with
1252  * caution as the C language standard provides no guarantees about the alignment or
1253  * atomicity of device memory accesses. The recommended practice for writing
1254  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1255  * alt_write_word() functions.
1256  *
1257  * The struct declaration for register ALT_ACPIDMAP_VID5WR.
1258  */
1260 {
1261  uint32_t : 4; /* *UNDEFINED* */
1262  uint32_t user : 5; /* AWUSER value to SCU */
1263  uint32_t : 3; /* *UNDEFINED* */
1264  uint32_t page : 2; /* AWADDR 1GB Page Decoder */
1265  uint32_t : 2; /* *UNDEFINED* */
1266  uint32_t mid : 12; /* Remap Master ID */
1267  uint32_t : 3; /* *UNDEFINED* */
1268  uint32_t force : 1; /* Force Mapping */
1269 };
1270
1271 /* The typedef declaration for register ALT_ACPIDMAP_VID5WR. */
1272 typedef volatile struct ALT_ACPIDMAP_VID5WR_s ALT_ACPIDMAP_VID5WR_t;
1273 #endif /* __ASSEMBLY__ */
1274
1275 /* The byte offset of the ALT_ACPIDMAP_VID5WR register from the beginning of the component. */
1276 #define ALT_ACPIDMAP_VID5WR_OFST 0x1c
1277
1278 /*
1279  * Register : Read AXI Master Mapping Register for Fixed Virtual ID 6 - vid6rd
1280  *
1281  * The Read AXI Master Mapping Register contains the USER, ADDR page, and ID
1282  * signals mapping values for particular transaction with 12-bit ID which locks the
1283  * fixed 3-bit virtual ID.
1284  *
1285  * Register Layout
1286  *
1287  * Bits | Access | Reset | Description
1288  * :--------|:-------|:------|:------------------------
1289  * [3:0] | ??? | 0x0 | *UNDEFINED*
1290  * [8:4] | RW | 0x0 | ARUSER value to SCU
1291  * [11:9] | ??? | 0x0 | *UNDEFINED*
1292  * [13:12] | RW | 0x0 | ARADDR 1GB Page Decoder
1293  * [15:14] | ??? | 0x0 | *UNDEFINED*
1294  * [27:16] | RW | 0x0 | Remap Master ID
1295  * [30:28] | ??? | 0x0 | *UNDEFINED*
1296  * [31] | RW | 0x0 | Force Mapping
1297  *
1298  */
1299 /*
1300  * Field : ARUSER value to SCU - user
1301  *
1302  * This value is propagated to SCU as ARUSERS.
1303  *
1304  * Field Access Macros:
1305  *
1306  */
1307 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID6RD_USER register field. */
1308 #define ALT_ACPIDMAP_VID6RD_USER_LSB 4
1309 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID6RD_USER register field. */
1310 #define ALT_ACPIDMAP_VID6RD_USER_MSB 8
1311 /* The width in bits of the ALT_ACPIDMAP_VID6RD_USER register field. */
1312 #define ALT_ACPIDMAP_VID6RD_USER_WIDTH 5
1313 /* The mask used to set the ALT_ACPIDMAP_VID6RD_USER register field value. */
1314 #define ALT_ACPIDMAP_VID6RD_USER_SET_MSK 0x000001f0
1315 /* The mask used to clear the ALT_ACPIDMAP_VID6RD_USER register field value. */
1316 #define ALT_ACPIDMAP_VID6RD_USER_CLR_MSK 0xfffffe0f
1317 /* The reset value of the ALT_ACPIDMAP_VID6RD_USER register field. */
1318 #define ALT_ACPIDMAP_VID6RD_USER_RESET 0x0
1319 /* Extracts the ALT_ACPIDMAP_VID6RD_USER field value from a register. */
1320 #define ALT_ACPIDMAP_VID6RD_USER_GET(value) (((value) & 0x000001f0) >> 4)
1321 /* Produces a ALT_ACPIDMAP_VID6RD_USER register field value suitable for setting the register. */
1322 #define ALT_ACPIDMAP_VID6RD_USER_SET(value) (((value) << 4) & 0x000001f0)
1323
1324 /*
1325  * Field : ARADDR 1GB Page Decoder - page
1326  *
1327  * ARADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
1328  *
1329  * Field Access Macros:
1330  *
1331  */
1332 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID6RD_PAGE register field. */
1333 #define ALT_ACPIDMAP_VID6RD_PAGE_LSB 12
1334 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID6RD_PAGE register field. */
1335 #define ALT_ACPIDMAP_VID6RD_PAGE_MSB 13
1336 /* The width in bits of the ALT_ACPIDMAP_VID6RD_PAGE register field. */
1337 #define ALT_ACPIDMAP_VID6RD_PAGE_WIDTH 2
1338 /* The mask used to set the ALT_ACPIDMAP_VID6RD_PAGE register field value. */
1339 #define ALT_ACPIDMAP_VID6RD_PAGE_SET_MSK 0x00003000
1340 /* The mask used to clear the ALT_ACPIDMAP_VID6RD_PAGE register field value. */
1341 #define ALT_ACPIDMAP_VID6RD_PAGE_CLR_MSK 0xffffcfff
1342 /* The reset value of the ALT_ACPIDMAP_VID6RD_PAGE register field. */
1343 #define ALT_ACPIDMAP_VID6RD_PAGE_RESET 0x0
1344 /* Extracts the ALT_ACPIDMAP_VID6RD_PAGE field value from a register. */
1345 #define ALT_ACPIDMAP_VID6RD_PAGE_GET(value) (((value) & 0x00003000) >> 12)
1346 /* Produces a ALT_ACPIDMAP_VID6RD_PAGE register field value suitable for setting the register. */
1347 #define ALT_ACPIDMAP_VID6RD_PAGE_SET(value) (((value) << 12) & 0x00003000)
1348
1349 /*
1350  * Field : Remap Master ID - mid
1351  *
1352  * The 12-bit ID of the master to remap to 3-bit virtual ID N, where N is the 3-bit
1353  * ID to use.
1354  *
1355  * Field Access Macros:
1356  *
1357  */
1358 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID6RD_MID register field. */
1359 #define ALT_ACPIDMAP_VID6RD_MID_LSB 16
1360 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID6RD_MID register field. */
1361 #define ALT_ACPIDMAP_VID6RD_MID_MSB 27
1362 /* The width in bits of the ALT_ACPIDMAP_VID6RD_MID register field. */
1363 #define ALT_ACPIDMAP_VID6RD_MID_WIDTH 12
1364 /* The mask used to set the ALT_ACPIDMAP_VID6RD_MID register field value. */
1365 #define ALT_ACPIDMAP_VID6RD_MID_SET_MSK 0x0fff0000
1366 /* The mask used to clear the ALT_ACPIDMAP_VID6RD_MID register field value. */
1367 #define ALT_ACPIDMAP_VID6RD_MID_CLR_MSK 0xf000ffff
1368 /* The reset value of the ALT_ACPIDMAP_VID6RD_MID register field. */
1369 #define ALT_ACPIDMAP_VID6RD_MID_RESET 0x0
1370 /* Extracts the ALT_ACPIDMAP_VID6RD_MID field value from a register. */
1371 #define ALT_ACPIDMAP_VID6RD_MID_GET(value) (((value) & 0x0fff0000) >> 16)
1372 /* Produces a ALT_ACPIDMAP_VID6RD_MID register field value suitable for setting the register. */
1373 #define ALT_ACPIDMAP_VID6RD_MID_SET(value) (((value) << 16) & 0x0fff0000)
1374
1375 /*
1376  * Field : Force Mapping - force
1377  *
1378  * Set to 1 to force the mapping between the 12-bit ID and 3-bit virtual ID N. Set
1379  * to 0 to allow the 3-bit ID N to be dynamically allocated.
1380  *
1381  * Field Access Macros:
1382  *
1383  */
1384 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID6RD_FORCE register field. */
1385 #define ALT_ACPIDMAP_VID6RD_FORCE_LSB 31
1386 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID6RD_FORCE register field. */
1387 #define ALT_ACPIDMAP_VID6RD_FORCE_MSB 31
1388 /* The width in bits of the ALT_ACPIDMAP_VID6RD_FORCE register field. */
1389 #define ALT_ACPIDMAP_VID6RD_FORCE_WIDTH 1
1390 /* The mask used to set the ALT_ACPIDMAP_VID6RD_FORCE register field value. */
1391 #define ALT_ACPIDMAP_VID6RD_FORCE_SET_MSK 0x80000000
1392 /* The mask used to clear the ALT_ACPIDMAP_VID6RD_FORCE register field value. */
1393 #define ALT_ACPIDMAP_VID6RD_FORCE_CLR_MSK 0x7fffffff
1394 /* The reset value of the ALT_ACPIDMAP_VID6RD_FORCE register field. */
1395 #define ALT_ACPIDMAP_VID6RD_FORCE_RESET 0x0
1396 /* Extracts the ALT_ACPIDMAP_VID6RD_FORCE field value from a register. */
1397 #define ALT_ACPIDMAP_VID6RD_FORCE_GET(value) (((value) & 0x80000000) >> 31)
1398 /* Produces a ALT_ACPIDMAP_VID6RD_FORCE register field value suitable for setting the register. */
1399 #define ALT_ACPIDMAP_VID6RD_FORCE_SET(value) (((value) << 31) & 0x80000000)
1400
1401 #ifndef __ASSEMBLY__
1402 /*
1403  * WARNING: The C register and register group struct declarations are provided for
1404  * convenience and illustrative purposes. They should, however, be used with
1405  * caution as the C language standard provides no guarantees about the alignment or
1406  * atomicity of device memory accesses. The recommended practice for writing
1407  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1408  * alt_write_word() functions.
1409  *
1410  * The struct declaration for register ALT_ACPIDMAP_VID6RD.
1411  */
1413 {
1414  uint32_t : 4; /* *UNDEFINED* */
1415  uint32_t user : 5; /* ARUSER value to SCU */
1416  uint32_t : 3; /* *UNDEFINED* */
1417  uint32_t page : 2; /* ARADDR 1GB Page Decoder */
1418  uint32_t : 2; /* *UNDEFINED* */
1419  uint32_t mid : 12; /* Remap Master ID */
1420  uint32_t : 3; /* *UNDEFINED* */
1421  uint32_t force : 1; /* Force Mapping */
1422 };
1423
1424 /* The typedef declaration for register ALT_ACPIDMAP_VID6RD. */
1425 typedef volatile struct ALT_ACPIDMAP_VID6RD_s ALT_ACPIDMAP_VID6RD_t;
1426 #endif /* __ASSEMBLY__ */
1427
1428 /* The byte offset of the ALT_ACPIDMAP_VID6RD register from the beginning of the component. */
1429 #define ALT_ACPIDMAP_VID6RD_OFST 0x20
1430
1431 /*
1432  * Register : Write AXI Master Mapping Register for Fixed Virtual ID 6 - vid6wr
1433  *
1434  * The Write AXI Master Mapping Register contains the USER, ADDR page, and ID
1435  * signals mapping values for particular transaction with 12-bit ID which locks the
1436  * fixed 3-bit virtual ID.
1437  *
1438  * Register Layout
1439  *
1440  * Bits | Access | Reset | Description
1441  * :--------|:-------|:------|:------------------------
1442  * [3:0] | ??? | 0x0 | *UNDEFINED*
1443  * [8:4] | RW | 0x0 | AWUSER value to SCU
1444  * [11:9] | ??? | 0x0 | *UNDEFINED*
1445  * [13:12] | RW | 0x0 | AWADDR 1GB Page Decoder
1446  * [15:14] | ??? | 0x0 | *UNDEFINED*
1447  * [27:16] | RW | 0x0 | Remap Master ID
1448  * [30:28] | ??? | 0x0 | *UNDEFINED*
1449  * [31] | RW | 0x0 | Force Mapping
1450  *
1451  */
1452 /*
1453  * Field : AWUSER value to SCU - user
1454  *
1455  * This value is propagated to SCU as AWUSERS.
1456  *
1457  * Field Access Macros:
1458  *
1459  */
1460 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID6WR_USER register field. */
1461 #define ALT_ACPIDMAP_VID6WR_USER_LSB 4
1462 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID6WR_USER register field. */
1463 #define ALT_ACPIDMAP_VID6WR_USER_MSB 8
1464 /* The width in bits of the ALT_ACPIDMAP_VID6WR_USER register field. */
1465 #define ALT_ACPIDMAP_VID6WR_USER_WIDTH 5
1466 /* The mask used to set the ALT_ACPIDMAP_VID6WR_USER register field value. */
1467 #define ALT_ACPIDMAP_VID6WR_USER_SET_MSK 0x000001f0
1468 /* The mask used to clear the ALT_ACPIDMAP_VID6WR_USER register field value. */
1469 #define ALT_ACPIDMAP_VID6WR_USER_CLR_MSK 0xfffffe0f
1470 /* The reset value of the ALT_ACPIDMAP_VID6WR_USER register field. */
1471 #define ALT_ACPIDMAP_VID6WR_USER_RESET 0x0
1472 /* Extracts the ALT_ACPIDMAP_VID6WR_USER field value from a register. */
1473 #define ALT_ACPIDMAP_VID6WR_USER_GET(value) (((value) & 0x000001f0) >> 4)
1474 /* Produces a ALT_ACPIDMAP_VID6WR_USER register field value suitable for setting the register. */
1475 #define ALT_ACPIDMAP_VID6WR_USER_SET(value) (((value) << 4) & 0x000001f0)
1476
1477 /*
1478  * Field : AWADDR 1GB Page Decoder - page
1479  *
1480  * AWADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
1481  *
1482  * Field Access Macros:
1483  *
1484  */
1485 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID6WR_PAGE register field. */
1486 #define ALT_ACPIDMAP_VID6WR_PAGE_LSB 12
1487 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID6WR_PAGE register field. */
1488 #define ALT_ACPIDMAP_VID6WR_PAGE_MSB 13
1489 /* The width in bits of the ALT_ACPIDMAP_VID6WR_PAGE register field. */
1490 #define ALT_ACPIDMAP_VID6WR_PAGE_WIDTH 2
1491 /* The mask used to set the ALT_ACPIDMAP_VID6WR_PAGE register field value. */
1492 #define ALT_ACPIDMAP_VID6WR_PAGE_SET_MSK 0x00003000
1493 /* The mask used to clear the ALT_ACPIDMAP_VID6WR_PAGE register field value. */
1494 #define ALT_ACPIDMAP_VID6WR_PAGE_CLR_MSK 0xffffcfff
1495 /* The reset value of the ALT_ACPIDMAP_VID6WR_PAGE register field. */
1496 #define ALT_ACPIDMAP_VID6WR_PAGE_RESET 0x0
1497 /* Extracts the ALT_ACPIDMAP_VID6WR_PAGE field value from a register. */
1498 #define ALT_ACPIDMAP_VID6WR_PAGE_GET(value) (((value) & 0x00003000) >> 12)
1499 /* Produces a ALT_ACPIDMAP_VID6WR_PAGE register field value suitable for setting the register. */
1500 #define ALT_ACPIDMAP_VID6WR_PAGE_SET(value) (((value) << 12) & 0x00003000)
1501
1502 /*
1503  * Field : Remap Master ID - mid
1504  *
1505  * The 12-bit ID of the master to remap to 3-bit virtual ID N, where N is the 3-bit
1506  * ID to use.
1507  *
1508  * Field Access Macros:
1509  *
1510  */
1511 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID6WR_MID register field. */
1512 #define ALT_ACPIDMAP_VID6WR_MID_LSB 16
1513 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID6WR_MID register field. */
1514 #define ALT_ACPIDMAP_VID6WR_MID_MSB 27
1515 /* The width in bits of the ALT_ACPIDMAP_VID6WR_MID register field. */
1516 #define ALT_ACPIDMAP_VID6WR_MID_WIDTH 12
1517 /* The mask used to set the ALT_ACPIDMAP_VID6WR_MID register field value. */
1518 #define ALT_ACPIDMAP_VID6WR_MID_SET_MSK 0x0fff0000
1519 /* The mask used to clear the ALT_ACPIDMAP_VID6WR_MID register field value. */
1520 #define ALT_ACPIDMAP_VID6WR_MID_CLR_MSK 0xf000ffff
1521 /* The reset value of the ALT_ACPIDMAP_VID6WR_MID register field. */
1522 #define ALT_ACPIDMAP_VID6WR_MID_RESET 0x0
1523 /* Extracts the ALT_ACPIDMAP_VID6WR_MID field value from a register. */
1524 #define ALT_ACPIDMAP_VID6WR_MID_GET(value) (((value) & 0x0fff0000) >> 16)
1525 /* Produces a ALT_ACPIDMAP_VID6WR_MID register field value suitable for setting the register. */
1526 #define ALT_ACPIDMAP_VID6WR_MID_SET(value) (((value) << 16) & 0x0fff0000)
1527
1528 /*
1529  * Field : Force Mapping - force
1530  *
1531  * Set to 1 to force the mapping between the 12-bit ID and 3-bit virtual ID N. Set
1532  * to 0 to allow the 3-bit ID N to be dynamically allocated.
1533  *
1534  * Field Access Macros:
1535  *
1536  */
1537 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID6WR_FORCE register field. */
1538 #define ALT_ACPIDMAP_VID6WR_FORCE_LSB 31
1539 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID6WR_FORCE register field. */
1540 #define ALT_ACPIDMAP_VID6WR_FORCE_MSB 31
1541 /* The width in bits of the ALT_ACPIDMAP_VID6WR_FORCE register field. */
1542 #define ALT_ACPIDMAP_VID6WR_FORCE_WIDTH 1
1543 /* The mask used to set the ALT_ACPIDMAP_VID6WR_FORCE register field value. */
1544 #define ALT_ACPIDMAP_VID6WR_FORCE_SET_MSK 0x80000000
1545 /* The mask used to clear the ALT_ACPIDMAP_VID6WR_FORCE register field value. */
1546 #define ALT_ACPIDMAP_VID6WR_FORCE_CLR_MSK 0x7fffffff
1547 /* The reset value of the ALT_ACPIDMAP_VID6WR_FORCE register field. */
1548 #define ALT_ACPIDMAP_VID6WR_FORCE_RESET 0x0
1549 /* Extracts the ALT_ACPIDMAP_VID6WR_FORCE field value from a register. */
1550 #define ALT_ACPIDMAP_VID6WR_FORCE_GET(value) (((value) & 0x80000000) >> 31)
1551 /* Produces a ALT_ACPIDMAP_VID6WR_FORCE register field value suitable for setting the register. */
1552 #define ALT_ACPIDMAP_VID6WR_FORCE_SET(value) (((value) << 31) & 0x80000000)
1553
1554 #ifndef __ASSEMBLY__
1555 /*
1556  * WARNING: The C register and register group struct declarations are provided for
1557  * convenience and illustrative purposes. They should, however, be used with
1558  * caution as the C language standard provides no guarantees about the alignment or
1559  * atomicity of device memory accesses. The recommended practice for writing
1560  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1561  * alt_write_word() functions.
1562  *
1563  * The struct declaration for register ALT_ACPIDMAP_VID6WR.
1564  */
1566 {
1567  uint32_t : 4; /* *UNDEFINED* */
1568  uint32_t user : 5; /* AWUSER value to SCU */
1569  uint32_t : 3; /* *UNDEFINED* */
1570  uint32_t page : 2; /* AWADDR 1GB Page Decoder */
1571  uint32_t : 2; /* *UNDEFINED* */
1572  uint32_t mid : 12; /* Remap Master ID */
1573  uint32_t : 3; /* *UNDEFINED* */
1574  uint32_t force : 1; /* Force Mapping */
1575 };
1576
1577 /* The typedef declaration for register ALT_ACPIDMAP_VID6WR. */
1578 typedef volatile struct ALT_ACPIDMAP_VID6WR_s ALT_ACPIDMAP_VID6WR_t;
1579 #endif /* __ASSEMBLY__ */
1580
1581 /* The byte offset of the ALT_ACPIDMAP_VID6WR register from the beginning of the component. */
1582 #define ALT_ACPIDMAP_VID6WR_OFST 0x24
1583
1584 /*
1585  * Register : Read AXI Master Mapping Register for Dynamic Virtual ID Remap - dynrd
1586  *
1587  * The Read AXI Master Mapping Register contains the USER, and ADDR page signals
1588  * mapping values for transaction that dynamically remapped to one of the available
1589  * 3-bit virtual IDs.
1590  *
1591  * Register Layout
1592  *
1593  * Bits | Access | Reset | Description
1594  * :--------|:-------|:------|:------------------------
1595  * [3:0] | ??? | 0x0 | *UNDEFINED*
1596  * [8:4] | RW | 0x0 | ARUSER value to SCU
1597  * [11:9] | ??? | 0x0 | *UNDEFINED*
1598  * [13:12] | RW | 0x0 | ARADDR 1GB Page Decoder
1599  * [31:14] | ??? | 0x0 | *UNDEFINED*
1600  *
1601  */
1602 /*
1603  * Field : ARUSER value to SCU - user
1604  *
1605  * This value is propagated to SCU as ARUSERS.
1606  *
1607  * Field Access Macros:
1608  *
1609  */
1610 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_DYNRD_USER register field. */
1611 #define ALT_ACPIDMAP_DYNRD_USER_LSB 4
1612 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_DYNRD_USER register field. */
1613 #define ALT_ACPIDMAP_DYNRD_USER_MSB 8
1614 /* The width in bits of the ALT_ACPIDMAP_DYNRD_USER register field. */
1615 #define ALT_ACPIDMAP_DYNRD_USER_WIDTH 5
1616 /* The mask used to set the ALT_ACPIDMAP_DYNRD_USER register field value. */
1617 #define ALT_ACPIDMAP_DYNRD_USER_SET_MSK 0x000001f0
1618 /* The mask used to clear the ALT_ACPIDMAP_DYNRD_USER register field value. */
1619 #define ALT_ACPIDMAP_DYNRD_USER_CLR_MSK 0xfffffe0f
1620 /* The reset value of the ALT_ACPIDMAP_DYNRD_USER register field. */
1621 #define ALT_ACPIDMAP_DYNRD_USER_RESET 0x0
1622 /* Extracts the ALT_ACPIDMAP_DYNRD_USER field value from a register. */
1623 #define ALT_ACPIDMAP_DYNRD_USER_GET(value) (((value) & 0x000001f0) >> 4)
1624 /* Produces a ALT_ACPIDMAP_DYNRD_USER register field value suitable for setting the register. */
1625 #define ALT_ACPIDMAP_DYNRD_USER_SET(value) (((value) << 4) & 0x000001f0)
1626
1627 /*
1628  * Field : ARADDR 1GB Page Decoder - page
1629  *
1630  * ARADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
1631  *
1632  * Field Access Macros:
1633  *
1634  */
1635 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_DYNRD_PAGE register field. */
1636 #define ALT_ACPIDMAP_DYNRD_PAGE_LSB 12
1637 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_DYNRD_PAGE register field. */
1638 #define ALT_ACPIDMAP_DYNRD_PAGE_MSB 13
1639 /* The width in bits of the ALT_ACPIDMAP_DYNRD_PAGE register field. */
1640 #define ALT_ACPIDMAP_DYNRD_PAGE_WIDTH 2
1641 /* The mask used to set the ALT_ACPIDMAP_DYNRD_PAGE register field value. */
1642 #define ALT_ACPIDMAP_DYNRD_PAGE_SET_MSK 0x00003000
1643 /* The mask used to clear the ALT_ACPIDMAP_DYNRD_PAGE register field value. */
1644 #define ALT_ACPIDMAP_DYNRD_PAGE_CLR_MSK 0xffffcfff
1645 /* The reset value of the ALT_ACPIDMAP_DYNRD_PAGE register field. */
1646 #define ALT_ACPIDMAP_DYNRD_PAGE_RESET 0x0
1647 /* Extracts the ALT_ACPIDMAP_DYNRD_PAGE field value from a register. */
1648 #define ALT_ACPIDMAP_DYNRD_PAGE_GET(value) (((value) & 0x00003000) >> 12)
1649 /* Produces a ALT_ACPIDMAP_DYNRD_PAGE register field value suitable for setting the register. */
1650 #define ALT_ACPIDMAP_DYNRD_PAGE_SET(value) (((value) << 12) & 0x00003000)
1651
1652 #ifndef __ASSEMBLY__
1653 /*
1654  * WARNING: The C register and register group struct declarations are provided for
1655  * convenience and illustrative purposes. They should, however, be used with
1656  * caution as the C language standard provides no guarantees about the alignment or
1657  * atomicity of device memory accesses. The recommended practice for writing
1658  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1659  * alt_write_word() functions.
1660  *
1661  * The struct declaration for register ALT_ACPIDMAP_DYNRD.
1662  */
1664 {
1665  uint32_t : 4; /* *UNDEFINED* */
1666  uint32_t user : 5; /* ARUSER value to SCU */
1667  uint32_t : 3; /* *UNDEFINED* */
1668  uint32_t page : 2; /* ARADDR 1GB Page Decoder */
1669  uint32_t : 18; /* *UNDEFINED* */
1670 };
1671
1672 /* The typedef declaration for register ALT_ACPIDMAP_DYNRD. */
1673 typedef volatile struct ALT_ACPIDMAP_DYNRD_s ALT_ACPIDMAP_DYNRD_t;
1674 #endif /* __ASSEMBLY__ */
1675
1676 /* The byte offset of the ALT_ACPIDMAP_DYNRD register from the beginning of the component. */
1677 #define ALT_ACPIDMAP_DYNRD_OFST 0x28
1678
1679 /*
1680  * Register : Write AXI Master Mapping Register for Dynamic Virtual ID Remap - dynwr
1681  *
1682  * The Write AXI Master Mapping Register contains the USER, and ADDR page signals
1683  * mapping values for transaction that dynamically remapped to one of the available
1684  * 3-bit virtual IDs.
1685  *
1686  * Register Layout
1687  *
1688  * Bits | Access | Reset | Description
1689  * :--------|:-------|:------|:------------------------
1690  * [3:0] | ??? | 0x0 | *UNDEFINED*
1691  * [8:4] | RW | 0x0 | AWUSER value to SCU
1692  * [11:9] | ??? | 0x0 | *UNDEFINED*
1693  * [13:12] | RW | 0x0 | AWADDR 1GB Page Decoder
1694  * [31:14] | ??? | 0x0 | *UNDEFINED*
1695  *
1696  */
1697 /*
1698  * Field : AWUSER value to SCU - user
1699  *
1700  * This value is propagated to SCU as AWUSERS.
1701  *
1702  * Field Access Macros:
1703  *
1704  */
1705 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_DYNWR_USER register field. */
1706 #define ALT_ACPIDMAP_DYNWR_USER_LSB 4
1707 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_DYNWR_USER register field. */
1708 #define ALT_ACPIDMAP_DYNWR_USER_MSB 8
1709 /* The width in bits of the ALT_ACPIDMAP_DYNWR_USER register field. */
1710 #define ALT_ACPIDMAP_DYNWR_USER_WIDTH 5
1711 /* The mask used to set the ALT_ACPIDMAP_DYNWR_USER register field value. */
1712 #define ALT_ACPIDMAP_DYNWR_USER_SET_MSK 0x000001f0
1713 /* The mask used to clear the ALT_ACPIDMAP_DYNWR_USER register field value. */
1714 #define ALT_ACPIDMAP_DYNWR_USER_CLR_MSK 0xfffffe0f
1715 /* The reset value of the ALT_ACPIDMAP_DYNWR_USER register field. */
1716 #define ALT_ACPIDMAP_DYNWR_USER_RESET 0x0
1717 /* Extracts the ALT_ACPIDMAP_DYNWR_USER field value from a register. */
1718 #define ALT_ACPIDMAP_DYNWR_USER_GET(value) (((value) & 0x000001f0) >> 4)
1719 /* Produces a ALT_ACPIDMAP_DYNWR_USER register field value suitable for setting the register. */
1720 #define ALT_ACPIDMAP_DYNWR_USER_SET(value) (((value) << 4) & 0x000001f0)
1721
1722 /*
1723  * Field : AWADDR 1GB Page Decoder - page
1724  *
1725  * AWADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
1726  *
1727  * Field Access Macros:
1728  *
1729  */
1730 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_DYNWR_PAGE register field. */
1731 #define ALT_ACPIDMAP_DYNWR_PAGE_LSB 12
1732 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_DYNWR_PAGE register field. */
1733 #define ALT_ACPIDMAP_DYNWR_PAGE_MSB 13
1734 /* The width in bits of the ALT_ACPIDMAP_DYNWR_PAGE register field. */
1735 #define ALT_ACPIDMAP_DYNWR_PAGE_WIDTH 2
1736 /* The mask used to set the ALT_ACPIDMAP_DYNWR_PAGE register field value. */
1737 #define ALT_ACPIDMAP_DYNWR_PAGE_SET_MSK 0x00003000
1738 /* The mask used to clear the ALT_ACPIDMAP_DYNWR_PAGE register field value. */
1739 #define ALT_ACPIDMAP_DYNWR_PAGE_CLR_MSK 0xffffcfff
1740 /* The reset value of the ALT_ACPIDMAP_DYNWR_PAGE register field. */
1741 #define ALT_ACPIDMAP_DYNWR_PAGE_RESET 0x0
1742 /* Extracts the ALT_ACPIDMAP_DYNWR_PAGE field value from a register. */
1743 #define ALT_ACPIDMAP_DYNWR_PAGE_GET(value) (((value) & 0x00003000) >> 12)
1744 /* Produces a ALT_ACPIDMAP_DYNWR_PAGE register field value suitable for setting the register. */
1745 #define ALT_ACPIDMAP_DYNWR_PAGE_SET(value) (((value) << 12) & 0x00003000)
1746
1747 #ifndef __ASSEMBLY__
1748 /*
1749  * WARNING: The C register and register group struct declarations are provided for
1750  * convenience and illustrative purposes. They should, however, be used with
1751  * caution as the C language standard provides no guarantees about the alignment or
1752  * atomicity of device memory accesses. The recommended practice for writing
1753  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1754  * alt_write_word() functions.
1755  *
1756  * The struct declaration for register ALT_ACPIDMAP_DYNWR.
1757  */
1759 {
1760  uint32_t : 4; /* *UNDEFINED* */
1761  uint32_t user : 5; /* AWUSER value to SCU */
1762  uint32_t : 3; /* *UNDEFINED* */
1763  uint32_t page : 2; /* AWADDR 1GB Page Decoder */
1764  uint32_t : 18; /* *UNDEFINED* */
1765 };
1766
1767 /* The typedef declaration for register ALT_ACPIDMAP_DYNWR. */
1768 typedef volatile struct ALT_ACPIDMAP_DYNWR_s ALT_ACPIDMAP_DYNWR_t;
1769 #endif /* __ASSEMBLY__ */
1770
1771 /* The byte offset of the ALT_ACPIDMAP_DYNWR register from the beginning of the component. */
1772 #define ALT_ACPIDMAP_DYNWR_OFST 0x2c
1773
1774 /*
1775  * Register : Read AXI Master Mapping Status Register for Fixed Virtual ID 2 - vid2rd_s
1776  *
1777  * The Read AXI Master Mapping Status Register contains the configured USER, ADDR
1778  * page, and ID signals mapping values for particular transaction with 12-bit ID
1779  * which locks the fixed 3-bit virtual ID.
1780  *
1781  * Register Layout
1782  *
1783  * Bits | Access | Reset | Description
1784  * :--------|:-------|:--------|:--------------------------------------
1785  * [3:0] | ??? | 0x0 | *UNDEFINED*
1786  * [8:4] | R | 0x1 | ARUSER value to SCU for ID=2 (Status)
1787  * [11:9] | ??? | 0x0 | *UNDEFINED*
1788  * [13:12] | R | Unknown | ARADDR 1GB Page Decoder (Status)
1789  * [15:14] | ??? | 0x0 | *UNDEFINED*
1790  * [27:16] | R | 0x4 | Remap Master ID = DAP ID (Status)
1791  * [30:28] | ??? | 0x0 | *UNDEFINED*
1792  * [31] | R | 0x1 | Force Mapping for ID=2 (Status)
1793  *
1794  */
1795 /*
1796  * Field : ARUSER value to SCU for ID=2 (Status) - user
1797  *
1798  * This value is propagated to SCU as ARUSERS.
1799  *
1800  * Field Access Macros:
1801  *
1802  */
1803 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID2RD_S_USER register field. */
1804 #define ALT_ACPIDMAP_VID2RD_S_USER_LSB 4
1805 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID2RD_S_USER register field. */
1806 #define ALT_ACPIDMAP_VID2RD_S_USER_MSB 8
1807 /* The width in bits of the ALT_ACPIDMAP_VID2RD_S_USER register field. */
1808 #define ALT_ACPIDMAP_VID2RD_S_USER_WIDTH 5
1809 /* The mask used to set the ALT_ACPIDMAP_VID2RD_S_USER register field value. */
1810 #define ALT_ACPIDMAP_VID2RD_S_USER_SET_MSK 0x000001f0
1811 /* The mask used to clear the ALT_ACPIDMAP_VID2RD_S_USER register field value. */
1812 #define ALT_ACPIDMAP_VID2RD_S_USER_CLR_MSK 0xfffffe0f
1813 /* The reset value of the ALT_ACPIDMAP_VID2RD_S_USER register field. */
1814 #define ALT_ACPIDMAP_VID2RD_S_USER_RESET 0x1
1815 /* Extracts the ALT_ACPIDMAP_VID2RD_S_USER field value from a register. */
1816 #define ALT_ACPIDMAP_VID2RD_S_USER_GET(value) (((value) & 0x000001f0) >> 4)
1817 /* Produces a ALT_ACPIDMAP_VID2RD_S_USER register field value suitable for setting the register. */
1818 #define ALT_ACPIDMAP_VID2RD_S_USER_SET(value) (((value) << 4) & 0x000001f0)
1819
1820 /*
1821  * Field : ARADDR 1GB Page Decoder (Status) - page
1822  *
1823  * ARADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
1824  *
1825  * Field Access Macros:
1826  *
1827  */
1828 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID2RD_S_PAGE register field. */
1829 #define ALT_ACPIDMAP_VID2RD_S_PAGE_LSB 12
1830 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID2RD_S_PAGE register field. */
1831 #define ALT_ACPIDMAP_VID2RD_S_PAGE_MSB 13
1832 /* The width in bits of the ALT_ACPIDMAP_VID2RD_S_PAGE register field. */
1833 #define ALT_ACPIDMAP_VID2RD_S_PAGE_WIDTH 2
1834 /* The mask used to set the ALT_ACPIDMAP_VID2RD_S_PAGE register field value. */
1835 #define ALT_ACPIDMAP_VID2RD_S_PAGE_SET_MSK 0x00003000
1836 /* The mask used to clear the ALT_ACPIDMAP_VID2RD_S_PAGE register field value. */
1837 #define ALT_ACPIDMAP_VID2RD_S_PAGE_CLR_MSK 0xffffcfff
1838 /* The reset value of the ALT_ACPIDMAP_VID2RD_S_PAGE register field is UNKNOWN. */
1839 #define ALT_ACPIDMAP_VID2RD_S_PAGE_RESET 0x0
1840 /* Extracts the ALT_ACPIDMAP_VID2RD_S_PAGE field value from a register. */
1841 #define ALT_ACPIDMAP_VID2RD_S_PAGE_GET(value) (((value) & 0x00003000) >> 12)
1842 /* Produces a ALT_ACPIDMAP_VID2RD_S_PAGE register field value suitable for setting the register. */
1843 #define ALT_ACPIDMAP_VID2RD_S_PAGE_SET(value) (((value) << 12) & 0x00003000)
1844
1845 /*
1846  * Field : Remap Master ID = DAP ID (Status) - mid
1847  *
1848  * The 12-bit ID of the master to remap to 3-bit virtual ID N, where N is the 3-bit
1849  * ID to use.
1850  *
1851  * Field Access Macros:
1852  *
1853  */
1854 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID2RD_S_MID register field. */
1855 #define ALT_ACPIDMAP_VID2RD_S_MID_LSB 16
1856 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID2RD_S_MID register field. */
1857 #define ALT_ACPIDMAP_VID2RD_S_MID_MSB 27
1858 /* The width in bits of the ALT_ACPIDMAP_VID2RD_S_MID register field. */
1859 #define ALT_ACPIDMAP_VID2RD_S_MID_WIDTH 12
1860 /* The mask used to set the ALT_ACPIDMAP_VID2RD_S_MID register field value. */
1861 #define ALT_ACPIDMAP_VID2RD_S_MID_SET_MSK 0x0fff0000
1862 /* The mask used to clear the ALT_ACPIDMAP_VID2RD_S_MID register field value. */
1863 #define ALT_ACPIDMAP_VID2RD_S_MID_CLR_MSK 0xf000ffff
1864 /* The reset value of the ALT_ACPIDMAP_VID2RD_S_MID register field. */
1865 #define ALT_ACPIDMAP_VID2RD_S_MID_RESET 0x4
1866 /* Extracts the ALT_ACPIDMAP_VID2RD_S_MID field value from a register. */
1867 #define ALT_ACPIDMAP_VID2RD_S_MID_GET(value) (((value) & 0x0fff0000) >> 16)
1868 /* Produces a ALT_ACPIDMAP_VID2RD_S_MID register field value suitable for setting the register. */
1869 #define ALT_ACPIDMAP_VID2RD_S_MID_SET(value) (((value) << 16) & 0x0fff0000)
1870
1871 /*
1872  * Field : Force Mapping for ID=2 (Status) - force
1873  *
1874  * Set to 1 to force the mapping between the 12-bit ID and 3-bit virtual ID N. Set
1875  * to 0 to allow the 3-bit ID N to be dynamically allocated.
1876  *
1877  * Field Access Macros:
1878  *
1879  */
1880 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID2RD_S_FORCE register field. */
1881 #define ALT_ACPIDMAP_VID2RD_S_FORCE_LSB 31
1882 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID2RD_S_FORCE register field. */
1883 #define ALT_ACPIDMAP_VID2RD_S_FORCE_MSB 31
1884 /* The width in bits of the ALT_ACPIDMAP_VID2RD_S_FORCE register field. */
1885 #define ALT_ACPIDMAP_VID2RD_S_FORCE_WIDTH 1
1886 /* The mask used to set the ALT_ACPIDMAP_VID2RD_S_FORCE register field value. */
1887 #define ALT_ACPIDMAP_VID2RD_S_FORCE_SET_MSK 0x80000000
1888 /* The mask used to clear the ALT_ACPIDMAP_VID2RD_S_FORCE register field value. */
1889 #define ALT_ACPIDMAP_VID2RD_S_FORCE_CLR_MSK 0x7fffffff
1890 /* The reset value of the ALT_ACPIDMAP_VID2RD_S_FORCE register field. */
1891 #define ALT_ACPIDMAP_VID2RD_S_FORCE_RESET 0x1
1892 /* Extracts the ALT_ACPIDMAP_VID2RD_S_FORCE field value from a register. */
1893 #define ALT_ACPIDMAP_VID2RD_S_FORCE_GET(value) (((value) & 0x80000000) >> 31)
1894 /* Produces a ALT_ACPIDMAP_VID2RD_S_FORCE register field value suitable for setting the register. */
1895 #define ALT_ACPIDMAP_VID2RD_S_FORCE_SET(value) (((value) << 31) & 0x80000000)
1896
1897 #ifndef __ASSEMBLY__
1898 /*
1899  * WARNING: The C register and register group struct declarations are provided for
1900  * convenience and illustrative purposes. They should, however, be used with
1901  * caution as the C language standard provides no guarantees about the alignment or
1902  * atomicity of device memory accesses. The recommended practice for writing
1903  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1904  * alt_write_word() functions.
1905  *
1906  * The struct declaration for register ALT_ACPIDMAP_VID2RD_S.
1907  */
1909 {
1910  uint32_t : 4; /* *UNDEFINED* */
1911  const uint32_t user : 5; /* ARUSER value to SCU for ID=2 (Status) */
1912  uint32_t : 3; /* *UNDEFINED* */
1913  const uint32_t page : 2; /* ARADDR 1GB Page Decoder (Status) */
1914  uint32_t : 2; /* *UNDEFINED* */
1915  const uint32_t mid : 12; /* Remap Master ID = DAP ID (Status) */
1916  uint32_t : 3; /* *UNDEFINED* */
1917  const uint32_t force : 1; /* Force Mapping for ID=2 (Status) */
1918 };
1919
1920 /* The typedef declaration for register ALT_ACPIDMAP_VID2RD_S. */
1921 typedef volatile struct ALT_ACPIDMAP_VID2RD_S_s ALT_ACPIDMAP_VID2RD_S_t;
1922 #endif /* __ASSEMBLY__ */
1923
1924 /* The byte offset of the ALT_ACPIDMAP_VID2RD_S register from the beginning of the component. */
1925 #define ALT_ACPIDMAP_VID2RD_S_OFST 0x30
1926
1927 /*
1928  * Register : Write AXI Master Mapping Status Register for Fixed Virtual ID 2 - vid2wr_s
1929  *
1930  * The Write AXI Master Mapping Status Register contains the configured USER, ADDR
1931  * page, and ID signals mapping values for particular transaction with 12-bit ID
1932  * which locks the fixed 3-bit virtual ID.
1933  *
1934  * Register Layout
1935  *
1936  * Bits | Access | Reset | Description
1937  * :--------|:-------|:--------|:--------------------------------------
1938  * [3:0] | ??? | 0x0 | *UNDEFINED*
1939  * [8:4] | R | 0x1 | AWUSER value to SCU for ID=2 (Status)
1940  * [11:9] | ??? | 0x0 | *UNDEFINED*
1941  * [13:12] | R | Unknown | AWADDR 1GB Page Decoder (Status)
1942  * [15:14] | ??? | 0x0 | *UNDEFINED*
1943  * [27:16] | R | 0x4 | Remap Master ID = DAP ID (Status)
1944  * [30:28] | ??? | 0x0 | *UNDEFINED*
1945  * [31] | R | 0x1 | Force Mapping for ID=2 (Status)
1946  *
1947  */
1948 /*
1949  * Field : AWUSER value to SCU for ID=2 (Status) - user
1950  *
1951  * This value is propagated to SCU as AWUSERS.
1952  *
1953  * Field Access Macros:
1954  *
1955  */
1956 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID2WR_S_USER register field. */
1957 #define ALT_ACPIDMAP_VID2WR_S_USER_LSB 4
1958 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID2WR_S_USER register field. */
1959 #define ALT_ACPIDMAP_VID2WR_S_USER_MSB 8
1960 /* The width in bits of the ALT_ACPIDMAP_VID2WR_S_USER register field. */
1961 #define ALT_ACPIDMAP_VID2WR_S_USER_WIDTH 5
1962 /* The mask used to set the ALT_ACPIDMAP_VID2WR_S_USER register field value. */
1963 #define ALT_ACPIDMAP_VID2WR_S_USER_SET_MSK 0x000001f0
1964 /* The mask used to clear the ALT_ACPIDMAP_VID2WR_S_USER register field value. */
1965 #define ALT_ACPIDMAP_VID2WR_S_USER_CLR_MSK 0xfffffe0f
1966 /* The reset value of the ALT_ACPIDMAP_VID2WR_S_USER register field. */
1967 #define ALT_ACPIDMAP_VID2WR_S_USER_RESET 0x1
1968 /* Extracts the ALT_ACPIDMAP_VID2WR_S_USER field value from a register. */
1969 #define ALT_ACPIDMAP_VID2WR_S_USER_GET(value) (((value) & 0x000001f0) >> 4)
1970 /* Produces a ALT_ACPIDMAP_VID2WR_S_USER register field value suitable for setting the register. */
1971 #define ALT_ACPIDMAP_VID2WR_S_USER_SET(value) (((value) << 4) & 0x000001f0)
1972
1973 /*
1974  * Field : AWADDR 1GB Page Decoder (Status) - page
1975  *
1976  * AWADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
1977  *
1978  * Field Access Macros:
1979  *
1980  */
1981 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID2WR_S_PAGE register field. */
1982 #define ALT_ACPIDMAP_VID2WR_S_PAGE_LSB 12
1983 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID2WR_S_PAGE register field. */
1984 #define ALT_ACPIDMAP_VID2WR_S_PAGE_MSB 13
1985 /* The width in bits of the ALT_ACPIDMAP_VID2WR_S_PAGE register field. */
1986 #define ALT_ACPIDMAP_VID2WR_S_PAGE_WIDTH 2
1987 /* The mask used to set the ALT_ACPIDMAP_VID2WR_S_PAGE register field value. */
1988 #define ALT_ACPIDMAP_VID2WR_S_PAGE_SET_MSK 0x00003000
1989 /* The mask used to clear the ALT_ACPIDMAP_VID2WR_S_PAGE register field value. */
1990 #define ALT_ACPIDMAP_VID2WR_S_PAGE_CLR_MSK 0xffffcfff
1991 /* The reset value of the ALT_ACPIDMAP_VID2WR_S_PAGE register field is UNKNOWN. */
1992 #define ALT_ACPIDMAP_VID2WR_S_PAGE_RESET 0x0
1993 /* Extracts the ALT_ACPIDMAP_VID2WR_S_PAGE field value from a register. */
1994 #define ALT_ACPIDMAP_VID2WR_S_PAGE_GET(value) (((value) & 0x00003000) >> 12)
1995 /* Produces a ALT_ACPIDMAP_VID2WR_S_PAGE register field value suitable for setting the register. */
1996 #define ALT_ACPIDMAP_VID2WR_S_PAGE_SET(value) (((value) << 12) & 0x00003000)
1997
1998 /*
1999  * Field : Remap Master ID = DAP ID (Status) - mid
2000  *
2001  * The 12-bit ID of the master to remap to 3-bit virtual ID N, where N is the 3-bit
2002  * ID to use.
2003  *
2004  * Field Access Macros:
2005  *
2006  */
2007 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID2WR_S_MID register field. */
2008 #define ALT_ACPIDMAP_VID2WR_S_MID_LSB 16
2009 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID2WR_S_MID register field. */
2010 #define ALT_ACPIDMAP_VID2WR_S_MID_MSB 27
2011 /* The width in bits of the ALT_ACPIDMAP_VID2WR_S_MID register field. */
2012 #define ALT_ACPIDMAP_VID2WR_S_MID_WIDTH 12
2013 /* The mask used to set the ALT_ACPIDMAP_VID2WR_S_MID register field value. */
2014 #define ALT_ACPIDMAP_VID2WR_S_MID_SET_MSK 0x0fff0000
2015 /* The mask used to clear the ALT_ACPIDMAP_VID2WR_S_MID register field value. */
2016 #define ALT_ACPIDMAP_VID2WR_S_MID_CLR_MSK 0xf000ffff
2017 /* The reset value of the ALT_ACPIDMAP_VID2WR_S_MID register field. */
2018 #define ALT_ACPIDMAP_VID2WR_S_MID_RESET 0x4
2019 /* Extracts the ALT_ACPIDMAP_VID2WR_S_MID field value from a register. */
2020 #define ALT_ACPIDMAP_VID2WR_S_MID_GET(value) (((value) & 0x0fff0000) >> 16)
2021 /* Produces a ALT_ACPIDMAP_VID2WR_S_MID register field value suitable for setting the register. */
2022 #define ALT_ACPIDMAP_VID2WR_S_MID_SET(value) (((value) << 16) & 0x0fff0000)
2023
2024 /*
2025  * Field : Force Mapping for ID=2 (Status) - force
2026  *
2027  * Set to 1 to force the mapping between the 12-bit ID and 3-bit virtual ID N. Set
2028  * to 0 to allow the 3-bit ID N to be dynamically allocated.
2029  *
2030  * Field Access Macros:
2031  *
2032  */
2033 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID2WR_S_FORCE register field. */
2034 #define ALT_ACPIDMAP_VID2WR_S_FORCE_LSB 31
2035 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID2WR_S_FORCE register field. */
2036 #define ALT_ACPIDMAP_VID2WR_S_FORCE_MSB 31
2037 /* The width in bits of the ALT_ACPIDMAP_VID2WR_S_FORCE register field. */
2038 #define ALT_ACPIDMAP_VID2WR_S_FORCE_WIDTH 1
2039 /* The mask used to set the ALT_ACPIDMAP_VID2WR_S_FORCE register field value. */
2040 #define ALT_ACPIDMAP_VID2WR_S_FORCE_SET_MSK 0x80000000
2041 /* The mask used to clear the ALT_ACPIDMAP_VID2WR_S_FORCE register field value. */
2042 #define ALT_ACPIDMAP_VID2WR_S_FORCE_CLR_MSK 0x7fffffff
2043 /* The reset value of the ALT_ACPIDMAP_VID2WR_S_FORCE register field. */
2044 #define ALT_ACPIDMAP_VID2WR_S_FORCE_RESET 0x1
2045 /* Extracts the ALT_ACPIDMAP_VID2WR_S_FORCE field value from a register. */
2046 #define ALT_ACPIDMAP_VID2WR_S_FORCE_GET(value) (((value) & 0x80000000) >> 31)
2047 /* Produces a ALT_ACPIDMAP_VID2WR_S_FORCE register field value suitable for setting the register. */
2048 #define ALT_ACPIDMAP_VID2WR_S_FORCE_SET(value) (((value) << 31) & 0x80000000)
2049
2050 #ifndef __ASSEMBLY__
2051 /*
2052  * WARNING: The C register and register group struct declarations are provided for
2053  * convenience and illustrative purposes. They should, however, be used with
2054  * caution as the C language standard provides no guarantees about the alignment or
2055  * atomicity of device memory accesses. The recommended practice for writing
2056  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2057  * alt_write_word() functions.
2058  *
2059  * The struct declaration for register ALT_ACPIDMAP_VID2WR_S.
2060  */
2062 {
2063  uint32_t : 4; /* *UNDEFINED* */
2064  const uint32_t user : 5; /* AWUSER value to SCU for ID=2 (Status) */
2065  uint32_t : 3; /* *UNDEFINED* */
2066  const uint32_t page : 2; /* AWADDR 1GB Page Decoder (Status) */
2067  uint32_t : 2; /* *UNDEFINED* */
2068  const uint32_t mid : 12; /* Remap Master ID = DAP ID (Status) */
2069  uint32_t : 3; /* *UNDEFINED* */
2070  const uint32_t force : 1; /* Force Mapping for ID=2 (Status) */
2071 };
2072
2073 /* The typedef declaration for register ALT_ACPIDMAP_VID2WR_S. */
2074 typedef volatile struct ALT_ACPIDMAP_VID2WR_S_s ALT_ACPIDMAP_VID2WR_S_t;
2075 #endif /* __ASSEMBLY__ */
2076
2077 /* The byte offset of the ALT_ACPIDMAP_VID2WR_S register from the beginning of the component. */
2078 #define ALT_ACPIDMAP_VID2WR_S_OFST 0x34
2079
2080 /*
2081  * Register : Read AXI Master Mapping Status Register for Fixed Virtual ID 3 - vid3rd_s
2082  *
2083  * The Read AXI Master Mapping Status Register contains the configured USER, ADDR
2084  * page, and ID signals mapping values for particular transaction with 12-bit ID
2085  * which locks the fixed 3-bit virtual ID.
2086  *
2087  * Register Layout
2088  *
2089  * Bits | Access | Reset | Description
2090  * :--------|:-------|:--------|:---------------------------------
2091  * [3:0] | ??? | 0x0 | *UNDEFINED*
2092  * [8:4] | R | Unknown | ARUSER value to SCU (Status)
2093  * [11:9] | ??? | 0x0 | *UNDEFINED*
2094  * [13:12] | R | Unknown | ARADDR 1GB Page Decoder (Status)
2095  * [15:14] | ??? | 0x0 | *UNDEFINED*
2096  * [27:16] | R | Unknown | Remap Master ID (Status)
2097  * [30:28] | ??? | 0x0 | *UNDEFINED*
2098  * [31] | R | Unknown | Force Mapping (Status)
2099  *
2100  */
2101 /*
2102  * Field : ARUSER value to SCU (Status) - user
2103  *
2104  * This value is propagated to SCU as ARUSERS.
2105  *
2106  * Field Access Macros:
2107  *
2108  */
2109 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID3RD_S_USER register field. */
2110 #define ALT_ACPIDMAP_VID3RD_S_USER_LSB 4
2111 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID3RD_S_USER register field. */
2112 #define ALT_ACPIDMAP_VID3RD_S_USER_MSB 8
2113 /* The width in bits of the ALT_ACPIDMAP_VID3RD_S_USER register field. */
2114 #define ALT_ACPIDMAP_VID3RD_S_USER_WIDTH 5
2115 /* The mask used to set the ALT_ACPIDMAP_VID3RD_S_USER register field value. */
2116 #define ALT_ACPIDMAP_VID3RD_S_USER_SET_MSK 0x000001f0
2117 /* The mask used to clear the ALT_ACPIDMAP_VID3RD_S_USER register field value. */
2118 #define ALT_ACPIDMAP_VID3RD_S_USER_CLR_MSK 0xfffffe0f
2119 /* The reset value of the ALT_ACPIDMAP_VID3RD_S_USER register field is UNKNOWN. */
2120 #define ALT_ACPIDMAP_VID3RD_S_USER_RESET 0x0
2121 /* Extracts the ALT_ACPIDMAP_VID3RD_S_USER field value from a register. */
2122 #define ALT_ACPIDMAP_VID3RD_S_USER_GET(value) (((value) & 0x000001f0) >> 4)
2123 /* Produces a ALT_ACPIDMAP_VID3RD_S_USER register field value suitable for setting the register. */
2124 #define ALT_ACPIDMAP_VID3RD_S_USER_SET(value) (((value) << 4) & 0x000001f0)
2125
2126 /*
2127  * Field : ARADDR 1GB Page Decoder (Status) - page
2128  *
2129  * ARADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
2130  *
2131  * Field Access Macros:
2132  *
2133  */
2134 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID3RD_S_PAGE register field. */
2135 #define ALT_ACPIDMAP_VID3RD_S_PAGE_LSB 12
2136 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID3RD_S_PAGE register field. */
2137 #define ALT_ACPIDMAP_VID3RD_S_PAGE_MSB 13
2138 /* The width in bits of the ALT_ACPIDMAP_VID3RD_S_PAGE register field. */
2139 #define ALT_ACPIDMAP_VID3RD_S_PAGE_WIDTH 2
2140 /* The mask used to set the ALT_ACPIDMAP_VID3RD_S_PAGE register field value. */
2141 #define ALT_ACPIDMAP_VID3RD_S_PAGE_SET_MSK 0x00003000
2142 /* The mask used to clear the ALT_ACPIDMAP_VID3RD_S_PAGE register field value. */
2143 #define ALT_ACPIDMAP_VID3RD_S_PAGE_CLR_MSK 0xffffcfff
2144 /* The reset value of the ALT_ACPIDMAP_VID3RD_S_PAGE register field is UNKNOWN. */
2145 #define ALT_ACPIDMAP_VID3RD_S_PAGE_RESET 0x0
2146 /* Extracts the ALT_ACPIDMAP_VID3RD_S_PAGE field value from a register. */
2147 #define ALT_ACPIDMAP_VID3RD_S_PAGE_GET(value) (((value) & 0x00003000) >> 12)
2148 /* Produces a ALT_ACPIDMAP_VID3RD_S_PAGE register field value suitable for setting the register. */
2149 #define ALT_ACPIDMAP_VID3RD_S_PAGE_SET(value) (((value) << 12) & 0x00003000)
2150
2151 /*
2152  * Field : Remap Master ID (Status) - mid
2153  *
2154  * The 12-bit ID of the master to remap to 3-bit virtual ID N, where N is the 3-bit
2155  * ID to use.
2156  *
2157  * Field Access Macros:
2158  *
2159  */
2160 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID3RD_S_MID register field. */
2161 #define ALT_ACPIDMAP_VID3RD_S_MID_LSB 16
2162 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID3RD_S_MID register field. */
2163 #define ALT_ACPIDMAP_VID3RD_S_MID_MSB 27
2164 /* The width in bits of the ALT_ACPIDMAP_VID3RD_S_MID register field. */
2165 #define ALT_ACPIDMAP_VID3RD_S_MID_WIDTH 12
2166 /* The mask used to set the ALT_ACPIDMAP_VID3RD_S_MID register field value. */
2167 #define ALT_ACPIDMAP_VID3RD_S_MID_SET_MSK 0x0fff0000
2168 /* The mask used to clear the ALT_ACPIDMAP_VID3RD_S_MID register field value. */
2169 #define ALT_ACPIDMAP_VID3RD_S_MID_CLR_MSK 0xf000ffff
2170 /* The reset value of the ALT_ACPIDMAP_VID3RD_S_MID register field is UNKNOWN. */
2171 #define ALT_ACPIDMAP_VID3RD_S_MID_RESET 0x0
2172 /* Extracts the ALT_ACPIDMAP_VID3RD_S_MID field value from a register. */
2173 #define ALT_ACPIDMAP_VID3RD_S_MID_GET(value) (((value) & 0x0fff0000) >> 16)
2174 /* Produces a ALT_ACPIDMAP_VID3RD_S_MID register field value suitable for setting the register. */
2175 #define ALT_ACPIDMAP_VID3RD_S_MID_SET(value) (((value) << 16) & 0x0fff0000)
2176
2177 /*
2178  * Field : Force Mapping (Status) - force
2179  *
2180  * Set to 1 to force the mapping between the 12-bit ID and 3-bit virtual ID N. Set
2181  * to 0 to allow the 3-bit ID N to be dynamically allocated.
2182  *
2183  * Field Access Macros:
2184  *
2185  */
2186 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID3RD_S_FORCE register field. */
2187 #define ALT_ACPIDMAP_VID3RD_S_FORCE_LSB 31
2188 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID3RD_S_FORCE register field. */
2189 #define ALT_ACPIDMAP_VID3RD_S_FORCE_MSB 31
2190 /* The width in bits of the ALT_ACPIDMAP_VID3RD_S_FORCE register field. */
2191 #define ALT_ACPIDMAP_VID3RD_S_FORCE_WIDTH 1
2192 /* The mask used to set the ALT_ACPIDMAP_VID3RD_S_FORCE register field value. */
2193 #define ALT_ACPIDMAP_VID3RD_S_FORCE_SET_MSK 0x80000000
2194 /* The mask used to clear the ALT_ACPIDMAP_VID3RD_S_FORCE register field value. */
2195 #define ALT_ACPIDMAP_VID3RD_S_FORCE_CLR_MSK 0x7fffffff
2196 /* The reset value of the ALT_ACPIDMAP_VID3RD_S_FORCE register field is UNKNOWN. */
2197 #define ALT_ACPIDMAP_VID3RD_S_FORCE_RESET 0x0
2198 /* Extracts the ALT_ACPIDMAP_VID3RD_S_FORCE field value from a register. */
2199 #define ALT_ACPIDMAP_VID3RD_S_FORCE_GET(value) (((value) & 0x80000000) >> 31)
2200 /* Produces a ALT_ACPIDMAP_VID3RD_S_FORCE register field value suitable for setting the register. */
2201 #define ALT_ACPIDMAP_VID3RD_S_FORCE_SET(value) (((value) << 31) & 0x80000000)
2202
2203 #ifndef __ASSEMBLY__
2204 /*
2205  * WARNING: The C register and register group struct declarations are provided for
2206  * convenience and illustrative purposes. They should, however, be used with
2207  * caution as the C language standard provides no guarantees about the alignment or
2208  * atomicity of device memory accesses. The recommended practice for writing
2209  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2210  * alt_write_word() functions.
2211  *
2212  * The struct declaration for register ALT_ACPIDMAP_VID3RD_S.
2213  */
2215 {
2216  uint32_t : 4; /* *UNDEFINED* */
2217  const uint32_t user : 5; /* ARUSER value to SCU (Status) */
2218  uint32_t : 3; /* *UNDEFINED* */
2219  const uint32_t page : 2; /* ARADDR 1GB Page Decoder (Status) */
2220  uint32_t : 2; /* *UNDEFINED* */
2221  const uint32_t mid : 12; /* Remap Master ID (Status) */
2222  uint32_t : 3; /* *UNDEFINED* */
2223  const uint32_t force : 1; /* Force Mapping (Status) */
2224 };
2225
2226 /* The typedef declaration for register ALT_ACPIDMAP_VID3RD_S. */
2227 typedef volatile struct ALT_ACPIDMAP_VID3RD_S_s ALT_ACPIDMAP_VID3RD_S_t;
2228 #endif /* __ASSEMBLY__ */
2229
2230 /* The byte offset of the ALT_ACPIDMAP_VID3RD_S register from the beginning of the component. */
2231 #define ALT_ACPIDMAP_VID3RD_S_OFST 0x38
2232
2233 /*
2234  * Register : Write AXI Master Mapping Status Register for Fixed Virtual ID 3 - vid3wr_s
2235  *
2236  * The Write AXI Master Mapping Status Register contains the configured USER, ADDR
2237  * page, and ID signals mapping values for particular transaction with 12-bit ID
2238  * which locks the fixed 3-bit virtual ID.
2239  *
2240  * Register Layout
2241  *
2242  * Bits | Access | Reset | Description
2243  * :--------|:-------|:--------|:---------------------------------
2244  * [3:0] | ??? | 0x0 | *UNDEFINED*
2245  * [8:4] | R | Unknown | AWUSER value to SCU (Status)
2246  * [11:9] | ??? | 0x0 | *UNDEFINED*
2247  * [13:12] | R | Unknown | AWADDR 1GB Page Decoder (Status)
2248  * [15:14] | ??? | 0x0 | *UNDEFINED*
2249  * [27:16] | R | Unknown | Remap Master ID (Status)
2250  * [30:28] | ??? | 0x0 | *UNDEFINED*
2251  * [31] | R | Unknown | Force Mapping (Status)
2252  *
2253  */
2254 /*
2255  * Field : AWUSER value to SCU (Status) - user
2256  *
2257  * This value is propagated to SCU as AWUSERS.
2258  *
2259  * Field Access Macros:
2260  *
2261  */
2262 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID3WR_S_USER register field. */
2263 #define ALT_ACPIDMAP_VID3WR_S_USER_LSB 4
2264 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID3WR_S_USER register field. */
2265 #define ALT_ACPIDMAP_VID3WR_S_USER_MSB 8
2266 /* The width in bits of the ALT_ACPIDMAP_VID3WR_S_USER register field. */
2267 #define ALT_ACPIDMAP_VID3WR_S_USER_WIDTH 5
2268 /* The mask used to set the ALT_ACPIDMAP_VID3WR_S_USER register field value. */
2269 #define ALT_ACPIDMAP_VID3WR_S_USER_SET_MSK 0x000001f0
2270 /* The mask used to clear the ALT_ACPIDMAP_VID3WR_S_USER register field value. */
2271 #define ALT_ACPIDMAP_VID3WR_S_USER_CLR_MSK 0xfffffe0f
2272 /* The reset value of the ALT_ACPIDMAP_VID3WR_S_USER register field is UNKNOWN. */
2273 #define ALT_ACPIDMAP_VID3WR_S_USER_RESET 0x0
2274 /* Extracts the ALT_ACPIDMAP_VID3WR_S_USER field value from a register. */
2275 #define ALT_ACPIDMAP_VID3WR_S_USER_GET(value) (((value) & 0x000001f0) >> 4)
2276 /* Produces a ALT_ACPIDMAP_VID3WR_S_USER register field value suitable for setting the register. */
2277 #define ALT_ACPIDMAP_VID3WR_S_USER_SET(value) (((value) << 4) & 0x000001f0)
2278
2279 /*
2280  * Field : AWADDR 1GB Page Decoder (Status) - page
2281  *
2282  * AWADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
2283  *
2284  * Field Access Macros:
2285  *
2286  */
2287 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID3WR_S_PAGE register field. */
2288 #define ALT_ACPIDMAP_VID3WR_S_PAGE_LSB 12
2289 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID3WR_S_PAGE register field. */
2290 #define ALT_ACPIDMAP_VID3WR_S_PAGE_MSB 13
2291 /* The width in bits of the ALT_ACPIDMAP_VID3WR_S_PAGE register field. */
2292 #define ALT_ACPIDMAP_VID3WR_S_PAGE_WIDTH 2
2293 /* The mask used to set the ALT_ACPIDMAP_VID3WR_S_PAGE register field value. */
2294 #define ALT_ACPIDMAP_VID3WR_S_PAGE_SET_MSK 0x00003000
2295 /* The mask used to clear the ALT_ACPIDMAP_VID3WR_S_PAGE register field value. */
2296 #define ALT_ACPIDMAP_VID3WR_S_PAGE_CLR_MSK 0xffffcfff
2297 /* The reset value of the ALT_ACPIDMAP_VID3WR_S_PAGE register field is UNKNOWN. */
2298 #define ALT_ACPIDMAP_VID3WR_S_PAGE_RESET 0x0
2299 /* Extracts the ALT_ACPIDMAP_VID3WR_S_PAGE field value from a register. */
2300 #define ALT_ACPIDMAP_VID3WR_S_PAGE_GET(value) (((value) & 0x00003000) >> 12)
2301 /* Produces a ALT_ACPIDMAP_VID3WR_S_PAGE register field value suitable for setting the register. */
2302 #define ALT_ACPIDMAP_VID3WR_S_PAGE_SET(value) (((value) << 12) & 0x00003000)
2303
2304 /*
2305  * Field : Remap Master ID (Status) - mid
2306  *
2307  * The 12-bit ID of the master to remap to 3-bit virtual ID N, where N is the 3-bit
2308  * ID to use.
2309  *
2310  * Field Access Macros:
2311  *
2312  */
2313 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID3WR_S_MID register field. */
2314 #define ALT_ACPIDMAP_VID3WR_S_MID_LSB 16
2315 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID3WR_S_MID register field. */
2316 #define ALT_ACPIDMAP_VID3WR_S_MID_MSB 27
2317 /* The width in bits of the ALT_ACPIDMAP_VID3WR_S_MID register field. */
2318 #define ALT_ACPIDMAP_VID3WR_S_MID_WIDTH 12
2319 /* The mask used to set the ALT_ACPIDMAP_VID3WR_S_MID register field value. */
2320 #define ALT_ACPIDMAP_VID3WR_S_MID_SET_MSK 0x0fff0000
2321 /* The mask used to clear the ALT_ACPIDMAP_VID3WR_S_MID register field value. */
2322 #define ALT_ACPIDMAP_VID3WR_S_MID_CLR_MSK 0xf000ffff
2323 /* The reset value of the ALT_ACPIDMAP_VID3WR_S_MID register field is UNKNOWN. */
2324 #define ALT_ACPIDMAP_VID3WR_S_MID_RESET 0x0
2325 /* Extracts the ALT_ACPIDMAP_VID3WR_S_MID field value from a register. */
2326 #define ALT_ACPIDMAP_VID3WR_S_MID_GET(value) (((value) & 0x0fff0000) >> 16)
2327 /* Produces a ALT_ACPIDMAP_VID3WR_S_MID register field value suitable for setting the register. */
2328 #define ALT_ACPIDMAP_VID3WR_S_MID_SET(value) (((value) << 16) & 0x0fff0000)
2329
2330 /*
2331  * Field : Force Mapping (Status) - force
2332  *
2333  * Set to 1 to force the mapping between the 12-bit ID and 3-bit virtual ID N. Set
2334  * to 0 to allow the 3-bit ID N to be dynamically allocated.
2335  *
2336  * Field Access Macros:
2337  *
2338  */
2339 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID3WR_S_FORCE register field. */
2340 #define ALT_ACPIDMAP_VID3WR_S_FORCE_LSB 31
2341 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID3WR_S_FORCE register field. */
2342 #define ALT_ACPIDMAP_VID3WR_S_FORCE_MSB 31
2343 /* The width in bits of the ALT_ACPIDMAP_VID3WR_S_FORCE register field. */
2344 #define ALT_ACPIDMAP_VID3WR_S_FORCE_WIDTH 1
2345 /* The mask used to set the ALT_ACPIDMAP_VID3WR_S_FORCE register field value. */
2346 #define ALT_ACPIDMAP_VID3WR_S_FORCE_SET_MSK 0x80000000
2347 /* The mask used to clear the ALT_ACPIDMAP_VID3WR_S_FORCE register field value. */
2348 #define ALT_ACPIDMAP_VID3WR_S_FORCE_CLR_MSK 0x7fffffff
2349 /* The reset value of the ALT_ACPIDMAP_VID3WR_S_FORCE register field is UNKNOWN. */
2350 #define ALT_ACPIDMAP_VID3WR_S_FORCE_RESET 0x0
2351 /* Extracts the ALT_ACPIDMAP_VID3WR_S_FORCE field value from a register. */
2352 #define ALT_ACPIDMAP_VID3WR_S_FORCE_GET(value) (((value) & 0x80000000) >> 31)
2353 /* Produces a ALT_ACPIDMAP_VID3WR_S_FORCE register field value suitable for setting the register. */
2354 #define ALT_ACPIDMAP_VID3WR_S_FORCE_SET(value) (((value) << 31) & 0x80000000)
2355
2356 #ifndef __ASSEMBLY__
2357 /*
2358  * WARNING: The C register and register group struct declarations are provided for
2359  * convenience and illustrative purposes. They should, however, be used with
2360  * caution as the C language standard provides no guarantees about the alignment or
2361  * atomicity of device memory accesses. The recommended practice for writing
2362  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2363  * alt_write_word() functions.
2364  *
2365  * The struct declaration for register ALT_ACPIDMAP_VID3WR_S.
2366  */
2368 {
2369  uint32_t : 4; /* *UNDEFINED* */
2370  const uint32_t user : 5; /* AWUSER value to SCU (Status) */
2371  uint32_t : 3; /* *UNDEFINED* */
2372  const uint32_t page : 2; /* AWADDR 1GB Page Decoder (Status) */
2373  uint32_t : 2; /* *UNDEFINED* */
2374  const uint32_t mid : 12; /* Remap Master ID (Status) */
2375  uint32_t : 3; /* *UNDEFINED* */
2376  const uint32_t force : 1; /* Force Mapping (Status) */
2377 };
2378
2379 /* The typedef declaration for register ALT_ACPIDMAP_VID3WR_S. */
2380 typedef volatile struct ALT_ACPIDMAP_VID3WR_S_s ALT_ACPIDMAP_VID3WR_S_t;
2381 #endif /* __ASSEMBLY__ */
2382
2383 /* The byte offset of the ALT_ACPIDMAP_VID3WR_S register from the beginning of the component. */
2384 #define ALT_ACPIDMAP_VID3WR_S_OFST 0x3c
2385
2386 /*
2387  * Register : Read AXI Master Mapping Status Register for Fixed Virtual ID 4 - vid4rd_s
2388  *
2389  * The Read AXI Master Mapping Status Register contains the configured USER, ADDR
2390  * page, and ID signals mapping values for particular transaction with 12-bit ID
2391  * which locks the fixed 3-bit virtual ID.
2392  *
2393  * Register Layout
2394  *
2395  * Bits | Access | Reset | Description
2396  * :--------|:-------|:--------|:---------------------------------
2397  * [3:0] | ??? | 0x0 | *UNDEFINED*
2398  * [8:4] | R | Unknown | ARUSER value to SCU (Status)
2399  * [11:9] | ??? | 0x0 | *UNDEFINED*
2400  * [13:12] | R | Unknown | ARADDR 1GB Page Decoder (Status)
2401  * [15:14] | ??? | 0x0 | *UNDEFINED*
2402  * [27:16] | R | Unknown | Remap Master ID (Status)
2403  * [30:28] | ??? | 0x0 | *UNDEFINED*
2404  * [31] | R | Unknown | Force Mapping (Status)
2405  *
2406  */
2407 /*
2408  * Field : ARUSER value to SCU (Status) - user
2409  *
2410  * This value is propagated to SCU as ARUSERS.
2411  *
2412  * Field Access Macros:
2413  *
2414  */
2415 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID4RD_S_USER register field. */
2416 #define ALT_ACPIDMAP_VID4RD_S_USER_LSB 4
2417 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID4RD_S_USER register field. */
2418 #define ALT_ACPIDMAP_VID4RD_S_USER_MSB 8
2419 /* The width in bits of the ALT_ACPIDMAP_VID4RD_S_USER register field. */
2420 #define ALT_ACPIDMAP_VID4RD_S_USER_WIDTH 5
2421 /* The mask used to set the ALT_ACPIDMAP_VID4RD_S_USER register field value. */
2422 #define ALT_ACPIDMAP_VID4RD_S_USER_SET_MSK 0x000001f0
2423 /* The mask used to clear the ALT_ACPIDMAP_VID4RD_S_USER register field value. */
2424 #define ALT_ACPIDMAP_VID4RD_S_USER_CLR_MSK 0xfffffe0f
2425 /* The reset value of the ALT_ACPIDMAP_VID4RD_S_USER register field is UNKNOWN. */
2426 #define ALT_ACPIDMAP_VID4RD_S_USER_RESET 0x0
2427 /* Extracts the ALT_ACPIDMAP_VID4RD_S_USER field value from a register. */
2428 #define ALT_ACPIDMAP_VID4RD_S_USER_GET(value) (((value) & 0x000001f0) >> 4)
2429 /* Produces a ALT_ACPIDMAP_VID4RD_S_USER register field value suitable for setting the register. */
2430 #define ALT_ACPIDMAP_VID4RD_S_USER_SET(value) (((value) << 4) & 0x000001f0)
2431
2432 /*
2433  * Field : ARADDR 1GB Page Decoder (Status) - page
2434  *
2435  * ARADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
2436  *
2437  * Field Access Macros:
2438  *
2439  */
2440 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID4RD_S_PAGE register field. */
2441 #define ALT_ACPIDMAP_VID4RD_S_PAGE_LSB 12
2442 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID4RD_S_PAGE register field. */
2443 #define ALT_ACPIDMAP_VID4RD_S_PAGE_MSB 13
2444 /* The width in bits of the ALT_ACPIDMAP_VID4RD_S_PAGE register field. */
2445 #define ALT_ACPIDMAP_VID4RD_S_PAGE_WIDTH 2
2446 /* The mask used to set the ALT_ACPIDMAP_VID4RD_S_PAGE register field value. */
2447 #define ALT_ACPIDMAP_VID4RD_S_PAGE_SET_MSK 0x00003000
2448 /* The mask used to clear the ALT_ACPIDMAP_VID4RD_S_PAGE register field value. */
2449 #define ALT_ACPIDMAP_VID4RD_S_PAGE_CLR_MSK 0xffffcfff
2450 /* The reset value of the ALT_ACPIDMAP_VID4RD_S_PAGE register field is UNKNOWN. */
2451 #define ALT_ACPIDMAP_VID4RD_S_PAGE_RESET 0x0
2452 /* Extracts the ALT_ACPIDMAP_VID4RD_S_PAGE field value from a register. */
2453 #define ALT_ACPIDMAP_VID4RD_S_PAGE_GET(value) (((value) & 0x00003000) >> 12)
2454 /* Produces a ALT_ACPIDMAP_VID4RD_S_PAGE register field value suitable for setting the register. */
2455 #define ALT_ACPIDMAP_VID4RD_S_PAGE_SET(value) (((value) << 12) & 0x00003000)
2456
2457 /*
2458  * Field : Remap Master ID (Status) - mid
2459  *
2460  * The 12-bit ID of the master to remap to 3-bit virtual ID N, where N is the 3-bit
2461  * ID to use.
2462  *
2463  * Field Access Macros:
2464  *
2465  */
2466 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID4RD_S_MID register field. */
2467 #define ALT_ACPIDMAP_VID4RD_S_MID_LSB 16
2468 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID4RD_S_MID register field. */
2469 #define ALT_ACPIDMAP_VID4RD_S_MID_MSB 27
2470 /* The width in bits of the ALT_ACPIDMAP_VID4RD_S_MID register field. */
2471 #define ALT_ACPIDMAP_VID4RD_S_MID_WIDTH 12
2472 /* The mask used to set the ALT_ACPIDMAP_VID4RD_S_MID register field value. */
2473 #define ALT_ACPIDMAP_VID4RD_S_MID_SET_MSK 0x0fff0000
2474 /* The mask used to clear the ALT_ACPIDMAP_VID4RD_S_MID register field value. */
2475 #define ALT_ACPIDMAP_VID4RD_S_MID_CLR_MSK 0xf000ffff
2476 /* The reset value of the ALT_ACPIDMAP_VID4RD_S_MID register field is UNKNOWN. */
2477 #define ALT_ACPIDMAP_VID4RD_S_MID_RESET 0x0
2478 /* Extracts the ALT_ACPIDMAP_VID4RD_S_MID field value from a register. */
2479 #define ALT_ACPIDMAP_VID4RD_S_MID_GET(value) (((value) & 0x0fff0000) >> 16)
2480 /* Produces a ALT_ACPIDMAP_VID4RD_S_MID register field value suitable for setting the register. */
2481 #define ALT_ACPIDMAP_VID4RD_S_MID_SET(value) (((value) << 16) & 0x0fff0000)
2482
2483 /*
2484  * Field : Force Mapping (Status) - force
2485  *
2486  * Set to 1 to force the mapping between the 12-bit ID and 3-bit virtual ID N. Set
2487  * to 0 to allow the 3-bit ID N to be dynamically allocated.
2488  *
2489  * Field Access Macros:
2490  *
2491  */
2492 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID4RD_S_FORCE register field. */
2493 #define ALT_ACPIDMAP_VID4RD_S_FORCE_LSB 31
2494 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID4RD_S_FORCE register field. */
2495 #define ALT_ACPIDMAP_VID4RD_S_FORCE_MSB 31
2496 /* The width in bits of the ALT_ACPIDMAP_VID4RD_S_FORCE register field. */
2497 #define ALT_ACPIDMAP_VID4RD_S_FORCE_WIDTH 1
2498 /* The mask used to set the ALT_ACPIDMAP_VID4RD_S_FORCE register field value. */
2499 #define ALT_ACPIDMAP_VID4RD_S_FORCE_SET_MSK 0x80000000
2500 /* The mask used to clear the ALT_ACPIDMAP_VID4RD_S_FORCE register field value. */
2501 #define ALT_ACPIDMAP_VID4RD_S_FORCE_CLR_MSK 0x7fffffff
2502 /* The reset value of the ALT_ACPIDMAP_VID4RD_S_FORCE register field is UNKNOWN. */
2503 #define ALT_ACPIDMAP_VID4RD_S_FORCE_RESET 0x0
2504 /* Extracts the ALT_ACPIDMAP_VID4RD_S_FORCE field value from a register. */
2505 #define ALT_ACPIDMAP_VID4RD_S_FORCE_GET(value) (((value) & 0x80000000) >> 31)
2506 /* Produces a ALT_ACPIDMAP_VID4RD_S_FORCE register field value suitable for setting the register. */
2507 #define ALT_ACPIDMAP_VID4RD_S_FORCE_SET(value) (((value) << 31) & 0x80000000)
2508
2509 #ifndef __ASSEMBLY__
2510 /*
2511  * WARNING: The C register and register group struct declarations are provided for
2512  * convenience and illustrative purposes. They should, however, be used with
2513  * caution as the C language standard provides no guarantees about the alignment or
2514  * atomicity of device memory accesses. The recommended practice for writing
2515  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2516  * alt_write_word() functions.
2517  *
2518  * The struct declaration for register ALT_ACPIDMAP_VID4RD_S.
2519  */
2521 {
2522  uint32_t : 4; /* *UNDEFINED* */
2523  const uint32_t user : 5; /* ARUSER value to SCU (Status) */
2524  uint32_t : 3; /* *UNDEFINED* */
2525  const uint32_t page : 2; /* ARADDR 1GB Page Decoder (Status) */
2526  uint32_t : 2; /* *UNDEFINED* */
2527  const uint32_t mid : 12; /* Remap Master ID (Status) */
2528  uint32_t : 3; /* *UNDEFINED* */
2529  const uint32_t force : 1; /* Force Mapping (Status) */
2530 };
2531
2532 /* The typedef declaration for register ALT_ACPIDMAP_VID4RD_S. */
2533 typedef volatile struct ALT_ACPIDMAP_VID4RD_S_s ALT_ACPIDMAP_VID4RD_S_t;
2534 #endif /* __ASSEMBLY__ */
2535
2536 /* The byte offset of the ALT_ACPIDMAP_VID4RD_S register from the beginning of the component. */
2537 #define ALT_ACPIDMAP_VID4RD_S_OFST 0x40
2538
2539 /*
2540  * Register : Write AXI Master Mapping Status Register for Fixed Virtual ID 4 - vid4wr_s
2541  *
2542  * The Write AXI Master Mapping Status Register contains the configured USER, ADDR
2543  * page, and ID signals mapping values for particular transaction with 12-bit ID
2544  * which locks the fixed 3-bit virtual ID.
2545  *
2546  * Register Layout
2547  *
2548  * Bits | Access | Reset | Description
2549  * :--------|:-------|:--------|:---------------------------------
2550  * [3:0] | ??? | 0x0 | *UNDEFINED*
2551  * [8:4] | R | Unknown | AWUSER value to SCU (Status)
2552  * [11:9] | ??? | 0x0 | *UNDEFINED*
2553  * [13:12] | R | Unknown | AWADDR 1GB Page Decoder (Status)
2554  * [15:14] | ??? | 0x0 | *UNDEFINED*
2555  * [27:16] | R | Unknown | Remap Master ID (Status)
2556  * [30:28] | ??? | 0x0 | *UNDEFINED*
2557  * [31] | R | Unknown | Force Mapping (Status)
2558  *
2559  */
2560 /*
2561  * Field : AWUSER value to SCU (Status) - user
2562  *
2563  * This value is propagated to SCU as AWUSERS.
2564  *
2565  * Field Access Macros:
2566  *
2567  */
2568 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID4WR_S_USER register field. */
2569 #define ALT_ACPIDMAP_VID4WR_S_USER_LSB 4
2570 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID4WR_S_USER register field. */
2571 #define ALT_ACPIDMAP_VID4WR_S_USER_MSB 8
2572 /* The width in bits of the ALT_ACPIDMAP_VID4WR_S_USER register field. */
2573 #define ALT_ACPIDMAP_VID4WR_S_USER_WIDTH 5
2574 /* The mask used to set the ALT_ACPIDMAP_VID4WR_S_USER register field value. */
2575 #define ALT_ACPIDMAP_VID4WR_S_USER_SET_MSK 0x000001f0
2576 /* The mask used to clear the ALT_ACPIDMAP_VID4WR_S_USER register field value. */
2577 #define ALT_ACPIDMAP_VID4WR_S_USER_CLR_MSK 0xfffffe0f
2578 /* The reset value of the ALT_ACPIDMAP_VID4WR_S_USER register field is UNKNOWN. */
2579 #define ALT_ACPIDMAP_VID4WR_S_USER_RESET 0x0
2580 /* Extracts the ALT_ACPIDMAP_VID4WR_S_USER field value from a register. */
2581 #define ALT_ACPIDMAP_VID4WR_S_USER_GET(value) (((value) & 0x000001f0) >> 4)
2582 /* Produces a ALT_ACPIDMAP_VID4WR_S_USER register field value suitable for setting the register. */
2583 #define ALT_ACPIDMAP_VID4WR_S_USER_SET(value) (((value) << 4) & 0x000001f0)
2584
2585 /*
2586  * Field : AWADDR 1GB Page Decoder (Status) - page
2587  *
2588  * AWADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
2589  *
2590  * Field Access Macros:
2591  *
2592  */
2593 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID4WR_S_PAGE register field. */
2594 #define ALT_ACPIDMAP_VID4WR_S_PAGE_LSB 12
2595 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID4WR_S_PAGE register field. */
2596 #define ALT_ACPIDMAP_VID4WR_S_PAGE_MSB 13
2597 /* The width in bits of the ALT_ACPIDMAP_VID4WR_S_PAGE register field. */
2598 #define ALT_ACPIDMAP_VID4WR_S_PAGE_WIDTH 2
2599 /* The mask used to set the ALT_ACPIDMAP_VID4WR_S_PAGE register field value. */
2600 #define ALT_ACPIDMAP_VID4WR_S_PAGE_SET_MSK 0x00003000
2601 /* The mask used to clear the ALT_ACPIDMAP_VID4WR_S_PAGE register field value. */
2602 #define ALT_ACPIDMAP_VID4WR_S_PAGE_CLR_MSK 0xffffcfff
2603 /* The reset value of the ALT_ACPIDMAP_VID4WR_S_PAGE register field is UNKNOWN. */
2604 #define ALT_ACPIDMAP_VID4WR_S_PAGE_RESET 0x0
2605 /* Extracts the ALT_ACPIDMAP_VID4WR_S_PAGE field value from a register. */
2606 #define ALT_ACPIDMAP_VID4WR_S_PAGE_GET(value) (((value) & 0x00003000) >> 12)
2607 /* Produces a ALT_ACPIDMAP_VID4WR_S_PAGE register field value suitable for setting the register. */
2608 #define ALT_ACPIDMAP_VID4WR_S_PAGE_SET(value) (((value) << 12) & 0x00003000)
2609
2610 /*
2611  * Field : Remap Master ID (Status) - mid
2612  *
2613  * The 12-bit ID of the master to remap to 3-bit virtual ID N, where N is the 3-bit
2614  * ID to use.
2615  *
2616  * Field Access Macros:
2617  *
2618  */
2619 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID4WR_S_MID register field. */
2620 #define ALT_ACPIDMAP_VID4WR_S_MID_LSB 16
2621 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID4WR_S_MID register field. */
2622 #define ALT_ACPIDMAP_VID4WR_S_MID_MSB 27
2623 /* The width in bits of the ALT_ACPIDMAP_VID4WR_S_MID register field. */
2624 #define ALT_ACPIDMAP_VID4WR_S_MID_WIDTH 12
2625 /* The mask used to set the ALT_ACPIDMAP_VID4WR_S_MID register field value. */
2626 #define ALT_ACPIDMAP_VID4WR_S_MID_SET_MSK 0x0fff0000
2627 /* The mask used to clear the ALT_ACPIDMAP_VID4WR_S_MID register field value. */
2628 #define ALT_ACPIDMAP_VID4WR_S_MID_CLR_MSK 0xf000ffff
2629 /* The reset value of the ALT_ACPIDMAP_VID4WR_S_MID register field is UNKNOWN. */
2630 #define ALT_ACPIDMAP_VID4WR_S_MID_RESET 0x0
2631 /* Extracts the ALT_ACPIDMAP_VID4WR_S_MID field value from a register. */
2632 #define ALT_ACPIDMAP_VID4WR_S_MID_GET(value) (((value) & 0x0fff0000) >> 16)
2633 /* Produces a ALT_ACPIDMAP_VID4WR_S_MID register field value suitable for setting the register. */
2634 #define ALT_ACPIDMAP_VID4WR_S_MID_SET(value) (((value) << 16) & 0x0fff0000)
2635
2636 /*
2637  * Field : Force Mapping (Status) - force
2638  *
2639  * Set to 1 to force the mapping between the 12-bit ID and 3-bit virtual ID N. Set
2640  * to 0 to allow the 3-bit ID N to be dynamically allocated.
2641  *
2642  * Field Access Macros:
2643  *
2644  */
2645 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID4WR_S_FORCE register field. */
2646 #define ALT_ACPIDMAP_VID4WR_S_FORCE_LSB 31
2647 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID4WR_S_FORCE register field. */
2648 #define ALT_ACPIDMAP_VID4WR_S_FORCE_MSB 31
2649 /* The width in bits of the ALT_ACPIDMAP_VID4WR_S_FORCE register field. */
2650 #define ALT_ACPIDMAP_VID4WR_S_FORCE_WIDTH 1
2651 /* The mask used to set the ALT_ACPIDMAP_VID4WR_S_FORCE register field value. */
2652 #define ALT_ACPIDMAP_VID4WR_S_FORCE_SET_MSK 0x80000000
2653 /* The mask used to clear the ALT_ACPIDMAP_VID4WR_S_FORCE register field value. */
2654 #define ALT_ACPIDMAP_VID4WR_S_FORCE_CLR_MSK 0x7fffffff
2655 /* The reset value of the ALT_ACPIDMAP_VID4WR_S_FORCE register field is UNKNOWN. */
2656 #define ALT_ACPIDMAP_VID4WR_S_FORCE_RESET 0x0
2657 /* Extracts the ALT_ACPIDMAP_VID4WR_S_FORCE field value from a register. */
2658 #define ALT_ACPIDMAP_VID4WR_S_FORCE_GET(value) (((value) & 0x80000000) >> 31)
2659 /* Produces a ALT_ACPIDMAP_VID4WR_S_FORCE register field value suitable for setting the register. */
2660 #define ALT_ACPIDMAP_VID4WR_S_FORCE_SET(value) (((value) << 31) & 0x80000000)
2661
2662 #ifndef __ASSEMBLY__
2663 /*
2664  * WARNING: The C register and register group struct declarations are provided for
2665  * convenience and illustrative purposes. They should, however, be used with
2666  * caution as the C language standard provides no guarantees about the alignment or
2667  * atomicity of device memory accesses. The recommended practice for writing
2668  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2669  * alt_write_word() functions.
2670  *
2671  * The struct declaration for register ALT_ACPIDMAP_VID4WR_S.
2672  */
2674 {
2675  uint32_t : 4; /* *UNDEFINED* */
2676  const uint32_t user : 5; /* AWUSER value to SCU (Status) */
2677  uint32_t : 3; /* *UNDEFINED* */
2678  const uint32_t page : 2; /* AWADDR 1GB Page Decoder (Status) */
2679  uint32_t : 2; /* *UNDEFINED* */
2680  const uint32_t mid : 12; /* Remap Master ID (Status) */
2681  uint32_t : 3; /* *UNDEFINED* */
2682  const uint32_t force : 1; /* Force Mapping (Status) */
2683 };
2684
2685 /* The typedef declaration for register ALT_ACPIDMAP_VID4WR_S. */
2686 typedef volatile struct ALT_ACPIDMAP_VID4WR_S_s ALT_ACPIDMAP_VID4WR_S_t;
2687 #endif /* __ASSEMBLY__ */
2688
2689 /* The byte offset of the ALT_ACPIDMAP_VID4WR_S register from the beginning of the component. */
2690 #define ALT_ACPIDMAP_VID4WR_S_OFST 0x44
2691
2692 /*
2693  * Register : Read AXI Master Mapping Status Register for Fixed Virtual ID 5 - vid5rd_s
2694  *
2695  * The Read AXI Master Mapping Status Register contains the configured USER, ADDR
2696  * page, and ID signals mapping values for particular transaction with 12-bit ID
2697  * which locks the fixed 3-bit virtual ID.
2698  *
2699  * Register Layout
2700  *
2701  * Bits | Access | Reset | Description
2702  * :--------|:-------|:--------|:---------------------------------
2703  * [3:0] | ??? | 0x0 | *UNDEFINED*
2704  * [8:4] | R | Unknown | ARUSER value to SCU (Status)
2705  * [11:9] | ??? | 0x0 | *UNDEFINED*
2706  * [13:12] | R | Unknown | ARADDR 1GB Page Decoder (Status)
2707  * [15:14] | ??? | 0x0 | *UNDEFINED*
2708  * [27:16] | R | Unknown | Remap Master ID (Status)
2709  * [30:28] | ??? | 0x0 | *UNDEFINED*
2710  * [31] | R | Unknown | Force Mapping (Status)
2711  *
2712  */
2713 /*
2714  * Field : ARUSER value to SCU (Status) - user
2715  *
2716  * This value is propagated to SCU as ARUSERS.
2717  *
2718  * Field Access Macros:
2719  *
2720  */
2721 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID5RD_S_USER register field. */
2722 #define ALT_ACPIDMAP_VID5RD_S_USER_LSB 4
2723 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID5RD_S_USER register field. */
2724 #define ALT_ACPIDMAP_VID5RD_S_USER_MSB 8
2725 /* The width in bits of the ALT_ACPIDMAP_VID5RD_S_USER register field. */
2726 #define ALT_ACPIDMAP_VID5RD_S_USER_WIDTH 5
2727 /* The mask used to set the ALT_ACPIDMAP_VID5RD_S_USER register field value. */
2728 #define ALT_ACPIDMAP_VID5RD_S_USER_SET_MSK 0x000001f0
2729 /* The mask used to clear the ALT_ACPIDMAP_VID5RD_S_USER register field value. */
2730 #define ALT_ACPIDMAP_VID5RD_S_USER_CLR_MSK 0xfffffe0f
2731 /* The reset value of the ALT_ACPIDMAP_VID5RD_S_USER register field is UNKNOWN. */
2732 #define ALT_ACPIDMAP_VID5RD_S_USER_RESET 0x0
2733 /* Extracts the ALT_ACPIDMAP_VID5RD_S_USER field value from a register. */
2734 #define ALT_ACPIDMAP_VID5RD_S_USER_GET(value) (((value) & 0x000001f0) >> 4)
2735 /* Produces a ALT_ACPIDMAP_VID5RD_S_USER register field value suitable for setting the register. */
2736 #define ALT_ACPIDMAP_VID5RD_S_USER_SET(value) (((value) << 4) & 0x000001f0)
2737
2738 /*
2739  * Field : ARADDR 1GB Page Decoder (Status) - page
2740  *
2741  * ARADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
2742  *
2743  * Field Access Macros:
2744  *
2745  */
2746 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID5RD_S_PAGE register field. */
2747 #define ALT_ACPIDMAP_VID5RD_S_PAGE_LSB 12
2748 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID5RD_S_PAGE register field. */
2749 #define ALT_ACPIDMAP_VID5RD_S_PAGE_MSB 13
2750 /* The width in bits of the ALT_ACPIDMAP_VID5RD_S_PAGE register field. */
2751 #define ALT_ACPIDMAP_VID5RD_S_PAGE_WIDTH 2
2752 /* The mask used to set the ALT_ACPIDMAP_VID5RD_S_PAGE register field value. */
2753 #define ALT_ACPIDMAP_VID5RD_S_PAGE_SET_MSK 0x00003000
2754 /* The mask used to clear the ALT_ACPIDMAP_VID5RD_S_PAGE register field value. */
2755 #define ALT_ACPIDMAP_VID5RD_S_PAGE_CLR_MSK 0xffffcfff
2756 /* The reset value of the ALT_ACPIDMAP_VID5RD_S_PAGE register field is UNKNOWN. */
2757 #define ALT_ACPIDMAP_VID5RD_S_PAGE_RESET 0x0
2758 /* Extracts the ALT_ACPIDMAP_VID5RD_S_PAGE field value from a register. */
2759 #define ALT_ACPIDMAP_VID5RD_S_PAGE_GET(value) (((value) & 0x00003000) >> 12)
2760 /* Produces a ALT_ACPIDMAP_VID5RD_S_PAGE register field value suitable for setting the register. */
2761 #define ALT_ACPIDMAP_VID5RD_S_PAGE_SET(value) (((value) << 12) & 0x00003000)
2762
2763 /*
2764  * Field : Remap Master ID (Status) - mid
2765  *
2766  * The 12-bit ID of the master to remap to 3-bit virtual ID N, where N is the 3-bit
2767  * ID to use.
2768  *
2769  * Field Access Macros:
2770  *
2771  */
2772 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID5RD_S_MID register field. */
2773 #define ALT_ACPIDMAP_VID5RD_S_MID_LSB 16
2774 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID5RD_S_MID register field. */
2775 #define ALT_ACPIDMAP_VID5RD_S_MID_MSB 27
2776 /* The width in bits of the ALT_ACPIDMAP_VID5RD_S_MID register field. */
2777 #define ALT_ACPIDMAP_VID5RD_S_MID_WIDTH 12
2778 /* The mask used to set the ALT_ACPIDMAP_VID5RD_S_MID register field value. */
2779 #define ALT_ACPIDMAP_VID5RD_S_MID_SET_MSK 0x0fff0000
2780 /* The mask used to clear the ALT_ACPIDMAP_VID5RD_S_MID register field value. */
2781 #define ALT_ACPIDMAP_VID5RD_S_MID_CLR_MSK 0xf000ffff
2782 /* The reset value of the ALT_ACPIDMAP_VID5RD_S_MID register field is UNKNOWN. */
2783 #define ALT_ACPIDMAP_VID5RD_S_MID_RESET 0x0
2784 /* Extracts the ALT_ACPIDMAP_VID5RD_S_MID field value from a register. */
2785 #define ALT_ACPIDMAP_VID5RD_S_MID_GET(value) (((value) & 0x0fff0000) >> 16)
2786 /* Produces a ALT_ACPIDMAP_VID5RD_S_MID register field value suitable for setting the register. */
2787 #define ALT_ACPIDMAP_VID5RD_S_MID_SET(value) (((value) << 16) & 0x0fff0000)
2788
2789 /*
2790  * Field : Force Mapping (Status) - force
2791  *
2792  * Set to 1 to force the mapping between the 12-bit ID and 3-bit virtual ID N. Set
2793  * to 0 to allow the 3-bit ID N to be dynamically allocated.
2794  *
2795  * Field Access Macros:
2796  *
2797  */
2798 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID5RD_S_FORCE register field. */
2799 #define ALT_ACPIDMAP_VID5RD_S_FORCE_LSB 31
2800 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID5RD_S_FORCE register field. */
2801 #define ALT_ACPIDMAP_VID5RD_S_FORCE_MSB 31
2802 /* The width in bits of the ALT_ACPIDMAP_VID5RD_S_FORCE register field. */
2803 #define ALT_ACPIDMAP_VID5RD_S_FORCE_WIDTH 1
2804 /* The mask used to set the ALT_ACPIDMAP_VID5RD_S_FORCE register field value. */
2805 #define ALT_ACPIDMAP_VID5RD_S_FORCE_SET_MSK 0x80000000
2806 /* The mask used to clear the ALT_ACPIDMAP_VID5RD_S_FORCE register field value. */
2807 #define ALT_ACPIDMAP_VID5RD_S_FORCE_CLR_MSK 0x7fffffff
2808 /* The reset value of the ALT_ACPIDMAP_VID5RD_S_FORCE register field is UNKNOWN. */
2809 #define ALT_ACPIDMAP_VID5RD_S_FORCE_RESET 0x0
2810 /* Extracts the ALT_ACPIDMAP_VID5RD_S_FORCE field value from a register. */
2811 #define ALT_ACPIDMAP_VID5RD_S_FORCE_GET(value) (((value) & 0x80000000) >> 31)
2812 /* Produces a ALT_ACPIDMAP_VID5RD_S_FORCE register field value suitable for setting the register. */
2813 #define ALT_ACPIDMAP_VID5RD_S_FORCE_SET(value) (((value) << 31) & 0x80000000)
2814
2815 #ifndef __ASSEMBLY__
2816 /*
2817  * WARNING: The C register and register group struct declarations are provided for
2818  * convenience and illustrative purposes. They should, however, be used with
2819  * caution as the C language standard provides no guarantees about the alignment or
2820  * atomicity of device memory accesses. The recommended practice for writing
2821  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2822  * alt_write_word() functions.
2823  *
2824  * The struct declaration for register ALT_ACPIDMAP_VID5RD_S.
2825  */
2827 {
2828  uint32_t : 4; /* *UNDEFINED* */
2829  const uint32_t user : 5; /* ARUSER value to SCU (Status) */
2830  uint32_t : 3; /* *UNDEFINED* */
2831  const uint32_t page : 2; /* ARADDR 1GB Page Decoder (Status) */
2832  uint32_t : 2; /* *UNDEFINED* */
2833  const uint32_t mid : 12; /* Remap Master ID (Status) */
2834  uint32_t : 3; /* *UNDEFINED* */
2835  const uint32_t force : 1; /* Force Mapping (Status) */
2836 };
2837
2838 /* The typedef declaration for register ALT_ACPIDMAP_VID5RD_S. */
2839 typedef volatile struct ALT_ACPIDMAP_VID5RD_S_s ALT_ACPIDMAP_VID5RD_S_t;
2840 #endif /* __ASSEMBLY__ */
2841
2842 /* The byte offset of the ALT_ACPIDMAP_VID5RD_S register from the beginning of the component. */
2843 #define ALT_ACPIDMAP_VID5RD_S_OFST 0x48
2844
2845 /*
2846  * Register : Write AXI Master Mapping Status Register for Fixed Virtual ID 5 - vid5wr_s
2847  *
2848  * The Write AXI Master Mapping Status Register contains the configured USER, ADDR
2849  * page, and ID signals mapping values for particular transaction with 12-bit ID
2850  * which locks the fixed 3-bit virtual ID.
2851  *
2852  * Register Layout
2853  *
2854  * Bits | Access | Reset | Description
2855  * :--------|:-------|:--------|:---------------------------------
2856  * [3:0] | ??? | 0x0 | *UNDEFINED*
2857  * [8:4] | R | Unknown | AWUSER value to SCU (Status)
2858  * [11:9] | ??? | 0x0 | *UNDEFINED*
2859  * [13:12] | R | Unknown | AWADDR 1GB Page Decoder (Status)
2860  * [15:14] | ??? | 0x0 | *UNDEFINED*
2861  * [27:16] | R | Unknown | Remap Master ID (Status)
2862  * [30:28] | ??? | 0x0 | *UNDEFINED*
2863  * [31] | R | Unknown | Force Mapping (Status)
2864  *
2865  */
2866 /*
2867  * Field : AWUSER value to SCU (Status) - user
2868  *
2869  * This value is propagated to SCU as AWUSERS.
2870  *
2871  * Field Access Macros:
2872  *
2873  */
2874 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID5WR_S_USER register field. */
2875 #define ALT_ACPIDMAP_VID5WR_S_USER_LSB 4
2876 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID5WR_S_USER register field. */
2877 #define ALT_ACPIDMAP_VID5WR_S_USER_MSB 8
2878 /* The width in bits of the ALT_ACPIDMAP_VID5WR_S_USER register field. */
2879 #define ALT_ACPIDMAP_VID5WR_S_USER_WIDTH 5
2880 /* The mask used to set the ALT_ACPIDMAP_VID5WR_S_USER register field value. */
2881 #define ALT_ACPIDMAP_VID5WR_S_USER_SET_MSK 0x000001f0
2882 /* The mask used to clear the ALT_ACPIDMAP_VID5WR_S_USER register field value. */
2883 #define ALT_ACPIDMAP_VID5WR_S_USER_CLR_MSK 0xfffffe0f
2884 /* The reset value of the ALT_ACPIDMAP_VID5WR_S_USER register field is UNKNOWN. */
2885 #define ALT_ACPIDMAP_VID5WR_S_USER_RESET 0x0
2886 /* Extracts the ALT_ACPIDMAP_VID5WR_S_USER field value from a register. */
2887 #define ALT_ACPIDMAP_VID5WR_S_USER_GET(value) (((value) & 0x000001f0) >> 4)
2888 /* Produces a ALT_ACPIDMAP_VID5WR_S_USER register field value suitable for setting the register. */
2889 #define ALT_ACPIDMAP_VID5WR_S_USER_SET(value) (((value) << 4) & 0x000001f0)
2890
2891 /*
2892  * Field : AWADDR 1GB Page Decoder (Status) - page
2893  *
2894  * AWADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
2895  *
2896  * Field Access Macros:
2897  *
2898  */
2899 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID5WR_S_PAGE register field. */
2900 #define ALT_ACPIDMAP_VID5WR_S_PAGE_LSB 12
2901 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID5WR_S_PAGE register field. */
2902 #define ALT_ACPIDMAP_VID5WR_S_PAGE_MSB 13
2903 /* The width in bits of the ALT_ACPIDMAP_VID5WR_S_PAGE register field. */
2904 #define ALT_ACPIDMAP_VID5WR_S_PAGE_WIDTH 2
2905 /* The mask used to set the ALT_ACPIDMAP_VID5WR_S_PAGE register field value. */
2906 #define ALT_ACPIDMAP_VID5WR_S_PAGE_SET_MSK 0x00003000
2907 /* The mask used to clear the ALT_ACPIDMAP_VID5WR_S_PAGE register field value. */
2908 #define ALT_ACPIDMAP_VID5WR_S_PAGE_CLR_MSK 0xffffcfff
2909 /* The reset value of the ALT_ACPIDMAP_VID5WR_S_PAGE register field is UNKNOWN. */
2910 #define ALT_ACPIDMAP_VID5WR_S_PAGE_RESET 0x0
2911 /* Extracts the ALT_ACPIDMAP_VID5WR_S_PAGE field value from a register. */
2912 #define ALT_ACPIDMAP_VID5WR_S_PAGE_GET(value) (((value) & 0x00003000) >> 12)
2913 /* Produces a ALT_ACPIDMAP_VID5WR_S_PAGE register field value suitable for setting the register. */
2914 #define ALT_ACPIDMAP_VID5WR_S_PAGE_SET(value) (((value) << 12) & 0x00003000)
2915
2916 /*
2917  * Field : Remap Master ID (Status) - mid
2918  *
2919  * The 12-bit ID of the master to remap to 3-bit virtual ID N, where N is the 3-bit
2920  * ID to use.
2921  *
2922  * Field Access Macros:
2923  *
2924  */
2925 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID5WR_S_MID register field. */
2926 #define ALT_ACPIDMAP_VID5WR_S_MID_LSB 16
2927 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID5WR_S_MID register field. */
2928 #define ALT_ACPIDMAP_VID5WR_S_MID_MSB 27
2929 /* The width in bits of the ALT_ACPIDMAP_VID5WR_S_MID register field. */
2930 #define ALT_ACPIDMAP_VID5WR_S_MID_WIDTH 12
2931 /* The mask used to set the ALT_ACPIDMAP_VID5WR_S_MID register field value. */
2932 #define ALT_ACPIDMAP_VID5WR_S_MID_SET_MSK 0x0fff0000
2933 /* The mask used to clear the ALT_ACPIDMAP_VID5WR_S_MID register field value. */
2934 #define ALT_ACPIDMAP_VID5WR_S_MID_CLR_MSK 0xf000ffff
2935 /* The reset value of the ALT_ACPIDMAP_VID5WR_S_MID register field is UNKNOWN. */
2936 #define ALT_ACPIDMAP_VID5WR_S_MID_RESET 0x0
2937 /* Extracts the ALT_ACPIDMAP_VID5WR_S_MID field value from a register. */
2938 #define ALT_ACPIDMAP_VID5WR_S_MID_GET(value) (((value) & 0x0fff0000) >> 16)
2939 /* Produces a ALT_ACPIDMAP_VID5WR_S_MID register field value suitable for setting the register. */
2940 #define ALT_ACPIDMAP_VID5WR_S_MID_SET(value) (((value) << 16) & 0x0fff0000)
2941
2942 /*
2943  * Field : Force Mapping (Status) - force
2944  *
2945  * Set to 1 to force the mapping between the 12-bit ID and 3-bit virtual ID N. Set
2946  * to 0 to allow the 3-bit ID N to be dynamically allocated.
2947  *
2948  * Field Access Macros:
2949  *
2950  */
2951 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID5WR_S_FORCE register field. */
2952 #define ALT_ACPIDMAP_VID5WR_S_FORCE_LSB 31
2953 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID5WR_S_FORCE register field. */
2954 #define ALT_ACPIDMAP_VID5WR_S_FORCE_MSB 31
2955 /* The width in bits of the ALT_ACPIDMAP_VID5WR_S_FORCE register field. */
2956 #define ALT_ACPIDMAP_VID5WR_S_FORCE_WIDTH 1
2957 /* The mask used to set the ALT_ACPIDMAP_VID5WR_S_FORCE register field value. */
2958 #define ALT_ACPIDMAP_VID5WR_S_FORCE_SET_MSK 0x80000000
2959 /* The mask used to clear the ALT_ACPIDMAP_VID5WR_S_FORCE register field value. */
2960 #define ALT_ACPIDMAP_VID5WR_S_FORCE_CLR_MSK 0x7fffffff
2961 /* The reset value of the ALT_ACPIDMAP_VID5WR_S_FORCE register field is UNKNOWN. */
2962 #define ALT_ACPIDMAP_VID5WR_S_FORCE_RESET 0x0
2963 /* Extracts the ALT_ACPIDMAP_VID5WR_S_FORCE field value from a register. */
2964 #define ALT_ACPIDMAP_VID5WR_S_FORCE_GET(value) (((value) & 0x80000000) >> 31)
2965 /* Produces a ALT_ACPIDMAP_VID5WR_S_FORCE register field value suitable for setting the register. */
2966 #define ALT_ACPIDMAP_VID5WR_S_FORCE_SET(value) (((value) << 31) & 0x80000000)
2967
2968 #ifndef __ASSEMBLY__
2969 /*
2970  * WARNING: The C register and register group struct declarations are provided for
2971  * convenience and illustrative purposes. They should, however, be used with
2972  * caution as the C language standard provides no guarantees about the alignment or
2973  * atomicity of device memory accesses. The recommended practice for writing
2974  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2975  * alt_write_word() functions.
2976  *
2977  * The struct declaration for register ALT_ACPIDMAP_VID5WR_S.
2978  */
2980 {
2981  uint32_t : 4; /* *UNDEFINED* */
2982  const uint32_t user : 5; /* AWUSER value to SCU (Status) */
2983  uint32_t : 3; /* *UNDEFINED* */
2984  const uint32_t page : 2; /* AWADDR 1GB Page Decoder (Status) */
2985  uint32_t : 2; /* *UNDEFINED* */
2986  const uint32_t mid : 12; /* Remap Master ID (Status) */
2987  uint32_t : 3; /* *UNDEFINED* */
2988  const uint32_t force : 1; /* Force Mapping (Status) */
2989 };
2990
2991 /* The typedef declaration for register ALT_ACPIDMAP_VID5WR_S. */
2992 typedef volatile struct ALT_ACPIDMAP_VID5WR_S_s ALT_ACPIDMAP_VID5WR_S_t;
2993 #endif /* __ASSEMBLY__ */
2994
2995 /* The byte offset of the ALT_ACPIDMAP_VID5WR_S register from the beginning of the component. */
2996 #define ALT_ACPIDMAP_VID5WR_S_OFST 0x4c
2997
2998 /*
2999  * Register : Read AXI Master Mapping Status Register for Fixed Virtual ID 6 - vid6rd_s
3000  *
3001  * The Read AXI Master Mapping Status Register contains the configured USER, ADDR
3002  * page, and ID signals mapping values for particular transaction with 12-bit ID
3003  * which locks the fixed 3-bit virtual ID.
3004  *
3005  * Register Layout
3006  *
3007  * Bits | Access | Reset | Description
3008  * :--------|:-------|:--------|:---------------------------------
3009  * [3:0] | ??? | 0x0 | *UNDEFINED*
3010  * [8:4] | R | Unknown | ARUSER value to SCU (Status)
3011  * [11:9] | ??? | 0x0 | *UNDEFINED*
3012  * [13:12] | R | Unknown | ARADDR 1GB Page Decoder (Status)
3013  * [15:14] | ??? | 0x0 | *UNDEFINED*
3014  * [27:16] | R | Unknown | Remap Master ID (Status)
3015  * [30:28] | ??? | 0x0 | *UNDEFINED*
3016  * [31] | R | Unknown | Force Mapping (Status)
3017  *
3018  */
3019 /*
3020  * Field : ARUSER value to SCU (Status) - user
3021  *
3022  * This value is propagated to SCU as ARUSERS.
3023  *
3024  * Field Access Macros:
3025  *
3026  */
3027 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID6RD_S_USER register field. */
3028 #define ALT_ACPIDMAP_VID6RD_S_USER_LSB 4
3029 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID6RD_S_USER register field. */
3030 #define ALT_ACPIDMAP_VID6RD_S_USER_MSB 8
3031 /* The width in bits of the ALT_ACPIDMAP_VID6RD_S_USER register field. */
3032 #define ALT_ACPIDMAP_VID6RD_S_USER_WIDTH 5
3033 /* The mask used to set the ALT_ACPIDMAP_VID6RD_S_USER register field value. */
3034 #define ALT_ACPIDMAP_VID6RD_S_USER_SET_MSK 0x000001f0
3035 /* The mask used to clear the ALT_ACPIDMAP_VID6RD_S_USER register field value. */
3036 #define ALT_ACPIDMAP_VID6RD_S_USER_CLR_MSK 0xfffffe0f
3037 /* The reset value of the ALT_ACPIDMAP_VID6RD_S_USER register field is UNKNOWN. */
3038 #define ALT_ACPIDMAP_VID6RD_S_USER_RESET 0x0
3039 /* Extracts the ALT_ACPIDMAP_VID6RD_S_USER field value from a register. */
3040 #define ALT_ACPIDMAP_VID6RD_S_USER_GET(value) (((value) & 0x000001f0) >> 4)
3041 /* Produces a ALT_ACPIDMAP_VID6RD_S_USER register field value suitable for setting the register. */
3042 #define ALT_ACPIDMAP_VID6RD_S_USER_SET(value) (((value) << 4) & 0x000001f0)
3043
3044 /*
3045  * Field : ARADDR 1GB Page Decoder (Status) - page
3046  *
3047  * ARADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
3048  *
3049  * Field Access Macros:
3050  *
3051  */
3052 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID6RD_S_PAGE register field. */
3053 #define ALT_ACPIDMAP_VID6RD_S_PAGE_LSB 12
3054 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID6RD_S_PAGE register field. */
3055 #define ALT_ACPIDMAP_VID6RD_S_PAGE_MSB 13
3056 /* The width in bits of the ALT_ACPIDMAP_VID6RD_S_PAGE register field. */
3057 #define ALT_ACPIDMAP_VID6RD_S_PAGE_WIDTH 2
3058 /* The mask used to set the ALT_ACPIDMAP_VID6RD_S_PAGE register field value. */
3059 #define ALT_ACPIDMAP_VID6RD_S_PAGE_SET_MSK 0x00003000
3060 /* The mask used to clear the ALT_ACPIDMAP_VID6RD_S_PAGE register field value. */
3061 #define ALT_ACPIDMAP_VID6RD_S_PAGE_CLR_MSK 0xffffcfff
3062 /* The reset value of the ALT_ACPIDMAP_VID6RD_S_PAGE register field is UNKNOWN. */
3063 #define ALT_ACPIDMAP_VID6RD_S_PAGE_RESET 0x0
3064 /* Extracts the ALT_ACPIDMAP_VID6RD_S_PAGE field value from a register. */
3065 #define ALT_ACPIDMAP_VID6RD_S_PAGE_GET(value) (((value) & 0x00003000) >> 12)
3066 /* Produces a ALT_ACPIDMAP_VID6RD_S_PAGE register field value suitable for setting the register. */
3067 #define ALT_ACPIDMAP_VID6RD_S_PAGE_SET(value) (((value) << 12) & 0x00003000)
3068
3069 /*
3070  * Field : Remap Master ID (Status) - mid
3071  *
3072  * The 12-bit ID of the master to remap to 3-bit virtual ID N, where N is the 3-bit
3073  * ID to use.
3074  *
3075  * Field Access Macros:
3076  *
3077  */
3078 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID6RD_S_MID register field. */
3079 #define ALT_ACPIDMAP_VID6RD_S_MID_LSB 16
3080 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID6RD_S_MID register field. */
3081 #define ALT_ACPIDMAP_VID6RD_S_MID_MSB 27
3082 /* The width in bits of the ALT_ACPIDMAP_VID6RD_S_MID register field. */
3083 #define ALT_ACPIDMAP_VID6RD_S_MID_WIDTH 12
3084 /* The mask used to set the ALT_ACPIDMAP_VID6RD_S_MID register field value. */
3085 #define ALT_ACPIDMAP_VID6RD_S_MID_SET_MSK 0x0fff0000
3086 /* The mask used to clear the ALT_ACPIDMAP_VID6RD_S_MID register field value. */
3087 #define ALT_ACPIDMAP_VID6RD_S_MID_CLR_MSK 0xf000ffff
3088 /* The reset value of the ALT_ACPIDMAP_VID6RD_S_MID register field is UNKNOWN. */
3089 #define ALT_ACPIDMAP_VID6RD_S_MID_RESET 0x0
3090 /* Extracts the ALT_ACPIDMAP_VID6RD_S_MID field value from a register. */
3091 #define ALT_ACPIDMAP_VID6RD_S_MID_GET(value) (((value) & 0x0fff0000) >> 16)
3092 /* Produces a ALT_ACPIDMAP_VID6RD_S_MID register field value suitable for setting the register. */
3093 #define ALT_ACPIDMAP_VID6RD_S_MID_SET(value) (((value) << 16) & 0x0fff0000)
3094
3095 /*
3096  * Field : Force Mapping (Status) - force
3097  *
3098  * Set to 1 to force the mapping between the 12-bit ID and 3-bit virtual ID N. Set
3099  * to 0 to allow the 3-bit ID N to be dynamically allocated.
3100  *
3101  * Field Access Macros:
3102  *
3103  */
3104 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID6RD_S_FORCE register field. */
3105 #define ALT_ACPIDMAP_VID6RD_S_FORCE_LSB 31
3106 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID6RD_S_FORCE register field. */
3107 #define ALT_ACPIDMAP_VID6RD_S_FORCE_MSB 31
3108 /* The width in bits of the ALT_ACPIDMAP_VID6RD_S_FORCE register field. */
3109 #define ALT_ACPIDMAP_VID6RD_S_FORCE_WIDTH 1
3110 /* The mask used to set the ALT_ACPIDMAP_VID6RD_S_FORCE register field value. */
3111 #define ALT_ACPIDMAP_VID6RD_S_FORCE_SET_MSK 0x80000000
3112 /* The mask used to clear the ALT_ACPIDMAP_VID6RD_S_FORCE register field value. */
3113 #define ALT_ACPIDMAP_VID6RD_S_FORCE_CLR_MSK 0x7fffffff
3114 /* The reset value of the ALT_ACPIDMAP_VID6RD_S_FORCE register field is UNKNOWN. */
3115 #define ALT_ACPIDMAP_VID6RD_S_FORCE_RESET 0x0
3116 /* Extracts the ALT_ACPIDMAP_VID6RD_S_FORCE field value from a register. */
3117 #define ALT_ACPIDMAP_VID6RD_S_FORCE_GET(value) (((value) & 0x80000000) >> 31)
3118 /* Produces a ALT_ACPIDMAP_VID6RD_S_FORCE register field value suitable for setting the register. */
3119 #define ALT_ACPIDMAP_VID6RD_S_FORCE_SET(value) (((value) << 31) & 0x80000000)
3120
3121 #ifndef __ASSEMBLY__
3122 /*
3123  * WARNING: The C register and register group struct declarations are provided for
3124  * convenience and illustrative purposes. They should, however, be used with
3125  * caution as the C language standard provides no guarantees about the alignment or
3126  * atomicity of device memory accesses. The recommended practice for writing
3127  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3128  * alt_write_word() functions.
3129  *
3130  * The struct declaration for register ALT_ACPIDMAP_VID6RD_S.
3131  */
3133 {
3134  uint32_t : 4; /* *UNDEFINED* */
3135  const uint32_t user : 5; /* ARUSER value to SCU (Status) */
3136  uint32_t : 3; /* *UNDEFINED* */
3137  const uint32_t page : 2; /* ARADDR 1GB Page Decoder (Status) */
3138  uint32_t : 2; /* *UNDEFINED* */
3139  const uint32_t mid : 12; /* Remap Master ID (Status) */
3140  uint32_t : 3; /* *UNDEFINED* */
3141  const uint32_t force : 1; /* Force Mapping (Status) */
3142 };
3143
3144 /* The typedef declaration for register ALT_ACPIDMAP_VID6RD_S. */
3145 typedef volatile struct ALT_ACPIDMAP_VID6RD_S_s ALT_ACPIDMAP_VID6RD_S_t;
3146 #endif /* __ASSEMBLY__ */
3147
3148 /* The byte offset of the ALT_ACPIDMAP_VID6RD_S register from the beginning of the component. */
3149 #define ALT_ACPIDMAP_VID6RD_S_OFST 0x50
3150
3151 /*
3152  * Register : Write AXI Master Mapping Status Register for Fixed Virtual ID 6 - vid6wr_s
3153  *
3154  * The Write AXI Master Mapping Status Register contains the configured USER, ADDR
3155  * page, and ID signals mapping values for particular transaction with 12-bit ID
3156  * which locks the fixed 3-bit virtual ID.
3157  *
3158  * Register Layout
3159  *
3160  * Bits | Access | Reset | Description
3161  * :--------|:-------|:--------|:---------------------------------
3162  * [3:0] | ??? | 0x0 | *UNDEFINED*
3163  * [8:4] | R | Unknown | AWUSER value to SCU (Status)
3164  * [11:9] | ??? | 0x0 | *UNDEFINED*
3165  * [13:12] | R | Unknown | AWADDR 1GB Page Decoder (Status)
3166  * [15:14] | ??? | 0x0 | *UNDEFINED*
3167  * [27:16] | R | Unknown | Remap Master ID (Status)
3168  * [30:28] | ??? | 0x0 | *UNDEFINED*
3169  * [31] | R | Unknown | Force Mapping (Status)
3170  *
3171  */
3172 /*
3173  * Field : AWUSER value to SCU (Status) - user
3174  *
3175  * This value is propagated to SCU as AWUSERS.
3176  *
3177  * Field Access Macros:
3178  *
3179  */
3180 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID6WR_S_USER register field. */
3181 #define ALT_ACPIDMAP_VID6WR_S_USER_LSB 4
3182 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID6WR_S_USER register field. */
3183 #define ALT_ACPIDMAP_VID6WR_S_USER_MSB 8
3184 /* The width in bits of the ALT_ACPIDMAP_VID6WR_S_USER register field. */
3185 #define ALT_ACPIDMAP_VID6WR_S_USER_WIDTH 5
3186 /* The mask used to set the ALT_ACPIDMAP_VID6WR_S_USER register field value. */
3187 #define ALT_ACPIDMAP_VID6WR_S_USER_SET_MSK 0x000001f0
3188 /* The mask used to clear the ALT_ACPIDMAP_VID6WR_S_USER register field value. */
3189 #define ALT_ACPIDMAP_VID6WR_S_USER_CLR_MSK 0xfffffe0f
3190 /* The reset value of the ALT_ACPIDMAP_VID6WR_S_USER register field is UNKNOWN. */
3191 #define ALT_ACPIDMAP_VID6WR_S_USER_RESET 0x0
3192 /* Extracts the ALT_ACPIDMAP_VID6WR_S_USER field value from a register. */
3193 #define ALT_ACPIDMAP_VID6WR_S_USER_GET(value) (((value) & 0x000001f0) >> 4)
3194 /* Produces a ALT_ACPIDMAP_VID6WR_S_USER register field value suitable for setting the register. */
3195 #define ALT_ACPIDMAP_VID6WR_S_USER_SET(value) (((value) << 4) & 0x000001f0)
3196
3197 /*
3198  * Field : AWADDR 1GB Page Decoder (Status) - page
3199  *
3200  * AWADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
3201  *
3202  * Field Access Macros:
3203  *
3204  */
3205 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID6WR_S_PAGE register field. */
3206 #define ALT_ACPIDMAP_VID6WR_S_PAGE_LSB 12
3207 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID6WR_S_PAGE register field. */
3208 #define ALT_ACPIDMAP_VID6WR_S_PAGE_MSB 13
3209 /* The width in bits of the ALT_ACPIDMAP_VID6WR_S_PAGE register field. */
3210 #define ALT_ACPIDMAP_VID6WR_S_PAGE_WIDTH 2
3211 /* The mask used to set the ALT_ACPIDMAP_VID6WR_S_PAGE register field value. */
3212 #define ALT_ACPIDMAP_VID6WR_S_PAGE_SET_MSK 0x00003000
3213 /* The mask used to clear the ALT_ACPIDMAP_VID6WR_S_PAGE register field value. */
3214 #define ALT_ACPIDMAP_VID6WR_S_PAGE_CLR_MSK 0xffffcfff
3215 /* The reset value of the ALT_ACPIDMAP_VID6WR_S_PAGE register field is UNKNOWN. */
3216 #define ALT_ACPIDMAP_VID6WR_S_PAGE_RESET 0x0
3217 /* Extracts the ALT_ACPIDMAP_VID6WR_S_PAGE field value from a register. */
3218 #define ALT_ACPIDMAP_VID6WR_S_PAGE_GET(value) (((value) & 0x00003000) >> 12)
3219 /* Produces a ALT_ACPIDMAP_VID6WR_S_PAGE register field value suitable for setting the register. */
3220 #define ALT_ACPIDMAP_VID6WR_S_PAGE_SET(value) (((value) << 12) & 0x00003000)
3221
3222 /*
3223  * Field : Remap Master ID (Status) - mid
3224  *
3225  * The 12-bit ID of the master to remap to 3-bit virtual ID N, where N is the 3-bit
3226  * ID to use.
3227  *
3228  * Field Access Macros:
3229  *
3230  */
3231 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID6WR_S_MID register field. */
3232 #define ALT_ACPIDMAP_VID6WR_S_MID_LSB 16
3233 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID6WR_S_MID register field. */
3234 #define ALT_ACPIDMAP_VID6WR_S_MID_MSB 27
3235 /* The width in bits of the ALT_ACPIDMAP_VID6WR_S_MID register field. */
3236 #define ALT_ACPIDMAP_VID6WR_S_MID_WIDTH 12
3237 /* The mask used to set the ALT_ACPIDMAP_VID6WR_S_MID register field value. */
3238 #define ALT_ACPIDMAP_VID6WR_S_MID_SET_MSK 0x0fff0000
3239 /* The mask used to clear the ALT_ACPIDMAP_VID6WR_S_MID register field value. */
3240 #define ALT_ACPIDMAP_VID6WR_S_MID_CLR_MSK 0xf000ffff
3241 /* The reset value of the ALT_ACPIDMAP_VID6WR_S_MID register field is UNKNOWN. */
3242 #define ALT_ACPIDMAP_VID6WR_S_MID_RESET 0x0
3243 /* Extracts the ALT_ACPIDMAP_VID6WR_S_MID field value from a register. */
3244 #define ALT_ACPIDMAP_VID6WR_S_MID_GET(value) (((value) & 0x0fff0000) >> 16)
3245 /* Produces a ALT_ACPIDMAP_VID6WR_S_MID register field value suitable for setting the register. */
3246 #define ALT_ACPIDMAP_VID6WR_S_MID_SET(value) (((value) << 16) & 0x0fff0000)
3247
3248 /*
3249  * Field : Force Mapping (Status) - force
3250  *
3251  * Set to 1 to force the mapping between the 12-bit ID and 3-bit virtual ID N. Set
3252  * to 0 to allow the 3-bit ID N to be dynamically allocated.
3253  *
3254  * Field Access Macros:
3255  *
3256  */
3257 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_VID6WR_S_FORCE register field. */
3258 #define ALT_ACPIDMAP_VID6WR_S_FORCE_LSB 31
3259 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_VID6WR_S_FORCE register field. */
3260 #define ALT_ACPIDMAP_VID6WR_S_FORCE_MSB 31
3261 /* The width in bits of the ALT_ACPIDMAP_VID6WR_S_FORCE register field. */
3262 #define ALT_ACPIDMAP_VID6WR_S_FORCE_WIDTH 1
3263 /* The mask used to set the ALT_ACPIDMAP_VID6WR_S_FORCE register field value. */
3264 #define ALT_ACPIDMAP_VID6WR_S_FORCE_SET_MSK 0x80000000
3265 /* The mask used to clear the ALT_ACPIDMAP_VID6WR_S_FORCE register field value. */
3266 #define ALT_ACPIDMAP_VID6WR_S_FORCE_CLR_MSK 0x7fffffff
3267 /* The reset value of the ALT_ACPIDMAP_VID6WR_S_FORCE register field is UNKNOWN. */
3268 #define ALT_ACPIDMAP_VID6WR_S_FORCE_RESET 0x0
3269 /* Extracts the ALT_ACPIDMAP_VID6WR_S_FORCE field value from a register. */
3270 #define ALT_ACPIDMAP_VID6WR_S_FORCE_GET(value) (((value) & 0x80000000) >> 31)
3271 /* Produces a ALT_ACPIDMAP_VID6WR_S_FORCE register field value suitable for setting the register. */
3272 #define ALT_ACPIDMAP_VID6WR_S_FORCE_SET(value) (((value) << 31) & 0x80000000)
3273
3274 #ifndef __ASSEMBLY__
3275 /*
3276  * WARNING: The C register and register group struct declarations are provided for
3277  * convenience and illustrative purposes. They should, however, be used with
3278  * caution as the C language standard provides no guarantees about the alignment or
3279  * atomicity of device memory accesses. The recommended practice for writing
3280  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3281  * alt_write_word() functions.
3282  *
3283  * The struct declaration for register ALT_ACPIDMAP_VID6WR_S.
3284  */
3286 {
3287  uint32_t : 4; /* *UNDEFINED* */
3288  const uint32_t user : 5; /* AWUSER value to SCU (Status) */
3289  uint32_t : 3; /* *UNDEFINED* */
3290  const uint32_t page : 2; /* AWADDR 1GB Page Decoder (Status) */
3291  uint32_t : 2; /* *UNDEFINED* */
3292  const uint32_t mid : 12; /* Remap Master ID (Status) */
3293  uint32_t : 3; /* *UNDEFINED* */
3294  const uint32_t force : 1; /* Force Mapping (Status) */
3295 };
3296
3297 /* The typedef declaration for register ALT_ACPIDMAP_VID6WR_S. */
3298 typedef volatile struct ALT_ACPIDMAP_VID6WR_S_s ALT_ACPIDMAP_VID6WR_S_t;
3299 #endif /* __ASSEMBLY__ */
3300
3301 /* The byte offset of the ALT_ACPIDMAP_VID6WR_S register from the beginning of the component. */
3302 #define ALT_ACPIDMAP_VID6WR_S_OFST 0x54
3303
3304 /*
3305  * Register : Read AXI Master Mapping Status Register for Dynamic Virtual ID Remap - dynrd_s
3306  *
3307  * The Read AXI Master Mapping Status Register contains the configured USER, and
3308  * ADDR page signals mapping values for transaction that dynamically remapped to
3309  * one of the available 3-bit virtual IDs.
3310  *
3311  * Register Layout
3312  *
3313  * Bits | Access | Reset | Description
3314  * :--------|:-------|:--------|:---------------------------------
3315  * [3:0] | ??? | 0x0 | *UNDEFINED*
3316  * [8:4] | R | Unknown | ARUSER value to SCU (Status)
3317  * [11:9] | ??? | 0x0 | *UNDEFINED*
3318  * [13:12] | R | Unknown | ARADDR 1GB Page Decoder (Status)
3319  * [31:14] | ??? | 0x0 | *UNDEFINED*
3320  *
3321  */
3322 /*
3323  * Field : ARUSER value to SCU (Status) - user
3324  *
3325  * This value is propagated to SCU as ARUSERS.
3326  *
3327  * Field Access Macros:
3328  *
3329  */
3330 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_DYNRD_S_USER register field. */
3331 #define ALT_ACPIDMAP_DYNRD_S_USER_LSB 4
3332 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_DYNRD_S_USER register field. */
3333 #define ALT_ACPIDMAP_DYNRD_S_USER_MSB 8
3334 /* The width in bits of the ALT_ACPIDMAP_DYNRD_S_USER register field. */
3335 #define ALT_ACPIDMAP_DYNRD_S_USER_WIDTH 5
3336 /* The mask used to set the ALT_ACPIDMAP_DYNRD_S_USER register field value. */
3337 #define ALT_ACPIDMAP_DYNRD_S_USER_SET_MSK 0x000001f0
3338 /* The mask used to clear the ALT_ACPIDMAP_DYNRD_S_USER register field value. */
3339 #define ALT_ACPIDMAP_DYNRD_S_USER_CLR_MSK 0xfffffe0f
3340 /* The reset value of the ALT_ACPIDMAP_DYNRD_S_USER register field is UNKNOWN. */
3341 #define ALT_ACPIDMAP_DYNRD_S_USER_RESET 0x0
3342 /* Extracts the ALT_ACPIDMAP_DYNRD_S_USER field value from a register. */
3343 #define ALT_ACPIDMAP_DYNRD_S_USER_GET(value) (((value) & 0x000001f0) >> 4)
3344 /* Produces a ALT_ACPIDMAP_DYNRD_S_USER register field value suitable for setting the register. */
3345 #define ALT_ACPIDMAP_DYNRD_S_USER_SET(value) (((value) << 4) & 0x000001f0)
3346
3347 /*
3348  * Field : ARADDR 1GB Page Decoder (Status) - page
3349  *
3350  * ARADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
3351  *
3352  * Field Access Macros:
3353  *
3354  */
3355 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_DYNRD_S_PAGE register field. */
3356 #define ALT_ACPIDMAP_DYNRD_S_PAGE_LSB 12
3357 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_DYNRD_S_PAGE register field. */
3358 #define ALT_ACPIDMAP_DYNRD_S_PAGE_MSB 13
3359 /* The width in bits of the ALT_ACPIDMAP_DYNRD_S_PAGE register field. */
3360 #define ALT_ACPIDMAP_DYNRD_S_PAGE_WIDTH 2
3361 /* The mask used to set the ALT_ACPIDMAP_DYNRD_S_PAGE register field value. */
3362 #define ALT_ACPIDMAP_DYNRD_S_PAGE_SET_MSK 0x00003000
3363 /* The mask used to clear the ALT_ACPIDMAP_DYNRD_S_PAGE register field value. */
3364 #define ALT_ACPIDMAP_DYNRD_S_PAGE_CLR_MSK 0xffffcfff
3365 /* The reset value of the ALT_ACPIDMAP_DYNRD_S_PAGE register field is UNKNOWN. */
3366 #define ALT_ACPIDMAP_DYNRD_S_PAGE_RESET 0x0
3367 /* Extracts the ALT_ACPIDMAP_DYNRD_S_PAGE field value from a register. */
3368 #define ALT_ACPIDMAP_DYNRD_S_PAGE_GET(value) (((value) & 0x00003000) >> 12)
3369 /* Produces a ALT_ACPIDMAP_DYNRD_S_PAGE register field value suitable for setting the register. */
3370 #define ALT_ACPIDMAP_DYNRD_S_PAGE_SET(value) (((value) << 12) & 0x00003000)
3371
3372 #ifndef __ASSEMBLY__
3373 /*
3374  * WARNING: The C register and register group struct declarations are provided for
3375  * convenience and illustrative purposes. They should, however, be used with
3376  * caution as the C language standard provides no guarantees about the alignment or
3377  * atomicity of device memory accesses. The recommended practice for writing
3378  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3379  * alt_write_word() functions.
3380  *
3381  * The struct declaration for register ALT_ACPIDMAP_DYNRD_S.
3382  */
3384 {
3385  uint32_t : 4; /* *UNDEFINED* */
3386  const uint32_t user : 5; /* ARUSER value to SCU (Status) */
3387  uint32_t : 3; /* *UNDEFINED* */
3388  const uint32_t page : 2; /* ARADDR 1GB Page Decoder (Status) */
3389  uint32_t : 18; /* *UNDEFINED* */
3390 };
3391
3392 /* The typedef declaration for register ALT_ACPIDMAP_DYNRD_S. */
3393 typedef volatile struct ALT_ACPIDMAP_DYNRD_S_s ALT_ACPIDMAP_DYNRD_S_t;
3394 #endif /* __ASSEMBLY__ */
3395
3396 /* The byte offset of the ALT_ACPIDMAP_DYNRD_S register from the beginning of the component. */
3397 #define ALT_ACPIDMAP_DYNRD_S_OFST 0x58
3398
3399 /*
3400  * Register : Write AXI Master Mapping Status Register for Dynamic Virtual ID Remap - dynwr_s
3401  *
3402  * The Write AXI Master Mapping Status Register contains the configured USER, and
3403  * ADDR page signals mapping values for transaction that dynamically remapped to
3404  * one of the available 3-bit virtual IDs.
3405  *
3406  * Register Layout
3407  *
3408  * Bits | Access | Reset | Description
3409  * :--------|:-------|:--------|:---------------------------------
3410  * [3:0] | ??? | 0x0 | *UNDEFINED*
3411  * [8:4] | R | Unknown | AWUSER value to SCU (Status)
3412  * [11:9] | ??? | 0x0 | *UNDEFINED*
3413  * [13:12] | R | Unknown | AWADDR 1GB Page Decoder (Status)
3414  * [31:14] | ??? | 0x0 | *UNDEFINED*
3415  *
3416  */
3417 /*
3418  * Field : AWUSER value to SCU (Status) - user
3419  *
3420  * This value is propagated to SCU as AWUSERS.
3421  *
3422  * Field Access Macros:
3423  *
3424  */
3425 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_DYNWR_S_USER register field. */
3426 #define ALT_ACPIDMAP_DYNWR_S_USER_LSB 4
3427 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_DYNWR_S_USER register field. */
3428 #define ALT_ACPIDMAP_DYNWR_S_USER_MSB 8
3429 /* The width in bits of the ALT_ACPIDMAP_DYNWR_S_USER register field. */
3430 #define ALT_ACPIDMAP_DYNWR_S_USER_WIDTH 5
3431 /* The mask used to set the ALT_ACPIDMAP_DYNWR_S_USER register field value. */
3432 #define ALT_ACPIDMAP_DYNWR_S_USER_SET_MSK 0x000001f0
3433 /* The mask used to clear the ALT_ACPIDMAP_DYNWR_S_USER register field value. */
3434 #define ALT_ACPIDMAP_DYNWR_S_USER_CLR_MSK 0xfffffe0f
3435 /* The reset value of the ALT_ACPIDMAP_DYNWR_S_USER register field is UNKNOWN. */
3436 #define ALT_ACPIDMAP_DYNWR_S_USER_RESET 0x0
3437 /* Extracts the ALT_ACPIDMAP_DYNWR_S_USER field value from a register. */
3438 #define ALT_ACPIDMAP_DYNWR_S_USER_GET(value) (((value) & 0x000001f0) >> 4)
3439 /* Produces a ALT_ACPIDMAP_DYNWR_S_USER register field value suitable for setting the register. */
3440 #define ALT_ACPIDMAP_DYNWR_S_USER_SET(value) (((value) << 4) & 0x000001f0)
3441
3442 /*
3443  * Field : AWADDR 1GB Page Decoder (Status) - page
3444  *
3445  * AWADDR remap to 1st, 2nd, 3rd, or 4th 1GB memory region.
3446  *
3447  * Field Access Macros:
3448  *
3449  */
3450 /* The Least Significant Bit (LSB) position of the ALT_ACPIDMAP_DYNWR_S_PAGE register field. */
3451 #define ALT_ACPIDMAP_DYNWR_S_PAGE_LSB 12
3452 /* The Most Significant Bit (MSB) position of the ALT_ACPIDMAP_DYNWR_S_PAGE register field. */
3453 #define ALT_ACPIDMAP_DYNWR_S_PAGE_MSB 13
3454 /* The width in bits of the ALT_ACPIDMAP_DYNWR_S_PAGE register field. */
3455 #define ALT_ACPIDMAP_DYNWR_S_PAGE_WIDTH 2
3456 /* The mask used to set the ALT_ACPIDMAP_DYNWR_S_PAGE register field value. */
3457 #define ALT_ACPIDMAP_DYNWR_S_PAGE_SET_MSK 0x00003000
3458 /* The mask used to clear the ALT_ACPIDMAP_DYNWR_S_PAGE register field value. */
3459 #define ALT_ACPIDMAP_DYNWR_S_PAGE_CLR_MSK 0xffffcfff
3460 /* The reset value of the ALT_ACPIDMAP_DYNWR_S_PAGE register field is UNKNOWN. */
3461 #define ALT_ACPIDMAP_DYNWR_S_PAGE_RESET 0x0
3462 /* Extracts the ALT_ACPIDMAP_DYNWR_S_PAGE field value from a register. */
3463 #define ALT_ACPIDMAP_DYNWR_S_PAGE_GET(value) (((value) & 0x00003000) >> 12)
3464 /* Produces a ALT_ACPIDMAP_DYNWR_S_PAGE register field value suitable for setting the register. */
3465 #define ALT_ACPIDMAP_DYNWR_S_PAGE_SET(value) (((value) << 12) & 0x00003000)
3466
3467 #ifndef __ASSEMBLY__
3468 /*
3469  * WARNING: The C register and register group struct declarations are provided for
3470  * convenience and illustrative purposes. They should, however, be used with
3471  * caution as the C language standard provides no guarantees about the alignment or
3472  * atomicity of device memory accesses. The recommended practice for writing
3473  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3474  * alt_write_word() functions.
3475  *
3476  * The struct declaration for register ALT_ACPIDMAP_DYNWR_S.
3477  */
3479 {
3480  uint32_t : 4; /* *UNDEFINED* */
3481  const uint32_t user : 5; /* AWUSER value to SCU (Status) */
3482  uint32_t : 3; /* *UNDEFINED* */
3483  const uint32_t page : 2; /* AWADDR 1GB Page Decoder (Status) */
3484  uint32_t : 18; /* *UNDEFINED* */
3485 };
3486
3487 /* The typedef declaration for register ALT_ACPIDMAP_DYNWR_S. */
3488 typedef volatile struct ALT_ACPIDMAP_DYNWR_S_s ALT_ACPIDMAP_DYNWR_S_t;
3489 #endif /* __ASSEMBLY__ */
3490
3491 /* The byte offset of the ALT_ACPIDMAP_DYNWR_S register from the beginning of the component. */
3492 #define ALT_ACPIDMAP_DYNWR_S_OFST 0x5c
3493
3494 #ifndef __ASSEMBLY__
3495 /*
3496  * WARNING: The C register and register group struct declarations are provided for
3497  * convenience and illustrative purposes. They should, however, be used with
3498  * caution as the C language standard provides no guarantees about the alignment or
3499  * atomicity of device memory accesses. The recommended practice for writing
3500  * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3501  * alt_write_word() functions.
3502  *
3503  * The struct declaration for register group ALT_ACPIDMAP.
3504  */
3506 {
3507  volatile ALT_ACPIDMAP_VID2RD_t vid2rd; /* ALT_ACPIDMAP_VID2RD */
3508  volatile ALT_ACPIDMAP_VID2WR_t vid2wr; /* ALT_ACPIDMAP_VID2WR */
3509  volatile ALT_ACPIDMAP_VID3RD_t vid3rd; /* ALT_ACPIDMAP_VID3RD */
3510  volatile ALT_ACPIDMAP_VID3WR_t vid3wr; /* ALT_ACPIDMAP_VID3WR */
3511  volatile ALT_ACPIDMAP_VID4RD_t vid4rd; /* ALT_ACPIDMAP_VID4RD */
3512  volatile ALT_ACPIDMAP_VID4WR_t vid4wr; /* ALT_ACPIDMAP_VID4WR */
3513  volatile ALT_ACPIDMAP_VID5RD_t vid5rd; /* ALT_ACPIDMAP_VID5RD */
3514  volatile ALT_ACPIDMAP_VID5WR_t vid5wr; /* ALT_ACPIDMAP_VID5WR */
3515  volatile ALT_ACPIDMAP_VID6RD_t vid6rd; /* ALT_ACPIDMAP_VID6RD */
3516  volatile ALT_ACPIDMAP_VID6WR_t vid6wr; /* ALT_ACPIDMAP_VID6WR */
3517  volatile ALT_ACPIDMAP_DYNRD_t dynrd; /* ALT_ACPIDMAP_DYNRD */
3518  volatile ALT_ACPIDMAP_DYNWR_t dynwr; /* ALT_ACPIDMAP_DYNWR */
3519  volatile ALT_ACPIDMAP_VID2RD_S_t vid2rd_s; /* ALT_ACPIDMAP_VID2RD_S */
3520  volatile ALT_ACPIDMAP_VID2WR_S_t vid2wr_s; /* ALT_ACPIDMAP_VID2WR_S */
3521  volatile ALT_ACPIDMAP_VID3RD_S_t vid3rd_s; /* ALT_ACPIDMAP_VID3RD_S */
3522  volatile ALT_ACPIDMAP_VID3WR_S_t vid3wr_s; /* ALT_ACPIDMAP_VID3WR_S */
3523  volatile ALT_ACPIDMAP_VID4RD_S_t vid4rd_s; /* ALT_ACPIDMAP_VID4RD_S */
3524  volatile ALT_ACPIDMAP_VID4WR_S_t vid4wr_s; /* ALT_ACPIDMAP_VID4WR_S */
3525  volatile ALT_ACPIDMAP_VID5RD_S_t vid5rd_s; /* ALT_ACPIDMAP_VID5RD_S */
3526  volatile ALT_ACPIDMAP_VID5WR_S_t vid5wr_s; /* ALT_ACPIDMAP_VID5WR_S */
3527  volatile ALT_ACPIDMAP_VID6RD_S_t vid6rd_s; /* ALT_ACPIDMAP_VID6RD_S */
3528  volatile ALT_ACPIDMAP_VID6WR_S_t vid6wr_s; /* ALT_ACPIDMAP_VID6WR_S */
3529  volatile ALT_ACPIDMAP_DYNRD_S_t dynrd_s; /* ALT_ACPIDMAP_DYNRD_S */
3530  volatile ALT_ACPIDMAP_DYNWR_S_t dynwr_s; /* ALT_ACPIDMAP_DYNWR_S */
3531  volatile uint32_t _pad_0x60_0x1000[1000]; /* *UNDEFINED* */
3532 };
3533
3534 /* The typedef declaration for register group ALT_ACPIDMAP. */
3535 typedef volatile struct ALT_ACPIDMAP_s ALT_ACPIDMAP_t;
3536 /* The struct declaration for the raw register contents of register group ALT_ACPIDMAP. */
3538 {
3539  volatile uint32_t vid2rd; /* ALT_ACPIDMAP_VID2RD */
3540  volatile uint32_t vid2wr; /* ALT_ACPIDMAP_VID2WR */
3541  volatile uint32_t vid3rd; /* ALT_ACPIDMAP_VID3RD */
3542  volatile uint32_t vid3wr; /* ALT_ACPIDMAP_VID3WR */
3543  volatile uint32_t vid4rd; /* ALT_ACPIDMAP_VID4RD */
3544  volatile uint32_t vid4wr; /* ALT_ACPIDMAP_VID4WR */
3545  volatile uint32_t vid5rd; /* ALT_ACPIDMAP_VID5RD */
3546  volatile uint32_t vid5wr; /* ALT_ACPIDMAP_VID5WR */
3547  volatile uint32_t vid6rd; /* ALT_ACPIDMAP_VID6RD */
3548  volatile uint32_t vid6wr; /* ALT_ACPIDMAP_VID6WR */
3549  volatile uint32_t dynrd; /* ALT_ACPIDMAP_DYNRD */
3550  volatile uint32_t dynwr; /* ALT_ACPIDMAP_DYNWR */
3551  volatile uint32_t vid2rd_s; /* ALT_ACPIDMAP_VID2RD_S */
3552  volatile uint32_t vid2wr_s; /* ALT_ACPIDMAP_VID2WR_S */
3553  volatile uint32_t vid3rd_s; /* ALT_ACPIDMAP_VID3RD_S */
3554  volatile uint32_t vid3wr_s; /* ALT_ACPIDMAP_VID3WR_S */
3555  volatile uint32_t vid4rd_s; /* ALT_ACPIDMAP_VID4RD_S */
3556  volatile uint32_t vid4wr_s; /* ALT_ACPIDMAP_VID4WR_S */
3557  volatile uint32_t vid5rd_s; /* ALT_ACPIDMAP_VID5RD_S */
3558  volatile uint32_t vid5wr_s; /* ALT_ACPIDMAP_VID5WR_S */
3559  volatile uint32_t vid6rd_s; /* ALT_ACPIDMAP_VID6RD_S */
3560  volatile uint32_t vid6wr_s; /* ALT_ACPIDMAP_VID6WR_S */
3561  volatile uint32_t dynrd_s; /* ALT_ACPIDMAP_DYNRD_S */
3562  volatile uint32_t dynwr_s; /* ALT_ACPIDMAP_DYNWR_S */
3563  volatile uint32_t _pad_0x60_0x1000[1000]; /* *UNDEFINED* */
3564 };
3565
3566 /* The typedef declaration for the raw register contents of register group ALT_ACPIDMAP. */
3567 typedef volatile struct ALT_ACPIDMAP_raw_s ALT_ACPIDMAP_raw_t;
3568 #endif /* __ASSEMBLY__ */
3569
3570
3571 #ifdef __cplusplus
3572 }
3573 #endif /* __cplusplus */
3574 #endif /* __ALTERA_ALT_ACPIDMAP_H__ */
3575
Definition: alt_acpidmap.h:494
Definition: alt_acpidmap.h:3478
Definition: alt_acpidmap.h:3505
Definition: alt_acpidmap.h:1663
Definition: alt_acpidmap.h:3383
Definition: alt_acpidmap.h:1259
Definition: alt_acpidmap.h:341
Definition: alt_acpidmap.h:1412
Definition: misc.c:36
Definition: alt_acpidmap.h:647
Definition: alt_acpidmap.h:800
Definition: alt_acpidmap.h:3537
Definition: alt_acpidmap.h:1758
Definition: alt_acpidmap.h:2367
Definition: alt_acpidmap.h:3285
Definition: alt_acpidmap.h:2979
Definition: alt_acpidmap.h:2673
Definition: alt_acpidmap.h:2061
Definition: alt_acpidmap.h:1565
Definition: alt_acpidmap.h:953
Definition: alt_acpidmap.h:2214
Definition: alt_acpidmap.h:3132
Definition: alt_acpidmap.h:2826
Definition: alt_acpidmap.h:2520
Definition: alt_acpidmap.h:1106
Definition: alt_acpidmap.h:1908
Definition: alt_acpidmap.h:188
