| File: | /home/joel/rtems-4.11-work/build/rtems/c/src/../../cpukit/posix/src/semopen.c |
| Description: | Value stored to 'mode' is never read |
| 1 | /* |
| 2 | * COPYRIGHT (c) 1989-2007. |
| 3 | * On-Line Applications Research Corporation (OAR). |
| 4 | * |
| 5 | * The license and distribution terms for this file may be |
| 6 | * found in the file LICENSE in this distribution or at |
| 7 | * http://www.rtems.com/license/LICENSE. |
| 8 | * |
| 9 | * $Id: semopen.c,v 1.15 2009/05/03 23:10:02 joel Exp $ |
| 10 | */ |
| 11 | |
| 12 | #if HAVE_CONFIG_H1 |
| 13 | #include "config.h" |
| 14 | #endif |
| 15 | |
| 16 | #include <stdarg.h> |
| 17 | |
| 18 | #include <errno(*__errno_location ()).h> |
| 19 | #include <fcntl.h> |
| 20 | #include <pthread.h> |
| 21 | #include <semaphore.h> |
| 22 | #include <limits.h> |
| 23 | |
| 24 | #include <rtems/system.h> |
| 25 | #include <rtems/score/object.h> |
| 26 | #include <rtems/posix/semaphore.h> |
| 27 | #include <rtems/posix/time.h> |
| 28 | #include <rtems/seterr.h> |
| 29 | |
| 30 | /*PAGE |
| 31 | * |
| 32 | * sem_open |
| 33 | * |
| 34 | * Opens a named semaphore. Used in conjunction with the sem_close |
| 35 | * and sem_unlink commands. |
| 36 | * |
| 37 | * 11.2.3 Initialize/Open a Named Semaphore, P1003.1b-1993, p.221 |
| 38 | * |
| 39 | * NOTE: When oflag is O_CREAT, then optional third and fourth |
| 40 | * parameters must be present. |
| 41 | */ |
| 42 | |
| 43 | sem_t *sem_open( |
| 44 | const char *name, |
| 45 | int oflag, |
| 46 | ... |
| 47 | /* mode_t mode, */ |
| 48 | /* unsigned int value */ |
| 49 | ) |
| 50 | { |
| 51 | va_list arg; |
| 52 | mode_t mode; |
| 53 | unsigned int value = 0; |
| 54 | int status; |
| 55 | sem_t the_semaphore_id; |
| 56 | sem_t *id; |
| 57 | POSIX_Semaphore_Control *the_semaphore; |
| 58 | Objects_Locations location; |
| 59 | |
| 60 | _Thread_Disable_dispatch(); |
| 61 | |
| 62 | if ( oflag & O_CREAT0100 ) { |
| 63 | va_start(arg, oflag)__builtin_va_start(arg, oflag); |
| 64 | mode = (mode_t) va_arg( arg, unsigned int )__builtin_va_arg(arg, unsigned int); |
Value stored to 'mode' is never read | |
| 65 | value = va_arg( arg, unsigned int )__builtin_va_arg(arg, unsigned int); |
| 66 | va_end(arg)__builtin_va_end(arg); |
| 67 | } |
| 68 | |
| 69 | status = _POSIX_Semaphore_Name_to_id( name, &the_semaphore_id ); |
| 70 | |
| 71 | /* |
| 72 | * If the name to id translation worked, then the semaphore exists |
| 73 | * and we can just return a pointer to the id. Otherwise we may |
| 74 | * need to check to see if this is a "semaphore does not exist" |
| 75 | * or some other miscellaneous error on the name. |
| 76 | */ |
| 77 | |
| 78 | if ( status ) { |
| 79 | |
| 80 | /* |
| 81 | * Unless provided a valid name that did not already exist |
| 82 | * and we are willing to create then it is an error. |
| 83 | */ |
| 84 | |
| 85 | if ( !( status == ENOENT2 && (oflag & O_CREAT0100) ) ) { |
| 86 | _Thread_Enable_dispatch(); |
| 87 | rtems_set_errno_and_return_minus_one_cast( status, sem_t * )do { (*__errno_location ()) = (status); return (sem_t *) -1; } while(0); |
| 88 | } |
| 89 | } else { |
| 90 | |
| 91 | /* |
| 92 | * Check for existence with creation. |
| 93 | */ |
| 94 | |
| 95 | if ( (oflag & (O_CREAT0100 | O_EXCL0200)) == (O_CREAT0100 | O_EXCL0200) ) { |
| 96 | _Thread_Enable_dispatch(); |
| 97 | rtems_set_errno_and_return_minus_one_cast( EEXIST, sem_t * )do { (*__errno_location ()) = (17); return (sem_t *) -1; } while (0); |
| 98 | } |
| 99 | |
| 100 | the_semaphore = _POSIX_Semaphore_Get( &the_semaphore_id, &location ); |
| 101 | the_semaphore->open_count += 1; |
| 102 | _Thread_Enable_dispatch(); |
| 103 | _Thread_Enable_dispatch(); |
| 104 | goto return_id; |
| 105 | } |
| 106 | |
| 107 | /* |
| 108 | * At this point, the semaphore does not exist and everything has been |
| 109 | * checked. We should go ahead and create a semaphore. |
| 110 | */ |
| 111 | |
| 112 | status =_POSIX_Semaphore_Create_support( |
| 113 | name, |
| 114 | false0, /* not shared across processes */ |
| 115 | value, |
| 116 | &the_semaphore |
| 117 | ); |
| 118 | |
| 119 | /* |
| 120 | * errno was set by Create_support, so don't set it again. |
| 121 | */ |
| 122 | |
| 123 | _Thread_Enable_dispatch(); |
| 124 | |
| 125 | if ( status == -1 ) |
| 126 | return SEM_FAILED(sem_t *) -1; |
| 127 | |
| 128 | return_id: |
| 129 | #if defined(RTEMS_USE_16_BIT_OBJECT) |
| 130 | the_semaphore->Semaphore_id = the_semaphore->Object.id; |
| 131 | id = &the_semaphore->Semaphore_id; |
| 132 | #else |
| 133 | id = (sem_t *)&the_semaphore->Object.id; |
| 134 | #endif |
| 135 | return id; |
| 136 | } |
