RTEMS  5.1
_kernel_uio.h
1 /*-
2  * SPDX-License-Identifier: BSD-3-Clause
3  *
4  * Copyright (c) 1982, 1986, 1993, 1994
5  * The Regents of the University of California. All rights reserved.
6  *
7  * Redistribution and use in source and binary forms, with or without
8  * modification, are permitted provided that the following conditions
9  * are met:
10  * 1. Redistributions of source code must retain the above copyright
11  * notice, this list of conditions and the following disclaimer.
12  * 2. Redistributions in binary form must reproduce the above copyright
13  * notice, this list of conditions and the following disclaimer in the
14  * documentation and/or other materials provided with the distribution.
15  * 3. Neither the name of the University nor the names of its contributors
16  * may be used to endorse or promote products derived from this software
17  * without specific prior written permission.
18  *
19  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
20  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
21  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
22  * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
23  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
24  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
25  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
26  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
27  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
28  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
29  * SUCH DAMAGE.
30  *
31  * @(#)uio.h 8.5 (Berkeley) 2/22/94
32  * $FreeBSD: head/sys/sys/uio.h 331621 2018-03-27 15:20:03Z brooks $
33  */
34
35 #if !defined(_SYS_UIO_H_) || !defined(_KERNEL)
36 #error "must be included via <sys/uio.h> in kernel space"
37 #endif
38
39 struct uio {
40  struct iovec *uio_iov; /* scatter/gather list */
41  int uio_iovcnt; /* length of scatter/gather list */
42  off_t uio_offset; /* offset in target object */
43  ssize_t uio_resid; /* remaining bytes to process */
44  enum uio_seg uio_segflg; /* address space */
45  enum uio_rw uio_rw; /* operation */
46  struct thread *uio_td; /* owner */
47 };
48
49 /*
50  * Limits
51  *
52  * N.B.: UIO_MAXIOV must be no less than IOV_MAX from <sys/syslimits.h>
53  * which in turn must be no less than _XOPEN_IOV_MAX from <limits.h>. If
54  * we ever make this tunable (probably pointless), then IOV_MAX should be
55  * removed from <sys/syslimits.h> and applications would be expected to use
56  * sysconf(3) to find out the correct value, or else assume the worst
57  * (_XOPEN_IOV_MAX). Perhaps UIO_MAXIOV should be simply defined as
58  * IOV_MAX.
59  */
60 #define UIO_MAXIOV 1024 /* max 1K of iov's */
61
62 struct vm_object;
63 struct vm_page;
64 struct bus_dma_segment;
65
66 struct uio *cloneuio(struct uio *uiop);
67 int copyinfrom(const void * __restrict src, void * __restrict dst,
68  size_t len, int seg);
69 int copyiniov(const struct iovec *iovp, u_int iovcnt, struct iovec **iov,
70  int error);
71 int copyinstrfrom(const void * __restrict src, void * __restrict dst,
72  size_t len, size_t * __restrict copied, int seg);
73 int copyinuio(const struct iovec *iovp, u_int iovcnt, struct uio **uiop);
74 int copyout_map(struct thread *td, vm_offset_t *addr, size_t sz);
75 int copyout_unmap(struct thread *td, vm_offset_t addr, size_t sz);
76 int physcopyin(void *src, vm_paddr_t dst, size_t len);
77 int physcopyout(vm_paddr_t src, void *dst, size_t len);
78 int physcopyin_vlist(struct bus_dma_segment *src, off_t offset,
79  vm_paddr_t dst, size_t len);
80 int physcopyout_vlist(vm_paddr_t src, struct bus_dma_segment *dst,
81  off_t offset, size_t len);
82 int uiomove(void *cp, int n, struct uio *uio);
83 int uiomove_frombuf(void *buf, int buflen, struct uio *uio);
84 int uiomove_fromphys(struct vm_page *ma[], vm_offset_t offset, int n,
85  struct uio *uio);
86 int uiomove_nofault(void *cp, int n, struct uio *uio);
87 int uiomove_object(struct vm_object *obj, off_t obj_size, struct uio *uio);
Definition: _kernel_uio.h:39
unsigned cp
Definition: tte.h:87
