| File: | /home/joel/rtems-4.11-work/build/rtems/c/src/../../cpukit/score/cpu/sparc/cpu.c |
| Description: | Value stored to 'the_size' is never read |
| 1 | /* |
| 2 | * SPARC Dependent Source |
| 3 | * |
| 4 | * COPYRIGHT (c) 1989-2007. |
| 5 | * On-Line Applications Research Corporation (OAR). |
| 6 | * |
| 7 | * The license and distribution terms for this file may be |
| 8 | * found in the file LICENSE in this distribution or at |
| 9 | * http://www.rtems.com/license/LICENSE. |
| 10 | * |
| 11 | * $Id: cpu.c,v 1.30 2010/03/27 15:03:09 joel Exp $ |
| 12 | */ |
| 13 | |
| 14 | #ifdef HAVE_CONFIG_H1 |
| 15 | #include "config.h" |
| 16 | #endif |
| 17 | |
| 18 | #include <rtems/system.h> |
| 19 | #include <rtems/score/isr.h> |
| 20 | #include <rtems/rtems/cache.h> |
| 21 | |
| 22 | /* |
| 23 | * This initializes the set of opcodes placed in each trap |
| 24 | * table entry. The routine which installs a handler is responsible |
| 25 | * for filling in the fields for the _handler address and the _vector |
| 26 | * trap type. |
| 27 | * |
| 28 | * The constants following this structure are masks for the fields which |
| 29 | * must be filled in when the handler is installed. |
| 30 | */ |
| 31 | |
| 32 | const CPU_Trap_table_entry _CPU_Trap_slot_template = { |
| 33 | 0xa1480000, /* mov %psr, %l0 */ |
| 34 | 0x29000000, /* sethi %hi(_handler), %l4 */ |
| 35 | 0x81c52000, /* jmp %l4 + %lo(_handler) */ |
| 36 | 0xa6102000 /* mov _vector, %l3 */ |
| 37 | }; |
| 38 | |
| 39 | /*PAGE |
| 40 | * |
| 41 | * _CPU_Initialize |
| 42 | * |
| 43 | * This routine performs processor dependent initialization. |
| 44 | * |
| 45 | * INPUT PARAMETERS: NONE |
| 46 | * |
| 47 | * Output Parameters: NONE |
| 48 | * |
| 49 | * NOTE: There is no need to save the pointer to the thread dispatch routine. |
| 50 | * The SPARC's assembly code can reference it directly with no problems. |
| 51 | */ |
| 52 | |
| 53 | void _CPU_Initialize(void) |
| 54 | { |
| 55 | #if (SPARC_HAS_FPU1 == 1) |
| 56 | Context_Control_fp *pointer; |
| 57 | |
| 58 | /* |
| 59 | * This seems to be the most appropriate way to obtain an initial |
| 60 | * FP context on the SPARC. The NULL fp context is copied it to |
| 61 | * the task's FP context during Context_Initialize. |
| 62 | */ |
| 63 | |
| 64 | pointer = &_CPU_Null_fp_context; |
| 65 | _CPU_Context_save_fp( &pointer ); |
| 66 | #endif |
| 67 | |
| 68 | /* |
| 69 | * Since no tasks have been created yet and no interrupts have occurred, |
| 70 | * there is no way that the currently executing thread can have an |
| 71 | * _ISR_Dispatch stack frame on its stack. |
| 72 | */ |
| 73 | _CPU_ISR_Dispatch_disable = 0; |
| 74 | } |
| 75 | |
| 76 | /*PAGE |
| 77 | * |
| 78 | * _CPU_ISR_Get_level |
| 79 | * |
| 80 | * Input Parameters: NONE |
| 81 | * |
| 82 | * Output Parameters: |
| 83 | * returns the current interrupt level (PIL field of the PSR) |
| 84 | */ |
| 85 | |
| 86 | uint32_t _CPU_ISR_Get_level( void ) |
| 87 | { |
| 88 | uint32_t level; |
| 89 | |
| 90 | sparc_get_interrupt_level( level )do { register uint32_t _psr_level = 0; do { (_psr_level) = 0; asm volatile( "rd %%psr, %0" : "=r" (_psr_level) : "0" (_psr_level ) ); } while ( 0 ); (level) = (_psr_level & 0x00000F00) >> 8; } while ( 0 ); |
| 91 | |
| 92 | return level; |
| 93 | } |
| 94 | |
| 95 | /*PAGE |
| 96 | * |
| 97 | * _CPU_ISR_install_raw_handler |
| 98 | * |
| 99 | * This routine installs the specified handler as a "raw" non-executive |
| 100 | * supported trap handler (a.k.a. interrupt service routine). |
| 101 | * |
| 102 | * Input Parameters: |
| 103 | * vector - trap table entry number plus synchronous |
| 104 | * vs. asynchronous information |
| 105 | * new_handler - address of the handler to be installed |
| 106 | * old_handler - pointer to an address of the handler previously installed |
| 107 | * |
| 108 | * Output Parameters: NONE |
| 109 | * *new_handler - address of the handler previously installed |
| 110 | * |
| 111 | * NOTE: |
| 112 | * |
| 113 | * On the SPARC, there are really only 256 vectors. However, the executive |
| 114 | * has no easy, fast, reliable way to determine which traps are synchronous |
| 115 | * and which are asynchronous. By default, synchronous traps return to the |
| 116 | * instruction which caused the interrupt. So if you install a software |
| 117 | * trap handler as an executive interrupt handler (which is desirable since |
| 118 | * RTEMS takes care of window and register issues), then the executive needs |
| 119 | * to know that the return address is to the trap rather than the instruction |
| 120 | * following the trap. |
| 121 | * |
| 122 | * So vectors 0 through 255 are treated as regular asynchronous traps which |
| 123 | * provide the "correct" return address. Vectors 256 through 512 are assumed |
| 124 | * by the executive to be synchronous and to require that the return address |
| 125 | * be fudged. |
| 126 | * |
| 127 | * If you use this mechanism to install a trap handler which must reexecute |
| 128 | * the instruction which caused the trap, then it should be installed as |
| 129 | * an asynchronous trap. This will avoid the executive changing the return |
| 130 | * address. |
| 131 | */ |
| 132 | |
| 133 | void _CPU_ISR_install_raw_handler( |
| 134 | uint32_t vector, |
| 135 | proc_ptr new_handler, |
| 136 | proc_ptr *old_handler |
| 137 | ) |
| 138 | { |
| 139 | uint32_t real_vector; |
| 140 | CPU_Trap_table_entry *tbr; |
| 141 | CPU_Trap_table_entry *slot; |
| 142 | uint32_t u32_tbr; |
| 143 | uint32_t u32_handler; |
| 144 | |
| 145 | /* |
| 146 | * Get the "real" trap number for this vector ignoring the synchronous |
| 147 | * versus asynchronous indicator included with our vector numbers. |
| 148 | */ |
| 149 | |
| 150 | real_vector = SPARC_REAL_TRAP_NUMBER( vector )((vector) % 256); |
| 151 | |
| 152 | /* |
| 153 | * Get the current base address of the trap table and calculate a pointer |
| 154 | * to the slot we are interested in. |
| 155 | */ |
| 156 | |
| 157 | sparc_get_tbr( u32_tbr )do { (u32_tbr) = 0; asm volatile( "rd %%tbr, %0" : "=r" (u32_tbr ) : "0" (u32_tbr) ); } while ( 0 ); |
| 158 | |
| 159 | u32_tbr &= 0xfffff000; |
| 160 | |
| 161 | tbr = (CPU_Trap_table_entry *) u32_tbr; |
| 162 | |
| 163 | slot = &tbr[ real_vector ]; |
| 164 | |
| 165 | /* |
| 166 | * Get the address of the old_handler from the trap table. |
| 167 | * |
| 168 | * NOTE: The old_handler returned will be bogus if it does not follow |
| 169 | * the RTEMS model. |
| 170 | */ |
| 171 | |
| 172 | #define HIGH_BITS_MASK0xFFFFFC00 0xFFFFFC00 |
| 173 | #define HIGH_BITS_SHIFT10 10 |
| 174 | #define LOW_BITS_MASK0x000003FF 0x000003FF |
| 175 | |
| 176 | if ( slot->mov_psr_l0 == _CPU_Trap_slot_template.mov_psr_l0 ) { |
| 177 | u32_handler = |
| 178 | (slot->sethi_of_handler_to_l4 << HIGH_BITS_SHIFT10) | |
| 179 | (slot->jmp_to_low_of_handler_plus_l4 & LOW_BITS_MASK0x000003FF); |
| 180 | *old_handler = (proc_ptr) u32_handler; |
| 181 | } else |
| 182 | *old_handler = 0; |
| 183 | |
| 184 | /* |
| 185 | * Copy the template to the slot and then fix it. |
| 186 | */ |
| 187 | |
| 188 | *slot = _CPU_Trap_slot_template; |
| 189 | |
| 190 | u32_handler = (uint32_t) new_handler; |
| 191 | |
| 192 | slot->mov_vector_l3 |= vector; |
| 193 | slot->sethi_of_handler_to_l4 |= |
| 194 | (u32_handler & HIGH_BITS_MASK0xFFFFFC00) >> HIGH_BITS_SHIFT10; |
| 195 | slot->jmp_to_low_of_handler_plus_l4 |= (u32_handler & LOW_BITS_MASK0x000003FF); |
| 196 | |
| 197 | /* need to flush icache after this !!! */ |
| 198 | |
| 199 | rtems_cache_invalidate_entire_instruction(); |
| 200 | |
| 201 | } |
| 202 | |
| 203 | /*PAGE |
| 204 | * |
| 205 | * _CPU_ISR_install_vector |
| 206 | * |
| 207 | * This kernel routine installs the RTEMS handler for the |
| 208 | * specified vector. |
| 209 | * |
| 210 | * Input parameters: |
| 211 | * vector - interrupt vector number |
| 212 | * new_handler - replacement ISR for this vector number |
| 213 | * old_handler - pointer to former ISR for this vector number |
| 214 | * |
| 215 | * Output parameters: |
| 216 | * *old_handler - former ISR for this vector number |
| 217 | * |
| 218 | */ |
| 219 | |
| 220 | void _CPU_ISR_install_vector( |
| 221 | uint32_t vector, |
| 222 | proc_ptr new_handler, |
| 223 | proc_ptr *old_handler |
| 224 | ) |
| 225 | { |
| 226 | uint32_t real_vector; |
| 227 | proc_ptr ignored; |
| 228 | |
| 229 | /* |
| 230 | * Get the "real" trap number for this vector ignoring the synchronous |
| 231 | * versus asynchronous indicator included with our vector numbers. |
| 232 | */ |
| 233 | |
| 234 | real_vector = SPARC_REAL_TRAP_NUMBER( vector )((vector) % 256); |
| 235 | |
| 236 | /* |
| 237 | * Return the previous ISR handler. |
| 238 | */ |
| 239 | |
| 240 | *old_handler = _ISR_Vector_table[ real_vector ]; |
| 241 | |
| 242 | /* |
| 243 | * Install the wrapper so this ISR can be invoked properly. |
| 244 | */ |
| 245 | |
| 246 | _CPU_ISR_install_raw_handler( vector, _ISR_Handler, &ignored ); |
| 247 | |
| 248 | /* |
| 249 | * We put the actual user ISR address in '_ISR_vector_table'. This will |
| 250 | * be used by the _ISR_Handler so the user gets control. |
| 251 | */ |
| 252 | |
| 253 | _ISR_Vector_table[ real_vector ] = new_handler; |
| 254 | } |
| 255 | |
| 256 | /*PAGE |
| 257 | * |
| 258 | * _CPU_Context_Initialize |
| 259 | * |
| 260 | * This kernel routine initializes the basic non-FP context area associated |
| 261 | * with each thread. |
| 262 | * |
| 263 | * Input parameters: |
| 264 | * the_context - pointer to the context area |
| 265 | * stack_base - address of memory for the SPARC |
| 266 | * size - size in bytes of the stack area |
| 267 | * new_level - interrupt level for this context area |
| 268 | * entry_point - the starting execution point for this this context |
| 269 | * is_fp - TRUE if this context is associated with an FP thread |
| 270 | * |
| 271 | * Output parameters: NONE |
| 272 | */ |
| 273 | |
| 274 | void _CPU_Context_Initialize( |
| 275 | Context_Control *the_context, |
| 276 | uint32_t *stack_base, |
| 277 | uint32_t size, |
| 278 | uint32_t new_level, |
| 279 | void *entry_point, |
| 280 | bool_Bool is_fp |
| 281 | ) |
| 282 | { |
| 283 | uint32_t stack_high; /* highest "stack aligned" address */ |
| 284 | uint32_t the_size; |
| 285 | uint32_t tmp_psr; |
| 286 | |
| 287 | /* |
| 288 | * On CPUs with stacks which grow down (i.e. SPARC), we build the stack |
| 289 | * based on the stack_high address. |
| 290 | */ |
| 291 | |
| 292 | stack_high = ((uint32_t)(stack_base) + size); |
| 293 | stack_high &= ~(CPU_STACK_ALIGNMENT16 - 1); |
| 294 | |
| 295 | the_size = size & ~(CPU_STACK_ALIGNMENT16 - 1); |
Value stored to 'the_size' is never read | |
| 296 | |
| 297 | /* |
| 298 | * See the README in this directory for a diagram of the stack. |
| 299 | */ |
| 300 | |
| 301 | the_context->o7 = ((uint32_t) entry_point) - 8; |
| 302 | the_context->o6_sp = stack_high - CPU_MINIMUM_STACK_FRAME_SIZE0x60; |
| 303 | the_context->i6_fp = 0; |
| 304 | |
| 305 | /* |
| 306 | * Build the PSR for the task. Most everything can be 0 and the |
| 307 | * CWP is corrected during the context switch. |
| 308 | * |
| 309 | * The EF bit determines if the floating point unit is available. |
| 310 | * The FPU is ONLY enabled if the context is associated with an FP task |
| 311 | * and this SPARC model has an FPU. |
| 312 | */ |
| 313 | |
| 314 | sparc_get_psr( tmp_psr )do { (tmp_psr) = 0; asm volatile( "rd %%psr, %0" : "=r" (tmp_psr ) : "0" (tmp_psr) ); } while ( 0 ); |
| 315 | tmp_psr &= ~SPARC_PSR_PIL_MASK0x00000F00; |
| 316 | tmp_psr |= (new_level << 8) & SPARC_PSR_PIL_MASK0x00000F00; |
| 317 | tmp_psr &= ~SPARC_PSR_EF_MASK0x00001000; /* disabled by default */ |
| 318 | |
| 319 | #if (SPARC_HAS_FPU1 == 1) |
| 320 | /* |
| 321 | * If this bit is not set, then a task gets a fault when it accesses |
| 322 | * a floating point register. This is a nice way to detect floating |
| 323 | * point tasks which are not currently declared as such. |
| 324 | */ |
| 325 | |
| 326 | if ( is_fp ) |
| 327 | tmp_psr |= SPARC_PSR_EF_MASK0x00001000; |
| 328 | #endif |
| 329 | the_context->psr = tmp_psr; |
| 330 | |
| 331 | /* |
| 332 | * Since THIS thread is being created, there is no way that THIS |
| 333 | * thread can have an _ISR_Dispatch stack frame on its stack. |
| 334 | */ |
| 335 | the_context->isr_dispatch_disable = 0; |
| 336 | } |
