| 1 | |
| 2 | |
| 3 | |
| 4 | |
| 5 | |
| 6 | |
| 7 | |
| 8 | |
| 9 | |
| 10 | |
| 11 | |
| 12 | |
| 13 | |
| 14 | #if HAVE_CONFIG_H1 |
| 15 | #include "config.h" |
| 16 | #endif |
| 17 | |
| 18 | #include <rtems/system.h> |
| 19 | #include <rtems/rtems/status.h> |
| 20 | #include <rtems/rtems/support.h> |
| 21 | #include <rtems/rtems/modes.h> |
| 22 | #include <rtems/score/object.h> |
| 23 | #include <rtems/score/stack.h> |
| 24 | #include <rtems/score/states.h> |
| 25 | #include <rtems/rtems/tasks.h> |
| 26 | #include <rtems/score/thread.h> |
| 27 | #include <rtems/score/threadq.h> |
| 28 | #include <rtems/score/tod.h> |
| 29 | #include <rtems/score/userext.h> |
| 30 | #include <rtems/score/wkspace.h> |
| 31 | #include <rtems/score/apiext.h> |
| 32 | #include <rtems/score/sysstate.h> |
| 33 | |
| 34 | |
| 35 | |
| 36 | |
| 37 | |
| 38 | |
| 39 | |
| 40 | |
| 41 | |
| 42 | |
| 43 | |
| 44 | |
| 45 | |
| 46 | |
| 47 | |
| 48 | |
| 49 | |
| 50 | rtems_status_code rtems_task_mode( |
| 51 | rtems_mode mode_set, |
| 52 | rtems_mode mask, |
| 53 | rtems_mode *previous_mode_set |
| 54 | ) |
| 55 | { |
| 56 | Thread_Control *executing; |
| 57 | RTEMS_API_Control *api; |
| 58 | ASR_Information *asr; |
| 59 | bool_Bool is_asr_enabled = false0; |
| 60 | bool_Bool needs_asr_dispatching = false0; |
| 61 | rtems_mode old_mode; |
| 62 | |
| 63 | if ( !previous_mode_set ) |
| 64 | return RTEMS_INVALID_ADDRESS; |
| 65 | |
| 66 | executing = _Thread_Executing_Per_CPU_Information.executing; |
| 67 | api = executing->API_Extensions[ THREAD_API_RTEMS ]; |
| 68 | asr = &api->Signal; |
| 69 | |
| 70 | old_mode = (executing->is_preemptible) ? RTEMS_PREEMPT0x00000000 : RTEMS_NO_PREEMPT0x00000100; |
| 71 | |
| 72 | if ( executing->budget_algorithm == THREAD_CPU_BUDGET_ALGORITHM_NONE ) |
| 73 | old_mode |= RTEMS_NO_TIMESLICE0x00000000; |
| 74 | else |
| 75 | old_mode |= RTEMS_TIMESLICE0x00000200; |
| 76 | |
| 77 | old_mode |= (asr->is_enabled) ? RTEMS_ASR0x00000000 : RTEMS_NO_ASR0x00000400; |
| 78 | old_mode |= _ISR_Get_level()_CPU_ISR_Get_level(); |
| 79 | |
| 80 | *previous_mode_set = old_mode; |
| 81 | |
| 82 | |
| 83 | |
| 84 | |
| 85 | if ( mask & RTEMS_PREEMPT_MASK0x00000100 ) |
| 86 | executing->is_preemptible = _Modes_Is_preempt(mode_set) ? true1 : false0; |
| 87 | |
| 88 | if ( mask & RTEMS_TIMESLICE_MASK0x00000200 ) { |
| 89 | if ( _Modes_Is_timeslice(mode_set) ) { |
| 90 | executing->budget_algorithm = THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE; |
| 91 | executing->cpu_time_budget = _Thread_Ticks_per_timeslice; |
| 92 | } else |
| 93 | executing->budget_algorithm = THREAD_CPU_BUDGET_ALGORITHM_NONE; |
| 94 | } |
| 95 | |
| 96 | |
| 97 | |
| 98 | |
| 99 | if ( mask & RTEMS_INTERRUPT_MASK0x0000000F ) |
| 100 | _Modes_Set_interrupt_level( mode_set ); |
| 101 | |
| 102 | |
| 103 | |
| 104 | |
| 105 | is_asr_enabled = false0; |
| Value stored to 'is_asr_enabled' is never read |
| 106 | needs_asr_dispatching = false0; |
| 107 | |
| 108 | if ( mask & RTEMS_ASR_MASK0x00000400 ) { |
| 109 | is_asr_enabled = _Modes_Is_asr_disabled( mode_set ) ? false0 : true1; |
| 110 | if ( is_asr_enabled != asr->is_enabled ) { |
| 111 | asr->is_enabled = is_asr_enabled; |
| 112 | _ASR_Swap_signals( asr ); |
| 113 | if ( _ASR_Are_signals_pending( asr ) ) { |
| 114 | needs_asr_dispatching = true1; |
| 115 | } |
| 116 | } |
| 117 | } |
| 118 | |
| 119 | if ( _System_state_Is_up( _System_state_Get() ) ) { |
| 120 | if (_Thread_Evaluate_is_dispatch_needed( needs_asr_dispatching ) ) |
| 121 | _Thread_Dispatch(); |
| 122 | } |
| 123 | |
| 124 | return RTEMS_SUCCESSFUL; |
| 125 | } |
