RTEMS  5.1
aio_misc.h
1
9 /*
10  * Copyright 2010, Alin Rus <alin.codejunkie@gmail.com>
11  *
12  * The license and distribution terms for this file may be
13  * found in the file LICENSE in this distribution or at
14  * http://www.rtems.org/license/LICENSE.
15  */
16
17 #ifndef _AIO_MISC_H
18 #define _AIO_MISC_H
19
20 #include <stdio.h>
21 #include <string.h>
22 #include <aio.h>
23 #include <pthread.h>
24 #include <rtems.h>
25 #include <rtems/chain.h>
26 #include <rtems/seterr.h>
27
28 #ifdef __cplusplus
29 extern "C"
30 {
31 #endif
32
33  /* Actual request being processed */
34  typedef struct
35  {
36  rtems_chain_node next_prio; /* chain requests in order of priority */
37  int policy; /* If _POSIX_PRIORITIZED_IO and
38  _POSIX_PRIORITY_SCHEDULING are defined */
39  int priority; /* see above */
40  pthread_t caller_thread; /* used for notification */
41  struct aiocb *aiocbp; /* aio control block */
43
44  typedef struct
45  {
46  rtems_chain_node next_fd; /* order fd chains in queue */
47  rtems_chain_control perfd; /* chain of requests for this fd */
48  int fildes; /* file descriptor to be processed */
49  int new_fd; /* if this is a newly created chain */
50  pthread_mutex_t mutex;
51  pthread_cond_t cond;
52
54
55  typedef struct
56  {
57  pthread_mutex_t mutex;
58  pthread_cond_t new_req;
59  pthread_attr_t attr;
60
61  rtems_chain_control work_req; /* chains being worked by active threads */
62  rtems_chain_control idle_req; /* fd chains waiting to be processed */
63  unsigned int initialized; /* specific value if queue is initialized */
64  int active_threads; /* the number of active threads */
65  int idle_threads; /* number of idle threads */
66
68
69 extern rtems_aio_queue aio_request_queue;
70
71 #define AIO_QUEUE_INITIALIZED 0xB00B
72
73 #ifndef AIO_MAX_THREADS
74 #define AIO_MAX_THREADS 5
75 #endif
76
77 #ifndef AIO_MAX_QUEUE_SIZE
78 #define AIO_MAX_QUEUE_SIZE 30
79 #endif
80
81 int rtems_aio_init (void);
82 int rtems_aio_enqueue (rtems_aio_request *req);
83 rtems_aio_request_chain *rtems_aio_search_fd
84 (
85  rtems_chain_control *chain,
86  int fildes,
87  int create
88 );
89 void rtems_aio_remove_fd (rtems_aio_request_chain *r_chain);
90 int rtems_aio_remove_req (rtems_chain_control *chain,
91  struct aiocb *aiocbp);
92
93 #ifdef RTEMS_DEBUG
94 #include <assert.h>
95
96 #define AIO_assert(_x) assert(_x)
97 #define AIO_printf(_x) printf(_x)
98 #else
99 #define AIO_assert(_x)
100 #define AIO_printf(_x)
101 #endif
102
103 #define rtems_aio_set_errno_return_minus_one( _error, _aiocbp ) \
104  do { (_aiocbp)->error_code = (_error); \
105  (_aiocbp)->return_value = -1; \
106  rtems_set_errno_and_return_minus_one (_error);} while(0)
107
108 #ifdef __cplusplus
109 }
110 #endif
111
112 #endif
Definition: chain.h:68
Data which Ease the Burden of Consistently Setting Errno.
Definition: chain.h:86
POSIX Threads Private Support.
Definition: aio_misc.h:55
Information for the Assert Handler.
Chain API.
Definition: aio_misc.h:34
Definition: aio_misc.h:44
POSIX Asynchronous Input and Output.
Definition: mutex.h:4
