| 1 | |
| 2 | |
| 3 | |
| 4 | |
| 5 | |
| 6 | |
| 7 | |
| 8 | |
| 9 | |
| 10 | |
| 11 | |
| 12 | |
| 13 | |
| 14 | #ifdef HAVE_CONFIG_H1 |
| 15 | #include "config.h" |
| 16 | #endif |
| 17 | |
| 18 | #include <string.h> |
| 19 | #ifdef HAVE_STRINGS_H1 |
| 20 | #include <strings.h> |
| 21 | #endif |
| 22 | |
| 23 | #define __RTEMS_VIOLATE_KERNEL_VISIBILITY__ |
| 24 | #include <rtems.h> |
| 25 | #include <stdio.h> |
| 26 | #include <stdlib.h> |
| 27 | #include <inttypes.h> |
| 28 | |
| 29 | #include <rtems/monitor.h> |
| 30 | #include "symbols.h" |
| 31 | |
| 32 | |
| 33 | rtems_symbol_table_t * |
| 34 | rtems_symbol_table_create(void) |
| 35 | { |
| 36 | rtems_symbol_table_t *table; |
| 37 | |
| 38 | table = (rtems_symbol_table_t *) malloc(sizeof(rtems_symbol_table_t)); |
| 39 | memset((void *) table, 0, sizeof(*table)); |
| 40 | |
| 41 | table->growth_factor = 30; |
| 42 | |
| 43 | return table; |
| 44 | } |
| 45 | |
| 46 | void |
| 47 | rtems_symbol_table_destroy(rtems_symbol_table_t *table) |
| 48 | { |
| 49 | rtems_symbol_string_block_t *p, *pnext; |
| 50 | |
| 51 | if (table) |
| 52 | { |
| 53 | if (table->addresses) |
| 54 | (void) free(table->addresses); |
| 55 | table->addresses = 0; |
| 56 | p = table->string_buffer_head; |
| 57 | while (p) |
| 58 | { |
| 59 | pnext = p->next; |
| 60 | free(p); |
| 61 | p = pnext; |
| 62 | } |
| 63 | table->string_buffer_head = 0; |
| 64 | table->string_buffer_current = 0; |
| 65 | |
| 66 | free(table); |
| 67 | } |
| 68 | } |
| 69 | |
| 70 | rtems_symbol_t * |
| 71 | rtems_symbol_create( |
| 72 | rtems_symbol_table_t *table, |
| 73 | const char *name, |
| 74 | uint32_t value |
| 75 | ) |
| 76 | { |
| 77 | size_t symbol_length; |
| 78 | size_t newsize; |
| 79 | rtems_symbol_t *sp; |
| 80 | |
| 81 | symbol_length = strlen(name) + 1; |
| 82 | |
| 83 | |
| 84 | if (table->next >= table->size) |
| 85 | { |
| 86 | if (table->size == 0) |
| 87 | newsize = 100; |
| 88 | else |
| 89 | newsize = table->size + (table->size / (100 / table->growth_factor)); |
| 90 | |
| 91 | table->addresses = (rtems_symbol_t *) realloc((void *) table->addresses, newsize * sizeof(rtems_symbol_t)); |
| 92 | if (table->addresses == 0) |
| 93 | goto failed; |
| 94 | table->size = newsize; |
| 95 | } |
| 96 | |
| 97 | sp = &table->addresses[table->next]; |
| 98 | sp->value = value; |
| 99 | |
| 100 | |
| 101 | |
| 102 | |
| 103 | if ((table->string_buffer_head == 0) || |
| 104 | (table->strings_next + symbol_length) >= SYMBOL_STRING_BLOCK_SIZE4080) |
| 105 | { |
| 106 | rtems_symbol_string_block_t *p; |
| 107 | |
| 108 | p = (rtems_symbol_string_block_t *) malloc(sizeof(rtems_symbol_string_block_t)); |
| 109 | if (p == 0) |
| 110 | goto failed; |
| 6 | Control jumps to line 133 |
| 111 | p->next = 0; |
| 112 | if (table->string_buffer_head == 0) |
| 113 | table->string_buffer_head = p; |
| 114 | else |
| 115 | table->string_buffer_current->next = p; |
| 116 | table->string_buffer_current = p; |
| 117 | |
| 118 | table->strings_next = 0; |
| 119 | } |
| 120 | |
| 121 | sp->name = table->string_buffer_current->buffer + table->strings_next; |
| 122 | (void) strcpy(sp->name, name); |
| 123 | |
| 124 | table->strings_next += symbol_length; |
| 125 | table->sorted = 0; |
| 126 | table->next++; |
| 127 | |
| 128 | return sp; |
| 129 | |
| 130 | |
| 131 | |
| 132 | failed: |
| 133 | return 0; |
| 7 | Allocated memory never released. Potential memory leak |
| 134 | } |
| 135 | |
| 136 | |
| 137 | |
| 138 | |
| 139 | |
| 140 | static int |
| 141 | rtems_symbol_compare(const void *e1, |
| 142 | const void *e2) |
| 143 | { |
| 144 | rtems_symbol_t *s1, *s2; |
| 145 | s1 = (rtems_symbol_t *) e1; |
| 146 | s2 = (rtems_symbol_t *) e2; |
| 147 | |
| 148 | if (s1->value < s2->value) |
| 149 | return -1; |
| 150 | if (s1->value > s2->value) |
| 151 | return 1; |
| 152 | return 0; |
| 153 | } |
| 154 | |
| 155 | |
| 156 | |
| 157 | |
| 158 | |
| 159 | |
| 160 | static void |
| 161 | rtems_symbol_sort(rtems_symbol_table_t *table) |
| 162 | { |
| 163 | qsort((void *) table->addresses, (size_t) table->next, |
| 164 | sizeof(rtems_symbol_t), rtems_symbol_compare); |
| 165 | table->sorted = 1; |
| 166 | } |
| 167 | |
| 168 | |
| 169 | |
| 170 | |
| 171 | |
| 172 | |
| 173 | |
| 174 | |
| 175 | rtems_symbol_t * |
| 176 | rtems_symbol_value_lookup( |
| 177 | rtems_symbol_table_t *table, |
| 178 | uint32_t value |
| 179 | ) |
| 180 | { |
| 181 | rtems_symbol_t *sp; |
| 182 | rtems_symbol_t *base; |
| 183 | rtems_symbol_t *best = 0; |
| 184 | uint32_t distance; |
| 185 | uint32_t best_distance = ~0; |
| 186 | uint32_t elements; |
| 187 | |
| 188 | if (table == 0) |
| 189 | table = rtems_monitor_symbols; |
| 190 | |
| 191 | if ((table == 0) || (table->size == 0)) |
| 192 | return 0; |
| 193 | |
| 194 | if (table->sorted == 0) |
| 195 | rtems_symbol_sort(table); |
| 196 | |
| 197 | base = table->addresses; |
| 198 | elements = table->next; |
| 199 | |
| 200 | while (elements) |
| 201 | { |
| 202 | sp = base + (elements / 2); |
| 203 | if (value < sp->value) |
| 204 | elements /= 2; |
| 205 | else if (value > sp->value) |
| 206 | { |
| 207 | distance = value - sp->value; |
| 208 | if (distance < best_distance) |
| 209 | { |
| 210 | best_distance = distance; |
| 211 | best = sp; |
| 212 | } |
| 213 | base = sp + 1; |
| 214 | elements = (elements / 2) - (elements % 2 ? 0 : 1); |
| 215 | } |
| 216 | else |
| 217 | return sp; |
| 218 | } |
| 219 | |
| 220 | if (value == base->value) |
| 221 | return base; |
| 222 | |
| 223 | return best; |
| 224 | } |
| 225 | |
| 226 | |
| 227 | |
| 228 | |
| 229 | |
| 230 | |
| 231 | |
| 232 | |
| 233 | |
| 234 | |
| 235 | |
| 236 | |
| 237 | const rtems_symbol_t * |
| 238 | rtems_symbol_value_lookup_exact( |
| 239 | rtems_symbol_table_t *table, |
| 240 | uint32_t value |
| 241 | ) |
| 242 | { |
| 243 | uint32_t s; |
| 244 | rtems_symbol_t *sp; |
| 245 | |
| 246 | if (table == 0) |
| 247 | { |
| 248 | table = rtems_monitor_symbols; |
| 249 | if (table == 0) |
| 250 | return NULL((void*)0); |
| 251 | } |
| 252 | |
| 253 | if (table->sorted) |
| 254 | { |
| 255 | sp = rtems_symbol_value_lookup(table, value); |
| 256 | if ( rtems_symbol_value(sp)((sp)->value) == value ) |
| 257 | return sp; |
| 258 | else |
| 259 | return NULL((void*)0); |
| 260 | } |
| 261 | |
| 262 | for (s = 0, sp = table->addresses; s < table->next; s++, sp++) |
| 263 | { |
| 264 | if ( sp->value == value ) |
| 265 | return sp; |
| 266 | } |
| 267 | |
| 268 | return NULL((void*)0); |
| 269 | |
| 270 | } |
| 271 | |
| 272 | |
| 273 | |
| 274 | |
| 275 | |
| 276 | |
| 277 | rtems_symbol_t * |
| 278 | rtems_symbol_name_lookup( |
| 279 | rtems_symbol_table_t *table, |
| 280 | const char *name |
| 281 | ) |
| 282 | { |
| 283 | uint32_t s; |
| 284 | rtems_symbol_t *sp; |
| 285 | |
| 286 | if (table == 0) |
| 287 | { |
| 288 | table = rtems_monitor_symbols; |
| 289 | if (table == 0) |
| 290 | return NULL((void*)0); |
| 291 | } |
| 292 | |
| 293 | for (s = 0, sp = table->addresses; s < table->next; s++, sp++) |
| 294 | { |
| 295 | if ( strcasecmp(sp->name, name) == 0 ) |
| 296 | return sp; |
| 297 | } |
| 298 | |
| 299 | return NULL((void*)0); |
| 300 | } |
| 301 | |
| 302 | void * |
| 303 | rtems_monitor_symbol_next( |
| 304 | void *object_info, |
| 305 | rtems_monitor_symbol_t *canonical __attribute__((unused)), |
| 306 | rtems_id *next_id |
| 307 | ) |
| 308 | { |
| 309 | rtems_symbol_table_t *table; |
| 310 | uint32_t n = rtems_object_id_get_index(*next_id)_Objects_Get_index( *next_id ); |
| 311 | |
| 312 | table = *(rtems_symbol_table_t **) object_info; |
| 313 | if (table == 0) |
| 314 | goto failed; |
| 315 | |
| 316 | if (n >= table->next) |
| 317 | goto failed; |
| 318 | |
| 319 | |
| 320 | |
| 321 | if (table->sorted == 0) |
| 322 | rtems_symbol_sort(table); |
| 323 | |
| 324 | _Thread_Disable_dispatch(); |
| 325 | |
| 326 | *next_id += 1; |
| 327 | return (void *) (table->addresses + n); |
| 328 | |
| 329 | failed: |
| 330 | *next_id = RTEMS_OBJECT_ID_FINAL((Objects_Id)~0); |
| 331 | return 0; |
| 332 | } |
| 333 | |
| 334 | void |
| 335 | rtems_monitor_symbol_canonical( |
| 336 | rtems_monitor_symbol_t *canonical_symbol, |
| 337 | rtems_symbol_t *sp |
| 338 | ) |
| 339 | { |
| 340 | canonical_symbol->value = sp->value; |
| 341 | canonical_symbol->offset = 0; |
| 342 | strncpy(canonical_symbol->name, sp->name, sizeof(canonical_symbol->name)-1); |
| 343 | } |
| 344 | |
| 345 | |
| 346 | void |
| 347 | rtems_monitor_symbol_canonical_by_name( |
| 348 | rtems_monitor_symbol_t *canonical_symbol, |
| 349 | const char *name |
| 350 | ) |
| 351 | { |
| 352 | rtems_symbol_t *sp; |
| 353 | |
| 354 | sp = rtems_symbol_name_lookup(0, name); |
| 355 | |
| 356 | canonical_symbol->value = sp ? sp->value : 0; |
| 357 | |
| 358 | strncpy(canonical_symbol->name, name, sizeof(canonical_symbol->name) - 1); |
| 359 | canonical_symbol->offset = 0; |
| 360 | } |
| 361 | |
| 362 | void |
| 363 | rtems_monitor_symbol_canonical_by_value( |
| 364 | rtems_monitor_symbol_t *canonical_symbol, |
| 365 | void *value_void_p |
| 366 | ) |
| 367 | { |
| 368 | uintptr_t value = (uintptr_t) value_void_p; |
| 369 | rtems_symbol_t *sp; |
| 370 | |
| 371 | sp = rtems_symbol_value_lookup(0, value); |
| 372 | if (sp) |
| 373 | { |
| 374 | canonical_symbol->value = sp->value; |
| 375 | canonical_symbol->offset = value - sp->value; |
| 376 | strncpy(canonical_symbol->name, sp->name, sizeof(canonical_symbol->name)-1); |
| 377 | } |
| 378 | else |
| 379 | { |
| 380 | canonical_symbol->value = value; |
| 381 | canonical_symbol->offset = 0; |
| 382 | canonical_symbol->name[0] = '\0'; |
| 383 | } |
| 384 | } |
| 385 | |
| 386 | |
| 387 | uint32_t |
| 388 | rtems_monitor_symbol_dump( |
| 389 | rtems_monitor_symbol_t *canonical_symbol, |
| 390 | bool_Bool verbose |
| 391 | ) |
| 392 | { |
| 393 | uint32_t length = 0; |
| 394 | |
| 395 | |
| 396 | |
| 397 | |
| 398 | |
| 399 | |
| 400 | if (canonical_symbol->name[0] && (canonical_symbol->value != 0)) |
| 401 | { |
| 402 | if (canonical_symbol->offset == 0) |
| 403 | length += fprintf(stdoutstdout,"%.*s", |
| 404 | (int) sizeof(canonical_symbol->name), |
| 405 | canonical_symbol->name); |
| 406 | else |
| 407 | length += fprintf(stdoutstdout,"<%.*s+0x%" PRIx32"x" ">", |
| 408 | (int) sizeof(canonical_symbol->name), |
| 409 | canonical_symbol->name, |
| 410 | canonical_symbol->offset); |
| 411 | if (verbose) |
| 412 | length += fprintf(stdoutstdout, |
| 413 | " [0x%" PRIx32"x" "]", canonical_symbol->value); |
| 414 | } |
| 415 | else |
| 416 | length += fprintf(stdoutstdout,"[0x%" PRIx32"x" "]", canonical_symbol->value); |
| 417 | |
| 418 | return length; |
| 419 | } |
| 420 | |
| 421 | |
| 422 | void |
| 423 | rtems_monitor_symbol_dump_all( |
| 424 | rtems_symbol_table_t *table, |
| 425 | bool_Bool verbose __attribute__((unused)) |
| 426 | ) |
| 427 | { |
| 428 | uint32_t s; |
| 429 | rtems_symbol_t *sp; |
| 430 | |
| 431 | if (table == 0) |
| 432 | { |
| 433 | table = rtems_monitor_symbols; |
| 434 | if (table == 0) |
| 435 | return; |
| 436 | } |
| 437 | |
| 438 | if (table->sorted == 0) |
| 439 | rtems_symbol_sort(table); |
| 440 | |
| 441 | for (s = 0, sp = table->addresses; s < table->next; s++, sp++) |
| 442 | { |
| 443 | rtems_monitor_symbol_t canonical_symbol; |
| 444 | |
| 445 | rtems_monitor_symbol_canonical(&canonical_symbol, sp); |
| 446 | rtems_monitor_symbol_dump(&canonical_symbol, true1); |
| 447 | fprintf(stdoutstdout,"\n"); |
| 448 | } |
| 449 | } |
| 450 | |
| 451 | |
| 452 | |
| 453 | |
| 454 | |
| 455 | |
| 456 | void rtems_monitor_symbol_cmd( |
| 457 | int argc, |
| 458 | char **argv, |
| 459 | const rtems_monitor_command_arg_t *command_arg, |
| 460 | bool_Bool verbose |
| 461 | ) |
| 462 | { |
| 463 | int arg; |
| 464 | rtems_symbol_table_t *table; |
| 465 | |
| 466 | table = *command_arg->symbol_table; |
| 467 | if (table == 0) |
| 468 | { |
| 469 | table = rtems_monitor_symbols; |
| 470 | if (table == 0) |
| 471 | return; |
| 472 | } |
| 473 | |
| 474 | |
| 475 | |
| 476 | |
| 477 | if (argc == 1) |
| 478 | rtems_monitor_symbol_dump_all(table, verbose); |
| 479 | else |
| 480 | { |
| 481 | rtems_monitor_symbol_t canonical_symbol; |
| 482 | |
| 483 | for (arg=1; argv[arg]; arg++) |
| 484 | { |
| 485 | rtems_monitor_symbol_canonical_by_name(&canonical_symbol, argv[arg]); |
| 486 | rtems_monitor_symbol_dump(&canonical_symbol, verbose); |
| 487 | fprintf(stdoutstdout,"\n"); |
| 488 | } |
| 489 | } |
| 490 | } |
