| File: | /home/joel/rtems-4.11-work/build/rtems/c/src/../../cpukit/libmisc/monitor/mon-editor.c |
| Description: | Value stored to 'rp' is never read |
| 1 | /** |
| 2 | * @file |
| 3 | * |
| 4 | * @brief Command line editor for RTEMS monitor. |
| 5 | */ |
| 6 | |
| 7 | /* |
| 8 | * $Id: mon-editor.c,v 1.5 2010/06/21 16:25:09 joel Exp $ |
| 9 | * |
| 10 | * 2001-01-30 KJO (vac4050@cae597.rsc.raytheon.com): |
| 11 | * Fixed rtems_monitor_command_lookup() to accept partial |
| 12 | * commands to uniqeness. Added support for setting |
| 13 | * the monitor prompt via an environment variable: |
| 14 | * RTEMS_MONITOR_PROMPT |
| 15 | * |
| 16 | * CCJ: 26-3-2000, adding command history and command line |
| 17 | * editing. This code is donated from My Right Boot and not |
| 18 | * covered by GPL, only the RTEMS license. |
| 19 | */ |
| 20 | |
| 21 | #ifdef HAVE_CONFIG_H1 |
| 22 | #include "config.h" |
| 23 | #endif |
| 24 | |
| 25 | #include <rtems.h> |
| 26 | |
| 27 | #include <rtems/monitor.h> |
| 28 | |
| 29 | #include <stdio.h> |
| 30 | #include <string.h> |
| 31 | #include <stdlib.h> |
| 32 | #include <inttypes.h> |
| 33 | #include <termios.h> |
| 34 | #include <unistd.h> |
| 35 | |
| 36 | #ifndef MONITOR_PROMPT"rtems" |
| 37 | #define MONITOR_PROMPT"rtems" "rtems" /* will have '> ' appended */ |
| 38 | #endif |
| 39 | |
| 40 | /* |
| 41 | * Some key labels to define special keys. |
| 42 | */ |
| 43 | |
| 44 | #define KEYS_EXTENDED(0x8000) (0x8000) |
| 45 | #define KEYS_NORMAL_MASK(0x00ff) (0x00ff) |
| 46 | #define KEYS_INS(0) (0) |
| 47 | #define KEYS_DEL(1) (1) |
| 48 | #define KEYS_UARROW(2) (2) |
| 49 | #define KEYS_DARROW(3) (3) |
| 50 | #define KEYS_LARROW(4) (4) |
| 51 | #define KEYS_RARROW(5) (5) |
| 52 | #define KEYS_HOME(6) (6) |
| 53 | #define KEYS_END(7) (7) |
| 54 | #define KEYS_F1(8) (8) |
| 55 | #define KEYS_F2(9) (9) |
| 56 | #define KEYS_F3(10) (10) |
| 57 | #define KEYS_F4(11) (11) |
| 58 | #define KEYS_F5(12) (12) |
| 59 | #define KEYS_F6(13) (13) |
| 60 | #define KEYS_F7(14) (14) |
| 61 | #define KEYS_F8(15) (15) |
| 62 | #define KEYS_F9(16) (16) |
| 63 | #define KEYS_F10(17) (17) |
| 64 | |
| 65 | #define RTEMS_COMMAND_BUFFER_SIZE(75) (75) |
| 66 | |
| 67 | static char monitor_prompt[32]; |
| 68 | static char buffer[RTEMS_COMMAND_BUFFER_SIZE(75)]; |
| 69 | static int pos; |
| 70 | static int logged_in; |
| 71 | |
| 72 | /* |
| 73 | * History data. |
| 74 | */ |
| 75 | |
| 76 | #define RTEMS_COMMAND_HISTORIES(20) (20) |
| 77 | |
| 78 | static char history_buffer[RTEMS_COMMAND_HISTORIES(20)][RTEMS_COMMAND_BUFFER_SIZE(75)]; |
| 79 | static int history_pos[RTEMS_COMMAND_HISTORIES(20)]; |
| 80 | static int history; |
| 81 | static int history_next; |
| 82 | |
| 83 | /* |
| 84 | * Translation tables. Not sure if this is the best way to |
| 85 | * handle this, how-ever I wish to avoid the overhead of |
| 86 | * including a more complete and standard environment such |
| 87 | * as ncurses. |
| 88 | */ |
| 89 | |
| 90 | struct translation_table |
| 91 | { |
| 92 | char expecting; |
| 93 | const struct translation_table *branch; |
| 94 | unsigned int key; |
| 95 | }; |
| 96 | |
| 97 | static const struct translation_table trans_two[] = |
| 98 | { |
| 99 | { '~', 0, KEYS_INS(0) }, |
| 100 | { 0, 0, 0 } |
| 101 | }; |
| 102 | |
| 103 | static const struct translation_table trans_three[] = |
| 104 | { |
| 105 | { '~', 0, KEYS_DEL(1) }, |
| 106 | { 0, 0, 0 } |
| 107 | }; |
| 108 | |
| 109 | static const struct translation_table trans_tab_csi[] = |
| 110 | { |
| 111 | { '2', trans_two, 0 }, |
| 112 | { '3', trans_three, 0 }, |
| 113 | { 'A', 0, KEYS_UARROW(2) }, |
| 114 | { 'B', 0, KEYS_DARROW(3) }, |
| 115 | { 'D', 0, KEYS_LARROW(4) }, |
| 116 | { 'C', 0, KEYS_RARROW(5) }, |
| 117 | { 'F', 0, KEYS_END(7) }, |
| 118 | { 'H', 0, KEYS_HOME(6) }, |
| 119 | { 0, 0, 0 } |
| 120 | }; |
| 121 | |
| 122 | static const struct translation_table trans_tab_O[] = |
| 123 | { |
| 124 | { '1', 0, KEYS_F1(8) }, |
| 125 | { '2', 0, KEYS_F2(9) }, |
| 126 | { '3', 0, KEYS_F3(10) }, |
| 127 | { '4', 0, KEYS_F4(11) }, |
| 128 | { '5', 0, KEYS_F5(12) }, |
| 129 | { '6', 0, KEYS_F6(13) }, |
| 130 | { '7', 0, KEYS_F7(14) }, |
| 131 | { '8', 0, KEYS_F8(15) }, |
| 132 | { '9', 0, KEYS_F9(16) }, |
| 133 | { ':', 0, KEYS_F10(17) }, |
| 134 | { 'P', 0, KEYS_F1(8) }, |
| 135 | { 'Q', 0, KEYS_F2(9) }, |
| 136 | { 'R', 0, KEYS_F3(10) }, |
| 137 | { 'S', 0, KEYS_F4(11) }, |
| 138 | { 'T', 0, KEYS_F5(12) }, |
| 139 | { 'U', 0, KEYS_F6(13) }, |
| 140 | { 'V', 0, KEYS_F7(14) }, |
| 141 | { 'W', 0, KEYS_F8(15) }, |
| 142 | { 'X', 0, KEYS_F9(16) }, |
| 143 | { 'Y', 0, KEYS_F10(17) }, |
| 144 | { 0, 0, 0 } |
| 145 | }; |
| 146 | |
| 147 | static const struct translation_table trans_tab[] = |
| 148 | { |
| 149 | { '[', trans_tab_csi, 0 }, /* CSI command sequences */ |
| 150 | { 'O', trans_tab_O, 0 }, /* O are the fuction keys */ |
| 151 | { 0, 0, 0 } |
| 152 | }; |
| 153 | |
| 154 | /* |
| 155 | * Perform a basic translation for some ANSI/VT100 key codes. |
| 156 | * This code could do with a timeout on the ESC as it is |
| 157 | * now lost from the input stream. It is not* used by the |
| 158 | * line editor below so considiered not worth the effort. |
| 159 | */ |
| 160 | |
| 161 | static unsigned int |
| 162 | rtems_monitor_getchar (void) |
| 163 | { |
| 164 | const struct translation_table *translation = 0; |
| 165 | for (;;) |
| 166 | { |
| 167 | char c = getchar (); |
| 168 | if (c == 27) |
| 169 | translation = trans_tab; |
| 170 | else |
| 171 | { |
| 172 | /* |
| 173 | * If no translation happing just pass through |
| 174 | * and return the key. |
| 175 | */ |
| 176 | if (translation) |
| 177 | { |
| 178 | /* |
| 179 | * Scan the current table for the key, and if found |
| 180 | * see if this key is a fork. If so follow it and |
| 181 | * wait else return the extended key. |
| 182 | */ |
| 183 | int index = 0; |
| 184 | int branched = 0; |
| 185 | while ((translation[index].expecting != '\0') || |
| 186 | (translation[index].key != '\0')) |
| 187 | { |
| 188 | if (translation[index].expecting == c) |
| 189 | { |
| 190 | /* |
| 191 | * A branch is take if more keys are to come. |
| 192 | */ |
| 193 | if (translation[index].branch == 0) |
| 194 | return KEYS_EXTENDED(0x8000) | translation[index].key; |
| 195 | else |
| 196 | { |
| 197 | translation = translation[index].branch; |
| 198 | branched = 1; |
| 199 | break; |
| 200 | } |
| 201 | } |
| 202 | index++; |
| 203 | } |
| 204 | /* |
| 205 | * Who knows what these keys are, just drop them. |
| 206 | */ |
| 207 | if (!branched) |
| 208 | translation = 0; |
| 209 | } |
| 210 | else |
| 211 | return c; |
| 212 | } |
| 213 | } |
| 214 | } |
| 215 | |
| 216 | /* |
| 217 | * The line editor with history. |
| 218 | */ |
| 219 | |
| 220 | static int |
| 221 | rtems_monitor_line_editor ( |
| 222 | char *command |
| 223 | ) |
| 224 | { |
| 225 | int repeating = 0; |
| 226 | |
| 227 | memset (buffer, 0, RTEMS_COMMAND_BUFFER_SIZE(75)); |
| 228 | history = history_next; |
| 229 | pos = 0; |
| 230 | |
| 231 | if (!logged_in) |
| 232 | fprintf(stdoutstdout,"\nMonitor ready, press enter to login.\n\n"); |
| 233 | else |
| 234 | fprintf(stdoutstdout,"%s $ ", monitor_prompt); |
| 235 | |
| 236 | while (1) |
| 237 | { |
| 238 | unsigned int extended_key; |
| 239 | char c; |
| 240 | |
| 241 | fflush (stdoutstdout); |
| 242 | |
| 243 | extended_key = rtems_monitor_getchar (); |
| 244 | c = extended_key & KEYS_NORMAL_MASK(0x00ff); |
| 245 | |
| 246 | /* |
| 247 | * Make the extended_key usable as a boolean. |
| 248 | */ |
| 249 | extended_key &= ~KEYS_NORMAL_MASK(0x00ff); |
| 250 | |
| 251 | if (!extended_key && !logged_in) |
| 252 | { |
| 253 | if (c == '\n') |
| 254 | { |
| 255 | logged_in = 1; |
| 256 | /* |
| 257 | * The prompt has changed from `>' to `$' to help know |
| 258 | * which version of the monitor code people are using. |
| 259 | */ |
| 260 | fprintf(stdoutstdout,"%s $ ", monitor_prompt); |
| 261 | } |
| 262 | } |
| 263 | else |
| 264 | { |
| 265 | if (extended_key) |
| 266 | { |
| 267 | switch (c) |
| 268 | { |
| 269 | case KEYS_END(7): |
| 270 | fprintf(stdoutstdout,buffer + pos); |
| 271 | pos = (int) strlen (buffer); |
| 272 | break; |
| 273 | |
| 274 | case KEYS_HOME(6): |
| 275 | fprintf(stdoutstdout,"\r%s $ ", monitor_prompt); |
| 276 | pos = 0; |
| 277 | break; |
| 278 | |
| 279 | case KEYS_LARROW(4): |
| 280 | if (pos > 0) |
| 281 | { |
| 282 | pos--; |
| 283 | putchar ('\b'); |
| 284 | } |
| 285 | break; |
| 286 | |
| 287 | case KEYS_RARROW(5): |
| 288 | if ((pos < RTEMS_COMMAND_BUFFER_SIZE(75)) && (buffer[pos] != '\0')) |
| 289 | { |
| 290 | putchar (buffer[pos]); |
| 291 | pos++; |
| 292 | } |
| 293 | break; |
| 294 | |
| 295 | case KEYS_UARROW(2): |
| 296 | /* |
| 297 | * If we are moving up the histories then we need to save the working |
| 298 | * buffer. |
| 299 | */ |
| 300 | if (history) |
| 301 | { |
| 302 | int end; |
| 303 | int bs; |
| 304 | if (history == history_next) |
| 305 | { |
| 306 | memcpy (history_buffer[history_next], buffer, |
| 307 | RTEMS_COMMAND_BUFFER_SIZE(75)); |
| 308 | history_pos[history_next] = pos; |
| 309 | } |
| 310 | history--; |
| 311 | memcpy (buffer, history_buffer[history], |
| 312 | RTEMS_COMMAND_BUFFER_SIZE(75)); |
| 313 | pos = history_pos[history]; |
| 314 | fprintf(stdoutstdout,"\r%*c", RTEMS_COMMAND_BUFFER_SIZE(75), ' '); |
| 315 | fprintf(stdoutstdout,"\r%s $ %s", monitor_prompt, buffer); |
| 316 | end = (int) strlen (buffer); |
| 317 | for (bs = 0; bs < (end - pos); bs++) |
| 318 | putchar ('\b'); |
| 319 | } |
| 320 | break; |
| 321 | |
| 322 | case KEYS_DARROW(3): |
| 323 | if (history < history_next) |
| 324 | { |
| 325 | int end; |
| 326 | int bs; |
| 327 | history++; |
| 328 | memcpy (buffer, history_buffer[history], |
| 329 | RTEMS_COMMAND_BUFFER_SIZE(75)); |
| 330 | pos = history_pos[history]; |
| 331 | fprintf(stdoutstdout,"\r%*c", RTEMS_COMMAND_BUFFER_SIZE(75), ' '); |
| 332 | fprintf(stdoutstdout,"\r%s $ %s", monitor_prompt, buffer); |
| 333 | end = (int) strlen (buffer); |
| 334 | for (bs = 0; bs < (end - pos); bs++) |
| 335 | putchar ('\b'); |
| 336 | } |
| 337 | break; |
| 338 | |
| 339 | case KEYS_DEL(1): |
| 340 | if (buffer[pos] != '\0') |
| 341 | { |
| 342 | int end; |
| 343 | int bs; |
| 344 | strcpy (&buffer[pos], &buffer[pos + 1]); |
| 345 | fprintf(stdoutstdout,"\r%s $ %s", monitor_prompt, buffer); |
| 346 | end = (int) strlen (buffer); |
| 347 | for (bs = 0; bs < (end - pos); bs++) |
| 348 | putchar ('\b'); |
| 349 | } |
| 350 | break; |
| 351 | } |
| 352 | } |
| 353 | else |
| 354 | { |
| 355 | switch (c) |
| 356 | { |
| 357 | case '\b': |
| 358 | case '\x7e': |
| 359 | case '\x7f': |
| 360 | if (pos > 0) |
| 361 | { |
| 362 | int bs; |
| 363 | pos--; |
| 364 | strcpy (buffer + pos, buffer + pos + 1); |
| 365 | fprintf(stdoutstdout,"\b%s \b", buffer + pos); |
| 366 | for (bs = 0; bs < ((int) strlen (buffer) - pos); bs++) |
| 367 | putchar ('\b'); |
| 368 | } |
| 369 | break; |
| 370 | |
| 371 | case '\n': |
| 372 | /* |
| 373 | * Process the command. |
| 374 | */ |
| 375 | fprintf(stdoutstdout,"\n"); |
| 376 | repeating = 1; |
| 377 | /* |
| 378 | * Only process the history if we have a command and |
| 379 | *a history. |
| 380 | */ |
| 381 | if (strlen (buffer)) |
| 382 | { |
| 383 | if (history_next && (history == history_next)) |
| 384 | { |
| 385 | /* |
| 386 | * Do not place the last command into the history |
| 387 | *if the same. |
| 388 | */ |
| 389 | if (strcmp (history_buffer[history_next - 1], buffer)) |
| 390 | repeating = 0; |
| 391 | } |
| 392 | else |
| 393 | repeating = 0; |
| 394 | } |
| 395 | if (!repeating) |
| 396 | { |
| 397 | memcpy (history_buffer[history_next], buffer, |
| 398 | RTEMS_COMMAND_BUFFER_SIZE(75)); |
| 399 | history_pos[history_next] = pos; |
| 400 | if (history_next < (RTEMS_COMMAND_HISTORIES(20) - 1)) |
| 401 | history_next++; |
| 402 | else |
| 403 | { |
| 404 | memmove (history_buffer[0], history_buffer[1], |
| 405 | RTEMS_COMMAND_BUFFER_SIZE(75) * (RTEMS_COMMAND_HISTORIES(20) - 1)); |
| 406 | memmove (&history_pos[0], &history_pos[1], |
| 407 | sizeof (history_pos[0]) * (RTEMS_COMMAND_HISTORIES(20) - 1)); |
| 408 | } |
| 409 | } |
| 410 | else |
| 411 | { |
| 412 | #ifdef ENABLE_ENTER_REPEATS |
| 413 | if (history_next) |
| 414 | memcpy (buffer, history_buffer[history_next - 1], |
| 415 | RTEMS_COMMAND_BUFFER_SIZE(75)); |
| 416 | #endif |
| 417 | } |
| 418 | memmove (command, buffer, RTEMS_COMMAND_BUFFER_SIZE(75)); |
| 419 | return repeating; |
| 420 | break; |
| 421 | |
| 422 | default: |
| 423 | if ((pos < (RTEMS_COMMAND_BUFFER_SIZE(75) - 1)) && |
| 424 | (c >= ' ') && (c <= 'z')) |
| 425 | { |
| 426 | int end; |
| 427 | end = strlen (buffer); |
| 428 | if ((pos < end) && (end < RTEMS_COMMAND_BUFFER_SIZE(75))) |
| 429 | { |
| 430 | int ch, bs; |
| 431 | for (ch = end; ch > pos; ch--) |
| 432 | buffer[ch] = buffer[ch - 1]; |
| 433 | fprintf(stdoutstdout,buffer + pos); |
| 434 | for (bs = 0; bs < (end - pos + 1); bs++) |
| 435 | putchar ('\b'); |
| 436 | } |
| 437 | buffer[pos++] = c; |
| 438 | if (pos > end) |
| 439 | buffer[pos] = '\0'; |
| 440 | putchar (c); |
| 441 | } |
| 442 | break; |
| 443 | } |
| 444 | } |
| 445 | } |
| 446 | } |
| 447 | } |
| 448 | |
| 449 | /* |
| 450 | * make_argv(cp): token-count |
| 451 | * Break up the command line in 'cp' into global argv[] and argc (return |
| 452 | * value). |
| 453 | */ |
| 454 | |
| 455 | int |
| 456 | rtems_monitor_make_argv( |
| 457 | char *cp, |
| 458 | int *argc_p, |
| 459 | char **argv) |
| 460 | { |
| 461 | int argc = 0; |
| 462 | |
| 463 | while ((cp = strtok(cp, " \t\n\r"))) |
| 464 | { |
| 465 | argv[argc++] = cp; |
| 466 | cp = (char *) NULL((void*)0); |
| 467 | } |
| 468 | argv[argc] = (char *) NULL((void*)0); /* end of argv */ |
| 469 | |
| 470 | return *argc_p = argc; |
| 471 | } |
| 472 | |
| 473 | |
| 474 | /* |
| 475 | * Read and break up a monitor command |
| 476 | * |
| 477 | * We have to loop on the gets call, since it will return NULL under UNIX |
| 478 | * RTEMS when we get a signal (eg: SIGALRM). |
| 479 | */ |
| 480 | |
| 481 | int |
| 482 | rtems_monitor_command_read(char *command, |
| 483 | int *argc, |
| 484 | char **argv) |
| 485 | { |
| 486 | char *env_prompt; |
| 487 | |
| 488 | env_prompt = getenv("RTEMS_MONITOR_PROMPT"); |
| 489 | |
| 490 | /* |
| 491 | * put node number in the prompt if we are multiprocessing |
| 492 | */ |
| 493 | #if defined(RTEMS_MULTIPROCESSING) |
| 494 | if (!rtems_configuration_get_user_multiprocessing_table ()((void*)0)) |
| 495 | sprintf (monitor_prompt, "%s", |
| 496 | (env_prompt == NULL((void*)0)) ? MONITOR_PROMPT"rtems": env_prompt); |
| 497 | else /* .... */ |
| 498 | #endif |
| 499 | if (rtems_monitor_default_node != rtems_monitor_node) |
| 500 | sprintf (monitor_prompt, "%" PRId32"d" "-%s-%" PRId32"d" "", rtems_monitor_node, |
| 501 | (env_prompt == NULL((void*)0)) ? MONITOR_PROMPT"rtems" : env_prompt, |
| 502 | rtems_monitor_default_node); |
| 503 | else |
| 504 | sprintf (monitor_prompt, "%" PRId32"d" "-%s", rtems_monitor_node, |
| 505 | (env_prompt == NULL((void*)0)) ? MONITOR_PROMPT"rtems" : env_prompt); |
| 506 | |
| 507 | rtems_monitor_line_editor (command); |
| 508 | |
| 509 | return rtems_monitor_make_argv (command, argc, argv); |
| 510 | } |
| 511 | |
| 512 | /* |
| 513 | * Main monitor command loop |
| 514 | */ |
| 515 | |
| 516 | void |
| 517 | rtems_monitor_task( |
| 518 | rtems_task_argument monitor_flags |
| 519 | ) |
| 520 | { |
| 521 | rtems_tcb *debugee = 0; |
| 522 | rtems_context *rp; |
| 523 | #if (CPU_HARDWARE_FP1 == TRUE1) || (CPU_SOFTWARE_FP0 == TRUE1) |
| 524 | rtems_context_fp *fp; |
| 525 | #endif |
| 526 | char command_buffer[513]; |
| 527 | int argc; |
| 528 | char *argv[64]; |
| 529 | bool_Bool verbose = false0; |
| 530 | struct termios term; |
| 531 | |
| 532 | /* |
| 533 | * Make the stdin stream characte not line based. |
| 534 | */ |
| 535 | |
| 536 | if (tcgetattr (STDIN_FILENO0, &term) < 0) |
| 537 | { |
| 538 | fprintf(stdoutstdout,"rtems-monitor: cannot get terminal attributes.\n"); |
| 539 | } |
| 540 | else |
| 541 | { |
| 542 | /* |
| 543 | * No echo, no canonical processing. |
| 544 | */ |
| 545 | |
| 546 | term.c_lflag &= ~(ECHO0000010 | ICANON0000002 | IEXTEN0100000); |
| 547 | |
| 548 | /* |
| 549 | * No sigint on BREAK, CR-to-NL off, input parity off, |
| 550 | * don't strip 8th bit on input, output flow control off |
| 551 | */ |
| 552 | |
| 553 | term.c_lflag &= ~(INPCK0000020 | ISTRIP0000040 | IXON0002000); |
| 554 | term.c_cc[VMIN6] = 1; |
| 555 | term.c_cc[VTIME5] = 0; |
| 556 | |
| 557 | if (tcsetattr (STDIN_FILENO0, TCSANOW0, &term) < 0) |
| 558 | { |
| 559 | fprintf(stdoutstdout,"cannot set terminal attributes\n"); |
| 560 | } |
| 561 | } |
| 562 | |
| 563 | if (!(monitor_flags & RTEMS_MONITOR_NOSYMLOAD0x0008)) { |
| 564 | rtems_monitor_symbols_loadup(); |
| 565 | } |
| 566 | |
| 567 | if (monitor_flags & RTEMS_MONITOR_SUSPEND0x0001) |
| 568 | (void) rtems_monitor_suspend(RTEMS_NO_TIMEOUT0); |
| 569 | |
| 570 | for (;;) |
| 571 | { |
| 572 | const rtems_monitor_command_entry_t *command; |
| 573 | |
| 574 | debugee = _Thread_Executing_Per_CPU_Information.executing; |
| 575 | rp = &debugee->Registers; |
Value stored to 'rp' is never read | |
| 576 | #if (CPU_HARDWARE_FP1 == TRUE1) || (CPU_SOFTWARE_FP0 == TRUE1) |
| 577 | fp = debugee->fp_context; /* possibly 0 */ |
| 578 | #endif |
| 579 | |
| 580 | if (0 == rtems_monitor_command_read(command_buffer, &argc, argv)) |
| 581 | continue; |
| 582 | if (argc < 1 |
| 583 | || (command = rtems_monitor_command_lookup(argv [0])) == 0) { |
| 584 | /* no command */ |
| 585 | fprintf(stdoutstdout,"Unrecognised command; try 'help'\n"); |
| 586 | continue; |
| 587 | } |
| 588 | |
| 589 | command->command_function(argc, argv, &command->command_arg, verbose); |
| 590 | |
| 591 | fflush(stdoutstdout); |
| 592 | } |
| 593 | } |
| 594 | |
| 595 | |
| 596 | void |
| 597 | rtems_monitor_kill(void) |
| 598 | { |
| 599 | if (rtems_monitor_task_id) |
| 600 | rtems_task_delete(rtems_monitor_task_id); |
| 601 | rtems_monitor_task_id = 0; |
| 602 | |
| 603 | rtems_monitor_server_kill(); |
| 604 | } |
| 605 | |
| 606 | void |
| 607 | rtems_monitor_init( |
| 608 | uint32_t monitor_flags |
| 609 | ) |
| 610 | { |
| 611 | rtems_status_code status; |
| 612 | |
| 613 | rtems_monitor_kill(); |
| 614 | |
| 615 | status = rtems_task_create(RTEMS_MONITOR_NAME(( (uint32_t)('R') << 24 | (uint32_t)('M') << 16 | (uint32_t)('O') << 8 | (uint32_t)('N') )), |
| 616 | 1, |
| 617 | RTEMS_MINIMUM_STACK_SIZE(1024*4) * 2, |
| 618 | RTEMS_INTERRUPT_LEVEL(0)( (0) & 0x0000000F ), |
| 619 | RTEMS_DEFAULT_ATTRIBUTES0x00000000, |
| 620 | &rtems_monitor_task_id); |
| 621 | if (status != RTEMS_SUCCESSFUL) |
| 622 | { |
| 623 | rtems_error(status, "could not create monitor task"); |
| 624 | return; |
| 625 | } |
| 626 | |
| 627 | rtems_monitor_node = rtems_object_id_get_node(rtems_monitor_task_id)_Objects_Get_node( rtems_monitor_task_id ); |
| 628 | rtems_monitor_default_node = rtems_monitor_node; |
| 629 | |
| 630 | rtems_monitor_server_init(monitor_flags); |
| 631 | |
| 632 | if (!(monitor_flags & RTEMS_MONITOR_NOTASK0x0004)) { |
| 633 | /* |
| 634 | * Start the monitor task itself |
| 635 | */ |
| 636 | status = rtems_task_start( |
| 637 | rtems_monitor_task_id, rtems_monitor_task, monitor_flags); |
| 638 | if (status != RTEMS_SUCCESSFUL) { |
| 639 | rtems_error(status, "could not start monitor"); |
| 640 | return; |
| 641 | } |
| 642 | } |
| 643 | } |
