8. Lattice Mico32 Specific Information¶
This chaper discusses the Lattice Mico32 architecture dependencies in this port of RTEMS. The Lattice Mico32 is a 32-bit Harvard, RISC architecture “soft” microprocessor, available for free with an open IP core licensing agreement. Although mainly targeted for Lattice FPGA devices the microprocessor can be implemented on other vendors’ FPGAs, too.
Architecture Documents
For information on the Lattice Mico32 architecture, refer to the following documents available from Lattice Semiconductor http://www.latticesemi.com/.
- “LatticeMico32 Processor Reference Manual” http://www.latticesemi.com/dynamic/view_document.cfm?document_id=20890
8.1. CPU Model Dependent Features¶
The Lattice Mico32 architecture allows for different configurations of the processor. This port is based on the assumption that the following options are implemented:
- hardware multiplier
- hardware divider
- hardware barrel shifter
- sign extension instructions
- instruction cache
- data cache
- debug
8.2. Register Architecture¶
This section gives a brief introduction to the register architecture of the Lattice Mico32 processor.
The Lattice Mico32 is a RISC archictecture processor with a 32-register file of 32-bit registers.
Register Name
Function
r0
holds value zero
r1-r25
general purpose
r26/gp
general pupose / global pointer
r27/fp
general pupose / frame pointer
r28/sp
stack pointer
r29/ra
return address
r30/ea
exception address
r31/ba
breakpoint address
Note that on processor startup all register values are undefined including r0, thus r0 has to be initialized to zero.
8.3. Calling Conventions¶
8.3.1. Calling Mechanism¶
A call instruction places the return address to register r29 and a return from subroutine (ret) is actually a branch to r29/ra.
8.3.2. Register Usage¶
A subroutine may freely use registers r1 to r10 which are not preserved across subroutine invocations.
8.3.3. Parameter Passing¶
When calling a C function the first eight arguments are stored in registers r1 to r8. Registers r1 and r2 hold the return value.
8.4. Memory Model¶
The Lattice Mico32 processor supports a flat memory model with a 4 Gbyte address space with 32-bit addresses.
The following data types are supported:
| Type | Bits | C Compiler Type |
| unsigned byte | 8 | unsigned char |
| signed byte | 8 | char |
| unsigned half-word | 16 | unsigned short |
| signed half-word | 16 | short |
| unsigned word | 32 | unsigned int / unsigned long |
| signed word | 32 | int / long |
Data accesses need to be aligned, with unaligned accesses result are undefined.
8.5. Interrupt Processing¶
The Lattice Mico32 has 32 interrupt lines which are however served by only one exception vector. When an interrupt occurs following happens:
- address of next instruction placed in r30/ea
- IE field of IE CSR saved to EIE field and IE field cleared preventing further exceptions from occuring.
- branch to interrupt exception address EBA CSR + 0xC0
The interrupt exception handler determines from the state of the interrupt pending registers (IP CSR) and interrupt enable register (IE CSR) which interrupt to serve and jumps to the interrupt routine pointed to by the corresponding interrupt vector.
For now there is no dedicated interrupt stack so every task in the system MUST have enough stack space to accommodate the worst case stack usage of that particular task and the interrupt service routines COMBINED.
Nested interrupts are not supported.
8.6. Default Fatal Error Processing¶
Upon detection of a fatal error by either the application or RTEMS during
initialization the rtems_fatal_error_occurred directive supplied by the
Fatal Error Manager is invoked. The Fatal Error Manager will invoke the
user-supplied fatal error handlers. If no user-supplied handlers are
configured or all of them return without taking action to shutdown the
processor or reset, a default fatal error handler is invoked.
Most of the action performed as part of processing the fatal error are described in detail in the Fatal Error Manager chapter in the User’s Guide. However, the if no user provided extension or BSP specific fatal error handler takes action, the final default action is to invoke a CPU architecture specific function. Typically this function disables interrupts and halts the processor.
In each of the architecture specific chapters, this describes the precise operations of the default CPU specific fatal error handler.
8.7. Symmetric Multiprocessing¶
SMP is not supported.
8.8. Thread-Local Storage¶
Thread-local storage is not implemented.
