RTEMS  5.1
VMEDMA.h
1
9 #ifndef BSP_VME_DMA_H
10 #define BSP_VME_DMA_H
11
12 /*
13  * Authorship
14  * ----------
15  * This software was created by
16  * Till Straumann <strauman@slac.stanford.edu>, 2006, 2007
17  * Stanford Linear Accelerator Center, Stanford University.
18  *
19  * Acknowledgement of sponsorship
20  * ------------------------------
21  * This software was produced by
22  * the Stanford Linear Accelerator Center, Stanford University,
23  * under Contract DE-AC03-76SFO0515 with the Department of Energy.
24  *
25  * Government disclaimer of liability
26  * ----------------------------------
27  * Neither the United States nor the United States Department of Energy,
28  * nor any of their employees, makes any warranty, express or implied, or
29  * assumes any legal liability or responsibility for the accuracy,
30  * completeness, or usefulness of any data, apparatus, product, or process
31  * disclosed, or represents that its use would not infringe privately owned
32  * rights.
33  *
34  * Stanford disclaimer of liability
35  * --------------------------------
36  * Stanford University makes no representations or warranties, express or
37  * implied, nor assumes any liability for the use of this software.
38  *
39  * Stanford disclaimer of copyright
40  * --------------------------------
41  * Stanford University, owner of the copyright, hereby disclaims its
42  * copyright and all other rights in this software. Hence, anyone may
43  * freely use it for any purpose without restriction.
44  *
45  * Maintenance of notices
46  * ----------------------
47  * In the interest of clarity regarding the origin and status of this
48  * SLAC software, this and all the preceding Stanford University notices
49  * are to remain affixed to any copy or derivative of this software made
50  * or distributed by the recipient and are to be affixed to any copy of
51  * software made or distributed by the recipient that contains a copy or
52  * derivative of this software.
53  *
54  * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
55  */
56
57 #include <stdint.h>
58
59 #ifdef __cplusplus
60 extern "C" {
61 #endif
62
72 /* NOTE: Access to DMA Channels is *not* protected / thread-safe.
73  * It is the responsability of the user to provide appropriate
74  * locking/serialization.
75  */
76
77 /* Simple abstraction of DMA controller setup / bus utilization: */
78
79 /* Since VME is the bottleneck, the settings for PCI are always
80  * chosen aggressively.
81  */
82
83
84 /* Optimize for throughput; accept longer latencies:
85  * Choose a large block size (1k) and immediately re-request
86  * the bus at block boundaries.
87  */
88 #define BSP_VMEDMA_OPT_THROUGHPUT 1
89 /* Optimize for latency, accept throughput penalty:
90  * Choose a small block size (32b) and immediately re-request
91  * the bus at block boundaries.
92  */
93 #define BSP_VMEDMA_OPT_LOWLATENCY 2
94
95 /* Optimize for bus sharing with other devices:
96  * Choose relatively small block size (128) and back off for 64us
97  * at each block boundary.
98  */
99 #define BSP_VMEDMA_OPT_SHAREDBUS 3
100
101 /* Choose bridge default/reset configuration:
102  * (see manual)
103  */
104 #define BSP_VMEDMA_OPT_DEFAULT 4
105
106 /* Provide custom configuration pass pointer to array
107  * with as many 32-bit words the particular bridge chip
108  * expects.
109  */
110 #define BSP_VMEDMA_OPT_CUSTOM 5
111
112 /* VME Transfer modes */
113
114 /* Bitwise OR of the VME address-modifier/transfer-type
115  * with driver specific (no standard AM code for 2eVME and
116  * 2eSST defined) and optional special flags (see below)
117  */
118
119 /* Additional qualifiers: */
120
121 /* Don't increment VME address */
122 #define BSP_VMEDMA_MODE_NOINC_VME (1<<20)
123 /* Don't increment PCI address */
124 #define BSP_VMEDMA_MODE_NOINC_PCI (1<<21)
125
126 /* Direction */
127 #define BSP_VMEDMA_MODE_PCI2VME (1<<31)
128
129 typedef void *BSP_VMEDmaListDescriptor;
130
131 /* Program the device for the selected mode;
132  *
133  * 'bus_mode': one of the ...VMEDMA_OPT... choices
134  * listed above.
135  * 'xfer_mode': VME address-modifier optionally ORed with
136  * ...VMEDMA_MODE... bits listed above.
137  * 'custom': (only used if bus_mode is VMEDMA_OPT_CUSTOM)
138  * pointer to a list of setup parameters (chip-driver
139  * specific).
140  *
141  * RETURNS: 0 on success, nonzero on error (mode or channel
142  * unsupported).
143  *
144  * NOTES: The setup is preserved across multiple DMA transfers.
145  * It is the responsibility of the driver to reprogram
146  * the setup if the hardware does not preserve it.
147  * However - in linked list mode, some fields may be
148  * read from the list descriptors.
149  *
150  * Usually this routine must be used even in linked-list
151  * mode to program the 'bus_mode'.
152  *
153  * Direction of transfer is specified by a bit in the
154  * 'xfer_mode' (BSP_VMEDMA_MODE_PCI2VME).
155  */
156 int
157 BSP_VMEDmaSetup(int channel, uint32_t bus_mode, uint32_t xfer_mode, void *custom_setup);
158
159 /* Start direct (not linked-list) transfer.
160  *
161  * RETURNS: 0 on success, nonzero on failure
162  */
163 int
164 BSP_VMEDmaStart(int channel, uint32_t pci_addr, uint32_t vme_addr, uint32_t n_bytes);
165
166 /* Transfer status/result */
167 #define BSP_VMEDMA_STATUS_OK 0
168 /* Unsupported channel */
169 #define BSP_VMEDMA_STATUS_UNSUP (-1)
170 /* Bus error on VME */
171 #define BSP_VMEDMA_STATUS_BERR_VME 1
172 /* Bus error on PCI */
173 #define BSP_VMEDMA_STATUS_BERR_PCI 2
174 /* Channel busy */
175 #define BSP_VMEDMA_STATUS_BUSY 3
176 /* Setup/programming error */
177 #define BSP_VMEDMA_STATUS_PERR 4
178 /* Other/unspecified error */
179 #define BSP_VMEDMA_STATUS_OERR 5
180
181 /* Retrieve status of last transfer.
182  *
183  * RETURNS: 0 if the transfer was successful,
184  * nonzero on error (e.g., one of the
185  * values defined above).
186  *
187  * NOTE: Driver is allowed to pass other,
188  * device specific codes
189  */
190
191 uint32_t
192 BSP_VMEDmaStatus(int channel);
193
194 /*
195  * Hook a callback (executed from ISR context) to DMA interrupt and
196  * enable it.
197  * If called with NULL callback then an existing callback is removed
198  * and the interrupt disabled.
199  *
200  * RETURNS: 0 on success, nonzero on failure (IRQ in use, unsupported
201  * channel).
202  */
203 typedef void (*BSP_VMEDmaIRQCallback)(void *usr_arg);
204
205 int
206 BSP_VMEDmaInstallISR(int channel, BSP_VMEDmaIRQCallback cb, void *usr_arg);
207
208 /*
209  * DMA List operations.
210  *
211  * Note that the list is totally unprotected, i.e., the user is
212  * responsible for maintaining coherency against concurrent
213  * access by multiple threads or hardware.
214  * We assume the user builds/updates a list, hands it over to
215  * the hardware (list start command) and leaves it alone until
216  * the DMA controller is done with it.
217  */
218
219 /* Modify a list entry. If the list element pointer is NULL
220  * then a new list element is allocated.
221  * Only the fields with its corresponding bit set in the mask
222  * argument are touched.
223  *
224  * RETURNS: 'd' or newly allocated descriptor or NULL (no memory,
225  * or invalid setup).
226  */
227 #define BSP_VMEDMA_MSK_ATTR (1<<0)
228 #define BSP_VMEDMA_MSK_PCIA (1<<1)
229 #define BSP_VMEDMA_MSK_VMEA (1<<2)
230 #define BSP_VMEDMA_MSK_BCNT (1<<3)
231 #define BSP_VMEDMA_MSK_ALL (0xf)
232 BSP_VMEDmaListDescriptor
233 BSP_VMEDmaListDescriptorSetup(
234  BSP_VMEDmaListDescriptor d,
235  uint32_t attr_mask,
236  uint32_t xfer_mode,
237  uint32_t pci_addr,
238  uint32_t vme_addr,
239  uint32_t n_bytes);
240
241 /* De-allocate a list descriptor previously obtained by
242  * BSP_VMEDmaListDescriptorSetup(0,...);
243  *
244  * RETURNS: 0 on success, nonzero on failure (d currently on a list)
245  */
246 int
247 BSP_VMEDmaListDescriptorDestroy(BSP_VMEDmaListDescriptor d);
248
249 /* Traverse a list of descriptors and destroy all elements */
250 int
251 BSP_VMEDmaListDestroy(BSP_VMEDmaListDescriptor anchor);
252
253 /* Enqueue a list descriptor 'd' after 'tail'
254  *
255  * If 'tail' is NULL then 'd' is removed from
256  * the list it is currently on.
257  *
258  * RETURNS: 0 on success, nonzero if 'd' is already
259  * on a list (enqueue) or if it is not currently
260  * on a list (dequeue).
261  *
262  * NOTE: it is obviously the user's responsibility to update
263  * list queue/tail pointers when changing the
264  * structure of the list.
265  */
266 int
267 BSP_VMEDmaListDescriptorEnq(
268  BSP_VMEDmaListDescriptor tail,
269  BSP_VMEDmaListDescriptor d);
270
271 /* Obtain next and previous descriptors */
272 BSP_VMEDmaListDescriptor
273 BSP_VMEDmaListDescriptorNext(BSP_VMEDmaListDescriptor d);
274
275 BSP_VMEDmaListDescriptor
276 BSP_VMEDmaListDescriptorPrev(BSP_VMEDmaListDescriptor d);
277
278 /* Set and get a 'usrData' pointer in the descriptor */
279 void
280 BSP_VMEDmaListDescriptorSetUsr(BSP_VMEDmaListDescriptor d, void *usrData);
281
282 void *
283 BSP_VMEDmaListDescriptorGetUsr(BSP_VMEDmaListDescriptor d);
284
285 /* Refresh an entire list. Some DMA controllers modify certain
286  * fields (e.g., byte count) and this command restores the original
287  * setup.
288  */
289
290 int
291 BSP_VMEDmaListRefresh(BSP_VMEDmaListDescriptor anchor);
292
293 /* Start linked-list operation.
294  *
295  * RETURNS: 0 on success, nonzero on failure
296  */
297 int
298 BSP_VMEDmaListStart(int channel, BSP_VMEDmaListDescriptor list);
299
300 #ifdef DEBUG
301 void
302 BSP_VMEDmaListDump(BSP_VMEDmaListDescriptor p);
303 #endif
304
305 #ifdef __cplusplus
306 }
307 #endif
308
309 #endif
unsigned p
Definition: tte.h:90
