| 1 | |
| 2 | |
| 3 | |
| 4 | |
| 5 | |
| 6 | |
| 7 | |
| 8 | |
| 9 | |
| 10 | |
| 11 | #if HAVE_CONFIG_H1 |
| 12 | #include "config.h" |
| 13 | #endif |
| 14 | |
| 15 | #include <aio.h> |
| 16 | #include <rtems/posix/aio_misc.h> |
| 17 | #include <errno(*__errno_location ()).h> |
| 18 | #include <stdlib.h> |
| 19 | #include <rtems/system.h> |
| 20 | #include <rtems/seterr.h> |
| 21 | |
| 22 | |
| 23 | |
| 24 | |
| 25 | |
| 26 | |
| 27 | |
| 28 | |
| 29 | |
| 30 | |
| 31 | |
| 32 | |
| 33 | |
| 34 | |
| 35 | |
| 36 | |
| 37 | |
| 38 | |
| 39 | int aio_cancel(int fildes, struct aiocb *aiocbp) |
| 40 | { |
| 41 | rtems_aio_request_chain *r_chain; |
| 42 | int result; |
| 43 | |
| 44 | pthread_mutex_lock (&aio_request_queue.mutex); |
| 45 | |
| 46 | if (aiocbp == NULL((void *)0)) |
| 47 | { |
| 48 | if (fcntl (fildes, F_GETFL3) < 0) { |
| 49 | pthread_mutex_unlock(&aio_request_queue.mutex); |
| 50 | rtems_set_errno_and_return_minus_one (EBADF)do { (*__errno_location ()) = (9); return -1; } while(0); |
| 51 | } |
| 52 | |
| 53 | r_chain = rtems_aio_search_fd (&aio_request_queue.work_req, |
| 54 | fildes, |
| 55 | 0); |
| 56 | if (r_chain == NULL((void *)0)) |
| 57 | { |
| 58 | if (!rtems_chain_is_empty (&aio_request_queue.idle_req)) |
| 59 | { |
| 60 | r_chain = rtems_aio_search_fd (&aio_request_queue.idle_req, |
| 61 | fildes, |
| 62 | 0); |
| 63 | if (r_chain == NULL((void *)0)) { |
| 64 | pthread_mutex_unlock(&aio_request_queue.mutex); |
| 65 | return AIO_ALLDONE2; |
| 66 | } |
| 67 | |
| 68 | rtems_chain_extract (&r_chain->next_fd); |
| 69 | rtems_aio_remove_fd (r_chain); |
| 70 | pthread_mutex_destroy (&r_chain->mutex); |
| 71 | pthread_cond_destroy (&r_chain->mutex); |
| 72 | free (r_chain); |
| 73 | |
| 74 | pthread_mutex_unlock (&aio_request_queue.mutex); |
| 75 | return AIO_CANCELED0; |
| 76 | } |
| 77 | |
| 78 | pthread_mutex_unlock (&aio_request_queue.mutex); |
| 79 | return AIO_ALLDONE2; |
| 80 | } |
| 81 | |
| 82 | pthread_mutex_lock (&r_chain->mutex); |
| 83 | rtems_chain_extract (&r_chain->next_fd); |
| 84 | rtems_aio_remove_fd (r_chain); |
| 85 | pthread_mutex_unlock (&r_chain->mutex); |
| 86 | pthread_mutex_unlock (&aio_request_queue.mutex); |
| 87 | return AIO_CANCELED0; |
| 88 | } |
| 89 | else |
| 90 | { |
| 91 | if (aiocbp->aio_fildes != fildes) { |
| 92 | pthread_mutex_unlock (&aio_request_queue.mutex); |
| 93 | rtems_set_errno_and_return_minus_one (EINVAL)do { (*__errno_location ()) = (22); return -1; } while(0); |
| 94 | } |
| 95 | |
| 96 | r_chain = rtems_aio_search_fd (&aio_request_queue.work_req, |
| 97 | fildes, |
| 98 | 0); |
| 99 | if (r_chain == NULL((void *)0)) |
| 3 | Assuming pointer value is null |
| 100 | if (!rtems_chain_is_empty (&aio_request_queue.idle_req)) |
| 101 | { |
| 102 | r_chain = rtems_aio_search_fd (&aio_request_queue.idle_req, |
| 103 | fildes, |
| 104 | 0); |
| 105 | if (r_chain == NULL((void *)0)) |
| 106 | { |
| 107 | pthread_mutex_unlock (&aio_request_queue.mutex); |
| 108 | rtems_set_errno_and_return_minus_one (EINVAL)do { (*__errno_location ()) = (22); return -1; } while(0); |
| 109 | } |
| 110 | |
| 111 | result = rtems_aio_remove_req (&r_chain->next_fd, aiocbp); |
| 112 | pthread_mutex_unlock (&aio_request_queue.mutex); |
| 113 | return result; |
| 114 | |
| 115 | } |
| 116 | |
| 117 | pthread_mutex_lock (&r_chain->mutex); |
| 6 | Null pointer passed as an argument to a 'nonnull' parameter |
| 118 | result = rtems_aio_remove_req (&r_chain->next_fd, aiocbp); |
| 119 | pthread_mutex_unlock (&r_chain->mutex); |
| 120 | pthread_mutex_unlock (&aio_request_queue.mutex); |
| 121 | return result; |
| 122 | |
| 123 | } |
| 124 | |
| 125 | return AIO_ALLDONE2; |
| 126 | } |
