| File: | /home/joel/rtems-4.11-work/build/rtems/c/src/../../cpukit/zlib/gzread.c |
| Description: | Allocated memory never released. Potential memory leak |
| 1 | /* gzread.c -- zlib functions for reading gzip files | ||||
| 2 | * Copyright (C) 2004, 2005, 2010 Mark Adler | ||||
| 3 | * For conditions of distribution and use, see copyright notice in zlib.h | ||||
| 4 | */ | ||||
| 5 | |||||
| 6 | #include "gzguts.h" | ||||
| 7 | |||||
| 8 | /* Local functions */ | ||||
| 9 | localstatic int gz_load OF((gz_statep, unsigned char *, unsigned, unsigned *))(gz_statep, unsigned char *, unsigned, unsigned *); | ||||
| 10 | localstatic int gz_avail OF((gz_statep))(gz_statep); | ||||
| 11 | localstatic int gz_next4 OF((gz_statep, unsigned long *))(gz_statep, unsigned long *); | ||||
| 12 | localstatic int gz_head OF((gz_statep))(gz_statep); | ||||
| 13 | localstatic int gz_decomp OF((gz_statep))(gz_statep); | ||||
| 14 | localstatic int gz_make OF((gz_statep))(gz_statep); | ||||
| 15 | localstatic int gz_skip OF((gz_statep, z_off64_t))(gz_statep, off_t); | ||||
| 16 | |||||
| 17 | /* Use read() to load a buffer -- return -1 on error, otherwise 0. Read from | ||||
| 18 | state->fd, and update state->eof, state->err, and state->msg as appropriate. | ||||
| 19 | This function needs to loop on read(), since read() is not guaranteed to | ||||
| 20 | read the number of bytes requested, depending on the type of descriptor. */ | ||||
| 21 | localstatic int gz_load(state, buf, len, have) | ||||
| 22 | gz_statep state; | ||||
| 23 | unsigned char *buf; | ||||
| 24 | unsigned len; | ||||
| 25 | unsigned *have; | ||||
| 26 | { | ||||
| 27 | int ret; | ||||
| 28 | |||||
| 29 | *have = 0; | ||||
| 30 | do { | ||||
| 31 | ret = read(state->fd, buf + *have, len - *have); | ||||
| 32 | if (ret <= 0) | ||||
| 33 | break; | ||||
| 34 | *have += ret; | ||||
| 35 | } while (*have < len); | ||||
| 36 | if (ret < 0) { | ||||
| 37 | gz_errorz_gz_error(state, Z_ERRNO(-1), zstrerror()strerror((*__errno_location ()))); | ||||
| 38 | return -1; | ||||
| 39 | } | ||||
| 40 | if (ret == 0) | ||||
| 41 | state->eof = 1; | ||||
| 42 | return 0; | ||||
| 43 | } | ||||
| 44 | |||||
| 45 | /* Load up input buffer and set eof flag if last data loaded -- return -1 on | ||||
| 46 | error, 0 otherwise. Note that the eof flag is set when the end of the input | ||||
| 47 | file is reached, even though there may be unused data in the buffer. Once | ||||
| 48 | that data has been used, no more attempts will be made to read the file. | ||||
| 49 | gz_avail() assumes that strm->avail_in == 0. */ | ||||
| 50 | localstatic int gz_avail(state) | ||||
| 51 | gz_statep state; | ||||
| 52 | { | ||||
| 53 | z_streamp strm = &(state->strm); | ||||
| 54 | |||||
| 55 | if (state->err != Z_OK0) | ||||
| 56 | return -1; | ||||
| 57 | if (state->eof == 0) { | ||||
| 58 | if (gz_load(state, state->in, state->size, &(strm->avail_in)) == -1) | ||||
| 59 | return -1; | ||||
| 60 | strm->next_in = state->in; | ||||
| 61 | } | ||||
| 62 | return 0; | ||||
| 63 | } | ||||
| 64 | |||||
| 65 | /* Get next byte from input, or -1 if end or error. */ | ||||
| 66 | #define NEXT()((strm->avail_in == 0 && gz_avail(state) == -1) ? - 1 : (strm->avail_in == 0 ? -1 : (strm->avail_in--, *(strm ->next_in)++))) ((strm->avail_in == 0 && gz_avail(state) == -1) ? -1 : \ | ||||
| 67 | (strm->avail_in == 0 ? -1 : \ | ||||
| 68 | (strm->avail_in--, *(strm->next_in)++))) | ||||
| 69 | |||||
| 70 | /* Get a four-byte little-endian integer and return 0 on success and the value | ||||
| 71 | in *ret. Otherwise -1 is returned and *ret is not modified. */ | ||||
| 72 | localstatic int gz_next4(state, ret) | ||||
| 73 | gz_statep state; | ||||
| 74 | unsigned long *ret; | ||||
| 75 | { | ||||
| 76 | int ch; | ||||
| 77 | unsigned long val; | ||||
| 78 | z_streamp strm = &(state->strm); | ||||
| 79 | |||||
| 80 | val = NEXT()((strm->avail_in == 0 && gz_avail(state) == -1) ? - 1 : (strm->avail_in == 0 ? -1 : (strm->avail_in--, *(strm ->next_in)++))); | ||||
| 81 | val += (unsigned)NEXT()((strm->avail_in == 0 && gz_avail(state) == -1) ? - 1 : (strm->avail_in == 0 ? -1 : (strm->avail_in--, *(strm ->next_in)++))) << 8; | ||||
| 82 | val += (unsigned long)NEXT()((strm->avail_in == 0 && gz_avail(state) == -1) ? - 1 : (strm->avail_in == 0 ? -1 : (strm->avail_in--, *(strm ->next_in)++))) << 16; | ||||
| 83 | ch = NEXT()((strm->avail_in == 0 && gz_avail(state) == -1) ? - 1 : (strm->avail_in == 0 ? -1 : (strm->avail_in--, *(strm ->next_in)++))); | ||||
| 84 | if (ch == -1) | ||||
| 85 | return -1; | ||||
| 86 | val += (unsigned long)ch << 24; | ||||
| 87 | *ret = val; | ||||
| 88 | return 0; | ||||
| 89 | } | ||||
| 90 | |||||
| 91 | /* Look for gzip header, set up for inflate or copy. state->have must be zero. | ||||
| 92 | If this is the first time in, allocate required memory. state->how will be | ||||
| 93 | left unchanged if there is no more input data available, will be set to COPY | ||||
| 94 | if there is no gzip header and direct copying will be performed, or it will | ||||
| 95 | be set to GZIP for decompression, and the gzip header will be skipped so | ||||
| 96 | that the next available input data is the raw deflate stream. If direct | ||||
| 97 | copying, then leftover input data from the input buffer will be copied to | ||||
| 98 | the output buffer. In that case, all further file reads will be directly to | ||||
| 99 | either the output buffer or a user buffer. If decompressing, the inflate | ||||
| 100 | state and the check value will be initialized. gz_head() will return 0 on | ||||
| 101 | success or -1 on failure. Failures may include read errors or gzip header | ||||
| 102 | errors. */ | ||||
| 103 | localstatic int gz_head(state) | ||||
| 104 | gz_statep state; | ||||
| 105 | { | ||||
| 106 | z_streamp strm = &(state->strm); | ||||
| 107 | int flags; | ||||
| 108 | unsigned len; | ||||
| 109 | |||||
| 110 | /* allocate read buffers and inflate memory */ | ||||
| 111 | if (state->size == 0) { | ||||
| 112 | /* allocate buffers */ | ||||
| 113 | state->in = malloc(state->want); | ||||
| 114 | state->out = malloc(state->want << 1); | ||||
| 115 | if (state->in == NULL((void*)0) || state->out == NULL((void*)0)) { | ||||
| 116 | if (state->out != NULL((void*)0)) | ||||
| 117 | free(state->out); | ||||
| 118 | if (state->in != NULL((void*)0)) | ||||
| 119 | free(state->in); | ||||
| 120 | gz_errorz_gz_error(state, Z_MEM_ERROR(-4), "out of memory"); | ||||
| 121 | return -1; | ||||
| 122 | } | ||||
| 123 | state->size = state->want; | ||||
| 124 | |||||
| 125 | /* allocate inflate memory */ | ||||
| 126 | state->strm.zalloc = Z_NULL0; | ||||
| 127 | state->strm.zfree = Z_NULL0; | ||||
| 128 | state->strm.opaque = Z_NULL0; | ||||
| 129 | state->strm.avail_in = 0; | ||||
| 130 | state->strm.next_in = Z_NULL0; | ||||
| 131 | if (inflateInit2(&(state->strm), -15)z_inflateInit2_((&(state->strm)), (-15), "1.2.4", sizeof (z_stream)) != Z_OK0) { /* raw inflate */ | ||||
| 132 | free(state->out); | ||||
| 133 | free(state->in); | ||||
| 134 | state->size = 0; | ||||
| 135 | gz_errorz_gz_error(state, Z_MEM_ERROR(-4), "out of memory"); | ||||
| 136 | return -1; | ||||
| 137 | } | ||||
| 138 | } | ||||
| 139 | |||||
| 140 | /* get some data in the input buffer */ | ||||
| 141 | if (strm->avail_in == 0) { | ||||
| 142 | if (gz_avail(state) == -1) | ||||
| 143 | return -1; | ||||
| 144 | if (strm->avail_in == 0) | ||||
| 145 | return 0; | ||||
| 146 | } | ||||
| 147 | |||||
| 148 | /* look for the gzip magic header bytes 31 and 139 */ | ||||
| 149 | if (strm->next_in[0] == 31) { | ||||
| 150 | strm->avail_in--; | ||||
| 151 | strm->next_in++; | ||||
| 152 | if (strm->avail_in == 0 && gz_avail(state) == -1) | ||||
| 153 | return -1; | ||||
| 154 | if (strm->avail_in && strm->next_in[0] == 139) { | ||||
| 155 | /* we have a gzip header, woo hoo! */ | ||||
| 156 | strm->avail_in--; | ||||
| 157 | strm->next_in++; | ||||
| 158 | |||||
| 159 | /* skip rest of header */ | ||||
| 160 | if (NEXT()((strm->avail_in == 0 && gz_avail(state) == -1) ? - 1 : (strm->avail_in == 0 ? -1 : (strm->avail_in--, *(strm ->next_in)++))) != 8) { /* compression method */ | ||||
| 161 | gz_errorz_gz_error(state, Z_DATA_ERROR(-3), "unknown compression method"); | ||||
| 162 | return -1; | ||||
| 163 | } | ||||
| 164 | flags = NEXT()((strm->avail_in == 0 && gz_avail(state) == -1) ? - 1 : (strm->avail_in == 0 ? -1 : (strm->avail_in--, *(strm ->next_in)++))); | ||||
| 165 | if (flags & 0xe0) { /* reserved flag bits */ | ||||
| 166 | gz_errorz_gz_error(state, Z_DATA_ERROR(-3), "unknown header flags set"); | ||||
| 167 | return -1; | ||||
| 168 | } | ||||
| 169 | NEXT()((strm->avail_in == 0 && gz_avail(state) == -1) ? - 1 : (strm->avail_in == 0 ? -1 : (strm->avail_in--, *(strm ->next_in)++))); /* modification time */ | ||||
| 170 | NEXT()((strm->avail_in == 0 && gz_avail(state) == -1) ? - 1 : (strm->avail_in == 0 ? -1 : (strm->avail_in--, *(strm ->next_in)++))); | ||||
| 171 | NEXT()((strm->avail_in == 0 && gz_avail(state) == -1) ? - 1 : (strm->avail_in == 0 ? -1 : (strm->avail_in--, *(strm ->next_in)++))); | ||||
| 172 | NEXT()((strm->avail_in == 0 && gz_avail(state) == -1) ? - 1 : (strm->avail_in == 0 ? -1 : (strm->avail_in--, *(strm ->next_in)++))); | ||||
| 173 | NEXT()((strm->avail_in == 0 && gz_avail(state) == -1) ? - 1 : (strm->avail_in == 0 ? -1 : (strm->avail_in--, *(strm ->next_in)++))); /* extra flags */ | ||||
| 174 | NEXT()((strm->avail_in == 0 && gz_avail(state) == -1) ? - 1 : (strm->avail_in == 0 ? -1 : (strm->avail_in--, *(strm ->next_in)++))); /* operating system */ | ||||
| 175 | if (flags & 4) { /* extra field */ | ||||
| 176 | len = (unsigned)NEXT()((strm->avail_in == 0 && gz_avail(state) == -1) ? - 1 : (strm->avail_in == 0 ? -1 : (strm->avail_in--, *(strm ->next_in)++))); | ||||
| 177 | len += (unsigned)NEXT()((strm->avail_in == 0 && gz_avail(state) == -1) ? - 1 : (strm->avail_in == 0 ? -1 : (strm->avail_in--, *(strm ->next_in)++))) << 8; | ||||
| 178 | while (len--) | ||||
| 179 | if (NEXT()((strm->avail_in == 0 && gz_avail(state) == -1) ? - 1 : (strm->avail_in == 0 ? -1 : (strm->avail_in--, *(strm ->next_in)++))) < 0) | ||||
| 180 | break; | ||||
| 181 | } | ||||
| 182 | if (flags & 8) /* file name */ | ||||
| 183 | while (NEXT()((strm->avail_in == 0 && gz_avail(state) == -1) ? - 1 : (strm->avail_in == 0 ? -1 : (strm->avail_in--, *(strm ->next_in)++))) > 0) | ||||
| 184 | ; | ||||
| 185 | if (flags & 16) /* comment */ | ||||
| 186 | while (NEXT()((strm->avail_in == 0 && gz_avail(state) == -1) ? - 1 : (strm->avail_in == 0 ? -1 : (strm->avail_in--, *(strm ->next_in)++))) > 0) | ||||
| 187 | ; | ||||
| 188 | if (flags & 2) { /* header crc */ | ||||
| 189 | NEXT()((strm->avail_in == 0 && gz_avail(state) == -1) ? - 1 : (strm->avail_in == 0 ? -1 : (strm->avail_in--, *(strm ->next_in)++))); | ||||
| 190 | NEXT()((strm->avail_in == 0 && gz_avail(state) == -1) ? - 1 : (strm->avail_in == 0 ? -1 : (strm->avail_in--, *(strm ->next_in)++))); | ||||
| 191 | } | ||||
| 192 | /* an unexpected end of file is not checked for here -- it will be | ||||
| 193 | noticed on the first request for uncompressed data */ | ||||
| 194 | |||||
| 195 | /* set up for decompression */ | ||||
| 196 | inflateResetz_inflateReset(strm); | ||||
| 197 | strm->adler = crc32z_crc32(0L, Z_NULL0, 0); | ||||
| 198 | state->how = GZIP2; | ||||
| 199 | state->direct = 0; | ||||
| 200 | return 0; | ||||
| 201 | } | ||||
| 202 | else { | ||||
| 203 | /* not a gzip file -- save first byte (31) and fall to raw i/o */ | ||||
| 204 | state->out[0] = 31; | ||||
| 205 | state->have = 1; | ||||
| 206 | } | ||||
| 207 | } | ||||
| 208 | |||||
| 209 | /* doing raw i/o, save start of raw data for seeking, copy any leftover | ||||
| 210 | input to output -- this assumes that the output buffer is larger than | ||||
| 211 | the input buffer, which also assures space for gzungetc() */ | ||||
| 212 | state->raw = state->pos; | ||||
| 213 | state->next = state->out; | ||||
| 214 | if (strm->avail_in) { | ||||
| 215 | memcpy(state->next + state->have, strm->next_in, strm->avail_in); | ||||
| 216 | state->have += strm->avail_in; | ||||
| 217 | strm->avail_in = 0; | ||||
| 218 | } | ||||
| 219 | state->how = COPY1; | ||||
| 220 | state->direct = 1; | ||||
| 221 | return 0; | ||||
| 222 | } | ||||
| 223 | |||||
| 224 | /* Decompress from input to the provided next_out and avail_out in the state. | ||||
| 225 | If the end of the compressed data is reached, then verify the gzip trailer | ||||
| 226 | check value and length (modulo 2^32). state->have and state->next are set | ||||
| 227 | to point to the just decompressed data, and the crc is updated. If the | ||||
| 228 | trailer is verified, state->how is reset to LOOK to look for the next gzip | ||||
| 229 | stream or raw data, once state->have is depleted. Returns 0 on success, -1 | ||||
| 230 | on failure. Failures may include invalid compressed data or a failed gzip | ||||
| 231 | trailer verification. */ | ||||
| 232 | localstatic int gz_decomp(state) | ||||
| 233 | gz_statep state; | ||||
| 234 | { | ||||
| 235 | int ret; | ||||
| 236 | unsigned had; | ||||
| 237 | unsigned long crc, len; | ||||
| 238 | z_streamp strm = &(state->strm); | ||||
| 239 | |||||
| 240 | /* fill output buffer up to end of deflate stream */ | ||||
| 241 | had = strm->avail_out; | ||||
| 242 | do { | ||||
| 243 | /* get more input for inflate() */ | ||||
| 244 | if (strm->avail_in == 0 && gz_avail(state) == -1) | ||||
| 245 | return -1; | ||||
| 246 | if (strm->avail_in == 0) { | ||||
| 247 | gz_errorz_gz_error(state, Z_DATA_ERROR(-3), "unexpected end of file"); | ||||
| 248 | return -1; | ||||
| 249 | } | ||||
| 250 | |||||
| 251 | /* decompress and handle errors */ | ||||
| 252 | ret = inflatez_inflate(strm, Z_NO_FLUSH0); | ||||
| 253 | if (ret == Z_STREAM_ERROR(-2) || ret == Z_NEED_DICT2) { | ||||
| 254 | gz_errorz_gz_error(state, Z_STREAM_ERROR(-2), | ||||
| 255 | "internal error: inflate stream corrupt"); | ||||
| 256 | return -1; | ||||
| 257 | } | ||||
| 258 | if (ret == Z_MEM_ERROR(-4)) { | ||||
| 259 | gz_errorz_gz_error(state, Z_MEM_ERROR(-4), "out of memory"); | ||||
| 260 | return -1; | ||||
| 261 | } | ||||
| 262 | if (ret == Z_DATA_ERROR(-3)) { /* deflate stream invalid */ | ||||
| 263 | gz_errorz_gz_error(state, Z_DATA_ERROR(-3), | ||||
| 264 | strm->msg == NULL((void*)0) ? "compressed data error" : strm->msg); | ||||
| 265 | return -1; | ||||
| 266 | } | ||||
| 267 | } while (strm->avail_out && ret != Z_STREAM_END1); | ||||
| 268 | |||||
| 269 | /* update available output and crc check value */ | ||||
| 270 | state->have = had - strm->avail_out; | ||||
| 271 | state->next = strm->next_out - state->have; | ||||
| 272 | strm->adler = crc32z_crc32(strm->adler, state->next, state->have); | ||||
| 273 | |||||
| 274 | /* check gzip trailer if at end of deflate stream */ | ||||
| 275 | if (ret == Z_STREAM_END1) { | ||||
| 276 | if (gz_next4(state, &crc) == -1 || gz_next4(state, &len) == -1) { | ||||
| 277 | gz_errorz_gz_error(state, Z_DATA_ERROR(-3), "unexpected end of file"); | ||||
| 278 | return -1; | ||||
| 279 | } | ||||
| 280 | if (crc != strm->adler) { | ||||
| 281 | gz_errorz_gz_error(state, Z_DATA_ERROR(-3), "incorrect data check"); | ||||
| 282 | return -1; | ||||
| 283 | } | ||||
| 284 | if (len != (strm->total_out & 0xffffffffL)) { | ||||
| 285 | gz_errorz_gz_error(state, Z_DATA_ERROR(-3), "incorrect length check"); | ||||
| 286 | return -1; | ||||
| 287 | } | ||||
| 288 | state->how = LOOK0; /* ready for next stream, once have is 0 (leave | ||||
| 289 | state->direct unchanged to remember how) */ | ||||
| 290 | } | ||||
| 291 | |||||
| 292 | /* good decompression */ | ||||
| 293 | return 0; | ||||
| 294 | } | ||||
| 295 | |||||
| 296 | /* Make data and put in the output buffer. Assumes that state->have == 0. | ||||
| 297 | Data is either copied from the input file or decompressed from the input | ||||
| 298 | file depending on state->how. If state->how is LOOK, then a gzip header is | ||||
| 299 | looked for (and skipped if found) to determine wither to copy or decompress. | ||||
| 300 | Returns -1 on error, otherwise 0. gz_make() will leave state->have as COPY | ||||
| 301 | or GZIP unless the end of the input file has been reached and all data has | ||||
| 302 | been processed. */ | ||||
| 303 | localstatic int gz_make(state) | ||||
| 304 | gz_statep state; | ||||
| 305 | { | ||||
| 306 | z_streamp strm = &(state->strm); | ||||
| 307 | |||||
| 308 | if (state->how == LOOK0) { /* look for gzip header */ | ||||
| 309 | if (gz_head(state) == -1) | ||||
| 310 | return -1; | ||||
| 311 | if (state->have) /* got some data from gz_head() */ | ||||
| 312 | return 0; | ||||
| 313 | } | ||||
| 314 | if (state->how == COPY1) { /* straight copy */ | ||||
| 315 | if (gz_load(state, state->out, state->size << 1, &(state->have)) == -1) | ||||
| 316 | return -1; | ||||
| 317 | state->next = state->out; | ||||
| 318 | } | ||||
| 319 | else if (state->how == GZIP2) { /* decompress */ | ||||
| 320 | strm->avail_out = state->size << 1; | ||||
| 321 | strm->next_out = state->out; | ||||
| 322 | if (gz_decomp(state) == -1) | ||||
| 323 | return -1; | ||||
| 324 | } | ||||
| 325 | return 0; | ||||
| 326 | } | ||||
| 327 | |||||
| 328 | /* Skip len uncompressed bytes of output. Return -1 on error, 0 on success. */ | ||||
| 329 | localstatic int gz_skip(state, len) | ||||
| 330 | gz_statep state; | ||||
| 331 | z_off64_toff_t len; | ||||
| 332 | { | ||||
| 333 | unsigned n; | ||||
| 334 | |||||
| 335 | /* skip over len bytes or reach end-of-file, whichever comes first */ | ||||
| 336 | while (len) | ||||
| 337 | /* skip over whatever is in output buffer */ | ||||
| 338 | if (state->have) { | ||||
| 339 | n = GT_OFF(state->have)(sizeof(int) == sizeof(off_t) && (state->have) > 2147483647) || (z_off64_toff_t)state->have > len ? | ||||
| 340 | (unsigned)len : state->have; | ||||
| 341 | state->have -= n; | ||||
| 342 | state->next += n; | ||||
| 343 | state->pos += n; | ||||
| 344 | len -= n; | ||||
| 345 | } | ||||
| 346 | |||||
| 347 | /* output buffer empty -- return if we're at the end of the input */ | ||||
| 348 | else if (state->eof && state->strm.avail_in == 0) | ||||
| 349 | break; | ||||
| 350 | |||||
| 351 | /* need more data to skip -- load up output buffer */ | ||||
| 352 | else { | ||||
| 353 | /* get more output, looking for header if required */ | ||||
| 354 | if (gz_make(state) == -1) | ||||
| 355 | return -1; | ||||
| 356 | } | ||||
| 357 | return 0; | ||||
| 358 | } | ||||
| 359 | |||||
| 360 | /* -- see zlib.h -- */ | ||||
| 361 | int ZEXPORT gzreadz_gzread(file, buf, len) | ||||
| 362 | gzFilez_gzFile file; | ||||
| 363 | voidpz_voidp buf; | ||||
| 364 | unsigned len; | ||||
| 365 | { | ||||
| 366 | unsigned got, n; | ||||
| 367 | gz_statep state; | ||||
| 368 | z_streamp strm; | ||||
| 369 | |||||
| 370 | /* get internal structure */ | ||||
| 371 | if (file == NULL((void*)0)) | ||||
| 372 | return -1; | ||||
| 373 | state = (gz_statep)file; | ||||
| 374 | strm = &(state->strm); | ||||
| 375 | |||||
| 376 | /* check that we're reading and that there's no error */ | ||||
| 377 | if (state->mode != GZ_READ7247 || state->err != Z_OK0) | ||||
| 378 | return -1; | ||||
| 379 | |||||
| 380 | /* since an int is returned, make sure len fits in one, otherwise return | ||||
| 381 | with an error (this avoids the flaw in the interface) */ | ||||
| 382 | if ((int)len < 0) { | ||||
| 383 | gz_errorz_gz_error(state, Z_BUF_ERROR(-5), "requested length does not fit in int"); | ||||
| 384 | return -1; | ||||
| 385 | } | ||||
| 386 | |||||
| 387 | /* if len is zero, avoid unnecessary operations */ | ||||
| 388 | if (len == 0) | ||||
| 389 | return 0; | ||||
| 390 | |||||
| 391 | /* process a skip request */ | ||||
| 392 | if (state->seek) { | ||||
| 393 | state->seek = 0; | ||||
| 394 | if (gz_skip(state, state->skip) == -1) | ||||
| 395 | return -1; | ||||
| 396 | } | ||||
| 397 | |||||
| 398 | /* get len bytes to buf, or less than len if at the end */ | ||||
| 399 | got = 0; | ||||
| 400 | do { | ||||
| 401 | /* first just try copying data from the output buffer */ | ||||
| 402 | if (state->have) { | ||||
| 403 | n = state->have > len ? len : state->have; | ||||
| 404 | memcpy(buf, state->next, n); | ||||
| 405 | state->next += n; | ||||
| 406 | state->have -= n; | ||||
| 407 | } | ||||
| 408 | |||||
| 409 | /* output buffer empty -- return if we're at the end of the input */ | ||||
| 410 | else if (state->eof && strm->avail_in == 0) | ||||
| 411 | break; | ||||
| 412 | |||||
| 413 | /* need output data -- for small len or new stream load up our output | ||||
| 414 | buffer */ | ||||
| 415 | else if (state->how == LOOK0 || len < (state->size << 1)) { | ||||
| 416 | /* get more output, looking for header if required */ | ||||
| 417 | if (gz_make(state) == -1) | ||||
| 418 | return -1; | ||||
| 419 | continue; /* no progress yet -- go back to memcpy() above */ | ||||
| 420 | /* the copy above assures that we will leave with space in the | ||||
| 421 | output buffer, allowing at least one gzungetc() to succeed */ | ||||
| 422 | } | ||||
| 423 | |||||
| 424 | /* large len -- read directly into user buffer */ | ||||
| 425 | else if (state->how == COPY1) { /* read directly */ | ||||
| 426 | if (gz_load(state, buf, len, &n) == -1) | ||||
| 427 | return -1; | ||||
| 428 | } | ||||
| 429 | |||||
| 430 | /* large len -- decompress directly into user buffer */ | ||||
| 431 | else { /* state->how == GZIP */ | ||||
| 432 | strm->avail_out = len; | ||||
| 433 | strm->next_out = buf; | ||||
| 434 | if (gz_decomp(state) == -1) | ||||
| 435 | return -1; | ||||
| 436 | n = state->have; | ||||
| 437 | state->have = 0; | ||||
| 438 | } | ||||
| 439 | |||||
| 440 | /* update progress */ | ||||
| 441 | len -= n; | ||||
| 442 | buf = (char *)buf + n; | ||||
| 443 | got += n; | ||||
| 444 | state->pos += n; | ||||
| 445 | } while (len); | ||||
| 446 | |||||
| 447 | /* return number of bytes read into user buffer (will fit in int) */ | ||||
| 448 | return (int)got; | ||||
| 449 | } | ||||
| 450 | |||||
| 451 | /* -- see zlib.h -- */ | ||||
| 452 | int ZEXPORT gzgetcz_gzgetc(file) | ||||
| 453 | gzFilez_gzFile file; | ||||
| 454 | { | ||||
| 455 | int ret; | ||||
| 456 | unsigned char buf[1]; | ||||
| 457 | gz_statep state; | ||||
| 458 | |||||
| 459 | /* get internal structure */ | ||||
| 460 | if (file == NULL((void*)0)) | ||||
| 461 | return -1; | ||||
| 462 | state = (gz_statep)file; | ||||
| 463 | |||||
| 464 | /* check that we're reading and that there's no error */ | ||||
| 465 | if (state->mode != GZ_READ7247 || state->err != Z_OK0) | ||||
| 466 | return -1; | ||||
| 467 | |||||
| 468 | /* try output buffer (no need to check for skip request) */ | ||||
| 469 | if (state->have) { | ||||
| 470 | state->have--; | ||||
| 471 | state->pos++; | ||||
| 472 | return *(state->next)++; | ||||
| 473 | } | ||||
| 474 | |||||
| 475 | /* nothing there -- try gzread() */ | ||||
| 476 | ret = gzreadz_gzread(file, buf, 1); | ||||
| 477 | return ret < 1 ? -1 : buf[0]; | ||||
| 478 | } | ||||
| 479 | |||||
| 480 | /* -- see zlib.h -- */ | ||||
| 481 | int ZEXPORT gzungetcz_gzungetc(c, file) | ||||
| 482 | int c; | ||||
| 483 | gzFilez_gzFile file; | ||||
| 484 | { | ||||
| 485 | gz_statep state; | ||||
| 486 | |||||
| 487 | /* get internal structure */ | ||||
| 488 | if (file == NULL((void*)0)) | ||||
| 489 | return -1; | ||||
| 490 | state = (gz_statep)file; | ||||
| 491 | |||||
| 492 | /* check that we're reading and that there's no error */ | ||||
| 493 | if (state->mode != GZ_READ7247 || state->err != Z_OK0) | ||||
| 494 | return -1; | ||||
| 495 | |||||
| 496 | /* process a skip request */ | ||||
| 497 | if (state->seek) { | ||||
| 498 | state->seek = 0; | ||||
| 499 | if (gz_skip(state, state->skip) == -1) | ||||
| 500 | return -1; | ||||
| 501 | } | ||||
| 502 | |||||
| 503 | /* can't push EOF */ | ||||
| 504 | if (c < 0) | ||||
| 505 | return -1; | ||||
| 506 | |||||
| 507 | /* if output buffer empty, put byte at end (allows more pushing) */ | ||||
| 508 | if (state->have == 0) { | ||||
| 509 | state->have = 1; | ||||
| 510 | state->next = state->out + (state->size << 1) - 1; | ||||
| 511 | state->next[0] = c; | ||||
| 512 | state->pos--; | ||||
| 513 | return c; | ||||
| 514 | } | ||||
| 515 | |||||
| 516 | /* if no room, give up (must have already done a gzungetc()) */ | ||||
| 517 | if (state->have == (state->size << 1)) { | ||||
| 518 | gz_errorz_gz_error(state, Z_BUF_ERROR(-5), "out of room to push characters"); | ||||
| 519 | return -1; | ||||
| 520 | } | ||||
| 521 | |||||
| 522 | /* slide output data if needed and insert byte before existing data */ | ||||
| 523 | if (state->next == state->out) { | ||||
| 524 | unsigned char *src = state->out + state->have; | ||||
| 525 | unsigned char *dest = state->out + (state->size << 1); | ||||
| 526 | while (src > state->out) | ||||
| 527 | *--dest = *--src; | ||||
| 528 | state->next = dest; | ||||
| 529 | } | ||||
| 530 | state->have++; | ||||
| 531 | state->next--; | ||||
| 532 | state->next[0] = c; | ||||
| 533 | state->pos--; | ||||
| 534 | return c; | ||||
| 535 | } | ||||
| 536 | |||||
| 537 | /* -- see zlib.h -- */ | ||||
| 538 | char * ZEXPORT gzgetsz_gzgets(file, buf, len) | ||||
| 539 | gzFilez_gzFile file; | ||||
| 540 | char *buf; | ||||
| 541 | int len; | ||||
| 542 | { | ||||
| 543 | unsigned left, n; | ||||
| 544 | char *str; | ||||
| 545 | unsigned char *eol; | ||||
| 546 | gz_statep state; | ||||
| 547 | |||||
| 548 | /* check parameters and get internal structure */ | ||||
| 549 | if (file == NULL((void*)0) || buf == NULL((void*)0) || len < 1) | ||||
| 550 | return NULL((void*)0); | ||||
| 551 | state = (gz_statep)file; | ||||
| 552 | |||||
| 553 | /* check that we're reading and that there's no error */ | ||||
| 554 | if (state->mode != GZ_READ7247 || state->err != Z_OK0) | ||||
| 555 | return NULL((void*)0); | ||||
| 556 | |||||
| 557 | /* process a skip request */ | ||||
| 558 | if (state->seek) { | ||||
| 559 | state->seek = 0; | ||||
| 560 | if (gz_skip(state, state->skip) == -1) | ||||
| 561 | return NULL((void*)0); | ||||
| 562 | } | ||||
| 563 | |||||
| 564 | /* copy output bytes up to new line or len - 1, whichever comes first -- | ||||
| 565 | append a terminating zero to the string (we don't check for a zero in | ||||
| 566 | the contents, let the user worry about that) */ | ||||
| 567 | str = buf; | ||||
| 568 | left = (unsigned)len - 1; | ||||
| 569 | if (left) do { | ||||
| 570 | /* assure that something is in the output buffer */ | ||||
| 571 | if (state->have == 0) { | ||||
| 572 | if (gz_make(state) == -1) | ||||
| 573 | return NULL((void*)0); /* error */ | ||||
| 574 | if (state->have == 0) { /* end of file */ | ||||
| 575 | if (buf == str) /* got bupkus */ | ||||
| 576 | return NULL((void*)0); | ||||
| 577 | break; /* got something -- return it */ | ||||
| 578 | } | ||||
| 579 | } | ||||
| 580 | |||||
| 581 | /* look for end-of-line in current output buffer */ | ||||
| 582 | n = state->have > left ? left : state->have; | ||||
| 583 | eol = memchr(state->next, '\n', n); | ||||
| 584 | if (eol != NULL((void*)0)) | ||||
| 585 | n = (unsigned)(eol - state->next) + 1; | ||||
| 586 | |||||
| 587 | /* copy through end-of-line, or remainder if not found */ | ||||
| 588 | memcpy(buf, state->next, n); | ||||
| 589 | state->have -= n; | ||||
| 590 | state->next += n; | ||||
| 591 | state->pos += n; | ||||
| 592 | left -= n; | ||||
| 593 | buf += n; | ||||
| 594 | } while (left && eol == NULL((void*)0)); | ||||
| 595 | |||||
| 596 | /* found end-of-line or out of space -- terminate string and return it */ | ||||
| 597 | buf[0] = 0; | ||||
| 598 | return str; | ||||
| 599 | } | ||||
| 600 | |||||
| 601 | /* -- see zlib.h -- */ | ||||
| 602 | int ZEXPORT gzdirectz_gzdirect(file) | ||||
| 603 | gzFilez_gzFile file; | ||||
| 604 | { | ||||
| 605 | gz_statep state; | ||||
| 606 | |||||
| 607 | /* get internal structure */ | ||||
| 608 | if (file == NULL((void*)0)) | ||||
| 609 | return 0; | ||||
| 610 | state = (gz_statep)file; | ||||
| 611 | |||||
| 612 | /* check that we're reading */ | ||||
| 613 | if (state->mode != GZ_READ7247) | ||||
| 614 | return 0; | ||||
| 615 | |||||
| 616 | /* if the state is not known, but we can find out, then do so (this is | ||||
| 617 | mainly for right after a gzopen() or gzdopen()) */ | ||||
| 618 | if (state->how == LOOK0 && state->have == 0) | ||||
| 619 | (void)gz_head(state); | ||||
| 620 | |||||
| 621 | /* return 1 if reading direct, 0 if decompressing a gzip stream */ | ||||
| 622 | return state->direct; | ||||
| 623 | } | ||||
| 624 | |||||
| 625 | /* -- see zlib.h -- */ | ||||
| 626 | int ZEXPORT gzclose_rz_gzclose_r(file) | ||||
| 627 | gzFilez_gzFile file; | ||||
| 628 | { | ||||
| 629 | int ret; | ||||
| 630 | gz_statep state; | ||||
| 631 | |||||
| 632 | /* get internal structure */ | ||||
| 633 | if (file == NULL((void*)0)) | ||||
| 634 | return Z_STREAM_ERROR(-2); | ||||
| 635 | state = (gz_statep)file; | ||||
| 636 | |||||
| 637 | /* check that we're reading */ | ||||
| 638 | if (state->mode != GZ_READ7247) | ||||
| 639 | return Z_STREAM_ERROR(-2); | ||||
| 640 | |||||
| 641 | /* free memory and close file */ | ||||
| 642 | if (state->size) { | ||||
| 643 | inflateEndz_inflateEnd(&(state->strm)); | ||||
| 644 | free(state->out); | ||||
| 645 | free(state->in); | ||||
| 646 | } | ||||
| 647 | gz_errorz_gz_error(state, Z_OK0, NULL((void*)0)); | ||||
| 648 | free(state->path); | ||||
| 649 | ret = close(state->fd); | ||||
| 650 | free(state); | ||||
| 651 | return ret ? Z_ERRNO(-1) : Z_OK0; | ||||
| 652 | } |
