| File: | /home/joel/rtems-4.11-work/build/rtems/c/src/../../cpukit/libmisc/untar/untar.c |
| Description: | Although the value stored to 'n' is used in the enclosing expression, the value is never actually read from 'n' |
| 1 | /* FIXME: |
| 2 | * 1. Symbolic links are not created. |
| 3 | * 2. Untar_FromMemory uses FILE *fp. |
| 4 | * 3. How to determine end of archive? |
| 5 | * |
| 6 | * Written by: Jake Janovetz <janovetz@tempest.ece.uiuc.edu> |
| 7 | * |
| 8 | * The license and distribution terms for this file may be |
| 9 | * found in the file LICENSE in this distribution or at |
| 10 | * http://www.rtems.com/license/LICENSE. |
| 11 | * |
| 12 | * $Id: untar.c,v 1.14 2010/08/24 13:06:24 ralf Exp $ |
| 13 | */ |
| 14 | |
| 15 | #ifdef HAVE_CONFIG_H1 |
| 16 | #include "config.h" |
| 17 | #endif |
| 18 | |
| 19 | #include <stdio.h> |
| 20 | #include <string.h> |
| 21 | #include <stdlib.h> |
| 22 | #include <unistd.h> |
| 23 | #include <sys/stat.h> |
| 24 | #include <fcntl.h> |
| 25 | #include <rtems/untar.h> |
| 26 | #include <rtems/bspIo.h> |
| 27 | |
| 28 | |
| 29 | /************************************************************************** |
| 30 | * TAR file format: |
| 31 | * |
| 32 | * Offset Length Contents |
| 33 | * 0 100 bytes File name ('\0' terminated, 99 maxmum length) |
| 34 | * 100 8 bytes File mode (in octal ascii) |
| 35 | * 108 8 bytes User ID (in octal ascii) |
| 36 | * 116 8 bytes Group ID (in octal ascii) |
| 37 | * 124 12 bytes File size (s) (in octal ascii) |
| 38 | * 136 12 bytes Modify time (in octal ascii) |
| 39 | * 148 8 bytes Header checksum (in octal ascii) |
| 40 | * 156 1 bytes Link flag |
| 41 | * 157 100 bytes Linkname ('\0' terminated, 99 maxmum length) |
| 42 | * 257 8 bytes Magic PAX ("ustar\0" + 2 bytes padding) |
| 43 | * 257 8 bytes Magic GNU tar ("ustar \0") |
| 44 | * 265 32 bytes User name ('\0' terminated, 31 maxmum length) |
| 45 | * 297 32 bytes Group name ('\0' terminated, 31 maxmum length) |
| 46 | * 329 8 bytes Major device ID (in octal ascii) |
| 47 | * 337 8 bytes Minor device ID (in octal ascii) |
| 48 | * 345 155 bytes Prefix |
| 49 | * 512 (s+p)bytes File contents (s+p) := (((s) + 511) & ~511), |
| 50 | * round up to 512 bytes |
| 51 | * |
| 52 | * Checksum: |
| 53 | * int i, sum; |
| 54 | * char* header = tar_header_pointer; |
| 55 | * sum = 0; |
| 56 | * for(i = 0; i < 512; i++) |
| 57 | * sum += 0xFF & header[i]; |
| 58 | *************************************************************************/ |
| 59 | |
| 60 | #define MAX_NAME_FIELD_SIZE99 99 |
| 61 | |
| 62 | #define MIN(a,b)((a)>(b)?(b):(a)) ((a)>(b)?(b):(a)) |
| 63 | |
| 64 | |
| 65 | /************************************************************************** |
| 66 | * This converts octal ASCII number representations into an |
| 67 | * unsigned long. Only support 32-bit numbers for now. |
| 68 | *************************************************************************/ |
| 69 | unsigned long |
| 70 | _rtems_octal2ulong( |
| 71 | const char *octascii, |
| 72 | size_t len |
| 73 | ) |
| 74 | { |
| 75 | size_t i; |
| 76 | unsigned long num; |
| 77 | |
| 78 | num = 0; |
| 79 | for (i=0; i < len; i++) |
| 80 | { |
| 81 | if ((octascii[i] < '0') || (octascii[i] > '9')) |
| 82 | { |
| 83 | continue; |
| 84 | } |
| 85 | num = num * 8 + ((unsigned long)(octascii[i] - '0')); |
| 86 | } |
| 87 | return(num); |
| 88 | } |
| 89 | |
| 90 | |
| 91 | /************************************************************************** |
| 92 | * Function: Untar_FromMemory * |
| 93 | ************************************************************************** |
| 94 | * Description: * |
| 95 | * * |
| 96 | * This is a simple subroutine used to rip links, directories, and * |
| 97 | * files out of a block of memory. * |
| 98 | * * |
| 99 | * * |
| 100 | * Inputs: * |
| 101 | * * |
| 102 | * void * tar_buf - Pointer to TAR buffer. * |
| 103 | * size_t size - Length of TAR buffer. * |
| 104 | * * |
| 105 | * * |
| 106 | * Output: * |
| 107 | * * |
| 108 | * int - UNTAR_SUCCESSFUL (0) on successful completion. * |
| 109 | * UNTAR_INVALID_CHECKSUM for an invalid header checksum. * |
| 110 | * UNTAR_INVALID_HEADER for an invalid header. * |
| 111 | * * |
| 112 | **************************************************************************/ |
| 113 | int |
| 114 | Untar_FromMemory( |
| 115 | void *tar_buf, |
| 116 | size_t size |
| 117 | ) |
| 118 | { |
| 119 | FILE *fp; |
| 120 | const char *tar_ptr = (const char *)tar_buf; |
| 121 | const char *bufr; |
| 122 | size_t n; |
| 123 | char fname[100]; |
| 124 | char linkname[100]; |
| 125 | int sum; |
| 126 | int hdr_chksum; |
| 127 | int retval; |
| 128 | unsigned long ptr; |
| 129 | unsigned long i; |
| 130 | unsigned long nblocks; |
| 131 | unsigned long file_size; |
| 132 | unsigned char linkflag; |
| 133 | |
| 134 | |
| 135 | ptr = 0; |
| 136 | while (1) |
| 137 | { |
| 138 | if (ptr + 512 > size) |
| 139 | { |
| 140 | retval = UNTAR_SUCCESSFUL0; |
| 141 | break; |
| 142 | } |
| 143 | |
| 144 | /* Read the header */ |
| 145 | bufr = &tar_ptr[ptr]; |
| 146 | ptr += 512; |
| 147 | if (strncmp(&bufr[257], "ustar", 5)) |
| 148 | { |
| 149 | retval = UNTAR_SUCCESSFUL0; |
| 150 | break; |
| 151 | } |
| 152 | |
| 153 | strncpy(fname, bufr, MAX_NAME_FIELD_SIZE99); |
| 154 | fname[MAX_NAME_FIELD_SIZE99] = '\0'; |
| 155 | |
| 156 | linkflag = bufr[156]; |
| 157 | file_size = _rtems_octal2ulong(&bufr[124], 12); |
| 158 | |
| 159 | /****************************************************************** |
| 160 | * Compute the TAR checksum and check with the value in |
| 161 | * the archive. The checksum is computed over the entire |
| 162 | * header, but the checksum field is substituted with blanks. |
| 163 | ******************************************************************/ |
| 164 | hdr_chksum = _rtems_octal2ulong(&bufr[148], 8); |
| 165 | sum = _rtems_tar_header_checksum(bufr); |
| 166 | |
| 167 | if (sum != hdr_chksum) |
| 168 | { |
| 169 | retval = UNTAR_INVALID_CHECKSUM2; |
| 170 | break; |
| 171 | } |
| 172 | |
| 173 | |
| 174 | /****************************************************************** |
| 175 | * We've decoded the header, now figure out what it contains and |
| 176 | * do something with it. |
| 177 | *****************************************************************/ |
| 178 | if (linkflag == SYMTYPE'2') |
| 179 | { |
| 180 | strncpy(linkname, &bufr[157], MAX_NAME_FIELD_SIZE99); |
| 181 | linkname[MAX_NAME_FIELD_SIZE99] = '\0'; |
| 182 | symlink(linkname, fname); |
| 183 | } |
| 184 | else if (linkflag == REGTYPE'0') |
| 185 | { |
| 186 | nblocks = (((file_size) + 511) & ~511) / 512; |
| 187 | if ((fp = fopen(fname, "w")) == NULL((void*)0)) |
| 188 | { |
| 189 | printk("Untar: failed to create file %s\n", fname); |
| 190 | ptr += 512 * nblocks; |
| 191 | } |
| 192 | else |
| 193 | { |
| 194 | unsigned long sizeToGo = file_size; |
| 195 | size_t len; |
| 196 | |
| 197 | /*************************************************************** |
| 198 | * Read out the data. There are nblocks of data where nblocks |
| 199 | * is the file_size rounded to the nearest 512-byte boundary. |
| 200 | **************************************************************/ |
| 201 | for (i=0; i<nblocks; i++) |
| 202 | { |
| 203 | len = ((sizeToGo < 512L)?(sizeToGo):(512L)); |
| 204 | n = fwrite(&tar_ptr[ptr], 1, len, fp); |
| 205 | if (n != len) |
| 206 | { |
| 207 | printk("untar: Error during write\n"); |
| 208 | break; |
| 209 | } |
| 210 | ptr += 512; |
| 211 | sizeToGo -= n; |
| 212 | } |
| 213 | fclose(fp); |
| 214 | } |
| 215 | } |
| 216 | else if (linkflag == DIRTYPE'5') |
| 217 | { |
| 218 | mkdir(fname, S_IRWXU(0400|0200|0100) | S_IRWXG((0400|0200|0100) >> 3) | S_IRWXO(((0400|0200|0100) >> 3) >> 3)); |
| 219 | } |
| 220 | } |
| 221 | |
| 222 | return(retval); |
| 223 | } |
| 224 | |
| 225 | |
| 226 | /************************************************************************** |
| 227 | * Function: Untar_FromFile * |
| 228 | ************************************************************************** |
| 229 | * Description: * |
| 230 | * * |
| 231 | * This is a simple subroutine used to rip links, directories, and * |
| 232 | * files out of a TAR file. * |
| 233 | * * |
| 234 | * * |
| 235 | * Inputs: * |
| 236 | * * |
| 237 | * const char *tar_name - TAR filename. * |
| 238 | * * |
| 239 | * * |
| 240 | * Output: * |
| 241 | * * |
| 242 | * int - UNTAR_SUCCESSFUL (0) on successful completion. * |
| 243 | * UNTAR_INVALID_CHECKSUM for an invalid header checksum. * |
| 244 | * UNTAR_INVALID_HEADER for an invalid header. * |
| 245 | * * |
| 246 | ************************************************************************** |
| 247 | * Change History: * |
| 248 | * 12/30/1998 - Creation (JWJ) * |
| 249 | *************************************************************************/ |
| 250 | int |
| 251 | Untar_FromFile( |
| 252 | const char *tar_name |
| 253 | ) |
| 254 | { |
| 255 | int fd; |
| 256 | char *bufr; |
| 257 | ssize_t n; |
| 258 | char fname[100]; |
| 259 | char linkname[100]; |
| 260 | int sum; |
| 261 | int hdr_chksum; |
| 262 | int retval; |
| 263 | unsigned long i; |
| 264 | unsigned long nblocks; |
| 265 | unsigned long size; |
| 266 | unsigned char linkflag; |
| 267 | |
| 268 | retval = UNTAR_SUCCESSFUL0; |
| 269 | |
| 270 | if ((fd = open(tar_name, O_RDONLY00)) < 0) { |
| 271 | return UNTAR_FAIL1; |
| 272 | } |
| 273 | |
| 274 | bufr = (char *)malloc(512); |
| 275 | if (bufr == NULL((void*)0)) { |
| 276 | return(UNTAR_FAIL1); |
| 277 | } |
| 278 | |
| 279 | while (1) |
| 280 | { |
| 281 | /* Read the header */ |
| 282 | /* If the header read fails, we just consider it the end |
| 283 | of the tarfile. */ |
| 284 | if ((n = read(fd, bufr, 512)) != 512) |
Although the value stored to 'n' is used in the enclosing expression, the value is never actually read from 'n' | |
| 285 | { |
| 286 | break; |
| 287 | } |
| 288 | |
| 289 | if (strncmp(&bufr[257], "ustar", 5)) |
| 290 | { |
| 291 | break; |
| 292 | } |
| 293 | |
| 294 | strncpy(fname, bufr, MAX_NAME_FIELD_SIZE99); |
| 295 | fname[MAX_NAME_FIELD_SIZE99] = '\0'; |
| 296 | |
| 297 | linkflag = bufr[156]; |
| 298 | size = _rtems_octal2ulong(&bufr[124], 12); |
| 299 | |
| 300 | /****************************************************************** |
| 301 | * Compute the TAR checksum and check with the value in |
| 302 | * the archive. The checksum is computed over the entire |
| 303 | * header, but the checksum field is substituted with blanks. |
| 304 | ******************************************************************/ |
| 305 | hdr_chksum = _rtems_octal2ulong(&bufr[148], 8); |
| 306 | sum = _rtems_tar_header_checksum(bufr); |
| 307 | |
| 308 | if (sum != hdr_chksum) |
| 309 | { |
| 310 | retval = UNTAR_INVALID_CHECKSUM2; |
| 311 | break; |
| 312 | } |
| 313 | |
| 314 | /****************************************************************** |
| 315 | * We've decoded the header, now figure out what it contains and |
| 316 | * do something with it. |
| 317 | *****************************************************************/ |
| 318 | if (linkflag == SYMTYPE'2') |
| 319 | { |
| 320 | strncpy(linkname, &bufr[157], MAX_NAME_FIELD_SIZE99); |
| 321 | linkname[MAX_NAME_FIELD_SIZE99] = '\0'; |
| 322 | symlink(linkname,fname); |
| 323 | } |
| 324 | else if (linkflag == REGTYPE'0') |
| 325 | { |
| 326 | int out_fd; |
| 327 | |
| 328 | /****************************************************************** |
| 329 | * Read out the data. There are nblocks of data where nblocks |
| 330 | * is the size rounded to the nearest 512-byte boundary. |
| 331 | *****************************************************************/ |
| 332 | nblocks = (((size) + 511) & ~511) / 512; |
| 333 | |
| 334 | if ((out_fd = creat(fname, 0644)) == -1) |
| 335 | { |
| 336 | for (i=0; i<nblocks; i++) |
| 337 | { |
| 338 | n = read(fd, bufr, 512); |
| 339 | } |
| 340 | } |
| 341 | else |
| 342 | { |
| 343 | for (i=0; i<nblocks; i++) |
| 344 | { |
| 345 | n = read(fd, bufr, 512); |
| 346 | n = MIN(n, size - i*512)((n)>(size - i*512)?(size - i*512):(n)); |
| 347 | write(out_fd, bufr, n); |
| 348 | } |
| 349 | close(out_fd); |
| 350 | } |
| 351 | } |
| 352 | else if (linkflag == DIRTYPE'5') |
| 353 | { |
| 354 | mkdir(fname, S_IRWXU(0400|0200|0100) | S_IRWXG((0400|0200|0100) >> 3) | S_IRWXO(((0400|0200|0100) >> 3) >> 3)); |
| 355 | } |
| 356 | } |
| 357 | free(bufr); |
| 358 | close(fd); |
| 359 | |
| 360 | return(retval); |
| 361 | } |
| 362 | |
| 363 | /************************************************************************ |
| 364 | * Compute the TAR checksum and check with the value in |
| 365 | * the archive. The checksum is computed over the entire |
| 366 | * header, but the checksum field is substituted with blanks. |
| 367 | ************************************************************************/ |
| 368 | int |
| 369 | _rtems_tar_header_checksum( |
| 370 | const char *bufr |
| 371 | ) |
| 372 | { |
| 373 | int i, sum; |
| 374 | |
| 375 | sum = 0; |
| 376 | for (i=0; i<512; i++) |
| 377 | { |
| 378 | if ((i >= 148) && (i < 156)) |
| 379 | sum += 0xff & ' '; |
| 380 | else |
| 381 | sum += 0xff & bufr[i]; |
| 382 | } |
| 383 | return(sum); |
| 384 | } |
