| File: | /home/joel/rtems-4.11-work/build/rtems/c/src/../../cpukit/libmisc/monitor/mon-driver.c |
| Description: | Value stored to 'length' is never read |
| 1 | /* |
| 2 | * RTEMS monitor IO (device drivers) support |
| 3 | * |
| 4 | * There are 2 "driver" things the monitor knows about. |
| 5 | * |
| 6 | * 1. Regular RTEMS drivers. |
| 7 | * This is a table indexed by major device number and |
| 8 | * containing driver entry points only. |
| 9 | * |
| 10 | * 2. Driver name table. |
| 11 | * A separate table of names for drivers. |
| 12 | * The table converts driver names to a major number |
| 13 | * as index into the driver table and a minor number |
| 14 | * for an argument to driver. |
| 15 | * |
| 16 | * Drivers are displayed with 'driver' command. |
| 17 | * Names are displayed with 'name' command. |
| 18 | * |
| 19 | * $Id: mon-driver.c,v 1.18 2009/10/02 15:54:47 ralf Exp $ |
| 20 | */ |
| 21 | |
| 22 | #ifdef HAVE_CONFIG_H1 |
| 23 | #include "config.h" |
| 24 | #endif |
| 25 | |
| 26 | #define __RTEMS_VIOLATE_KERNEL_VISIBILITY__ |
| 27 | #include <rtems.h> |
| 28 | |
| 29 | #include <rtems/monitor.h> |
| 30 | |
| 31 | #include <stdio.h> |
| 32 | #include <stdlib.h> /* strtoul() */ |
| 33 | #include <inttypes.h> |
| 34 | |
| 35 | #define DATACOL15 15 |
| 36 | #define CONTCOL15 DATACOL15 /* continued col */ |
| 37 | |
| 38 | |
| 39 | void |
| 40 | rtems_monitor_driver_canonical( |
| 41 | rtems_monitor_driver_t *canonical_driver, |
| 42 | void *driver_void |
| 43 | ) |
| 44 | { |
| 45 | rtems_driver_address_table *d = (rtems_driver_address_table *) driver_void; |
| 46 | |
| 47 | rtems_monitor_symbol_canonical_by_value(&canonical_driver->initialization, |
| 48 | (void *) d->initialization_entry); |
| 49 | |
| 50 | rtems_monitor_symbol_canonical_by_value(&canonical_driver->open, |
| 51 | (void *) d->open_entry); |
| 52 | rtems_monitor_symbol_canonical_by_value(&canonical_driver->close, |
| 53 | (void *) d->close_entry); |
| 54 | rtems_monitor_symbol_canonical_by_value(&canonical_driver->read, |
| 55 | (void *) d->read_entry); |
| 56 | rtems_monitor_symbol_canonical_by_value(&canonical_driver->write, |
| 57 | (void *) d->write_entry); |
| 58 | rtems_monitor_symbol_canonical_by_value(&canonical_driver->control, |
| 59 | (void *) d->control_entry); |
| 60 | } |
| 61 | |
| 62 | |
| 63 | void * |
| 64 | rtems_monitor_driver_next( |
| 65 | void *object_info __attribute__((unused)), |
| 66 | rtems_monitor_driver_t *canonical_driver, |
| 67 | rtems_id *next_id |
| 68 | ) |
| 69 | { |
| 70 | rtems_configuration_table *c = &Configuration; |
| 71 | uint32_t n = rtems_object_id_get_index(*next_id)_Objects_Get_index( *next_id ); |
| 72 | |
| 73 | if (n >= c->number_of_device_drivers) |
| 74 | goto failed; |
| 75 | |
| 76 | _Thread_Disable_dispatch(); |
| 77 | |
| 78 | /* |
| 79 | * dummy up a fake id and name for this item |
| 80 | */ |
| 81 | |
| 82 | canonical_driver->id = n; |
| 83 | canonical_driver->name = rtems_build_name('-', '-', '-', '-')( (uint32_t)('-') << 24 | (uint32_t)('-') << 16 | (uint32_t)('-') << 8 | (uint32_t)('-') ); |
| 84 | |
| 85 | *next_id += 1; |
| 86 | return (void *) (c->Device_driver_table + n); |
| 87 | |
| 88 | failed: |
| 89 | *next_id = RTEMS_OBJECT_ID_FINAL((Objects_Id)~0); |
| 90 | return 0; |
| 91 | } |
| 92 | |
| 93 | |
| 94 | void |
| 95 | rtems_monitor_driver_dump_header( |
| 96 | bool_Bool verbose __attribute__((unused)) |
| 97 | ) |
| 98 | { |
| 99 | fprintf(stdoutstdout,"\ |
| 100 | Major Entry points\n"); |
| 101 | /*23456789 123456789 123456789 123456789 123456789 123456789 123456789 123456789 |
| 102 | 0 1 2 3 4 5 6 7 */ |
| 103 | rtems_monitor_separator(); |
| 104 | } |
| 105 | |
| 106 | void |
| 107 | rtems_monitor_driver_dump( |
| 108 | rtems_monitor_driver_t *monitor_driver, |
| 109 | bool_Bool verbose |
| 110 | ) |
| 111 | { |
| 112 | uint32_t length = 0; |
| 113 | |
| 114 | #if defined(RTEMS_USE_16_BIT_OBJECT) |
| 115 | length += fprintf(stdoutstdout," %" PRId16"d" "", monitor_driver->id); |
| 116 | #else |
| 117 | length += fprintf(stdoutstdout," %" PRId32"d" "", monitor_driver->id); |
| 118 | #endif |
| 119 | length += rtems_monitor_pad(13, length); |
| 120 | length += fprintf(stdoutstdout,"init: "); |
| 121 | length += rtems_monitor_symbol_dump(&monitor_driver->initialization, verbose); |
| 122 | length += fprintf(stdoutstdout,"; control: "); |
| 123 | length += rtems_monitor_symbol_dump(&monitor_driver->control, verbose); |
| 124 | length += fprintf(stdoutstdout,"\n"); |
| 125 | length = 0; |
| 126 | |
| 127 | length += rtems_monitor_pad(13, length); |
| 128 | |
| 129 | length += fprintf(stdoutstdout,"open: "); |
| 130 | length += rtems_monitor_symbol_dump(&monitor_driver->open, verbose); |
| 131 | length += fprintf(stdoutstdout,"; close: "); |
| 132 | length += rtems_monitor_symbol_dump(&monitor_driver->close, verbose); |
| 133 | length += fprintf(stdoutstdout,"\n"); |
| 134 | length = 0; |
| 135 | |
| 136 | length += rtems_monitor_pad(13, length); |
| 137 | |
| 138 | length += fprintf(stdoutstdout,"read: "); |
| 139 | length += rtems_monitor_symbol_dump(&monitor_driver->read, verbose); |
| 140 | length += fprintf(stdoutstdout,"; write: "); |
| 141 | length += rtems_monitor_symbol_dump(&monitor_driver->write, verbose); |
| 142 | length += fprintf(stdoutstdout,"\n"); |
Value stored to 'length' is never read | |
| 143 | length = 0; |
| 144 | } |
