| 1 | |
| 2 | |
| 3 | |
| 4 | |
| 5 | |
| 6 | |
| 7 | |
| 8 | |
| 9 | |
| 10 | |
| 11 | |
| 12 | |
| 13 | |
| 14 | |
| 15 | |
| 16 | |
| 17 | |
| 18 | |
| 19 | |
| 20 | |
| 21 | |
| 22 | #if defined(__GNUC__4) |
| 23 | |
| 24 | #if HAVE_CONFIG_H1 |
| 25 | #include "config.h" |
| 26 | #endif |
| 27 | |
| 28 | #include <rtems/gxx_wrappers.h> |
| 29 | |
| 30 | #include <stdlib.h> |
| 31 | |
| 32 | #include <rtems.h> |
| 33 | |
| 34 | |
| 35 | |
| 36 | |
| 37 | int rtems_gxx_once(__gthread_once_t *once, void (*func) (void)) |
| 38 | { |
| 39 | #ifdef DEBUG_GXX_WRAPPERS |
| 40 | printk( "gxx_wrappers: once=%x, func=%x\n", *once, func ); |
| 41 | #endif |
| 42 | |
| 43 | if ( *(volatile __gthread_once_t *)once == 0 ) { |
| 44 | rtems_mode saveMode; |
| 45 | __gthread_once_t o; |
| 46 | |
| 47 | rtems_task_mode(RTEMS_NO_PREEMPT0x00000100, RTEMS_PREEMPT_MASK0x00000100, &saveMode); |
| 48 | if ( (o = *(volatile __gthread_once_t *)once) == 0 ) { |
| 49 | *(volatile __gthread_once_t *)once = 1; |
| 50 | } |
| 51 | rtems_task_mode(saveMode, RTEMS_PREEMPT_MASK0x00000100, &saveMode); |
| 52 | if ( o == 0 ) |
| 53 | (*func)(); |
| 54 | } |
| 55 | return 0; |
| 56 | } |
| 57 | |
| 58 | int rtems_gxx_key_create (__gthread_key_t *key, void (*dtor) (void *)) |
| 59 | { |
| 60 | rtems_status_code status; |
| 61 | |
| 62 | |
| 63 | |
| 64 | |
| 65 | |
| 66 | |
| 67 | |
| 68 | __gthread_key_t new_key = (__gthread_key_t) malloc( sizeof( *new_key ) ); |
| 69 | *key = new_key; |
| 70 | new_key->val = NULL((void*)0); |
| 71 | new_key->dtor = dtor; |
| 72 | |
| 73 | #ifdef DEBUG_GXX_WRAPPERS |
| 74 | printk( |
| 75 | "gxx_wrappers: create key=%x, dtor=%x, new_key=%x\n", key, dtor, new_key |
| 76 | ); |
| 77 | #endif |
| 78 | |
| 79 | |
| 80 | status = rtems_task_variable_add( RTEMS_SELF((Objects_Id) 0), (void **)new_key, dtor ); |
| 81 | if ( status == RTEMS_SUCCESSFUL ) |
| 82 | return 0; |
| 2 | Allocated memory never released. Potential memory leak |
| 83 | return -1; |
| 84 | } |
| 85 | |
| 86 | int rtems_gxx_key_dtor (__gthread_key_t key, void *ptr) |
| 87 | { |
| 88 | #ifdef DEBUG_GXX_WRAPPERS |
| 89 | printk( "gxx_wrappers: dtor key=%x, ptr=%x\n", key, ptr ); |
| 90 | #endif |
| 91 | |
| 92 | key->val = 0; |
| 93 | return 0; |
| 94 | } |
| 95 | |
| 96 | int rtems_gxx_key_delete (__gthread_key_t key) |
| 97 | { |
| 98 | rtems_status_code status; |
| 99 | |
| 100 | #ifdef DEBUG_GXX_WRAPPERS |
| 101 | printk( "gxx_wrappers: delete key=%x\n", key ); |
| 102 | #endif |
| 103 | |
| 104 | |
| 105 | status = rtems_task_variable_delete( RTEMS_SELF((Objects_Id) 0), (void **)key ); |
| 106 | if ( status == RTEMS_SUCCESSFUL ) { |
| 107 | |
| 108 | if ( key ) free( *(void **)key ); |
| 109 | return 0; |
| 110 | } |
| 111 | key = NULL((void*)0); |
| 112 | return 0; |
| 113 | } |
| 114 | |
| 115 | void *rtems_gxx_getspecific(__gthread_key_t key) |
| 116 | { |
| 117 | rtems_status_code status; |
| 118 | void *p= 0; |
| 119 | |
| 120 | |
| 121 | status = rtems_task_variable_get( RTEMS_SELF((Objects_Id) 0), (void **)key, &p ); |
| 122 | if ( status == RTEMS_SUCCESSFUL ) { |
| 123 | |
| 124 | p= key->val; |
| 125 | } else { |
| 126 | |
| 127 | |
| 128 | |
| 129 | status = rtems_task_variable_add( RTEMS_SELF((Objects_Id) 0), (void **)key, key->dtor ); |
| 130 | if ( status != RTEMS_SUCCESSFUL ) { |
| 131 | _Internal_error_Occurred( |
| 132 | INTERNAL_ERROR_CORE, |
| 133 | true1, |
| 134 | INTERNAL_ERROR_GXX_KEY_ADD_FAILED |
| 135 | ); |
| 136 | } |
| 137 | key->val = (void *)0; |
| 138 | } |
| 139 | |
| 140 | #ifdef DEBUG_GXX_WRAPPERS |
| 141 | printk( |
| 142 | "gxx_wrappers: getspecific key=%x, ptr=%x, id=%x\n", |
| 143 | key, |
| 144 | p, |
| 145 | rtems_task_self() |
| 146 | ); |
| 147 | #endif |
| 148 | return p; |
| 149 | } |
| 150 | |
| 151 | int rtems_gxx_setspecific(__gthread_key_t key, const void *ptr) |
| 152 | { |
| 153 | rtems_status_code status; |
| 154 | |
| 155 | #ifdef DEBUG_GXX_WRAPPERS |
| 156 | printk( |
| 157 | "gxx_wrappers: setspecific key=%x, ptr=%x, id=%x\n", |
| 158 | key, |
| 159 | ptr, |
| 160 | rtems_task_self() |
| 161 | ); |
| 162 | #endif |
| 163 | |
| 164 | |
| 165 | status = rtems_task_variable_add( RTEMS_SELF((Objects_Id) 0), (void **)key, key->dtor ); |
| 166 | if ( status == RTEMS_SUCCESSFUL ) { |
| 167 | |
| 168 | key->val = (void *)ptr; |
| 169 | return 0; |
| 170 | } |
| 171 | return -1; |
| 172 | } |
| 173 | |
| 174 | |
| 175 | |
| 176 | |
| 177 | |
| 178 | void rtems_gxx_mutex_init (__gthread_mutex_t *mutex) |
| 179 | { |
| 180 | rtems_status_code status; |
| 181 | |
| 182 | #ifdef DEBUG_GXX_WRAPPERS |
| 183 | printk( "gxx_wrappers: mutex init =%X\n", *mutex ); |
| 184 | #endif |
| 185 | |
| 186 | status = rtems_semaphore_create( |
| 187 | rtems_build_name ('G', 'C', 'C', '2')( (uint32_t)('G') << 24 | (uint32_t)('C') << 16 | (uint32_t)('C') << 8 | (uint32_t)('2') ), |
| 188 | 1, |
| 189 | RTEMS_PRIORITY0x00000004|RTEMS_BINARY_SEMAPHORE0x00000010| |
| 190 | RTEMS_INHERIT_PRIORITY0x00000040|RTEMS_NO_PRIORITY_CEILING0x00000000|RTEMS_LOCAL0x00000000, |
| 191 | 0, |
| 192 | (rtems_id *)mutex |
| 193 | ); |
| 194 | if ( status != RTEMS_SUCCESSFUL ) { |
| 195 | #ifdef DEBUG_GXX_WRAPPERS |
| 196 | printk( |
| 197 | "gxx_wrappers: mutex init failed %s (%d)\n", |
| 198 | rtems_status_text(status), |
| 199 | status |
| 200 | ); |
| 201 | #endif |
| 202 | _Internal_error_Occurred( |
| 203 | INTERNAL_ERROR_CORE, |
| 204 | true1, |
| 205 | INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED |
| 206 | ); |
| 207 | } |
| 208 | #ifdef DEBUG_GXX_WRAPPERS |
| 209 | printk( "gxx_wrappers: mutex init complete =%X\n", *mutex ); |
| 210 | #endif |
| 211 | } |
| 212 | |
| 213 | int rtems_gxx_mutex_lock (__gthread_mutex_t *mutex) |
| 214 | { |
| 215 | rtems_status_code status; |
| 216 | |
| 217 | #ifdef DEBUG_GXX_WRAPPERS |
| 218 | printk( "gxx_wrappers: lock mutex=%X\n", *mutex ); |
| 219 | #endif |
| 220 | |
| 221 | status = rtems_semaphore_obtain( |
| 222 | *(rtems_id *)mutex, |
| 223 | RTEMS_WAIT0x00000000, |
| 224 | RTEMS_NO_TIMEOUT0 |
| 225 | ); |
| 226 | if ( status == RTEMS_SUCCESSFUL ) |
| 227 | return 0; |
| 228 | return -1; |
| 229 | } |
| 230 | |
| 231 | int rtems_gxx_mutex_destroy (__gthread_mutex_t *mutex) |
| 232 | { |
| 233 | rtems_status_code status; |
| 234 | |
| 235 | #ifdef DEBUG_GXX_WRAPPERS |
| 236 | printk( "gxx_wrappers: destroy mutex=%X\n", *mutex ); |
| 237 | #endif |
| 238 | |
| 239 | status = rtems_semaphore_delete(*(rtems_id *)mutex); |
| 240 | if ( status == RTEMS_SUCCESSFUL ) |
| 241 | return 0; |
| 242 | return -1; |
| 243 | } |
| 244 | |
| 245 | int rtems_gxx_mutex_trylock (__gthread_mutex_t *mutex) |
| 246 | { |
| 247 | rtems_status_code status; |
| 248 | |
| 249 | #ifdef DEBUG_GXX_WRAPPERS |
| 250 | printk( "gxx_wrappers: trylock mutex=%X\n", *mutex ); |
| 251 | #endif |
| 252 | |
| 253 | status = rtems_semaphore_obtain (*(rtems_id *)mutex, RTEMS_NO_WAIT0x00000001, 0); |
| 254 | if ( status == RTEMS_SUCCESSFUL ) |
| 255 | return 0; |
| 256 | return -1; |
| 257 | } |
| 258 | |
| 259 | int rtems_gxx_mutex_unlock (__gthread_mutex_t *mutex) |
| 260 | { |
| 261 | rtems_status_code status; |
| 262 | |
| 263 | #ifdef DEBUG_GXX_WRAPPERS |
| 264 | printk( "gxx_wrappers: unlock mutex=%X\n", *mutex ); |
| 265 | #endif |
| 266 | |
| 267 | status = rtems_semaphore_release( *(rtems_id *)mutex ); |
| 268 | if ( status == RTEMS_SUCCESSFUL ) |
| 269 | return 0; |
| 270 | return -1; |
| 271 | } |
| 272 | |
| 273 | void rtems_gxx_recursive_mutex_init(__gthread_recursive_mutex_t *mutex) |
| 274 | { |
| 275 | rtems_gxx_mutex_init(mutex); |
| 276 | } |
| 277 | |
| 278 | int rtems_gxx_recursive_mutex_lock(__gthread_recursive_mutex_t *mutex) |
| 279 | { |
| 280 | return rtems_gxx_mutex_lock(mutex); |
| 281 | } |
| 282 | |
| 283 | int rtems_gxx_recursive_mutex_trylock(__gthread_recursive_mutex_t *mutex) |
| 284 | { |
| 285 | return rtems_gxx_mutex_trylock(mutex); |
| 286 | } |
| 287 | |
| 288 | int rtems_gxx_recursive_mutex_unlock(__gthread_recursive_mutex_t *mutex) |
| 289 | { |
| 290 | return rtems_gxx_mutex_unlock(mutex); |
| 291 | } |
| 292 | |
| 293 | #endif /* __GNUC__ */ |
