| File: | /home/joel/rtems-4.11-work/build/rtems/c/src/../../cpukit/libmisc/capture/capture.c |
| Description: | Value stored to 'records' is never read |
| 1 | /* |
| 2 | ------------------------------------------------------------------------ |
| 3 | $Id: capture.c,v 1.20 2009/11/29 12:12:39 ralf Exp $ |
| 4 | ------------------------------------------------------------------------ |
| 5 | |
| 6 | Copyright Objective Design Systems Pty Ltd, 2002 |
| 7 | All rights reserved Objective Design Systems Pty Ltd, 2002 |
| 8 | Chris Johns (ccj@acm.org) |
| 9 | |
| 10 | COPYRIGHT (c) 1989-2009. |
| 11 | On-Line Applications Research Corporation (OAR). |
| 12 | |
| 13 | The license and distribution terms for this file may be |
| 14 | found in the file LICENSE in this distribution. |
| 15 | |
| 16 | This software with is provided ``as is'' and with NO WARRANTY. |
| 17 | |
| 18 | ------------------------------------------------------------------------ |
| 19 | |
| 20 | RTEMS Performance Monitoring and Measurement Framework. |
| 21 | |
| 22 | This is the Capture Engine component. |
| 23 | |
| 24 | */ |
| 25 | |
| 26 | #ifdef HAVE_CONFIG_H1 |
| 27 | #include "config.h" |
| 28 | #endif |
| 29 | |
| 30 | #include <stdlib.h> |
| 31 | #include <string.h> |
| 32 | |
| 33 | #include "capture.h" |
| 34 | #include <rtems/score/states.inl> |
| 35 | #include <rtems/score/wkspace.h> |
| 36 | #include <rtems/score/wkspace.inl> |
| 37 | |
| 38 | /* |
| 39 | * These events are always recorded and are not part of the |
| 40 | * watch filters. |
| 41 | * |
| 42 | * This feature has been disabled as it becomes confusing when |
| 43 | * setting up filters and some event leak. |
| 44 | */ |
| 45 | #if defined (RTEMS_CAPTURE_ENGINE_ALLOW_RELATED_EVENTS) |
| 46 | #define RTEMS_CAPTURE_RECORD_EVENTS(0) (RTEMS_CAPTURE_CREATED_BY_EVENT0x00010000U | \ |
| 47 | RTEMS_CAPTURE_CREATED_EVENT0x00020000U | \ |
| 48 | RTEMS_CAPTURE_STARTED_BY_EVENT0x00040000U | \ |
| 49 | RTEMS_CAPTURE_STARTED_EVENT0x00080000U | \ |
| 50 | RTEMS_CAPTURE_RESTARTED_BY_EVENT0x00100000U | \ |
| 51 | RTEMS_CAPTURE_RESTARTED_EVENT0x00200000U | \ |
| 52 | RTEMS_CAPTURE_DELETED_BY_EVENT0x00400000U | \ |
| 53 | RTEMS_CAPTURE_DELETED_EVENT0x00800000U | \ |
| 54 | RTEMS_CAPTURE_BEGIN_EVENT0x01000000U | \ |
| 55 | RTEMS_CAPTURE_EXITTED_EVENT0x02000000U) |
| 56 | #else |
| 57 | #define RTEMS_CAPTURE_RECORD_EVENTS(0) (0) |
| 58 | #endif |
| 59 | |
| 60 | /* |
| 61 | * Global capture flags. |
| 62 | */ |
| 63 | #define RTEMS_CAPTURE_ON(1 << 0) (1 << 0) |
| 64 | #define RTEMS_CAPTURE_NO_MEMORY(1 << 1) (1 << 1) |
| 65 | #define RTEMS_CAPTURE_OVERFLOW(1 << 2) (1 << 2) |
| 66 | #define RTEMS_CAPTURE_TRIGGERED(1 << 3) (1 << 3) |
| 67 | #define RTEMS_CAPTURE_READER_ACTIVE(1 << 4) (1 << 4) |
| 68 | #define RTEMS_CAPTURE_READER_WAITING(1 << 5) (1 << 5) |
| 69 | #define RTEMS_CAPTURE_GLOBAL_WATCH(1 << 6) (1 << 6) |
| 70 | #define RTEMS_CAPTURE_ONLY_MONITOR(1 << 7) (1 << 7) |
| 71 | |
| 72 | /* |
| 73 | * RTEMS Capture Data. |
| 74 | */ |
| 75 | static rtems_capture_record_t* capture_records; |
| 76 | static uint32_t capture_size; |
| 77 | static uint32_t capture_count; |
| 78 | static rtems_capture_record_t* capture_in; |
| 79 | static uint32_t capture_out; |
| 80 | static uint32_t capture_flags; |
| 81 | static rtems_capture_task_t* capture_tasks; |
| 82 | static rtems_capture_control_t* capture_controls; |
| 83 | static int capture_extension_index; |
| 84 | static rtems_id capture_id; |
| 85 | static rtems_capture_timestamp capture_timestamp; |
| 86 | static rtems_task_priority capture_ceiling; |
| 87 | static rtems_task_priority capture_floor; |
| 88 | static uint32_t capture_tick_period; |
| 89 | static rtems_id capture_reader; |
| 90 | |
| 91 | /* |
| 92 | * RTEMS Event text. |
| 93 | */ |
| 94 | static const char* capture_event_text[] = |
| 95 | { |
| 96 | "CREATED_BY", |
| 97 | "CREATED", |
| 98 | "STARTED_BY", |
| 99 | "STARTED", |
| 100 | "RESTARTED_BY", |
| 101 | "RESTARTED", |
| 102 | "DELETED_BY", |
| 103 | "DELETED", |
| 104 | "BEGIN", |
| 105 | "EXITTED", |
| 106 | "SWITCHED_OUT", |
| 107 | "SWITCHED_IN", |
| 108 | "TIMESTAMP" |
| 109 | }; |
| 110 | |
| 111 | /* |
| 112 | * rtems_capture_get_time |
| 113 | * |
| 114 | * DESCRIPTION: |
| 115 | * |
| 116 | * This function returns the current time. If a handler is provided |
| 117 | * by the user get the time from that. |
| 118 | */ |
| 119 | static inline void rtems_capture_get_time (uint32_t* ticks, |
| 120 | uint32_t* tick_offset) |
| 121 | { |
| 122 | if (capture_timestamp) |
| 123 | capture_timestamp (ticks, tick_offset); |
| 124 | else |
| 125 | { |
| 126 | *ticks = _Watchdog_Ticks_since_boot; |
| 127 | *tick_offset = 0; |
| 128 | } |
| 129 | } |
| 130 | |
| 131 | /* |
| 132 | * rtems_capture_match_names |
| 133 | * |
| 134 | * DESCRIPTION: |
| 135 | * |
| 136 | * This function compares rtems_names. It protects the |
| 137 | * capture engine from a change to the way names are supported |
| 138 | * in RTEMS. |
| 139 | * |
| 140 | */ |
| 141 | static inline bool_Bool |
| 142 | rtems_capture_match_names (rtems_name lhs, rtems_name rhs) |
| 143 | { |
| 144 | return lhs == rhs; |
| 145 | } |
| 146 | |
| 147 | /* |
| 148 | * rtems_capture_match_id |
| 149 | * |
| 150 | * DESCRIPTION: |
| 151 | * |
| 152 | * This function compares rtems_ids. It protects the |
| 153 | * capture engine from a change to the way id are supported |
| 154 | * in RTEMS. |
| 155 | * |
| 156 | */ |
| 157 | static inline bool_Bool |
| 158 | rtems_capture_match_ids (rtems_id lhs, rtems_id rhs) |
| 159 | { |
| 160 | return lhs == rhs; |
| 161 | } |
| 162 | |
| 163 | /* |
| 164 | * rtems_capture_match_name_id |
| 165 | * |
| 166 | * DESCRIPTION: |
| 167 | * |
| 168 | * This function matches a name and/or id. |
| 169 | */ |
| 170 | static inline bool_Bool |
| 171 | rtems_capture_match_name_id (rtems_name lhs_name, |
| 172 | rtems_id lhs_id, |
| 173 | rtems_name rhs_name, |
| 174 | rtems_id rhs_id) |
| 175 | { |
| 176 | /* |
| 177 | * The left hand side name or id could be 0 which means a wildcard. |
| 178 | */ |
| 179 | if ((lhs_name == 0) && (lhs_id == rhs_id)) |
| 180 | return 1; |
| 181 | else if ((lhs_id == 0) || (lhs_id == rhs_id)) |
| 182 | { |
| 183 | if (rtems_capture_match_names (lhs_name, rhs_name)) |
| 184 | return 1; |
| 185 | } |
| 186 | return 0; |
| 187 | } |
| 188 | |
| 189 | /* |
| 190 | * rtems_capture_dup_name |
| 191 | * |
| 192 | * DESCRIPTION: |
| 193 | * |
| 194 | * This function duplicates an rtems_names. It protects the |
| 195 | * capture engine from a change to the way names are supported |
| 196 | * in RTEMS. |
| 197 | * |
| 198 | */ |
| 199 | static inline void |
| 200 | rtems_capture_dup_name (rtems_name* dst, rtems_name src) |
| 201 | { |
| 202 | *dst = src; |
| 203 | } |
| 204 | |
| 205 | /* |
| 206 | * rtems_capture_by_in_to |
| 207 | * |
| 208 | * DESCRIPTION: |
| 209 | * |
| 210 | * This function sees if a BY control is in the BY names. The use |
| 211 | * of the valid_mask in this way assumes the number of trigger |
| 212 | * tasks is the number of bits in uint32_t. |
| 213 | * |
| 214 | */ |
| 215 | static inline bool_Bool |
| 216 | rtems_capture_by_in_to (uint32_t events, |
| 217 | rtems_capture_task_t* by, |
| 218 | rtems_capture_control_t* to) |
| 219 | { |
| 220 | uint32_t valid_mask = RTEMS_CAPTURE_CONTROL_FROM_MASK (0)(1U << ((32) - ((0) + 1))); |
| 221 | uint32_t valid_remainder = 0xffffffff; |
| 222 | int i; |
| 223 | |
| 224 | for (i = 0; i < RTEMS_CAPTURE_TRIGGER_TASKS(32); i++) |
| 225 | { |
| 226 | /* |
| 227 | * If there are no more valid BY entries then |
| 228 | * we are finished. |
| 229 | */ |
| 230 | if ((valid_remainder & to->by_valid) == 0) |
| 231 | break; |
| 232 | |
| 233 | /* |
| 234 | * Is the froby entry valid and does its name or id match. |
| 235 | */ |
| 236 | if ((valid_mask & to->by_valid) && |
| 237 | (to->by[i].trigger & events)) |
| 238 | { |
| 239 | /* |
| 240 | * We have the BY task on the right hand side so we |
| 241 | * match with id's first then labels if the id's are |
| 242 | * not set. |
| 243 | */ |
| 244 | if (rtems_capture_match_name_id (to->by[i].name, to->by[i].id, |
| 245 | by->name, by->id)) |
| 246 | return 1; |
| 247 | } |
| 248 | |
| 249 | valid_mask >>= 1; |
| 250 | valid_remainder >>= 1; |
| 251 | } |
| 252 | |
| 253 | return 0; |
| 254 | } |
| 255 | |
| 256 | /* |
| 257 | * rtems_capture_refcount_up |
| 258 | * |
| 259 | * DESCRIPTION: |
| 260 | * |
| 261 | * This function raises the reference count. |
| 262 | * |
| 263 | */ |
| 264 | static inline void |
| 265 | rtems_capture_refcount_up (rtems_capture_task_t* task) |
| 266 | { |
| 267 | task->refcount++; |
| 268 | } |
| 269 | |
| 270 | /* |
| 271 | * rtems_capture_refcount_down |
| 272 | * |
| 273 | * DESCRIPTION: |
| 274 | * |
| 275 | * This function lowers the reference count and if the count |
| 276 | * reaches 0 the task control block is returned to the heap. |
| 277 | * |
| 278 | */ |
| 279 | static inline void |
| 280 | rtems_capture_refcount_down (rtems_capture_task_t* task) |
| 281 | { |
| 282 | if (task->refcount) |
| 283 | task->refcount--; |
| 284 | } |
| 285 | |
| 286 | /* |
| 287 | * rtems_capture_init_stack_usage |
| 288 | * |
| 289 | * DESCRIPTION: |
| 290 | * |
| 291 | * This function setups a stack so its usage can be monitored. |
| 292 | */ |
| 293 | static inline void |
| 294 | rtems_capture_init_stack_usage (rtems_capture_task_t* task) |
| 295 | { |
| 296 | if (task->tcb) |
| 297 | { |
| 298 | uint32_t* s; |
| 299 | uint32_t i; |
| 300 | |
| 301 | task->stack_size = task->tcb->Start.Initial_stack.size; |
| 302 | task->stack_clean = task->stack_size; |
| 303 | |
| 304 | s = task->tcb->Start.Initial_stack.area; |
| 305 | |
| 306 | for (i = 0; i < (task->stack_size - 128); i += 4) |
| 307 | *(s++) = 0xdeaddead; |
| 308 | } |
| 309 | } |
| 310 | |
| 311 | /* |
| 312 | * rtems_capture_find_control |
| 313 | * |
| 314 | * DESCRIPTION: |
| 315 | * |
| 316 | * This function searches for a trigger given a name. |
| 317 | * |
| 318 | */ |
| 319 | static inline rtems_capture_control_t* |
| 320 | rtems_capture_find_control (rtems_name name, rtems_id id) |
| 321 | { |
| 322 | rtems_capture_control_t* control; |
| 323 | |
| 324 | for (control = capture_controls; control != NULL((void*)0); control = control->next) |
| 325 | if (rtems_capture_match_name_id (name, id, control->name, control->id)) |
| 326 | break; |
| 327 | return control; |
| 328 | } |
| 329 | |
| 330 | /* |
| 331 | * rtems_capture_create_control |
| 332 | * |
| 333 | * DESCRIPTION: |
| 334 | * |
| 335 | * This function creates a capture control for the capture engine. |
| 336 | * |
| 337 | */ |
| 338 | static inline rtems_capture_control_t* |
| 339 | rtems_capture_create_control (rtems_name name, rtems_id id) |
| 340 | { |
| 341 | rtems_interrupt_level level; |
| 342 | rtems_capture_control_t* control; |
| 343 | rtems_capture_task_t* task; |
| 344 | |
| 345 | if ((name == 0) && (id == 0)) |
| 346 | return NULL((void*)0); |
| 347 | |
| 348 | control = rtems_capture_find_control (name, id); |
| 349 | |
| 350 | if (control == NULL((void*)0)) |
| 351 | { |
| 352 | control = _Workspace_Allocate (sizeof (rtems_capture_control_t)); |
| 353 | |
| 354 | if (control == NULL((void*)0)) |
| 355 | { |
| 356 | capture_flags |= RTEMS_CAPTURE_NO_MEMORY(1 << 1); |
| 357 | return NULL((void*)0); |
| 358 | } |
| 359 | |
| 360 | control->name = name; |
| 361 | control->id = id; |
| 362 | control->flags = 0; |
| 363 | control->to_triggers = 0; |
| 364 | control->from_triggers = 0; |
| 365 | control->by_valid = 0; |
| 366 | |
| 367 | memset (control->by, 0, sizeof (control->by)); |
| 368 | |
| 369 | rtems_interrupt_disable (level)do { (level) = sparc_disable_interrupts(); asm volatile("" :: : "memory"); } while (0); |
| 370 | |
| 371 | control->next = capture_controls; |
| 372 | capture_controls = control; |
| 373 | |
| 374 | /* |
| 375 | * We need to scan the task list as set the control to the |
| 376 | * tasks. |
| 377 | */ |
| 378 | for (task = capture_tasks; task != NULL((void*)0); task = task->forw) |
| 379 | if (rtems_capture_match_name_id (name, id, task->name, task->id)) |
| 380 | task->control = control; |
| 381 | |
| 382 | rtems_interrupt_enable (level)do { asm volatile("" ::: "memory"); sparc_enable_interrupts( level ); } while (0); |
| 383 | } |
| 384 | |
| 385 | return control; |
| 386 | } |
| 387 | |
| 388 | /* |
| 389 | * rtems_capture_create_capture_task |
| 390 | * |
| 391 | * DESCRIPTION: |
| 392 | * |
| 393 | * This function create the task control. |
| 394 | * |
| 395 | */ |
| 396 | static inline rtems_capture_task_t* |
| 397 | rtems_capture_create_capture_task (rtems_tcb* new_task) |
| 398 | { |
| 399 | rtems_interrupt_level level; |
| 400 | rtems_capture_task_t* task; |
| 401 | rtems_capture_control_t* control; |
| 402 | rtems_name name; |
| 403 | |
| 404 | task = _Workspace_Allocate (sizeof (rtems_capture_task_t)); |
| 405 | |
| 406 | if (task == NULL((void*)0)) |
| 407 | { |
| 408 | capture_flags |= RTEMS_CAPTURE_NO_MEMORY(1 << 1); |
| 409 | return NULL((void*)0); |
| 410 | } |
| 411 | |
| 412 | /* |
| 413 | * Check the type of name the object has. |
| 414 | */ |
| 415 | |
| 416 | rtems_object_get_classic_name( new_task->Object.id, &name ); |
| 417 | |
| 418 | rtems_capture_dup_name (&task->name, name); |
| 419 | |
| 420 | task->id = new_task->Object.id; |
| 421 | task->flags = 0; |
| 422 | task->in = 0; |
| 423 | task->refcount = 0; |
| 424 | task->out = 0; |
| 425 | task->tcb = new_task; |
| 426 | task->ticks = 0; |
| 427 | task->tick_offset = 0; |
| 428 | task->ticks_in = 0; |
| 429 | task->tick_offset_in = 0; |
| 430 | task->control = 0; |
| 431 | task->last_ticks = 0; |
| 432 | task->last_tick_offset = 0; |
| 433 | |
| 434 | task->tcb->extensions[capture_extension_index] = task; |
| 435 | |
| 436 | task->start_priority = new_task->Start.initial_priority; |
| 437 | task->stack_size = new_task->Start.Initial_stack.size; |
| 438 | task->stack_clean = task->stack_size; |
| 439 | |
| 440 | rtems_interrupt_disable (level)do { (level) = sparc_disable_interrupts(); asm volatile("" :: : "memory"); } while (0); |
| 441 | |
| 442 | task->forw = capture_tasks; |
| 443 | if (task->forw) |
| 444 | task->forw->back = task; |
| 445 | task->back = NULL((void*)0); |
| 446 | capture_tasks = task; |
| 447 | |
| 448 | rtems_interrupt_enable (level)do { asm volatile("" ::: "memory"); sparc_enable_interrupts( level ); } while (0); |
| 449 | |
| 450 | /* |
| 451 | * We need to scan the default control list to initialise |
| 452 | * this control. |
| 453 | */ |
| 454 | |
| 455 | for (control = capture_controls; control != NULL((void*)0); control = control->next) |
| 456 | if (rtems_capture_match_name_id (control->name, control->id, |
| 457 | task->name, task->id)) |
| 458 | task->control = control; |
| 459 | |
| 460 | return task; |
| 461 | } |
| 462 | |
| 463 | /* |
| 464 | * rtems_capture_destroy_capture_task |
| 465 | * |
| 466 | * DESCRIPTION: |
| 467 | * |
| 468 | * This function destroy the task structure if the reference count |
| 469 | * is 0 and the tcb has been cleared signalling the task has been |
| 470 | * deleted. |
| 471 | * |
| 472 | */ |
| 473 | static inline void |
| 474 | rtems_capture_destroy_capture_task (rtems_capture_task_t* task) |
| 475 | { |
| 476 | if (task) |
| 477 | { |
| 478 | rtems_interrupt_level level; |
| 479 | |
| 480 | rtems_interrupt_disable (level)do { (level) = sparc_disable_interrupts(); asm volatile("" :: : "memory"); } while (0); |
| 481 | |
| 482 | if (task->tcb || task->refcount) |
| 483 | task = 0; |
| 484 | |
| 485 | if (task) |
| 486 | { |
| 487 | if (task->forw) |
| 488 | task->forw->back = task->back; |
| 489 | if (task->back) |
| 490 | task->back->forw = task->forw; |
| 491 | else |
| 492 | capture_tasks = task->forw; |
| 493 | } |
| 494 | |
| 495 | rtems_interrupt_enable (level)do { asm volatile("" ::: "memory"); sparc_enable_interrupts( level ); } while (0); |
| 496 | |
| 497 | if (task) |
| 498 | _Workspace_Free (task); |
| 499 | } |
| 500 | } |
| 501 | |
| 502 | /* |
| 503 | * rtems_capture_record |
| 504 | * |
| 505 | * DESCRIPTION: |
| 506 | * |
| 507 | * This function records a capture record into the capture buffer. |
| 508 | * |
| 509 | */ |
| 510 | static inline void |
| 511 | rtems_capture_record (rtems_capture_task_t* task, |
| 512 | uint32_t events) |
| 513 | { |
| 514 | /* |
| 515 | * Check the watch state if we have a task control, and |
| 516 | * the task's real priority is lower or equal to the ceiling. |
| 517 | */ |
| 518 | if (task && |
| 519 | ((capture_flags & |
| 520 | (RTEMS_CAPTURE_TRIGGERED(1 << 3) | RTEMS_CAPTURE_ONLY_MONITOR(1 << 7))) == |
| 521 | RTEMS_CAPTURE_TRIGGERED(1 << 3))) |
| 522 | { |
| 523 | rtems_capture_control_t* control; |
| 524 | |
| 525 | control = task->control; |
| 526 | |
| 527 | /* |
| 528 | * Capure the record if we have an event that is always |
| 529 | * captured, or the task's real priority is greater than the |
| 530 | * watch ceiling, and the global watch or task watch is enabled. |
| 531 | */ |
| 532 | |
| 533 | if ((events & RTEMS_CAPTURE_RECORD_EVENTS(0)) || |
| 534 | ((task->tcb->real_priority >= capture_ceiling) && |
| 535 | (task->tcb->real_priority <= capture_floor) && |
| 536 | ((capture_flags & RTEMS_CAPTURE_GLOBAL_WATCH(1 << 6)) || |
| 537 | (control && (control->flags & RTEMS_CAPTURE_WATCH(1 << 0)))))) |
| 538 | { |
| 539 | rtems_interrupt_level level; |
| 540 | |
| 541 | rtems_interrupt_disable (level)do { (level) = sparc_disable_interrupts(); asm volatile("" :: : "memory"); } while (0); |
| 542 | |
| 543 | if (capture_count < capture_size) |
| 544 | { |
| 545 | capture_count++; |
| 546 | capture_in->task = task; |
| 547 | capture_in->events = (events | |
| 548 | (task->tcb->real_priority) | |
| 549 | (task->tcb->current_priority << 8)); |
| 550 | |
| 551 | if ((events & RTEMS_CAPTURE_RECORD_EVENTS(0)) == 0) |
| 552 | task->flags |= RTEMS_CAPTURE_TRACED(1 << 0); |
| 553 | |
| 554 | rtems_capture_get_time (&capture_in->ticks, &capture_in->tick_offset); |
| 555 | |
| 556 | if (capture_in == &capture_records[capture_size - 1]) |
| 557 | capture_in = capture_records; |
| 558 | else |
| 559 | capture_in++; |
| 560 | |
| 561 | rtems_capture_refcount_up (task); |
| 562 | } |
| 563 | else |
| 564 | capture_flags |= RTEMS_CAPTURE_OVERFLOW(1 << 2); |
| 565 | rtems_interrupt_enable (level)do { asm volatile("" ::: "memory"); sparc_enable_interrupts( level ); } while (0); |
| 566 | } |
| 567 | } |
| 568 | } |
| 569 | |
| 570 | /* |
| 571 | * rtems_capture_trigger |
| 572 | * |
| 573 | * DESCRIPTION: |
| 574 | * |
| 575 | * See if we have triggered and if not see if this event is a |
| 576 | * cause of a trigger. |
| 577 | */ |
| 578 | bool_Bool |
| 579 | rtems_capture_trigger (rtems_capture_task_t* ft, |
| 580 | rtems_capture_task_t* tt, |
| 581 | uint32_t events) |
| 582 | { |
| 583 | /* |
| 584 | * If we have not triggered then see if this is a trigger condition. |
| 585 | */ |
| 586 | if (!(capture_flags & RTEMS_CAPTURE_TRIGGERED(1 << 3))) |
| 587 | { |
| 588 | rtems_capture_control_t* fc = NULL((void*)0); |
| 589 | rtems_capture_control_t* tc = NULL((void*)0); |
| 590 | uint32_t from_events = 0; |
| 591 | uint32_t to_events = 0; |
| 592 | uint32_t from_to_events = 0; |
| 593 | |
| 594 | if (ft) |
| 595 | { |
| 596 | fc = ft->control; |
| 597 | if (fc) |
| 598 | from_events = fc->from_triggers & events; |
| 599 | } |
| 600 | |
| 601 | if (tt) |
| 602 | { |
| 603 | tc = tt->control; |
| 604 | if (tc) |
| 605 | { |
| 606 | to_events = tc->to_triggers & events; |
| 607 | if (ft && tc->by_valid) |
| 608 | from_to_events = tc->by_triggers & events; |
| 609 | } |
| 610 | } |
| 611 | |
| 612 | /* |
| 613 | * Check if we have any from or to events. These are the |
| 614 | * from any or to any type triggers. All from/to triggers are |
| 615 | * listed in the to's control with the from in the from list. |
| 616 | * |
| 617 | * The masking above means any flag set is a trigger. |
| 618 | */ |
| 619 | if (from_events || to_events) |
| 620 | { |
| 621 | capture_flags |= RTEMS_CAPTURE_TRIGGERED(1 << 3); |
| 622 | return 1; |
| 623 | } |
| 624 | |
| 625 | /* |
| 626 | * Check the from->to events. |
| 627 | */ |
| 628 | if (from_to_events) |
| 629 | { |
| 630 | if (rtems_capture_by_in_to (events, ft, tc)) |
| 631 | { |
| 632 | capture_flags |= RTEMS_CAPTURE_TRIGGERED(1 << 3); |
| 633 | return 1; |
| 634 | } |
| 635 | } |
| 636 | |
| 637 | return 0; |
| 638 | } |
| 639 | |
| 640 | return 1; |
| 641 | } |
| 642 | |
| 643 | /* |
| 644 | * rtems_capture_create_task |
| 645 | * |
| 646 | * DESCRIPTION: |
| 647 | * |
| 648 | * This function is called when a task is created. |
| 649 | * |
| 650 | */ |
| 651 | static bool_Bool |
| 652 | rtems_capture_create_task (rtems_tcb* current_task, |
| 653 | rtems_tcb* new_task) |
| 654 | { |
| 655 | rtems_capture_task_t* ct; |
| 656 | rtems_capture_task_t* nt; |
| 657 | |
| 658 | ct = current_task->extensions[capture_extension_index]; |
| 659 | |
| 660 | /* |
| 661 | * The task pointers may not be known as the task may have |
| 662 | * been created before the capture engine was open. Add them. |
| 663 | */ |
| 664 | |
| 665 | if (ct == NULL((void*)0)) |
| 666 | ct = rtems_capture_create_capture_task (current_task); |
| 667 | |
| 668 | /* |
| 669 | * Create the new task's capture control block. |
| 670 | */ |
| 671 | nt = rtems_capture_create_capture_task (new_task); |
| 672 | |
| 673 | if (rtems_capture_trigger (ct, nt, RTEMS_CAPTURE_CREATE(1 << 1))) |
| 674 | { |
| 675 | rtems_capture_record (ct, RTEMS_CAPTURE_CREATED_BY_EVENT0x00010000U); |
| 676 | rtems_capture_record (nt, RTEMS_CAPTURE_CREATED_EVENT0x00020000U); |
| 677 | } |
| 678 | |
| 679 | return 1 == 1; |
| 680 | } |
| 681 | |
| 682 | /* |
| 683 | * rtems_capture_start_task |
| 684 | * |
| 685 | * DESCRIPTION: |
| 686 | * |
| 687 | * This function is called when a task is started. |
| 688 | * |
| 689 | */ |
| 690 | static void |
| 691 | rtems_capture_start_task (rtems_tcb* current_task, |
| 692 | rtems_tcb* started_task) |
| 693 | { |
| 694 | /* |
| 695 | * Get the capture task control block so we can trace this |
| 696 | * event. |
| 697 | */ |
| 698 | rtems_capture_task_t* ct; |
| 699 | rtems_capture_task_t* st; |
| 700 | |
| 701 | ct = current_task->extensions[capture_extension_index]; |
| 702 | st = started_task->extensions[capture_extension_index]; |
| 703 | |
| 704 | /* |
| 705 | * The task pointers may not be known as the task may have |
| 706 | * been created before the capture engine was open. Add them. |
| 707 | */ |
| 708 | |
| 709 | if (ct == NULL((void*)0)) |
| 710 | ct = rtems_capture_create_capture_task (current_task); |
| 711 | |
| 712 | if (st == NULL((void*)0)) |
| 713 | st = rtems_capture_create_capture_task (started_task); |
| 714 | |
| 715 | if (rtems_capture_trigger (ct, st, RTEMS_CAPTURE_START(1 << 2))) |
| 716 | { |
| 717 | rtems_capture_record (ct, RTEMS_CAPTURE_STARTED_BY_EVENT0x00040000U); |
| 718 | rtems_capture_record (st, RTEMS_CAPTURE_STARTED_EVENT0x00080000U); |
| 719 | } |
| 720 | |
| 721 | rtems_capture_init_stack_usage (st); |
| 722 | } |
| 723 | |
| 724 | /* |
| 725 | * rtems_capture_restart_task |
| 726 | * |
| 727 | * DESCRIPTION: |
| 728 | * |
| 729 | * This function is called when a task is restarted. |
| 730 | * |
| 731 | */ |
| 732 | static void |
| 733 | rtems_capture_restart_task (rtems_tcb* current_task, |
| 734 | rtems_tcb* restarted_task) |
| 735 | { |
| 736 | /* |
| 737 | * Get the capture task control block so we can trace this |
| 738 | * event. |
| 739 | */ |
| 740 | rtems_capture_task_t* ct; |
| 741 | rtems_capture_task_t* rt; |
| 742 | |
| 743 | ct = current_task->extensions[capture_extension_index]; |
| 744 | rt = restarted_task->extensions[capture_extension_index]; |
| 745 | |
| 746 | /* |
| 747 | * The task pointers may not be known as the task may have |
| 748 | * been created before the capture engine was open. Add them. |
| 749 | */ |
| 750 | |
| 751 | if (ct == NULL((void*)0)) |
| 752 | ct = rtems_capture_create_capture_task (current_task); |
| 753 | |
| 754 | if (rt == NULL((void*)0)) |
| 755 | rt = rtems_capture_create_capture_task (restarted_task); |
| 756 | |
| 757 | if (rtems_capture_trigger (ct, rt, RTEMS_CAPTURE_RESTART(1 << 3))) |
| 758 | { |
| 759 | rtems_capture_record (ct, RTEMS_CAPTURE_RESTARTED_BY_EVENT0x00100000U); |
| 760 | rtems_capture_record (rt, RTEMS_CAPTURE_RESTARTED_EVENT0x00200000U); |
| 761 | } |
| 762 | |
| 763 | rtems_capture_task_stack_usage (rt); |
| 764 | rtems_capture_init_stack_usage (rt); |
| 765 | } |
| 766 | |
| 767 | /* |
| 768 | * rtems_capture_delete_task |
| 769 | * |
| 770 | * DESCRIPTION: |
| 771 | * |
| 772 | * This function is called when a task is deleted. |
| 773 | * |
| 774 | */ |
| 775 | static void |
| 776 | rtems_capture_delete_task (rtems_tcb* current_task, |
| 777 | rtems_tcb* deleted_task) |
| 778 | { |
| 779 | /* |
| 780 | * Get the capture task control block so we can trace this |
| 781 | * event. |
| 782 | */ |
| 783 | rtems_capture_task_t* ct; |
| 784 | rtems_capture_task_t* dt; |
| 785 | |
| 786 | /* |
| 787 | * The task pointers may not be known as the task may have |
| 788 | * been created before the capture engine was open. Add them. |
| 789 | */ |
| 790 | |
| 791 | ct = current_task->extensions[capture_extension_index]; |
| 792 | dt = deleted_task->extensions[capture_extension_index]; |
| 793 | |
| 794 | if (ct == NULL((void*)0)) |
| 795 | ct = rtems_capture_create_capture_task (current_task); |
| 796 | |
| 797 | if (dt == NULL((void*)0)) |
| 798 | dt = rtems_capture_create_capture_task (deleted_task); |
| 799 | |
| 800 | if (rtems_capture_trigger (ct, dt, RTEMS_CAPTURE_DELETE(1 << 4))) |
| 801 | { |
| 802 | rtems_capture_record (ct, RTEMS_CAPTURE_DELETED_BY_EVENT0x00400000U); |
| 803 | rtems_capture_record (dt, RTEMS_CAPTURE_DELETED_EVENT0x00800000U); |
| 804 | } |
| 805 | |
| 806 | rtems_capture_task_stack_usage (dt); |
| 807 | |
| 808 | /* |
| 809 | * This task's tcb will be invalid. This signals the |
| 810 | * task has been deleted. |
| 811 | */ |
| 812 | dt->tcb = 0; |
| 813 | |
| 814 | rtems_capture_destroy_capture_task (dt); |
| 815 | } |
| 816 | |
| 817 | /* |
| 818 | * rtems_capture_begin_task |
| 819 | * |
| 820 | * DESCRIPTION: |
| 821 | * |
| 822 | * This function is called when a task is begun. |
| 823 | * |
| 824 | */ |
| 825 | static void |
| 826 | rtems_capture_begin_task (rtems_tcb* begin_task) |
| 827 | { |
| 828 | /* |
| 829 | * Get the capture task control block so we can trace this |
| 830 | * event. |
| 831 | */ |
| 832 | rtems_capture_task_t* bt; |
| 833 | |
| 834 | bt = begin_task->extensions[capture_extension_index]; |
| 835 | |
| 836 | /* |
| 837 | * The task pointers may not be known as the task may have |
| 838 | * been created before the capture engine was open. Add them. |
| 839 | */ |
| 840 | |
| 841 | if (bt == NULL((void*)0)) |
| 842 | bt = rtems_capture_create_capture_task (begin_task); |
| 843 | |
| 844 | if (rtems_capture_trigger (NULL((void*)0), bt, RTEMS_CAPTURE_BEGIN(1 << 5))) |
| 845 | rtems_capture_record (bt, RTEMS_CAPTURE_BEGIN_EVENT0x01000000U); |
| 846 | } |
| 847 | |
| 848 | /* |
| 849 | * rtems_capture_exitted_task |
| 850 | * |
| 851 | * DESCRIPTION: |
| 852 | * |
| 853 | * This function is called when a task is exitted. That is |
| 854 | * returned rather than was deleted. |
| 855 | * |
| 856 | */ |
| 857 | static void |
| 858 | rtems_capture_exitted_task (rtems_tcb* exitted_task) |
| 859 | { |
| 860 | /* |
| 861 | * Get the capture task control block so we can trace this |
| 862 | * event. |
| 863 | */ |
| 864 | rtems_capture_task_t* et; |
| 865 | |
| 866 | et = exitted_task->extensions[capture_extension_index]; |
| 867 | |
| 868 | /* |
| 869 | * The task pointers may not be known as the task may have |
| 870 | * been created before the capture engine was open. Add them. |
| 871 | */ |
| 872 | |
| 873 | if (et == NULL((void*)0)) |
| 874 | et = rtems_capture_create_capture_task (exitted_task); |
| 875 | |
| 876 | if (rtems_capture_trigger (NULL((void*)0), et, RTEMS_CAPTURE_EXITTED(1 << 6))) |
| 877 | rtems_capture_record (et, RTEMS_CAPTURE_EXITTED_EVENT0x02000000U); |
| 878 | |
| 879 | rtems_capture_task_stack_usage (et); |
| 880 | } |
| 881 | |
| 882 | /* |
| 883 | * rtems_capture_switch_task |
| 884 | * |
| 885 | * DESCRIPTION: |
| 886 | * |
| 887 | * This function is called when a context is switched. |
| 888 | * |
| 889 | */ |
| 890 | static void |
| 891 | rtems_capture_switch_task (rtems_tcb* current_task, |
| 892 | rtems_tcb* heir_task) |
| 893 | { |
| 894 | /* |
| 895 | * Only perform context switch trace processing if tracing is |
| 896 | * enabled. |
| 897 | */ |
| 898 | if (capture_flags & RTEMS_CAPTURE_ON(1 << 0)) |
| 899 | { |
| 900 | uint32_t ticks; |
| 901 | uint32_t tick_offset; |
| 902 | |
| 903 | /* |
| 904 | * Get the cpature task control block so we can update the |
| 905 | * reference and perform any watch or trigger functions. |
| 906 | * The task pointers may not be known as the task may have |
| 907 | * been created before the capture engine was open. Add them. |
| 908 | */ |
| 909 | rtems_capture_task_t* ct; |
| 910 | rtems_capture_task_t* ht; |
| 911 | |
| 912 | if (_States_Is_transient (current_task->current_state)) |
| 913 | { |
| 914 | rtems_id ct_id = current_task->Object.id; |
| 915 | |
| 916 | for (ct = capture_tasks; ct; ct = ct->forw) |
| 917 | if (ct->id == ct_id) |
| 918 | break; |
| 919 | } |
| 920 | else |
| 921 | { |
| 922 | ct = current_task->extensions[capture_extension_index]; |
| 923 | |
| 924 | if (ct == NULL((void*)0)) |
| 925 | ct = rtems_capture_create_capture_task (current_task); |
| 926 | } |
| 927 | |
| 928 | ht = heir_task->extensions[capture_extension_index]; |
| 929 | |
| 930 | if (ht == NULL((void*)0)) |
| 931 | ht = rtems_capture_create_capture_task (heir_task); |
| 932 | |
| 933 | /* |
| 934 | * Update the execution time. Assume the tick will not overflow |
| 935 | * for now. This may need to change. |
| 936 | */ |
| 937 | rtems_capture_get_time (&ticks, &tick_offset); |
| 938 | |
| 939 | /* |
| 940 | * We could end up with null pointers for both the current task |
| 941 | * and the heir task. |
| 942 | */ |
| 943 | |
| 944 | if (ht) |
| 945 | { |
| 946 | ht->in++; |
| 947 | ht->ticks_in = ticks; |
| 948 | ht->tick_offset_in = tick_offset; |
| 949 | } |
| 950 | |
| 951 | if (ct) |
| 952 | { |
| 953 | ct->out++; |
| 954 | ct->ticks += ticks - ct->ticks_in; |
| 955 | |
| 956 | if (capture_timestamp) |
| 957 | { |
| 958 | tick_offset += capture_tick_period - ct->tick_offset_in; |
| 959 | |
| 960 | if (tick_offset < capture_tick_period) |
| 961 | ct->tick_offset = tick_offset; |
| 962 | else |
| 963 | { |
| 964 | ct->ticks++; |
| 965 | ct->tick_offset = tick_offset - capture_tick_period; |
| 966 | } |
| 967 | } |
| 968 | else |
| 969 | { |
| 970 | ct->tick_offset += 100; |
| 971 | } |
| 972 | } |
| 973 | |
| 974 | if (rtems_capture_trigger (ct, ht, RTEMS_CAPTURE_SWITCH(1 << 0))) |
| 975 | { |
| 976 | rtems_capture_record (ct, RTEMS_CAPTURE_SWITCHED_OUT_EVENT0x04000000U); |
| 977 | rtems_capture_record (ht, RTEMS_CAPTURE_SWITCHED_IN_EVENT0x08000000U); |
| 978 | } |
| 979 | } |
| 980 | } |
| 981 | |
| 982 | /* |
| 983 | * rtems_capture_open |
| 984 | * |
| 985 | * DESCRIPTION: |
| 986 | * |
| 987 | * This function initialises the realtime capture engine allocating the trace |
| 988 | * buffer. It is assumed we have a working heap at stage of initialisation. |
| 989 | * |
| 990 | */ |
| 991 | rtems_status_code |
| 992 | rtems_capture_open (uint32_t size, rtems_capture_timestamp timestamp __attribute__((unused))) |
| 993 | { |
| 994 | rtems_extensions_table capture_extensions; |
| 995 | rtems_name name; |
| 996 | rtems_status_code sc; |
| 997 | |
| 998 | /* |
| 999 | * See if the capture engine is already open. |
| 1000 | */ |
| 1001 | |
| 1002 | if (capture_records) |
| 1003 | return RTEMS_RESOURCE_IN_USE; |
| 1004 | |
| 1005 | capture_records = malloc (size * sizeof (rtems_capture_record_t)); |
| 1006 | |
| 1007 | if (capture_records == NULL((void*)0)) |
| 1008 | return RTEMS_NO_MEMORY; |
| 1009 | |
| 1010 | capture_size = size; |
| 1011 | capture_count = 0; |
| 1012 | capture_in = capture_records; |
| 1013 | capture_out = 0; |
| 1014 | capture_flags = 0; |
| 1015 | capture_tasks = NULL((void*)0); |
| 1016 | capture_ceiling = 0; |
| 1017 | capture_floor = 255; |
| 1018 | |
| 1019 | /* |
| 1020 | * Create the extension table. This is copied so we |
| 1021 | * can create it as a local. |
| 1022 | */ |
| 1023 | capture_extensions.thread_create = rtems_capture_create_task; |
| 1024 | capture_extensions.thread_start = rtems_capture_start_task; |
| 1025 | capture_extensions.thread_restart = rtems_capture_restart_task; |
| 1026 | capture_extensions.thread_delete = rtems_capture_delete_task; |
| 1027 | capture_extensions.thread_switch = rtems_capture_switch_task; |
| 1028 | capture_extensions.thread_begin = rtems_capture_begin_task; |
| 1029 | capture_extensions.thread_exitted = rtems_capture_exitted_task; |
| 1030 | capture_extensions.fatal = NULL((void*)0); |
| 1031 | |
| 1032 | /* |
| 1033 | * Get the tick period from the BSP Configuration Table. |
| 1034 | */ |
| 1035 | capture_tick_period = Configuration.microseconds_per_tick; |
| 1036 | |
| 1037 | /* |
| 1038 | * Register the user extension handlers for the CAPture Engine. |
| 1039 | */ |
| 1040 | name = rtems_build_name ('C', 'A', 'P', 'E')( (uint32_t)('C') << 24 | (uint32_t)('A') << 16 | (uint32_t)('P') << 8 | (uint32_t)('E') ); |
| 1041 | sc = rtems_extension_create (name, &capture_extensions, &capture_id); |
| 1042 | |
| 1043 | if (sc != RTEMS_SUCCESSFUL) |
| 1044 | { |
| 1045 | capture_id = 0; |
| 1046 | free (capture_records); |
| 1047 | capture_records = NULL((void*)0); |
| 1048 | } |
| 1049 | else |
| 1050 | { |
| 1051 | capture_extension_index = rtems_object_id_get_index (capture_id)_Objects_Get_index( capture_id );; |
| 1052 | } |
| 1053 | |
| 1054 | /* |
| 1055 | * Iterate over the list of existing tasks. |
| 1056 | */ |
| 1057 | |
| 1058 | return sc; |
| 1059 | } |
| 1060 | |
| 1061 | /* |
| 1062 | * rtems_capture_close |
| 1063 | * |
| 1064 | * DESCRIPTION: |
| 1065 | * |
| 1066 | * This function shutdowns the capture engine and release any claimed |
| 1067 | * resources. |
| 1068 | */ |
| 1069 | rtems_status_code |
| 1070 | rtems_capture_close (void) |
| 1071 | { |
| 1072 | rtems_interrupt_level level; |
| 1073 | rtems_capture_task_t* task; |
| 1074 | rtems_capture_control_t* control; |
| 1075 | rtems_capture_record_t* records; |
| 1076 | rtems_status_code sc; |
| 1077 | |
| 1078 | rtems_interrupt_disable (level)do { (level) = sparc_disable_interrupts(); asm volatile("" :: : "memory"); } while (0); |
| 1079 | |
| 1080 | if (!capture_records) |
| 1081 | { |
| 1082 | rtems_interrupt_enable (level)do { asm volatile("" ::: "memory"); sparc_enable_interrupts( level ); } while (0); |
| 1083 | return RTEMS_SUCCESSFUL; |
| 1084 | } |
| 1085 | |
| 1086 | capture_flags &= ~(RTEMS_CAPTURE_ON(1 << 0) | RTEMS_CAPTURE_ONLY_MONITOR(1 << 7)); |
| 1087 | |
| 1088 | records = capture_records; |
Value stored to 'records' is never read | |
| 1089 | capture_records = NULL((void*)0); |
| 1090 | |
| 1091 | rtems_interrupt_enable (level)do { asm volatile("" ::: "memory"); sparc_enable_interrupts( level ); } while (0); |
| 1092 | |
| 1093 | /* |
| 1094 | * Delete the extension first. This means we are now able to |
| 1095 | * release the resources we have without them being used. |
| 1096 | */ |
| 1097 | |
| 1098 | sc = rtems_extension_delete (capture_id); |
| 1099 | |
| 1100 | if (sc != RTEMS_SUCCESSFUL) |
| 1101 | return sc; |
| 1102 | |
| 1103 | task = capture_tasks; |
| 1104 | |
| 1105 | while (task) |
| 1106 | { |
| 1107 | rtems_capture_task_t* delete = task; |
| 1108 | task = task->forw; |
| 1109 | _Workspace_Free (delete); |
| 1110 | } |
| 1111 | |
| 1112 | capture_tasks = NULL((void*)0); |
| 1113 | |
| 1114 | control = capture_controls; |
| 1115 | |
| 1116 | while (control) |
| 1117 | { |
| 1118 | rtems_capture_control_t* delete = control; |
| 1119 | control = control->next; |
| 1120 | _Workspace_Free (delete); |
| 1121 | } |
| 1122 | |
| 1123 | capture_controls = NULL((void*)0); |
| 1124 | |
| 1125 | if (capture_records) |
| 1126 | { |
| 1127 | free (capture_records); |
| 1128 | capture_records = NULL((void*)0); |
| 1129 | } |
| 1130 | |
| 1131 | return RTEMS_SUCCESSFUL; |
| 1132 | } |
| 1133 | |
| 1134 | /* |
| 1135 | * rtems_capture_control |
| 1136 | * |
| 1137 | * DESCRIPTION: |
| 1138 | * |
| 1139 | * This function allows control of tracing at a global level. |
| 1140 | */ |
| 1141 | rtems_status_code |
| 1142 | rtems_capture_control (bool_Bool enable) |
| 1143 | { |
| 1144 | rtems_interrupt_level level; |
| 1145 | |
| 1146 | rtems_interrupt_disable (level)do { (level) = sparc_disable_interrupts(); asm volatile("" :: : "memory"); } while (0); |
| 1147 | |
| 1148 | if (!capture_records) |
| 1149 | { |
| 1150 | rtems_interrupt_enable (level)do { asm volatile("" ::: "memory"); sparc_enable_interrupts( level ); } while (0); |
| 1151 | return RTEMS_UNSATISFIED; |
| 1152 | } |
| 1153 | |
| 1154 | if (enable) |
| 1155 | capture_flags |= RTEMS_CAPTURE_ON(1 << 0); |
| 1156 | else |
| 1157 | capture_flags &= ~RTEMS_CAPTURE_ON(1 << 0); |
| 1158 | |
| 1159 | rtems_interrupt_enable (level)do { asm volatile("" ::: "memory"); sparc_enable_interrupts( level ); } while (0); |
| 1160 | |
| 1161 | return RTEMS_SUCCESSFUL; |
| 1162 | } |
| 1163 | |
| 1164 | /* |
| 1165 | * rtems_capture_monitor |
| 1166 | * |
| 1167 | * DESCRIPTION: |
| 1168 | * |
| 1169 | * This function enable the monitor mode. When in the monitor mode |
| 1170 | * the tasks are monitored but no data is saved. This can be used |
| 1171 | * to profile the load on a system. |
| 1172 | */ |
| 1173 | rtems_status_code |
| 1174 | rtems_capture_monitor (bool_Bool enable) |
| 1175 | { |
| 1176 | rtems_interrupt_level level; |
| 1177 | |
| 1178 | rtems_interrupt_disable (level)do { (level) = sparc_disable_interrupts(); asm volatile("" :: : "memory"); } while (0); |
| 1179 | |
| 1180 | if (!capture_records) |
| 1181 | { |
| 1182 | rtems_interrupt_enable (level)do { asm volatile("" ::: "memory"); sparc_enable_interrupts( level ); } while (0); |
| 1183 | return RTEMS_UNSATISFIED; |
| 1184 | } |
| 1185 | |
| 1186 | if (enable) |
| 1187 | capture_flags |= RTEMS_CAPTURE_ONLY_MONITOR(1 << 7); |
| 1188 | else |
| 1189 | capture_flags &= ~RTEMS_CAPTURE_ONLY_MONITOR(1 << 7); |
| 1190 | |
| 1191 | rtems_interrupt_enable (level)do { asm volatile("" ::: "memory"); sparc_enable_interrupts( level ); } while (0); |
| 1192 | |
| 1193 | return RTEMS_SUCCESSFUL; |
| 1194 | } |
| 1195 | |
| 1196 | /* |
| 1197 | * rtems_capture_flush |
| 1198 | * |
| 1199 | * DESCRIPTION: |
| 1200 | * |
| 1201 | * This function flushes the capture buffer. The prime parameter allows the |
| 1202 | * capture engine to also be primed again. |
| 1203 | */ |
| 1204 | rtems_status_code |
| 1205 | rtems_capture_flush (bool_Bool prime) |
| 1206 | { |
| 1207 | rtems_interrupt_level level; |
| 1208 | rtems_capture_task_t* task; |
| 1209 | |
| 1210 | rtems_interrupt_disable (level)do { (level) = sparc_disable_interrupts(); asm volatile("" :: : "memory"); } while (0); |
| 1211 | |
| 1212 | for (task = capture_tasks; task != NULL((void*)0); task = task->forw) |
| 1213 | { |
| 1214 | task->flags &= ~RTEMS_CAPTURE_TRACED(1 << 0); |
| 1215 | task->refcount = 0; |
| 1216 | } |
| 1217 | |
| 1218 | if (prime) |
| 1219 | capture_flags &= ~(RTEMS_CAPTURE_TRIGGERED(1 << 3) | RTEMS_CAPTURE_OVERFLOW(1 << 2)); |
| 1220 | else |
| 1221 | capture_flags &= ~RTEMS_CAPTURE_OVERFLOW(1 << 2); |
| 1222 | |
| 1223 | capture_count = 0; |
| 1224 | capture_in = capture_records; |
| 1225 | capture_out = 0; |
| 1226 | |
| 1227 | rtems_interrupt_enable (level)do { asm volatile("" ::: "memory"); sparc_enable_interrupts( level ); } while (0); |
| 1228 | |
| 1229 | task = capture_tasks; |
| 1230 | |
| 1231 | while (task) |
| 1232 | { |
| 1233 | rtems_capture_task_t* check = task; |
| 1234 | task = task->forw; |
| 1235 | rtems_capture_destroy_capture_task (check); |
| 1236 | } |
| 1237 | |
| 1238 | return RTEMS_SUCCESSFUL; |
| 1239 | } |
| 1240 | |
| 1241 | /* |
| 1242 | * rtems_capture_watch_add |
| 1243 | * |
| 1244 | * DESCRIPTION: |
| 1245 | * |
| 1246 | * This function defines a watch for a specific task given a name. A watch |
| 1247 | * causes it to be traced either in or out of context. The watch can be |
| 1248 | * optionally enabled or disabled with the set routine. It is disabled by |
| 1249 | * default. |
| 1250 | */ |
| 1251 | rtems_status_code |
| 1252 | rtems_capture_watch_add (rtems_name name, rtems_id id) |
| 1253 | { |
| 1254 | rtems_capture_control_t* control; |
| 1255 | |
| 1256 | if ((name == 0) && (id == 0)) |
| 1257 | return RTEMS_UNSATISFIED; |
| 1258 | |
| 1259 | control = rtems_capture_find_control (name, id); |
| 1260 | |
| 1261 | if (control && !id) |
| 1262 | return RTEMS_TOO_MANY; |
| 1263 | |
| 1264 | if (!control) |
| 1265 | control = rtems_capture_create_control (name, id); |
| 1266 | |
| 1267 | if (!control) |
| 1268 | return RTEMS_NO_MEMORY; |
| 1269 | |
| 1270 | return RTEMS_SUCCESSFUL; |
| 1271 | } |
| 1272 | |
| 1273 | /* |
| 1274 | * rtems_capture_watch_del |
| 1275 | * |
| 1276 | * DESCRIPTION: |
| 1277 | * |
| 1278 | * This function removes a watch for a specific task given a name. The task |
| 1279 | * description will still exist if referenced by a trace record in the trace |
| 1280 | * buffer or a global watch is defined. |
| 1281 | */ |
| 1282 | rtems_status_code |
| 1283 | rtems_capture_watch_del (rtems_name name, rtems_id id) |
| 1284 | { |
| 1285 | rtems_interrupt_level level; |
| 1286 | rtems_capture_control_t* control; |
| 1287 | rtems_capture_control_t** prev_control; |
| 1288 | rtems_capture_task_t* task; |
| 1289 | bool_Bool found = false0; |
| 1290 | |
| 1291 | /* |
| 1292 | * Should this test be for wildcards ? |
| 1293 | */ |
| 1294 | |
| 1295 | for (prev_control = &capture_controls, control = capture_controls; |
| 1296 | control != NULL((void*)0); ) |
| 1297 | { |
| 1298 | if (rtems_capture_match_name_id (control->name, control->id, name, id)) |
| 1299 | { |
| 1300 | rtems_interrupt_disable (level)do { (level) = sparc_disable_interrupts(); asm volatile("" :: : "memory"); } while (0); |
| 1301 | |
| 1302 | for (task = capture_tasks; task != NULL((void*)0); task = task->forw) |
| 1303 | if (task->control == control) |
| 1304 | task->control = 0; |
| 1305 | |
| 1306 | *prev_control = control->next; |
| 1307 | |
| 1308 | rtems_interrupt_enable (level)do { asm volatile("" ::: "memory"); sparc_enable_interrupts( level ); } while (0); |
| 1309 | |
| 1310 | _Workspace_Free (control); |
| 1311 | |
| 1312 | control = *prev_control; |
| 1313 | |
| 1314 | found = true1; |
| 1315 | } |
| 1316 | else |
| 1317 | { |
| 1318 | prev_control = &control->next; |
| 1319 | control = control->next; |
| 1320 | } |
| 1321 | } |
| 1322 | |
| 1323 | if (found) |
| 1324 | return RTEMS_SUCCESSFUL; |
| 1325 | |
| 1326 | return RTEMS_INVALID_NAME; |
| 1327 | } |
| 1328 | |
| 1329 | /* |
| 1330 | * rtems_capture_watch_set |
| 1331 | * |
| 1332 | * DESCRIPTION: |
| 1333 | * |
| 1334 | * This function allows control of a watch. The watch can be enabled or |
| 1335 | * disabled. |
| 1336 | */ |
| 1337 | rtems_status_code |
| 1338 | rtems_capture_watch_ctrl (rtems_name name, rtems_id id, bool_Bool enable) |
| 1339 | { |
| 1340 | rtems_interrupt_level level; |
| 1341 | rtems_capture_control_t* control; |
| 1342 | bool_Bool found = false0; |
| 1343 | |
| 1344 | /* |
| 1345 | * Find the control and then set the watch. It must exist before it can |
| 1346 | * be controlled. |
| 1347 | */ |
| 1348 | for (control = capture_controls; control != NULL((void*)0); control = control->next) |
| 1349 | { |
| 1350 | if (rtems_capture_match_name_id (control->name, control->id, name, id)) |
| 1351 | { |
| 1352 | rtems_interrupt_disable (level)do { (level) = sparc_disable_interrupts(); asm volatile("" :: : "memory"); } while (0); |
| 1353 | |
| 1354 | if (enable) |
| 1355 | control->flags |= RTEMS_CAPTURE_WATCH(1 << 0); |
| 1356 | else |
| 1357 | control->flags &= ~RTEMS_CAPTURE_WATCH(1 << 0); |
| 1358 | |
| 1359 | rtems_interrupt_enable (level)do { asm volatile("" ::: "memory"); sparc_enable_interrupts( level ); } while (0); |
| 1360 | |
| 1361 | found = true1; |
| 1362 | } |
| 1363 | } |
| 1364 | |
| 1365 | if (found) |
| 1366 | return RTEMS_SUCCESSFUL; |
| 1367 | |
| 1368 | return RTEMS_INVALID_NAME; |
| 1369 | } |
| 1370 | |
| 1371 | /* |
| 1372 | * rtems_capture_watch_global |
| 1373 | * |
| 1374 | * DESCRIPTION: |
| 1375 | * |
| 1376 | * This function allows control of a global watch. The watch can be enabled or |
| 1377 | * disabled. A global watch configures all tasks below the ceiling and above |
| 1378 | * the floor to be traced. |
| 1379 | */ |
| 1380 | rtems_status_code |
| 1381 | rtems_capture_watch_global (bool_Bool enable) |
| 1382 | { |
| 1383 | rtems_interrupt_level level; |
| 1384 | |
| 1385 | rtems_interrupt_disable (level)do { (level) = sparc_disable_interrupts(); asm volatile("" :: : "memory"); } while (0); |
| 1386 | |
| 1387 | /* |
| 1388 | * We need to keep specific and global watches separate so |
| 1389 | * a global enable/disable does not lose a specific watch. |
| 1390 | */ |
| 1391 | if (enable) |
| 1392 | capture_flags |= RTEMS_CAPTURE_GLOBAL_WATCH(1 << 6); |
| 1393 | else |
| 1394 | capture_flags &= ~RTEMS_CAPTURE_GLOBAL_WATCH(1 << 6); |
| 1395 | |
| 1396 | rtems_interrupt_enable (level)do { asm volatile("" ::: "memory"); sparc_enable_interrupts( level ); } while (0); |
| 1397 | |
| 1398 | return RTEMS_SUCCESSFUL; |
| 1399 | } |
| 1400 | |
| 1401 | /* |
| 1402 | * rtems_capture_watch_global_on |
| 1403 | * |
| 1404 | * DESCRIPTION: |
| 1405 | * |
| 1406 | * This function returns the global watch state. |
| 1407 | */ |
| 1408 | bool_Bool |
| 1409 | rtems_capture_watch_global_on (void) |
| 1410 | { |
| 1411 | return capture_flags & RTEMS_CAPTURE_GLOBAL_WATCH(1 << 6) ? 1 : 0; |
| 1412 | } |
| 1413 | |
| 1414 | /* |
| 1415 | * rtems_capture_watch_ceiling |
| 1416 | * |
| 1417 | * DESCRIPTION: |
| 1418 | * |
| 1419 | * This function sets a watch ceiling. Tasks at or greating that the |
| 1420 | * ceiling priority are not watched. This is a simple way to monitor |
| 1421 | * an application and exclude system tasks running at a higher |
| 1422 | * priority level. |
| 1423 | */ |
| 1424 | rtems_status_code |
| 1425 | rtems_capture_watch_ceiling (rtems_task_priority ceiling) |
| 1426 | { |
| 1427 | capture_ceiling = ceiling; |
| 1428 | return RTEMS_SUCCESSFUL; |
| 1429 | } |
| 1430 | |
| 1431 | /* |
| 1432 | * rtems_capture_watch_get_ceiling |
| 1433 | * |
| 1434 | * DESCRIPTION: |
| 1435 | * |
| 1436 | * This function gets the watch ceiling. |
| 1437 | */ |
| 1438 | rtems_task_priority |
| 1439 | rtems_capture_watch_get_ceiling (void) |
| 1440 | { |
| 1441 | return capture_ceiling; |
| 1442 | } |
| 1443 | |
| 1444 | /* |
| 1445 | * rtems_capture_watch_floor |
| 1446 | * |
| 1447 | * DESCRIPTION: |
| 1448 | * |
| 1449 | * This function sets a watch floor. Tasks at or less that the |
| 1450 | * floor priority are not watched. This is a simple way to monitor |
| 1451 | * an application and exclude system tasks running at a lower |
| 1452 | * priority level. |
| 1453 | */ |
| 1454 | rtems_status_code |
| 1455 | rtems_capture_watch_floor (rtems_task_priority floor) |
| 1456 | { |
| 1457 | capture_floor = floor; |
| 1458 | return RTEMS_SUCCESSFUL; |
| 1459 | } |
| 1460 | |
| 1461 | /* |
| 1462 | * rtems_capture_watch_get_floor |
| 1463 | * |
| 1464 | * DESCRIPTION: |
| 1465 | * |
| 1466 | * This function gets the watch floor. |
| 1467 | */ |
| 1468 | rtems_task_priority |
| 1469 | rtems_capture_watch_get_floor (void) |
| 1470 | { |
| 1471 | return capture_floor; |
| 1472 | } |
| 1473 | |
| 1474 | /* |
| 1475 | * rtems_capture_map_trigger |
| 1476 | * |
| 1477 | * DESCRIPTION: |
| 1478 | * |
| 1479 | * Map the trigger to a bit mask. |
| 1480 | * |
| 1481 | */ |
| 1482 | uint32_t |
| 1483 | rtems_capture_map_trigger (rtems_capture_trigger_t trigger) |
| 1484 | { |
| 1485 | /* |
| 1486 | * Transform the mode and trigger to a bit map. |
| 1487 | */ |
| 1488 | switch (trigger) |
| 1489 | { |
| 1490 | case rtems_capture_switch: |
| 1491 | return RTEMS_CAPTURE_SWITCH(1 << 0); |
| 1492 | case rtems_capture_create: |
| 1493 | return RTEMS_CAPTURE_CREATE(1 << 1); |
| 1494 | case rtems_capture_start: |
| 1495 | return RTEMS_CAPTURE_START(1 << 2); |
| 1496 | case rtems_capture_restart: |
| 1497 | return RTEMS_CAPTURE_RESTART(1 << 3); |
| 1498 | case rtems_capture_delete: |
| 1499 | return RTEMS_CAPTURE_DELETE(1 << 4); |
| 1500 | case rtems_capture_begin: |
| 1501 | return RTEMS_CAPTURE_BEGIN(1 << 5); |
| 1502 | case rtems_capture_exitted: |
| 1503 | return RTEMS_CAPTURE_EXITTED(1 << 6); |
| 1504 | default: |
| 1505 | break; |
| 1506 | } |
| 1507 | return 0; |
| 1508 | } |
| 1509 | |
| 1510 | /* |
| 1511 | * rtems_capture_set_trigger |
| 1512 | * |
| 1513 | * DESCRIPTION: |
| 1514 | * |
| 1515 | * This function sets a trigger. |
| 1516 | * |
| 1517 | * This set trigger routine will create a capture control for the |
| 1518 | * target task. The task list is searched and any existing tasks |
| 1519 | * are linked to the new control. |
| 1520 | * |
| 1521 | * We can have a number of tasks that have the same name so we |
| 1522 | * search using names. This means a number of tasks can be |
| 1523 | * linked to single control. |
| 1524 | */ |
| 1525 | rtems_status_code |
| 1526 | rtems_capture_set_trigger (rtems_name from_name, |
| 1527 | rtems_id from_id, |
| 1528 | rtems_name to_name, |
| 1529 | rtems_id to_id, |
| 1530 | rtems_capture_trigger_mode_t mode, |
| 1531 | rtems_capture_trigger_t trigger) |
| 1532 | { |
| 1533 | rtems_capture_control_t* control; |
| 1534 | uint32_t flags; |
| 1535 | |
| 1536 | flags = rtems_capture_map_trigger (trigger); |
| 1537 | |
| 1538 | /* |
| 1539 | * The mode sets the opposite type of trigger. For example |
| 1540 | * FROM ANY means trigger when the event happens TO this |
| 1541 | * task. TO ANY means FROM this task. |
| 1542 | */ |
| 1543 | |
| 1544 | if (mode == rtems_capture_to_any) |
| 1545 | { |
| 1546 | control = rtems_capture_create_control (from_name, from_id); |
| 1547 | if (control == NULL((void*)0)) |
| 1548 | return RTEMS_NO_MEMORY; |
| 1549 | control->from_triggers |= flags & RTEMS_CAPTURE_FROM_TRIGS((1 << 0) | (1 << 1) | (1 << 2) | (1 << 3) | (1 << 4)); |
| 1550 | } |
| 1551 | else |
| 1552 | { |
| 1553 | control = rtems_capture_create_control (to_name, to_id); |
| 1554 | if (control == NULL((void*)0)) |
| 1555 | return RTEMS_NO_MEMORY; |
| 1556 | if (mode == rtems_capture_from_any) |
| 1557 | control->to_triggers |= flags; |
| 1558 | else |
| 1559 | { |
| 1560 | bool_Bool done = false0; |
| 1561 | int i; |
| 1562 | |
| 1563 | control->by_triggers |= flags; |
| 1564 | |
| 1565 | for (i = 0; i < RTEMS_CAPTURE_TRIGGER_TASKS(32); i++) |
| 1566 | { |
| 1567 | if (rtems_capture_control_by_valid (control, i) && |
| 1568 | ((control->by[i].name == from_name) || |
| 1569 | (from_id && (control->by[i].id == from_id)))) |
| 1570 | { |
| 1571 | control->by[i].trigger |= flags; |
| 1572 | done = true1; |
| 1573 | break; |
| 1574 | } |
| 1575 | } |
| 1576 | |
| 1577 | if (!done) |
| 1578 | { |
| 1579 | for (i = 0; i < RTEMS_CAPTURE_TRIGGER_TASKS(32); i++) |
| 1580 | { |
| 1581 | if (!rtems_capture_control_by_valid (control, i)) |
| 1582 | { |
| 1583 | control->by_valid |= RTEMS_CAPTURE_CONTROL_FROM_MASK (i)(1U << ((32) - ((i) + 1))); |
| 1584 | control->by[i].name = from_name; |
| 1585 | control->by[i].id = from_id; |
| 1586 | control->by[i].trigger = flags; |
| 1587 | done = true1; |
| 1588 | break; |
| 1589 | } |
| 1590 | } |
| 1591 | } |
| 1592 | |
| 1593 | if (!done) |
| 1594 | return RTEMS_TOO_MANY; |
| 1595 | } |
| 1596 | } |
| 1597 | return RTEMS_SUCCESSFUL; |
| 1598 | } |
| 1599 | |
| 1600 | /* |
| 1601 | * rtems_capture_clear_trigger |
| 1602 | * |
| 1603 | * DESCRIPTION: |
| 1604 | * |
| 1605 | * This function clear a trigger. |
| 1606 | */ |
| 1607 | rtems_status_code |
| 1608 | rtems_capture_clear_trigger (rtems_name from_name, |
| 1609 | rtems_id from_id, |
| 1610 | rtems_name to_name, |
| 1611 | rtems_id to_id, |
| 1612 | rtems_capture_trigger_mode_t mode, |
| 1613 | rtems_capture_trigger_t trigger) |
| 1614 | { |
| 1615 | rtems_capture_control_t* control; |
| 1616 | uint32_t flags; |
| 1617 | |
| 1618 | flags = rtems_capture_map_trigger (trigger); |
| 1619 | |
| 1620 | if (mode == rtems_capture_to_any) |
| 1621 | { |
| 1622 | control = rtems_capture_find_control (from_name, from_id); |
| 1623 | if (control == NULL((void*)0)) |
| 1624 | { |
| 1625 | if (from_id) |
| 1626 | return RTEMS_INVALID_ID; |
| 1627 | return RTEMS_INVALID_NAME; |
| 1628 | } |
| 1629 | control->from_triggers &= ~flags; |
| 1630 | } |
| 1631 | else |
| 1632 | { |
| 1633 | control = rtems_capture_find_control (to_name, to_id); |
| 1634 | if (control == NULL((void*)0)) |
| 1635 | { |
| 1636 | if (to_id) |
| 1637 | return RTEMS_INVALID_ID; |
| 1638 | return RTEMS_INVALID_NAME; |
| 1639 | } |
| 1640 | if (mode == rtems_capture_from_any) |
| 1641 | control->to_triggers &= ~flags; |
| 1642 | else |
| 1643 | { |
| 1644 | bool_Bool done = false0; |
| 1645 | int i; |
| 1646 | |
| 1647 | control->by_triggers &= ~flags; |
| 1648 | |
| 1649 | for (i = 0; i < RTEMS_CAPTURE_TRIGGER_TASKS(32); i++) |
| 1650 | { |
| 1651 | if (rtems_capture_control_by_valid (control, i) && |
| 1652 | ((control->by[i].name == from_name) || |
| 1653 | (control->by[i].id == from_id))) |
| 1654 | { |
| 1655 | control->by[i].trigger &= ~trigger; |
| 1656 | if (control->by[i].trigger == 0) |
| 1657 | control->by_valid &= ~RTEMS_CAPTURE_CONTROL_FROM_MASK (i)(1U << ((32) - ((i) + 1))); |
| 1658 | done = true1; |
| 1659 | break; |
| 1660 | } |
| 1661 | } |
| 1662 | |
| 1663 | if (!done) |
| 1664 | { |
| 1665 | if (from_id) |
| 1666 | return RTEMS_INVALID_ID; |
| 1667 | return RTEMS_INVALID_NAME; |
| 1668 | } |
| 1669 | } |
| 1670 | } |
| 1671 | return RTEMS_SUCCESSFUL; |
| 1672 | } |
| 1673 | |
| 1674 | /* |
| 1675 | * rtems_capture_read |
| 1676 | * |
| 1677 | * DESCRIPTION: |
| 1678 | * |
| 1679 | * This function reads a number of records from the capture buffer. |
| 1680 | * The user can optionally block and wait until the buffer as a |
| 1681 | * specific number of records available or a specific time has |
| 1682 | * elasped. |
| 1683 | * |
| 1684 | * The function returns the number of record that is has that are |
| 1685 | * in a continous block of memory. If the number of available records |
| 1686 | * wrap then only those records are provided. This removes the need for |
| 1687 | * caller to be concerned about buffer wrappings. If the number of |
| 1688 | * requested records cannot be met due to the wrapping of the records |
| 1689 | * less than the specified number will be returned. |
| 1690 | * |
| 1691 | * The user must release the records. This is achieved with a call to |
| 1692 | * rtems_capture_release. Calls this function without a release will |
| 1693 | * result in at least the same number of records being released. |
| 1694 | * |
| 1695 | * The 'threshold' parameter is the number of records that must be |
| 1696 | * captured before returning. If a timeout period is specified (non-0) |
| 1697 | * any captured records will be returned. These parameters stop |
| 1698 | * thrashing occuring for a small number of records, yet allows |
| 1699 | * a user configured latiency to be applied for single events. |
| 1700 | * |
| 1701 | * The 'timeout' parameter is in micro-seconds. A value of 0 will disable |
| 1702 | * the timeout. |
| 1703 | * |
| 1704 | */ |
| 1705 | rtems_status_code |
| 1706 | rtems_capture_read (uint32_t threshold, |
| 1707 | uint32_t timeout, |
| 1708 | uint32_t* read, |
| 1709 | rtems_capture_record_t** recs) |
| 1710 | { |
| 1711 | rtems_interrupt_level level; |
| 1712 | rtems_status_code sc = RTEMS_SUCCESSFUL; |
| 1713 | uint32_t count; |
| 1714 | |
| 1715 | *read = 0; |
| 1716 | *recs = NULL((void*)0); |
| 1717 | |
| 1718 | rtems_interrupt_disable (level)do { (level) = sparc_disable_interrupts(); asm volatile("" :: : "memory"); } while (0); |
| 1719 | |
| 1720 | /* |
| 1721 | * Only one reader is allowed. |
| 1722 | */ |
| 1723 | |
| 1724 | if (capture_flags & RTEMS_CAPTURE_READER_ACTIVE(1 << 4)) |
| 1725 | { |
| 1726 | rtems_interrupt_enable (level)do { asm volatile("" ::: "memory"); sparc_enable_interrupts( level ); } while (0); |
| 1727 | return RTEMS_RESOURCE_IN_USE; |
| 1728 | } |
| 1729 | |
| 1730 | capture_flags |= RTEMS_CAPTURE_READER_ACTIVE(1 << 4); |
| 1731 | *read = count = capture_count; |
| 1732 | |
| 1733 | rtems_interrupt_enable (level)do { asm volatile("" ::: "memory"); sparc_enable_interrupts( level ); } while (0); |
| 1734 | |
| 1735 | *recs = &capture_records[capture_out]; |
| 1736 | |
| 1737 | for (;;) |
| 1738 | { |
| 1739 | /* |
| 1740 | * See if the count wraps the end of the record buffer. |
| 1741 | */ |
| 1742 | if (count && ((capture_out + count) >= capture_size)) |
| 1743 | *read = capture_size - capture_out; |
| 1744 | |
| 1745 | /* |
| 1746 | * Do we have a threshold and the current count has not wrapped |
| 1747 | * around the end of the capture record buffer ? |
| 1748 | */ |
| 1749 | if ((*read == count) && threshold) |
| 1750 | { |
| 1751 | /* |
| 1752 | * Do we have enough records ? |
| 1753 | */ |
| 1754 | if (*read < threshold) |
| 1755 | { |
| 1756 | rtems_event_set event_out; |
| 1757 | |
| 1758 | rtems_task_ident (RTEMS_SELF((Objects_Id) 0), RTEMS_LOCAL0x00000000, &capture_reader); |
| 1759 | |
| 1760 | rtems_interrupt_disable (level)do { (level) = sparc_disable_interrupts(); asm volatile("" :: : "memory"); } while (0); |
| 1761 | |
| 1762 | capture_flags |= RTEMS_CAPTURE_READER_WAITING(1 << 5); |
| 1763 | |
| 1764 | rtems_interrupt_enable (level)do { asm volatile("" ::: "memory"); sparc_enable_interrupts( level ); } while (0); |
| 1765 | |
| 1766 | sc = rtems_event_receive (RTEMS_EVENT_00x00000001, |
| 1767 | RTEMS_WAIT0x00000000 | RTEMS_EVENT_ANY0x00000002, |
| 1768 | RTEMS_MICROSECONDS_TO_TICKS (timeout)((timeout) / (Configuration.microseconds_per_tick)), |
| 1769 | &event_out); |
| 1770 | |
| 1771 | /* |
| 1772 | * Let the user handle all other sorts of errors. This may |
| 1773 | * not be the best solution, but oh well, it will do for |
| 1774 | * now. |
| 1775 | */ |
| 1776 | if ((sc != RTEMS_SUCCESSFUL) && (sc != RTEMS_TIMEOUT)) |
| 1777 | break; |
| 1778 | |
| 1779 | rtems_interrupt_disable (level)do { (level) = sparc_disable_interrupts(); asm volatile("" :: : "memory"); } while (0); |
| 1780 | |
| 1781 | *read = count = capture_count; |
| 1782 | |
| 1783 | rtems_interrupt_enable (level)do { asm volatile("" ::: "memory"); sparc_enable_interrupts( level ); } while (0); |
| 1784 | |
| 1785 | continue; |
| 1786 | } |
| 1787 | } |
| 1788 | |
| 1789 | /* |
| 1790 | * Always out if we reach here. To loop use continue. |
| 1791 | */ |
| 1792 | break; |
| 1793 | } |
| 1794 | |
| 1795 | return sc; |
| 1796 | } |
| 1797 | |
| 1798 | /* |
| 1799 | * rtems_capture_release |
| 1800 | * |
| 1801 | * DESCRIPTION: |
| 1802 | * |
| 1803 | * This function releases the requested number of record slots back |
| 1804 | * to the capture engine. The count must match the number read. |
| 1805 | */ |
| 1806 | rtems_status_code |
| 1807 | rtems_capture_release (uint32_t count) |
| 1808 | { |
| 1809 | rtems_capture_record_t* rec; |
| 1810 | uint32_t counted; |
| 1811 | |
| 1812 | rtems_interrupt_level level; |
| 1813 | |
| 1814 | rtems_interrupt_disable (level)do { (level) = sparc_disable_interrupts(); asm volatile("" :: : "memory"); } while (0); |
| 1815 | |
| 1816 | if (count > capture_count) |
| 1817 | count = capture_count; |
| 1818 | |
| 1819 | rtems_interrupt_enable (level)do { asm volatile("" ::: "memory"); sparc_enable_interrupts( level ); } while (0); |
| 1820 | |
| 1821 | counted = count; |
| 1822 | |
| 1823 | rec = &capture_records[capture_out]; |
| 1824 | |
| 1825 | while (counted--) |
| 1826 | { |
| 1827 | rtems_capture_refcount_down (rec->task); |
| 1828 | rtems_capture_destroy_capture_task (rec->task); |
| 1829 | rec++; |
| 1830 | } |
| 1831 | |
| 1832 | rtems_interrupt_disable (level)do { (level) = sparc_disable_interrupts(); asm volatile("" :: : "memory"); } while (0); |
| 1833 | |
| 1834 | capture_count -= count; |
| 1835 | |
| 1836 | capture_out = (capture_out + count) % capture_size; |
| 1837 | |
| 1838 | capture_flags &= ~RTEMS_CAPTURE_READER_ACTIVE(1 << 4); |
| 1839 | |
| 1840 | rtems_interrupt_enable (level)do { asm volatile("" ::: "memory"); sparc_enable_interrupts( level ); } while (0); |
| 1841 | |
| 1842 | return RTEMS_SUCCESSFUL; |
| 1843 | } |
| 1844 | |
| 1845 | /* |
| 1846 | * rtems_capture_tick_time |
| 1847 | * |
| 1848 | * DESCRIPTION: |
| 1849 | * |
| 1850 | * This function returns the tick period in nano-seconds. |
| 1851 | */ |
| 1852 | uint32_t |
| 1853 | rtems_capture_tick_time (void) |
| 1854 | { |
| 1855 | return capture_tick_period; |
| 1856 | } |
| 1857 | |
| 1858 | /* |
| 1859 | * rtems_capture_event_text |
| 1860 | * |
| 1861 | * DESCRIPTION: |
| 1862 | * |
| 1863 | * This function returns a string for an event based on the bit in the |
| 1864 | * event. The functions takes the bit offset as a number not the bit |
| 1865 | * set in a bit map. |
| 1866 | */ |
| 1867 | const char* |
| 1868 | rtems_capture_event_text (int event) |
| 1869 | { |
| 1870 | if ((event < RTEMS_CAPTURE_EVENT_START(16)) || (event > RTEMS_CAPTURE_EVENT_END(28))) |
| 1871 | return "invalid event id"; |
| 1872 | return capture_event_text[event - RTEMS_CAPTURE_EVENT_START(16)]; |
| 1873 | } |
| 1874 | |
| 1875 | /* |
| 1876 | * rtems_capture_get_task_list |
| 1877 | * |
| 1878 | * DESCRIPTION: |
| 1879 | * |
| 1880 | * This function returns the head of the list of tasks that the |
| 1881 | * capture engine has detected. |
| 1882 | */ |
| 1883 | rtems_capture_task_t* |
| 1884 | rtems_capture_get_task_list (void) |
| 1885 | { |
| 1886 | return capture_tasks; |
| 1887 | } |
| 1888 | |
| 1889 | /* |
| 1890 | * rtems_capture_task_stack_usage |
| 1891 | * |
| 1892 | * DESCRIPTION: |
| 1893 | * |
| 1894 | * This function updates the stack usage. The task control block |
| 1895 | * is updated. |
| 1896 | */ |
| 1897 | uint32_t |
| 1898 | rtems_capture_task_stack_usage (rtems_capture_task_t* task) |
| 1899 | { |
| 1900 | if (task->tcb) |
| 1901 | { |
| 1902 | uint32_t* st; |
| 1903 | uint32_t* s; |
| 1904 | |
| 1905 | /* |
| 1906 | * @todo: Assumes all stacks move the same way. |
| 1907 | */ |
| 1908 | st = task->tcb->Start.Initial_stack.area + task->stack_size; |
| 1909 | s = task->tcb->Start.Initial_stack.area; |
| 1910 | |
| 1911 | while (s < st) |
| 1912 | { |
| 1913 | if (*s != 0xdeaddead) |
| 1914 | break; |
| 1915 | s++; |
| 1916 | } |
| 1917 | |
| 1918 | task->stack_clean = |
| 1919 | s - (uint32_t*) task->tcb->Start.Initial_stack.area; |
| 1920 | } |
| 1921 | |
| 1922 | return task->stack_clean; |
| 1923 | } |
| 1924 | |
| 1925 | /* |
| 1926 | * rtems_capture_get_control_list |
| 1927 | * |
| 1928 | * DESCRIPTION: |
| 1929 | * |
| 1930 | * This function returns the head of the list of control in the |
| 1931 | * capture engine. |
| 1932 | */ |
| 1933 | rtems_capture_control_t* |
| 1934 | rtems_capture_get_control_list (void) |
| 1935 | { |
| 1936 | return capture_controls; |
| 1937 | } |
