| 1 | |
| 2 | |
| 3 | |
| 4 | |
| 5 | |
| 6 | |
| 7 | |
| 8 | |
| 9 | #ifdef HAVE_CONFIG_H1 |
| 10 | #include "config.h" |
| 11 | #endif |
| 12 | |
| 13 | #define __RTEMS_VIOLATE_KERNEL_VISIBILITY__ |
| 14 | #include <rtems.h> |
| 15 | #include <rtems/monitor.h> |
| 16 | |
| 17 | #include <inttypes.h> |
| 18 | #include <stdio.h> |
| 19 | #include <stdlib.h> /* strtoul() */ |
| 20 | |
| 21 | #define DATACOL15 15 |
| 22 | #define CONTCOL15 DATACOL15 /* continued col */ |
| 23 | |
| 24 | |
| 25 | |
| 26 | |
| 27 | |
| 28 | |
| 29 | void |
| 30 | rtems_monitor_config_canonical( |
| 31 | rtems_monitor_config_t *canonical_config, |
| 32 | void *config_void |
| 33 | ) |
| 34 | { |
| 35 | rtems_configuration_table *c = (rtems_configuration_table *) config_void; |
| 36 | rtems_api_configuration_table *r = &Configuration_RTEMS_API; |
| 37 | |
| 38 | canonical_config->work_space_start = c->work_space_start; |
| 39 | canonical_config->work_space_size = c->work_space_size; |
| 40 | canonical_config->maximum_tasks = r->maximum_tasks; |
| 41 | canonical_config->maximum_timers = r->maximum_timers; |
| 42 | canonical_config->maximum_semaphores = r->maximum_semaphores; |
| 43 | canonical_config->maximum_message_queues = r->maximum_message_queues; |
| 44 | canonical_config->maximum_partitions = r->maximum_partitions; |
| 45 | canonical_config->maximum_regions = r->maximum_regions; |
| 46 | canonical_config->maximum_ports = r->maximum_ports; |
| 47 | canonical_config->maximum_periods = r->maximum_periods; |
| 48 | canonical_config->maximum_extensions = c->maximum_extensions; |
| 49 | canonical_config->microseconds_per_tick = c->microseconds_per_tick; |
| 50 | canonical_config->ticks_per_timeslice = c->ticks_per_timeslice; |
| 51 | canonical_config->number_of_initialization_tasks = r->number_of_initialization_tasks; |
| 52 | } |
| 53 | |
| 54 | |
| 55 | |
| 56 | |
| 57 | |
| 58 | |
| 59 | void * |
| 60 | rtems_monitor_config_next( |
| 61 | void *object_info __attribute__((unused)), |
| 62 | rtems_monitor_config_t *canonical_config __attribute__((unused)), |
| 63 | rtems_id *next_id |
| 64 | ) |
| 65 | { |
| 66 | rtems_configuration_table *c = &Configuration; |
| 67 | int n = rtems_object_id_get_index(*next_id)_Objects_Get_index( *next_id ); |
| 68 | |
| 69 | if (n >= 1) |
| 70 | goto failed; |
| 71 | |
| 72 | _Thread_Disable_dispatch(); |
| 73 | |
| 74 | *next_id += 1; |
| 75 | return (void *) c; |
| 76 | |
| 77 | failed: |
| 78 | *next_id = RTEMS_OBJECT_ID_FINAL((Objects_Id)~0); |
| 79 | return 0; |
| 80 | } |
| 81 | |
| 82 | |
| 83 | void |
| 84 | rtems_monitor_config_dump_header( |
| 85 | bool_Bool verbose __attribute__((unused)) |
| 86 | ) |
| 87 | { |
| 88 | fprintf(stdoutstdout,"\ |
| 89 | INITIAL (startup) Configuration Info\n"); |
| 90 | |
| 91 | |
| 92 | rtems_monitor_separator(); |
| 93 | } |
| 94 | |
| 95 | |
| 96 | int |
| 97 | rtems_monitor_config_dump( |
| 98 | rtems_monitor_config_t *monitor_config, |
| 99 | bool_Bool verbose __attribute__((unused)) |
| 100 | ) |
| 101 | { |
| 102 | int length = 0; |
| 103 | |
| 104 | length = 0; |
| 105 | length += fprintf(stdoutstdout,"WORKSPACE"); |
| 106 | length += rtems_monitor_pad(DATACOL15, length); |
| 107 | length += fprintf(stdoutstdout,"start: %p; size: 0x%" PRIx32"x" "\n", |
| 108 | monitor_config->work_space_start, |
| 109 | monitor_config->work_space_size); |
| 110 | |
| 111 | length = 0; |
| 112 | length += fprintf(stdoutstdout,"TIME"); |
| 113 | length += rtems_monitor_pad(DATACOL15, length); |
| 114 | length += fprintf(stdoutstdout,"usec/tick: %" PRId32"d" "; tick/timeslice: %" PRId32"d" "; tick/sec: %" PRId32"d" "\n", |
| 115 | monitor_config->microseconds_per_tick, |
| 116 | monitor_config->ticks_per_timeslice, |
| 117 | 1000000 / monitor_config->microseconds_per_tick); |
| 118 | |
| 119 | length = 0; |
| 120 | length += fprintf(stdoutstdout,"MAXIMUMS"); |
| 121 | length += rtems_monitor_pad(DATACOL15, length); |
| 122 | length += fprintf(stdoutstdout,"tasks: %" PRId32"d" "; timers: %" PRId32"d" "; sems: %" PRId32"d" "; que's: %" PRId32"d" "; ext's: %" PRId32"d" "\n", |
| Value stored to 'length' is never read |
| 123 | monitor_config->maximum_tasks, |
| 124 | monitor_config->maximum_timers, |
| 125 | monitor_config->maximum_semaphores, |
| 126 | monitor_config->maximum_message_queues, |
| 127 | monitor_config->maximum_extensions); |
| 128 | length = 0; |
| 129 | length += rtems_monitor_pad(CONTCOL15, length); |
| 130 | length += fprintf(stdoutstdout,"partitions: %" PRId32"d" "; regions: %" PRId32"d" "; ports: %" PRId32"d" "; periods: %" PRId32"d" "\n", |
| 131 | monitor_config->maximum_partitions, |
| 132 | monitor_config->maximum_regions, |
| 133 | monitor_config->maximum_ports, |
| 134 | monitor_config->maximum_periods); |
| 135 | return length; |
| 136 | } |
