RTEMS  5.1
3c509.h
1
9 /*
10  * Copyright (c) 1993 Herb Peyerl (hpeyerl@novatel.ca) All rights reserved.
11  *
12  * Redistribution and use in source and binary forms, with or without
13  * modification, are permitted provided that the following conditions are
14  * met: 1. Redistributions of source code must retain the above copyright
15  * notice, this list of conditions and the following disclaimer. 2. The name
16  * of the author may not be used to endorse or promote products derived from
17  * this software without specific prior written permission
18  *
19  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
20  * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
21  * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
22  * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
23  * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED
24  * TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
25  * PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
26  * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
27  * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
28  * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
29  *
30  * if_epreg.h,v 1.4 1994/11/13 10:12:37 gibbs Exp Modified by:
31  *
32  October 2, 1994
33
34  Modified by: Andres Vega Garcia
35
36  INRIA - Sophia Antipolis, France
37  e-mail: avega@sophia.inria.fr
38  finger: avega@pax.inria.fr
39
40  */
41 /*
42  * Promiscuous mode added and interrupt logic slightly changed
43  * to reduce the number of adapter failures. Transceiver select
44  * logic changed to use value from EEPROM. Autoconfiguration
45  * features added.
46  * Done by:
47  * Serge Babkin
48  * Chelindbank (Chelyabinsk, Russia)
49  * babkin@hq.icb.chel.su
50  */
51
52 /*
53  * Pccard support for 3C589 by:
54  * HAMADA Naoki
55  * nao@tom-yam.or.jp
56  */
57
66 /*
67 typedef unsigned short u_short;
68 typedef unsigned long u_long;
69 typedef unsigned char u_char;
70 */
71
72 /*
73  * Some global constants
74  */
75 #define F_RX_FIRST 0x1
76 #define F_PROMISC 0x8
77 #define F_ACCESS_32_BITS 0x100
78
79 #define TX_INIT_RATE 16
80 #define TX_INIT_MAX_RATE 64
81 #define RX_INIT_LATENCY 64
82 #define RX_INIT_EARLY_THRESH 208 /* not less than MINCLSIZE */
83 #define RX_NEXT_EARLY_THRESH 500
84
85 #define EEPROMSIZE 0x40
86 #define MAX_EEPROMBUSY 1000
87 #define EP_LAST_TAG 0xd7
88 #define EP_MAX_BOARDS 16
89 /*
90  * This `ID' port is a mere hack. There's currently no chance to register
91  * it with config's idea of the ports that are in use.
92  *
93  * "After the automatic configuration is completed, the IDS is in its initial
94  * state (ID-WAIT), and it monitors all write access to I/O port 01x0h, where
95  * 'x' is any hex digit. If a zero is written to any one of these ports, then
96  * that address is remembered and becomes the ID port. A second zero written
97  * to that port resets the ID sequence to its initial state. The IDS watches
98  * for the ID sequence to be written to the ID port."
99  *
100  * We prefer 0x110 over 0x100 so to not conflict with the Plaque&Pray
101  * ports.
102  */
103 #define EP_ID_PORT 0x110
104 #define EP_IOSIZE 16 /* 16 bytes of I/O space used. */
105
106 /*
107  * some macros to acces long named fields
108  */
109 #define IS_BASE (is->id_iobase)
110 #define BASE (sc->ep_io_addr)
111
112 /*
113  * Commands to read/write EEPROM trough EEPROM command register (Window 0,
114  * Offset 0xa)
115  */
116 #define EEPROM_CMD_RD 0x0080 /* Read: Address required (5 bits) */
117 #define EEPROM_CMD_WR 0x0040 /* Write: Address required (5 bits) */
118 #define EEPROM_CMD_ERASE 0x00c0 /* Erase: Address required (5 bits) */
119 #define EEPROM_CMD_EWEN 0x0030 /* Erase/Write Enable: No data required */
120
121 #define EEPROM_BUSY (1<<15)
122 #define EEPROM_TST_MODE (1<<14)
123
124 /*
125  * Some short functions, worth to let them be a macro
126  */
127 #define is_eeprom_busy(b) (inw((b)+EP_W0_EEPROM_COMMAND)&EEPROM_BUSY)
128 #define GO_WINDOW(x) outw(BASE+EP_COMMAND, WINDOW_SELECT|(x))
129
130 /**************************************************************************
131  * *
132  * These define the EEPROM data structure. They are used in the probe
133  * function to verify the existence of the adapter after having sent
134  * the ID_Sequence.
135  *
136  * There are others but only the ones we use are defined here.
137  *
138  **************************************************************************/
139
140 #define EEPROM_NODE_ADDR_0 0x0 /* Word */
141 #define EEPROM_NODE_ADDR_1 0x1 /* Word */
142 #define EEPROM_NODE_ADDR_2 0x2 /* Word */
143 #define EEPROM_PROD_ID 0x3 /* 0x9[0-f]50 */
144 #define EEPROM_MFG_ID 0x7 /* 0x6d50 */
145 #define EEPROM_ADDR_CFG 0x8 /* Base addr */
146 #define EEPROM_RESOURCE_CFG 0x9 /* IRQ. Bits 12-15 */
147
148 /**************************************************************************
149  * *
150  * These are the registers for the 3Com 3c509 and their bit patterns when *
151  * applicable. They have been taken out the the "EtherLink III Parallel *
152  * Tasking EISA and ISA Technical Reference" "Beta Draft 10/30/92" manual *
153  * from 3com. *
154  * *
155  **************************************************************************/
156
157 #define EP_COMMAND 0x0e /* Write. BASE+0x0e is always a
158  * command reg. */
159 #define EP_STATUS 0x0e /* Read. BASE+0x0e is always status
160  * reg. */
161 #define EP_WINDOW 0x0f /* Read. BASE+0x0f is always window
162  * reg. */
163 /*
164  * Window 0 registers. Setup.
165  */
166 /* Write */
167 #define EP_W0_EEPROM_DATA 0x0c
168 #define EP_W0_EEPROM_COMMAND 0x0a
169 #define EP_W0_RESOURCE_CFG 0x08
170 #define EP_W0_ADDRESS_CFG 0x06
171 #define EP_W0_CONFIG_CTRL 0x04
172 /* Read */
173 #define EP_W0_PRODUCT_ID 0x02
174 #define EP_W0_MFG_ID 0x00
175
176 /*
177  * Window 1 registers. Operating Set.
178  */
179 /* Write */
180 #define EP_W1_TX_PIO_WR_2 0x02
181 #define EP_W1_TX_PIO_WR_1 0x00
182 /* Read */
183 #define EP_W1_FREE_TX 0x0c
184 #define EP_W1_TX_STATUS 0x0b /* byte */
185 #define EP_W1_TIMER 0x0a /* byte */
186 #define EP_W1_RX_STATUS 0x08
187 #define EP_W1_RX_PIO_RD_2 0x02
188 #define EP_W1_RX_PIO_RD_1 0x00
189
190 /*
191  * Window 2 registers. Station Address Setup/Read
192  */
193 /* Read/Write */
194 #define EP_W2_ADDR_5 0x05
195 #define EP_W2_ADDR_4 0x04
196 #define EP_W2_ADDR_3 0x03
197 #define EP_W2_ADDR_2 0x02
198 #define EP_W2_ADDR_1 0x01
199 #define EP_W2_ADDR_0 0x00
200
201 /*
202  * Window 3 registers. FIFO Management.
203  */
204 /* Read */
205 #define EP_W3_FREE_TX 0x0c
206 #define EP_W3_FREE_RX 0x0a
207
208 /*
209  * Window 4 registers. Diagnostics.
210  */
211 /* Read/Write */
212 #define EP_W4_MEDIA_TYPE 0x0a
213 #define EP_W4_CTRLR_STATUS 0x08
214 #define EP_W4_NET_DIAG 0x06
215 #define EP_W4_FIFO_DIAG 0x04
216 #define EP_W4_HOST_DIAG 0x02
217 #define EP_W4_TX_DIAG 0x00
218
219 /*
220  * Window 5 Registers. Results and Internal status.
221  */
222 /* Read */
223 #define EP_W5_READ_0_MASK 0x0c
224 #define EP_W5_INTR_MASK 0x0a
225 #define EP_W5_RX_FILTER 0x08
226 #define EP_W5_RX_EARLY_THRESH 0x06
227 #define EP_W5_TX_AVAIL_THRESH 0x02
228 #define EP_W5_TX_START_THRESH 0x00
229
230 /*
231  * Window 6 registers. Statistics.
232  */
233 /* Read/Write */
234 #define TX_TOTAL_OK 0x0c
235 #define RX_TOTAL_OK 0x0a
236 #define TX_DEFERRALS 0x08
237 #define RX_FRAMES_OK 0x07
238 #define TX_FRAMES_OK 0x06
239 #define RX_OVERRUNS 0x05
240 #define TX_COLLISIONS 0x04
241 #define TX_AFTER_1_COLLISION 0x03
242 #define TX_AFTER_X_COLLISIONS 0x02
243 #define TX_NO_SQE 0x01
244 #define TX_CD_LOST 0x00
245
246 /****************************************
247  *
248  * Register definitions.
249  *
250  ****************************************/
251
252 /*
253  * Command register. All windows.
254  *
255  * 16 bit register.
256  * 15-11: 5-bit code for command to be executed.
257  * 10-0: 11-bit arg if any. For commands with no args;
258  * this can be set to anything.
259  */
260 #define GLOBAL_RESET (u_short) 0x0000 /* Wait at least 1ms
261  * after issuing */
262 #define WINDOW_SELECT (u_short) (0x1<<11)
263 #define START_TRANSCEIVER (u_short) (0x2<<11) /* Read ADDR_CFG reg to
264  * determine whether
265  * this is needed. If
266  * so; wait 800 uSec
267  * before using trans-
268  * ceiver. */
269 #define RX_DISABLE (u_short) (0x3<<11) /* state disabled on
270  * power-up */
271 #define RX_ENABLE (u_short) (0x4<<11)
272 #define RX_RESET (u_short) (0x5<<11)
273 #define RX_DISCARD_TOP_PACK (u_short) (0x8<<11)
274 #define TX_ENABLE (u_short) (0x9<<11)
275 #define TX_DISABLE (u_short) (0xa<<11)
276 #define TX_RESET (u_short) (0xb<<11)
277 #define REQ_INTR (u_short) (0xc<<11)
278 #define SET_INTR_MASK (u_short) (0xe<<11)
279 #define SET_RD_0_MASK (u_short) (0xf<<11)
280 #define SET_RX_FILTER (u_short) (0x10<<11)
281 #define FIL_INDIVIDUAL (u_short) (0x1)
282 #define FIL_GROUP (u_short) (0x2)
283 #define FIL_BRDCST (u_short) (0x4)
284 #define FIL_ALL (u_short) (0x8)
285 #define SET_RX_EARLY_THRESH (u_short) (0x11<<11)
286 #define SET_TX_AVAIL_THRESH (u_short) (0x12<<11)
287 #define SET_TX_START_THRESH (u_short) (0x13<<11)
288 #define STATS_ENABLE (u_short) (0x15<<11)
289 #define STATS_DISABLE (u_short) (0x16<<11)
290 #define STOP_TRANSCEIVER (u_short) (0x17<<11)
291 /*
292  * The following C_* acknowledge the various interrupts. Some of them don't
293  * do anything. See the manual.
294  */
295 #define ACK_INTR (u_short) (0x6800)
296 #define C_INTR_LATCH (u_short) (ACK_INTR|0x1)
297 #define C_CARD_FAILURE (u_short) (ACK_INTR|0x2)
298 #define C_TX_COMPLETE (u_short) (ACK_INTR|0x4)
299 #define C_TX_AVAIL (u_short) (ACK_INTR|0x8)
300 #define C_RX_COMPLETE (u_short) (ACK_INTR|0x10)
301 #define C_RX_EARLY (u_short) (ACK_INTR|0x20)
302 #define C_INT_RQD (u_short) (ACK_INTR|0x40)
303 #define C_UPD_STATS (u_short) (ACK_INTR|0x80)
304 #define C_MASK (u_short) 0xFF /* mask of C_* */
305
306 /*
307  * Status register. All windows.
308  *
309  * 15-13: Window number(0-7).
310  * 12: Command_in_progress.
311  * 11: reserved.
312  * 10: reserved.
313  * 9: reserved.
314  * 8: reserved.
315  * 7: Update Statistics.
316  * 6: Interrupt Requested.
317  * 5: RX Early.
318  * 4: RX Complete.
319  * 3: TX Available.
320  * 2: TX Complete.
321  * 1: Adapter Failure.
322  * 0: Interrupt Latch.
323  */
324 #define S_INTR_LATCH (u_short) (0x1)
325 #define S_CARD_FAILURE (u_short) (0x2)
326 #define S_TX_COMPLETE (u_short) (0x4)
327 #define S_TX_AVAIL (u_short) (0x8)
328 #define S_RX_COMPLETE (u_short) (0x10)
329 #define S_RX_EARLY (u_short) (0x20)
330 #define S_INT_RQD (u_short) (0x40)
331 #define S_UPD_STATS (u_short) (0x80)
332 #define S_MASK (u_short) 0xFF /* mask of S_* */
333 #define S_5_INTS (S_CARD_FAILURE|S_TX_COMPLETE|\
334  S_TX_AVAIL|S_RX_COMPLETE|S_RX_EARLY)
335 #define S_COMMAND_IN_PROGRESS (u_short) (0x1000)
336
337 /* Address Config. Register.
338  * Window 0/Port 06
339  */
340
341 #define ACF_CONNECTOR_BITS 14
342 #define ACF_CONNECTOR_UTP 0
343 #define ACF_CONNECTOR_AUI 1
344 #define ACF_CONNECTOR_BNC 3
345
346 /* Resource configuration register.
347  * Window 0/Port 08
348  *
349  */
350
351 #define SET_IRQ(base,irq) outw((base) + EP_W0_RESOURCE_CFG, \
352  ((inw((base) + EP_W0_RESOURCE_CFG) & 0x0fff) | \
353  ((u_short)(irq)<<12)) ) /* set IRQ i */
354
355 /*
356  * FIFO Registers.
357  * RX Status. Window 1/Port 08
358  *
359  * 15: Incomplete or FIFO empty.
360  * 14: 1: Error in RX Packet 0: Incomplete or no error.
361  * 13-11: Type of error.
362  * 1000 = Overrun.
363  * 1011 = Run Packet Error.
364  * 1100 = Alignment Error.
365  * 1101 = CRC Error.
366  * 1001 = Oversize Packet Error (>1514 bytes)
367  * 0010 = Dribble Bits.
368  * (all other error codes, no errors.)
369  *
370  * 10-0: RX Bytes (0-1514)
371  */
372 #define ERR_RX_INCOMPLETE (u_short) (0x1<<15)
373 #define ERR_RX (u_short) (0x1<<14)
374 #define ERR_RX_OVERRUN (u_short) (0x8<<11)
375 #define ERR_RX_RUN_PKT (u_short) (0xb<<11)
376 #define ERR_RX_ALIGN (u_short) (0xc<<11)
377 #define ERR_RX_CRC (u_short) (0xd<<11)
378 #define ERR_RX_OVERSIZE (u_short) (0x9<<11)
379 #define ERR_RX_DRIBBLE (u_short) (0x2<<11)
380
381 /*
382  * FIFO Registers.
383  * TX Status. Window 1/Port 0B
384  *
385  * Reports the transmit status of a completed transmission. Writing this
386  * register pops the transmit completion stack.
387  *
388  * Window 1/Port 0x0b.
389  *
390  * 7: Complete
391  * 6: Interrupt on successful transmission requested.
392  * 5: Jabber Error (TP Only, TX Reset required. )
393  * 4: Underrun (TX Reset required. )
394  * 3: Maximum Collisions.
395  * 2: TX Status Overflow.
396  * 1-0: Undefined.
397  *
398  */
399 #define TXS_COMPLETE 0x80
400 #define TXS_SUCCES_INTR_REQ 0x40
401 #define TXS_JABBER 0x20
402 #define TXS_UNDERRUN 0x10
403 #define TXS_MAX_COLLISION 0x8
404 #define TXS_STATUS_OVERFLOW 0x4
405
406 /*
407  * Configuration control register.
408  * Window 0/Port 04
409  */
410 /* Read */
411 #define IS_AUI (1<<13)
412 #define IS_BNC (1<<12)
413 #define IS_UTP (1<<9)
414 /* Write */
415 #define ENABLE_DRQ_IRQ 0x0001
416 #define W0_P4_CMD_RESET_ADAPTER 0x4
417 #define W0_P4_CMD_ENABLE_ADAPTER 0x1
418 /*
419  * Media type and status.
420  * Window 4/Port 0A
421  */
422 #define ENABLE_UTP 0xc0
423 #define DISABLE_UTP 0x0
424
425 /*
426  * Misc defines for various things.
427  */
428 #define ACTIVATE_ADAPTER_TO_CONFIG 0xff /* to the id_port */
429 #define MFG_ID 0x6d50 /* in EEPROM and W0 ADDR_CONFIG */
430 #define PROD_ID 0x9150
431
432 #define AUI 0x1
433 #define BNC 0x2
434 #define UTP 0x4
435
436 #define RX_BYTES_MASK (u_short) (0x07ff)
