| File: | /home/joel/rtems-4.11-work/build/rtems/c/src/../../cpukit/libblock/src/media-server.c |
| Description: | Allocated memory never released. Potential memory leak |
| 1 | /** | ||
| 2 | * @file | ||
| 3 | * | ||
| 4 | * @ingroup RTEMSMedia | ||
| 5 | * | ||
| 6 | * @brief Media implementation. | ||
| 7 | */ | ||
| 8 | |||
| 9 | /* | ||
| 10 | * Copyright (c) 2009, 2010 embedded brains GmbH. All rights reserved. | ||
| 11 | * | ||
| 12 | * embedded brains GmbH | ||
| 13 | * Obere Lagerstr. 30 | ||
| 14 | * 82178 Puchheim | ||
| 15 | * Germany | ||
| 16 | * <rtems@embedded-brains.de> | ||
| 17 | * | ||
| 18 | * The license and distribution terms for this file may be | ||
| 19 | * found in the file LICENSE in this distribution or at | ||
| 20 | * http://www.rtems.com/license/LICENSE. | ||
| 21 | */ | ||
| 22 | |||
| 23 | #include <string.h> | ||
| 24 | #include <stdlib.h> | ||
| 25 | #include <assert.h> | ||
| 26 | |||
| 27 | #include <rtems.h> | ||
| 28 | #include <rtems/chain.h> | ||
| 29 | #include <rtems/media.h> | ||
| 30 | |||
| 31 | #define EVENT0x00002000 RTEMS_EVENT_130x00002000 | ||
| 32 | |||
| 33 | typedef struct { | ||
| 34 | rtems_chain_node node; | ||
| 35 | rtems_media_event event; | ||
| 36 | const char *src; | ||
| 37 | rtems_media_worker worker; | ||
| 38 | void *worker_arg; | ||
| 39 | } message; | ||
| 40 | |||
| 41 | static RTEMS_CHAIN_DEFINE_EMPTY(message_chain)Chain_Control message_chain = { (Chain_Node *) &(message_chain ).permanent_null, ((void*)0), (Chain_Node *) &(message_chain ) }; | ||
| 42 | |||
| 43 | static rtems_id server_id = RTEMS_ID_NONE0; | ||
| 44 | |||
| 45 | static void media_server(rtems_task_argument arg __attribute__((unused))) | ||
| 46 | { | ||
| 47 | rtems_status_code sc = RTEMS_SUCCESSFUL; | ||
| 48 | |||
| 49 | while (true1) { | ||
| 50 | message *msg = NULL((void*)0); | ||
| 51 | |||
| 52 | sc = rtems_chain_get_with_wait( | ||
| 53 | &message_chain, | ||
| 54 | EVENT0x00002000, | ||
| 55 | RTEMS_NO_TIMEOUT0, | ||
| 56 | (rtems_chain_node **) &msg | ||
| 57 | ); | ||
| 58 | assert(sc == RTEMS_SUCCESSFUL)((sc == RTEMS_SUCCESSFUL) ? (void) (0) : __assert_fail ("sc == RTEMS_SUCCESSFUL" , "/home/joel/rtems-4.11-work/build/rtems/c/src/../../cpukit/libblock/src/media-server.c" , 58, __PRETTY_FUNCTION__)); | ||
| 59 | assert(msg != NULL)((msg != ((void*)0)) ? (void) (0) : __assert_fail ("msg != ((void*)0)" , "/home/joel/rtems-4.11-work/build/rtems/c/src/../../cpukit/libblock/src/media-server.c" , 59, __PRETTY_FUNCTION__)); | ||
| 60 | |||
| 61 | rtems_media_post_event( | ||
| 62 | msg->event, | ||
| 63 | msg->src, | ||
| 64 | NULL((void*)0), | ||
| 65 | msg->worker, | ||
| 66 | msg->worker_arg | ||
| 67 | ); | ||
| 68 | |||
| 69 | free(msg); | ||
| 70 | } | ||
| 71 | } | ||
| 72 | |||
| 73 | rtems_status_code rtems_media_server_initialize( | ||
| 74 | rtems_task_priority priority, | ||
| 75 | size_t stack_size, | ||
| 76 | rtems_mode modes, | ||
| 77 | rtems_attribute attributes | ||
| 78 | ) | ||
| 79 | { | ||
| 80 | rtems_status_code sc = RTEMS_SUCCESSFUL; | ||
| 81 | |||
| 82 | if (server_id == RTEMS_ID_NONE0) { | ||
| 83 | sc = rtems_media_initialize(); | ||
| 84 | if (sc != RTEMS_SUCCESSFUL) { | ||
| 85 | goto error; | ||
| 86 | } | ||
| 87 | |||
| 88 | sc = rtems_task_create( | ||
| 89 | rtems_build_name('M', 'D', 'I', 'A')( (uint32_t)('M') << 24 | (uint32_t)('D') << 16 | (uint32_t)('I') << 8 | (uint32_t)('A') ), | ||
| 90 | priority, | ||
| 91 | stack_size, | ||
| 92 | modes, | ||
| 93 | attributes, | ||
| 94 | &server_id | ||
| 95 | ); | ||
| 96 | if (sc != RTEMS_SUCCESSFUL) { | ||
| 97 | goto error; | ||
| 98 | } | ||
| 99 | |||
| 100 | sc = rtems_task_start(server_id, media_server, 0); | ||
| 101 | if (sc != RTEMS_SUCCESSFUL) { | ||
| 102 | goto error; | ||
| 103 | } | ||
| 104 | } | ||
| 105 | |||
| 106 | return RTEMS_SUCCESSFUL; | ||
| 107 | |||
| 108 | error: | ||
| 109 | |||
| 110 | if (server_id != RTEMS_ID_NONE0) { | ||
| 111 | rtems_task_delete(server_id); | ||
| 112 | } | ||
| 113 | |||
| 114 | return RTEMS_NO_MEMORY; | ||
| 115 | } | ||
| 116 | |||
| 117 | rtems_status_code rtems_media_server_post_event( | ||
| 118 | rtems_media_event event, | ||
| 119 | const char *src, | ||
| 120 | rtems_media_worker worker, | ||
| 121 | void *worker_arg | ||
| 122 | ) | ||
| 123 | { | ||
| 124 | rtems_status_code sc = RTEMS_SUCCESSFUL; | ||
| 125 | size_t src_size = strlen(src) + 1; | ||
| 126 | message *msg = malloc(sizeof(*msg) + src_size); | ||
| 127 | |||
| 128 | if (msg != NULL((void*)0)) { | ||
| 129 | char *s = (char *) msg + sizeof(*msg); | ||
| 130 | |||
| 131 | memcpy(s, src, src_size); | ||
| 132 | |||
| 133 | msg->event = event; | ||
| 134 | msg->src = s; | ||
| 135 | msg->worker = worker; | ||
| 136 | msg->worker_arg = worker_arg; | ||
| 137 | |||
| 138 | sc = rtems_chain_append_with_notification( | ||
| 139 | &message_chain, | ||
| 140 | &msg->node, | ||
| 141 | server_id, | ||
| 142 | EVENT0x00002000 | ||
| 143 | ); | ||
| 144 | if (sc != RTEMS_SUCCESSFUL) { | ||
| 145 | sc = RTEMS_NOT_CONFIGURED; | ||
| 146 | } | ||
| 147 | } else { | ||
| 148 | sc = RTEMS_NO_MEMORY; | ||
| 149 | } | ||
| 150 | |||
| 151 | return sc; | ||
| 152 | } |
