| File: | /home/joel/rtems-4.11-work/build/rtems/c/src/../../cpukit/posix/src/aio_fsync.c |
| Description: | Allocated memory never released. Potential memory leak |
| 1 | /* | ||
| 2 | * Copyright 2010, Alin Rus <alin.codejunkie@gmail.com> | ||
| 3 | * | ||
| 4 | * The license and distribution terms for this file may be | ||
| 5 | * found in the file LICENSE in this distribution or at | ||
| 6 | * http://www.rtems.com/license/LICENSE. | ||
| 7 | * | ||
| 8 | * $Id: aio_fsync.c,v 1.3 2010/08/20 09:08:05 ralf Exp $ | ||
| 9 | */ | ||
| 10 | |||
| 11 | #if HAVE_CONFIG_H1 | ||
| 12 | #include "config.h" | ||
| 13 | #endif | ||
| 14 | |||
| 15 | #include <aio.h> | ||
| 16 | #include <errno(*__errno_location ()).h> | ||
| 17 | #include <stdlib.h> | ||
| 18 | #include <rtems/posix/aio_misc.h> | ||
| 19 | #include <rtems/system.h> | ||
| 20 | #include <rtems/seterr.h> | ||
| 21 | |||
| 22 | /* | ||
| 23 | * aio_fsync | ||
| 24 | * | ||
| 25 | * Asynchronous file synchronization | ||
| 26 | * | ||
| 27 | * Input parameters: | ||
| 28 | * op - O_SYNC | ||
| 29 | * aiocbp - asynchronous I/O control block | ||
| 30 | * | ||
| 31 | * Output parameters: | ||
| 32 | * -1 - request could not pe enqueued | ||
| 33 | * - FD not opened for write | ||
| 34 | * - not enough memory | ||
| 35 | * - op is not O_SYNC | ||
| 36 | * 0 - otherwise | ||
| 37 | */ | ||
| 38 | |||
| 39 | int aio_fsync( | ||
| 40 | int op, | ||
| 41 | struct aiocb *aiocbp | ||
| 42 | ) | ||
| 43 | { | ||
| 44 | rtems_aio_request *req; | ||
| 45 | int mode; | ||
| 46 | |||
| 47 | if (op != O_SYNC04010000) | ||
| 48 | rtems_aio_set_errno_return_minus_one (EINVAL, aiocbp)do { (aiocbp)->error_code = (22); (aiocbp)->return_value = -1; do { (*__errno_location ()) = (22); return -1; } while (0);} while(0); | ||
| 49 | |||
| 50 | mode = fcntl (aiocbp->aio_fildes, F_GETFL3); | ||
| 51 | if (!(((mode & O_ACCMODE0003) == O_WRONLY01) || ((mode & O_ACCMODE0003) == O_RDWR02))) | ||
| 52 | rtems_aio_set_errno_return_minus_one (EBADF, aiocbp)do { (aiocbp)->error_code = (9); (aiocbp)->return_value = -1; do { (*__errno_location ()) = (9); return -1; } while( 0);} while(0); | ||
| 53 | |||
| 54 | req = malloc (sizeof (rtems_aio_request)); | ||
| 55 | if (req == NULL((void *)0)) | ||
| 56 | rtems_aio_set_errno_return_minus_one (EAGAIN, aiocbp)do { (aiocbp)->error_code = (11); (aiocbp)->return_value = -1; do { (*__errno_location ()) = (11); return -1; } while (0);} while(0); | ||
| 57 | |||
| 58 | req->aiocbp = aiocbp; | ||
| 59 | req->aiocbp->aio_lio_opcode = LIO_SYNC3; | ||
| 60 | |||
| 61 | return rtems_aio_enqueue (req); | ||
| 62 | |||
| 63 | } |
