| 1 | |
| 2 | |
| 3 | |
| 4 | |
| 5 | |
| 6 | |
| 7 | |
| 8 | |
| 9 | |
| 10 | |
| 11 | |
| 12 | |
| 13 | |
| 14 | #ifdef HAVE_CONFIG_H1 |
| 15 | #include "config.h" |
| 16 | #endif |
| 17 | |
| 18 | #include <rtems.h> |
| 19 | #include <stdlib.h> |
| 20 | #include <ctype.h> |
| 21 | #include <inttypes.h> |
| 22 | |
| 23 | #include <rtems/bspIo.h> |
| 24 | #include <rtems/score/timespec.h> |
| 25 | |
| 26 | #ifndef __RTEMS_USE_TICKS_FOR_STATISTICS__ |
| 27 | |
| 28 | #define NANOSECONDS_DIVIDER1000 1000 |
| 29 | #define PERCENT_FMT"%04" "d" "%04" PRId32"d" |
| 30 | #define NANOSECONDS_FMT"%06" "d" "%06" PRId32"d" |
| 31 | #endif |
| 32 | |
| 33 | |
| 34 | |
| 35 | |
| 36 | |
| 37 | |
| 38 | |
| 39 | |
| 40 | |
| 41 | void rtems_rate_monotonic_report_statistics_with_plugin( |
| 42 | void *context, |
| 43 | rtems_printk_plugin_t print |
| 44 | ) |
| 45 | { |
| 46 | rtems_status_code status; |
| 47 | rtems_id id; |
| 48 | rtems_rate_monotonic_period_statistics the_stats; |
| 49 | rtems_rate_monotonic_period_status the_status; |
| 50 | char name[5]; |
| 51 | |
| 52 | if ( !print ) |
| 53 | return; |
| 54 | |
| 55 | (*print)( context, "Period information by period\n" ); |
| 56 | #ifndef __RTEMS_USE_TICKS_FOR_STATISTICS__ |
| 57 | (*print)( context, "--- CPU times are in seconds ---\n" ); |
| 58 | (*print)( context, "--- Wall times are in seconds ---\n" ); |
| 59 | #endif |
| 60 | |
| 61 | |
| 62 | |
| 63 | |
| 64 | |
| 65 | |
| 66 | |
| 67 | |
| 68 | |
| 69 | |
| 70 | |
| 71 | |
| 72 | |
| 73 | (*print)( context, " ID OWNER COUNT MISSED " |
| 74 | #ifndef __RTEMS_USE_TICKS_FOR_STATISTICS__ |
| 75 | " " |
| 76 | #endif |
| 77 | "CPU TIME " |
| 78 | #ifndef __RTEMS_USE_TICKS_FOR_STATISTICS__ |
| 79 | " " |
| 80 | #endif |
| 81 | " WALL TIME\n" |
| 82 | ); |
| 83 | (*print)( context, " " |
| 84 | #ifndef __RTEMS_USE_TICKS_FOR_STATISTICS__ |
| 85 | " " |
| 86 | #endif |
| 87 | "MIN/MAX/AVG " |
| 88 | #ifndef __RTEMS_USE_TICKS_FOR_STATISTICS__ |
| 89 | " " |
| 90 | #endif |
| 91 | " MIN/MAX/AVG\n" |
| 92 | ); |
| 93 | |
| 94 | |
| 95 | |
| 96 | |
| 97 | |
| 98 | for ( id=_Rate_monotonic_Information.minimum_id ; |
| 99 | id <= _Rate_monotonic_Information.maximum_id ; |
| 100 | id++ ) { |
| 101 | status = rtems_rate_monotonic_get_statistics( id, &the_stats ); |
| 102 | if ( status != RTEMS_SUCCESSFUL ) |
| 103 | continue; |
| 104 | |
| 105 | |
| 106 | status = rtems_rate_monotonic_get_status( id, &the_status ); |
| Value stored to 'status' is never read |
| 107 | #if defined(RTEMS_DEBUG) |
| 108 | if ( status != RTEMS_SUCCESSFUL ) |
| 109 | continue; |
| 110 | #endif |
| 111 | |
| 112 | rtems_object_get_name( the_status.owner, sizeof(name), name ); |
| 113 | |
| 114 | |
| 115 | |
| 116 | |
| 117 | (*print)( context, |
| 118 | "0x%08" PRIx32"x" " %4s %5" PRId32"d" " %6" PRId32"d" " ", |
| 119 | id, name, |
| 120 | the_stats.count, the_stats.missed_count |
| 121 | ); |
| 122 | |
| 123 | |
| 124 | |
| 125 | |
| 126 | if (the_stats.count == 0) { |
| 127 | (*print)( context, "\n" ); |
| 128 | continue; |
| 129 | } |
| 130 | |
| 131 | |
| 132 | |
| 133 | |
| 134 | { |
| 135 | #ifndef __RTEMS_USE_TICKS_FOR_STATISTICS__ |
| 136 | struct timespec cpu_average; |
| 137 | struct timespec *min_cpu = &the_stats.min_cpu_time; |
| 138 | struct timespec *max_cpu = &the_stats.max_cpu_time; |
| 139 | struct timespec *total_cpu = &the_stats.total_cpu_time; |
| 140 | |
| 141 | _Timespec_Divide_by_integer( total_cpu, the_stats.count, &cpu_average ); |
| 142 | (*print)( context, |
| 143 | "%" PRId32"d" "." NANOSECONDS_FMT"%06" "d" "/" |
| 144 | "%" PRId32"d" "." NANOSECONDS_FMT"%06" "d" "/" |
| 145 | "%" PRId32"d" "." NANOSECONDS_FMT"%06" "d" " ", |
| 146 | _Timespec_Get_seconds( min_cpu )((min_cpu)->tv_sec), |
| 147 | _Timespec_Get_nanoseconds( min_cpu )((min_cpu)->tv_nsec) / NANOSECONDS_DIVIDER1000, |
| 148 | _Timespec_Get_seconds( max_cpu )((max_cpu)->tv_sec), |
| 149 | _Timespec_Get_nanoseconds( max_cpu )((max_cpu)->tv_nsec) / NANOSECONDS_DIVIDER1000, |
| 150 | _Timespec_Get_seconds( &cpu_average )((&cpu_average)->tv_sec), |
| 151 | _Timespec_Get_nanoseconds( &cpu_average )((&cpu_average)->tv_nsec) / NANOSECONDS_DIVIDER1000 |
| 152 | ); |
| 153 | #else |
| 154 | uint32_t ival_cpu, fval_cpu; |
| 155 | |
| 156 | ival_cpu = the_stats.total_cpu_time * 100 / the_stats.count; |
| 157 | fval_cpu = ival_cpu % 100; |
| 158 | ival_cpu /= 100; |
| 159 | |
| 160 | (*print)( context, |
| 161 | "%3" PRId32"d" "/%4" PRId32"d" "/%3" PRId32"d" ".%02" PRId32"d" " ", |
| 162 | the_stats.min_cpu_time, the_stats.max_cpu_time, ival_cpu, fval_cpu |
| 163 | ); |
| 164 | #endif |
| 165 | } |
| 166 | |
| 167 | |
| 168 | |
| 169 | |
| 170 | { |
| 171 | #ifndef __RTEMS_USE_TICKS_FOR_STATISTICS__ |
| 172 | struct timespec wall_average; |
| 173 | struct timespec *min_wall = &the_stats.min_wall_time; |
| 174 | struct timespec *max_wall = &the_stats.max_wall_time; |
| 175 | struct timespec *total_wall = &the_stats.total_wall_time; |
| 176 | |
| 177 | _Timespec_Divide_by_integer(total_wall, the_stats.count, &wall_average); |
| 178 | (*print)( context, |
| 179 | "%" PRId32"d" "." NANOSECONDS_FMT"%06" "d" "/" |
| 180 | "%" PRId32"d" "." NANOSECONDS_FMT"%06" "d" "/" |
| 181 | "%" PRId32"d" "." NANOSECONDS_FMT"%06" "d" "\n", |
| 182 | _Timespec_Get_seconds( min_wall )((min_wall)->tv_sec), |
| 183 | _Timespec_Get_nanoseconds( min_wall )((min_wall)->tv_nsec) / NANOSECONDS_DIVIDER1000, |
| 184 | _Timespec_Get_seconds( max_wall )((max_wall)->tv_sec), |
| 185 | _Timespec_Get_nanoseconds( max_wall )((max_wall)->tv_nsec) / NANOSECONDS_DIVIDER1000, |
| 186 | _Timespec_Get_seconds( &wall_average )((&wall_average)->tv_sec), |
| 187 | _Timespec_Get_nanoseconds( &wall_average )((&wall_average)->tv_nsec) / NANOSECONDS_DIVIDER1000 |
| 188 | ); |
| 189 | #else |
| 190 | uint32_t ival_wall, fval_wall; |
| 191 | |
| 192 | ival_wall = the_stats.total_wall_time * 100 / the_stats.count; |
| 193 | fval_wall = ival_wall % 100; |
| 194 | ival_wall /= 100; |
| 195 | (*print)( context, |
| 196 | "%3" PRId32"d" "/%4" PRId32"d" "/%3" PRId32"d" ".%02" PRId32"d" "\n", |
| 197 | the_stats.min_wall_time, the_stats.max_wall_time, ival_wall, fval_wall |
| 198 | ); |
| 199 | #endif |
| 200 | } |
| 201 | } |
| 202 | } |
| 203 | |
| 204 | void rtems_rate_monotonic_report_statistics( void ) |
| 205 | { |
| 206 | rtems_rate_monotonic_report_statistics_with_plugin( NULL((void*)0), printk_plugin ); |
| 207 | } |
