RTEMS  5.1
adc-defs.h
1
9 /*
10  * Copyright (c) 2014 Taller Technologies.
11  *
12  * @author Diaz Marcos (marcos.diaz@tallertechnologies.com)
13  *
14  * The license and distribution terms for this file may be
15  * found in the file LICENSE in this distribution or at
16  * http://www.rtems.org/license/LICENSE.
17  */
18 #ifndef LPC176X_ADC_DEFS_H
19 #define LPC176X_ADC_DEFS_H
20
21 #include <bsp.h>
22 #include <bsp/io.h>
23 #include <bsp/lpc176x.h>
24 #include <bsp/adc.h>
25
26 #ifdef __cplusplus
27 extern "C" {
28 #endif /* __cplusplus */
29
33 typedef enum {
34  ADC_0,
35  ADC_1,
36  ADC_2,
37  ADC_3,
38  ADC_4,
39  ADC_5,
40  ADC_6,
41  ADC_7,
42  ADC_DEVICES_COUNT
44
45 #define MAX_ADC_CLK 13000000u
46
47 #define ADC_RANGE 0xFFFu
48
49 #define ADC_NUMBER_VALID( number ) ( ( (uint32_t) number ) < \
50  ADC_DEVICES_COUNT )
51
52 #define ADC_CR_SEL( val ) BSP_FLD32( val, 0, 7 )
53 #define ADC_CR_SEL_GET( val ) BSP_FLD32GET( val, 0, 7 )
54 #define ADC_CR_SEL_SET( reg, val ) BSP_FLD32SET( reg, val, 0, 7 )
55 #define ADC_CR_CLKDIV( val ) BSP_FLD32( val, 8, 15 )
56 #define ADC_CR_CLKDIV_GET( reg ) BSP_FLD32GET( reg, 8, 15 )
57 #define ADC_CR_CLKDIV_SET( reg, val ) BSP_FLD32SET( reg, val, 8, 15 )
58 #define ADC_CR_BURST BSP_BIT32( 16 )
59 #define ADC_CR_CLKS( val ) BSP_FLD32( val, 17, 19 )
60 #define ADC_CR_PDN BSP_BIT32( 21 )
61 #define ADC_CR_START_NOW BSP_BIT32( 24 )
62 #define ADC_CR_START( val ) BSP_FLD32( val, 24, 26 )
63 #define ADC_CR_EDGE BSP_BIT32( 27 )
64
65 #define ADC_DR_VALUE( reg ) BSP_FLD32GET( reg, 4, 15 )
66 #define ADC_DR_OVERRUN BSP_BIT32( 30 )
67 #define ADC_DR_DONE BSP_BIT32( 31 )
68
69 #define ADC_DATA_CONVERSION_DONE( val ) ( ( val & ADC_DR_DONE ) != 0u )
70
74 typedef struct {
75  volatile uint32_t ADCR;
76  volatile uint32_t ADGDR;
77  volatile uint32_t RESERVED0;
78  volatile uint32_t ADINTEN;
79  volatile uint32_t ADDR[ ADC_DEVICES_COUNT ];
80  volatile uint32_t ADSTAT;
81  volatile uint32_t ADTRM;
83
87 typedef struct {
88  uint32_t pin_number;
89  lpc176x_pin_function pin_function;
91
92 #ifdef __cplusplus
93 }
94 #endif /* __cplusplus */
95
96 #endif
The ADC low-level device.
Definition: adc-defs.h:74
Defines the functions according to the pin.
Definition: io-defs.h:68
Specific register definitions according to lpc176x family boards.
ADC library for the lpc176x bsp.
lpc176x_adc_number
The ADC inputs of the board.
Definition: adc-defs.h:33
Represents the pin and function for each ADC input.
Definition: adc-defs.h:87
