| 1 | |
| 2 | |
| 3 | |
| 4 | |
| 5 | |
| 6 | |
| 7 | |
| 8 | |
| 9 | |
| 10 | |
| 11 | |
| 12 | |
| 13 | |
| 14 | |
| 15 | |
| 16 | |
| 17 | |
| 18 | |
| 19 | |
| 20 | |
| 21 | |
| 22 | |
| 23 | |
| 24 | |
| 25 | |
| 26 | |
| 27 | #ifdef HAVE_CONFIG_H1 |
| 28 | #include "config.h" |
| 29 | #endif |
| 30 | |
| 31 | #include <ctype.h> |
| 32 | #include <stdlib.h> |
| 33 | #include <stdio.h> |
| 34 | #include <string.h> |
| 35 | #include <inttypes.h> |
| 36 | |
| 37 | #include <rtems.h> |
| 38 | #include <rtems/capture-cli.h> |
| 39 | #include <rtems/monitor.h> |
| 40 | |
| 41 | #define RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS(20) (20) |
| 42 | |
| 43 | |
| 44 | |
| 45 | |
| 46 | static rtems_capture_timestamp capture_timestamp; |
| 47 | |
| 48 | |
| 49 | |
| 50 | |
| 51 | static volatile int cli_load_thread_active; |
| 52 | |
| 53 | |
| 54 | |
| 55 | |
| 56 | |
| 57 | |
| 58 | |
| 59 | |
| 60 | |
| 61 | |
| 62 | |
| 63 | static const char* open_usage = "usage: copen [-i] size\n"; |
| 64 | |
| 65 | static void |
| 66 | rtems_capture_cli_open (int argc, |
| 67 | char** argv, |
| 68 | const rtems_monitor_command_arg_t* command_arg __attribute__((unused)), |
| 69 | bool_Bool verbose __attribute__((unused))) |
| 70 | { |
| 71 | uint32_t size = 0; |
| 72 | bool_Bool enable = false0; |
| 73 | rtems_status_code sc; |
| 74 | int arg; |
| 75 | |
| 76 | if (argc <= 1) |
| 77 | { |
| 78 | fprintf (stdoutstdout, open_usage); |
| 79 | return; |
| 80 | } |
| 81 | |
| 82 | for (arg = 1; arg < argc; arg++) |
| 83 | { |
| 84 | if (argv[arg][0] == '-') |
| 85 | { |
| 86 | if (argv[arg][1] == 'i') |
| 87 | enable = true1; |
| 88 | else |
| 89 | fprintf (stdoutstdout, "warning: option -%c ignored\n", argv[arg][1]); |
| 90 | } |
| 91 | else |
| 92 | { |
| 93 | size = strtoul (argv[arg], 0, 0); |
| 94 | |
| 95 | if (size < 100) |
| 96 | { |
| 97 | fprintf (stdoutstdout, "error: size must be greater than or equal to 100\n"); |
| 98 | return; |
| 99 | } |
| 100 | } |
| 101 | } |
| 102 | |
| 103 | sc = rtems_capture_open (size, capture_timestamp); |
| 104 | |
| 105 | if (sc != RTEMS_SUCCESSFUL) |
| 106 | { |
| 107 | fprintf (stdoutstdout, "error: open failed: %s\n", rtems_status_text (sc)); |
| 108 | return; |
| 109 | } |
| 110 | |
| 111 | fprintf (stdoutstdout, "capture engine opened.\n"); |
| 112 | |
| 113 | if (!enable) |
| 114 | return; |
| 115 | |
| 116 | sc = rtems_capture_control (enable); |
| 117 | |
| 118 | if (sc != RTEMS_SUCCESSFUL) |
| 119 | { |
| 120 | fprintf (stdoutstdout, "error: open enable failed: %s\n", rtems_status_text (sc)); |
| 121 | return; |
| 122 | } |
| 123 | |
| 124 | fprintf (stdoutstdout, "capture engine enabled.\n"); |
| 125 | } |
| 126 | |
| 127 | |
| 128 | |
| 129 | |
| 130 | |
| 131 | |
| 132 | |
| 133 | |
| 134 | |
| 135 | |
| 136 | static void |
| 137 | rtems_capture_cli_close (int argc __attribute__((unused)), |
| 138 | char** argv __attribute__((unused)), |
| 139 | const rtems_monitor_command_arg_t* command_arg __attribute__((unused)), |
| 140 | bool_Bool verbose __attribute__((unused))) |
| 141 | { |
| 142 | rtems_status_code sc; |
| 143 | |
| 144 | sc = rtems_capture_close (); |
| 145 | |
| 146 | if (sc != RTEMS_SUCCESSFUL) |
| 147 | { |
| 148 | fprintf (stdoutstdout, "error: close failed: %s\n", rtems_status_text (sc)); |
| 149 | return; |
| 150 | } |
| 151 | |
| 152 | fprintf (stdoutstdout, "capture engine closed.\n"); |
| 153 | } |
| 154 | |
| 155 | |
| 156 | |
| 157 | |
| 158 | |
| 159 | |
| 160 | |
| 161 | |
| 162 | |
| 163 | |
| 164 | static void |
| 165 | rtems_capture_cli_enable (int argc __attribute__((unused)), |
| 166 | char** argv __attribute__((unused)), |
| 167 | const rtems_monitor_command_arg_t* command_arg __attribute__((unused)), |
| 168 | bool_Bool verbose __attribute__((unused))) |
| 169 | { |
| 170 | rtems_status_code sc; |
| 171 | |
| 172 | sc = rtems_capture_control (1); |
| 173 | |
| 174 | if (sc != RTEMS_SUCCESSFUL) |
| 175 | { |
| 176 | fprintf (stdoutstdout, "error: enable failed: %s\n", rtems_status_text (sc)); |
| 177 | return; |
| 178 | } |
| 179 | |
| 180 | fprintf (stdoutstdout, "capture engine enabled.\n"); |
| 181 | } |
| 182 | |
| 183 | |
| 184 | |
| 185 | |
| 186 | |
| 187 | |
| 188 | |
| 189 | |
| 190 | |
| 191 | |
| 192 | static void |
| 193 | rtems_capture_cli_disable (int argc __attribute__((unused)), |
| 194 | char** argv __attribute__((unused)), |
| 195 | const rtems_monitor_command_arg_t* command_arg __attribute__((unused)), |
| 196 | bool_Bool verbose __attribute__((unused))) |
| 197 | { |
| 198 | rtems_status_code sc; |
| 199 | |
| 200 | sc = rtems_capture_control (0); |
| 201 | |
| 202 | if (sc != RTEMS_SUCCESSFUL) |
| 203 | { |
| 204 | fprintf (stdoutstdout, "error: disable failed: %s\n", rtems_status_text (sc)); |
| 205 | return; |
| 206 | } |
| 207 | |
| 208 | fprintf (stdoutstdout, "capture engine disabled.\n"); |
| 209 | } |
| 210 | |
| 211 | |
| 212 | |
| 213 | |
| 214 | |
| 215 | |
| 216 | |
| 217 | |
| 218 | |
| 219 | |
| 220 | static void |
| 221 | rtems_capture_cli_task_list (int argc __attribute__((unused)), |
| 222 | char** argv __attribute__((unused)), |
| 223 | const rtems_monitor_command_arg_t* command_arg __attribute__((unused)), |
| 224 | bool_Bool verbose __attribute__((unused))) |
| 225 | { |
| 226 | rtems_task_priority ceiling = rtems_capture_watch_get_ceiling (); |
| 227 | rtems_task_priority floor = rtems_capture_watch_get_floor (); |
| 228 | rtems_capture_task_t* task = rtems_capture_get_task_list (); |
| 229 | uint32_t ticks; |
| 230 | uint32_t tick_offset; |
| 231 | unsigned long long total_time; |
| 232 | int count = rtems_capture_task_count (); |
| 233 | |
| 234 | if (capture_timestamp) |
| 235 | capture_timestamp (&ticks, &tick_offset); |
| 236 | else |
| 237 | { |
| 238 | ticks = _Watchdog_Ticks_since_boot; |
| 239 | tick_offset = 0; |
| 240 | } |
| 241 | |
| 242 | fprintf (stdoutstdout, "total %i\n", count); |
| 243 | |
| 244 | while (task) |
| 245 | { |
| 246 | rtems_task_priority priority; |
| 247 | int32_t stack_used; |
| 248 | int32_t time_used; |
| 249 | |
| 250 | stack_used = rtems_capture_task_stack_usage (task); |
| 251 | if (stack_used) |
| 252 | stack_used = (stack_used * 100) / stack_used; |
| 253 | |
| 254 | if (stack_used > 100) |
| 255 | stack_used = 100; |
| 256 | |
| 257 | total_time = (ticks * rtems_capture_task_time (task)) + tick_offset; |
| 258 | |
| 259 | time_used = (rtems_capture_task_time (task) * 100) / total_time; |
| 260 | |
| 261 | if (time_used > 100) |
| 262 | time_used = 100; |
| 263 | |
| 264 | priority = rtems_capture_task_real_priority (task); |
| 265 | |
| 266 | fprintf (stdoutstdout, " "); |
| 267 | rtems_monitor_dump_id (rtems_capture_task_id (task)); |
| 268 | fprintf (stdoutstdout, " "); |
| 269 | rtems_monitor_dump_name (rtems_capture_task_name (task)); |
| 270 | fprintf (stdoutstdout, " "); |
| 271 | rtems_monitor_dump_priority (rtems_capture_task_start_priority (task)); |
| 272 | fprintf (stdoutstdout, " "); |
| 273 | rtems_monitor_dump_priority (rtems_capture_task_real_priority (task)); |
| 274 | fprintf (stdoutstdout, " "); |
| 275 | rtems_monitor_dump_priority (rtems_capture_task_curr_priority (task)); |
| 276 | fprintf (stdoutstdout, " "); |
| 277 | rtems_monitor_dump_state (rtems_capture_task_state (task)); |
| 278 | fprintf (stdoutstdout, " %c%c", |
| 279 | rtems_capture_task_valid (task) ? 'a' : 'd', |
| 280 | rtems_capture_task_flags (task) & RTEMS_CAPTURE_TRACED(1 << 0) ? 't' : '-'); |
| 281 | |
| 282 | if ((floor > ceiling) && (ceiling > priority)) |
| 283 | fprintf (stdoutstdout, "--"); |
| 284 | else |
| 285 | { |
| 286 | uint32_t flags = rtems_capture_task_control_flags (task); |
| 287 | fprintf (stdoutstdout, "%c%c", |
| 288 | rtems_capture_task_control (task) ? |
| 289 | (flags & RTEMS_CAPTURE_WATCH(1 << 0) ? 'w' : '+') : '-', |
| 290 | rtems_capture_watch_global_on () ? 'g' : '-'); |
| 291 | } |
| 292 | fprintf (stdoutstdout, " %3" PRId32"d" "%% %3" PRId32"d" "%% (%" PRIu32"u" ")\n", |
| 293 | stack_used, time_used, rtems_capture_task_ticks (task)); |
| 294 | |
| 295 | task = rtems_capture_next_task (task); |
| 296 | } |
| 297 | } |
| 298 | |
| 299 | |
| 300 | |
| 301 | |
| 302 | |
| 303 | |
| 304 | |
| 305 | |
| 306 | |
| 307 | |
| 308 | static void |
| 309 | rtems_capture_cli_task_load_thread (rtems_task_argument arg __attribute__((unused))) |
| 310 | { |
| 311 | rtems_task_priority ceiling = rtems_capture_watch_get_ceiling (); |
| 312 | rtems_task_priority floor = rtems_capture_watch_get_floor (); |
| 313 | int last_count = 0; |
| 314 | |
| 315 | for (;;) |
| 1 | Loop condition is true. Entering loop body |
| 316 | { |
| 317 | rtems_capture_task_t* tasks[RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS(20) + 1]; |
| 318 | unsigned long long load[RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS(20) + 1]; |
| 319 | rtems_capture_task_t* task; |
| 320 | unsigned long long total_time; |
| 321 | int count = 0; |
| 322 | int i; |
| 323 | int j; |
| 324 | |
| 325 | cli_load_thread_active = 1; |
| 326 | |
| 327 | |
| 328 | |
| 329 | |
| 330 | |
| 331 | |
| 332 | |
| 333 | memset (tasks, 0, sizeof (tasks)); |
| 334 | memset (load, 0, sizeof (load)); |
| 335 | |
| 336 | task = rtems_capture_get_task_list (); |
| 337 | |
| 338 | total_time = 0; |
| 2 | The value 0 is assigned to 'total_time' |
| 339 | |
| 340 | while (task) |
| 3 | Loop condition is false. Execution continues on line 372 |
| 341 | { |
| 342 | if (rtems_capture_task_valid (task)) |
| 343 | { |
| 344 | unsigned long long l = rtems_capture_task_delta_time (task); |
| 345 | |
| 346 | count++; |
| 347 | |
| 348 | total_time += l; |
| 349 | |
| 350 | for (i = 0; i < RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS(20); i++) |
| 351 | { |
| 352 | if (tasks[i]) |
| 353 | { |
| 354 | if ((l == 0) || (l < load[i])) |
| 355 | continue; |
| 356 | |
| 357 | for (j = (RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS(20) - 1); j >= i; j--) |
| 358 | { |
| 359 | tasks[j + 1] = tasks[j]; |
| 360 | load[j + 1] = load[j]; |
| 361 | } |
| 362 | } |
| 363 | |
| 364 | tasks[i] = task; |
| 365 | load[i] = l; |
| 366 | break; |
| 367 | } |
| 368 | } |
| 369 | task = rtems_capture_next_task (task); |
| 370 | } |
| 371 | |
| 372 | fprintf (stdoutstdout, "\x1b[H\x1b[J Press ENTER to exit.\n\n"); |
| 373 | fprintf (stdoutstdout, |
| 374 | " PID NAME RPRI CPRI STATE %%CPU %%STK FLGS EXEC TIME\n"); |
| 375 | |
| 376 | if (count > last_count) |
| 377 | j = count; |
| 378 | else |
| 379 | j = last_count; |
| 380 | |
| 381 | for (i = 0; i < RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS(20); i++) |
| 5 | Loop condition is true. Entering loop body |
| 382 | { |
| 383 | rtems_task_priority priority; |
| 384 | int stack_used; |
| 385 | int task_load; |
| 386 | int k; |
| 387 | |
| 388 | if (!tasks[i]) |
| 389 | break; |
| 390 | |
| 391 | j--; |
| 392 | |
| 393 | stack_used = rtems_capture_task_stack_usage (tasks[i]); |
| 394 | if (stack_used) |
| 395 | stack_used = (stack_used * 100) / stack_used; |
| 396 | |
| 397 | if (stack_used > 100) |
| 398 | stack_used = 100; |
| 399 | |
| 400 | task_load = (int) ((load[i] * 100000) / total_time); |
| 401 | |
| 402 | priority = rtems_capture_task_real_priority (tasks[i]); |
| 403 | |
| 404 | fprintf (stdoutstdout, "\x1b[K"); |
| 405 | rtems_monitor_dump_id (rtems_capture_task_id (tasks[i])); |
| 406 | fprintf (stdoutstdout, " "); |
| 407 | rtems_monitor_dump_name (rtems_capture_task_name (tasks[i])); |
| 408 | fprintf (stdoutstdout, " "); |
| 409 | rtems_monitor_dump_priority (priority); |
| 410 | fprintf (stdoutstdout, " "); |
| 411 | rtems_monitor_dump_priority (rtems_capture_task_curr_priority (tasks[i])); |
| 412 | fprintf (stdoutstdout, " "); |
| 413 | k = rtems_monitor_dump_state (rtems_capture_task_state (tasks[i])); |
| 414 | fprintf (stdoutstdout, "%*c %3i.%03i%% ", 6 - k, ' ', |
| 415 | task_load / 1000, task_load % 1000); |
| 416 | fprintf (stdoutstdout, "%3i%% %c%c", stack_used, |
| 417 | rtems_capture_task_valid (tasks[i]) ? 'a' : 'd', |
| 418 | rtems_capture_task_flags (tasks[i]) & RTEMS_CAPTURE_TRACED(1 << 0) ? 't' : '-'); |
| 419 | |
| 420 | if ((floor > ceiling) && (ceiling > priority)) |
| 421 | fprintf (stdoutstdout, "--"); |
| 422 | else |
| 423 | fprintf (stdoutstdout, "%c%c", |
| 424 | rtems_capture_task_control (tasks[i]) ? |
| 425 | (rtems_capture_task_control_flags (tasks[i]) & |
| 426 | RTEMS_CAPTURE_WATCH(1 << 0) ? 'w' : '+') : '-', |
| 427 | rtems_capture_watch_global_on () ? 'g' : '-'); |
| 428 | |
| 429 | fprintf (stdoutstdout, " %qi\n", rtems_capture_task_time (tasks[i])); |
| 430 | } |
| 431 | |
| 432 | if (count < RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS(20)) |
| 433 | { |
| 434 | j = RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS(20) - count; |
| 435 | while (j > 0) |
| 436 | { |
| 437 | fprintf (stdoutstdout, "\x1b[K\n"); |
| 438 | j--; |
| 439 | } |
| 440 | } |
| 441 | |
| 442 | last_count = count; |
| 443 | |
| 444 | cli_load_thread_active = 0; |
| 445 | |
| 446 | rtems_task_wake_after (RTEMS_MICROSECONDS_TO_TICKS (5000000)((5000000) / (Configuration.microseconds_per_tick))); |
| 447 | } |
| 448 | } |
| 449 | |
| 450 | |
| 451 | |
| 452 | |
| 453 | |
| 454 | |
| 455 | |
| 456 | |
| 457 | |
| 458 | |
| 459 | static void |
| 460 | rtems_capture_cli_task_load (int argc __attribute__((unused)), |
| 461 | char** argv __attribute__((unused)), |
| 462 | const rtems_monitor_command_arg_t* command_arg __attribute__((unused)), |
| 463 | bool_Bool verbose __attribute__((unused))) |
| 464 | { |
| 465 | rtems_status_code sc; |
| 466 | rtems_task_priority priority; |
| 467 | rtems_name name; |
| 468 | rtems_id id; |
| 469 | |
| 470 | sc = rtems_task_set_priority (RTEMS_SELF((Objects_Id) 0), RTEMS_CURRENT_PRIORITY0, &priority); |
| 471 | |
| 472 | if (sc != RTEMS_SUCCESSFUL) |
| 473 | { |
| 474 | fprintf (stdoutstdout, "error: cannot obtain the current priority: %s\n", |
| 475 | rtems_status_text (sc)); |
| 476 | return; |
| 477 | } |
| 478 | |
| 479 | name = rtems_build_name('C', 'P', 'l', 't')( (uint32_t)('C') << 24 | (uint32_t)('P') << 16 | (uint32_t)('l') << 8 | (uint32_t)('t') ); |
| 480 | |
| 481 | sc = rtems_task_create (name, priority, 4 * 1024, |
| 482 | RTEMS_NO_FLOATING_POINT0x00000000 | RTEMS_LOCAL0x00000000, |
| 483 | RTEMS_PREEMPT0x00000000 | RTEMS_TIMESLICE0x00000200 | RTEMS_NO_ASR0x00000400, |
| 484 | &id); |
| 485 | |
| 486 | if (sc != RTEMS_SUCCESSFUL) |
| 487 | { |
| 488 | fprintf (stdoutstdout, "error: cannot create helper thread: %s\n", |
| 489 | rtems_status_text (sc)); |
| 490 | return; |
| 491 | } |
| 492 | |
| 493 | sc = rtems_task_start (id, rtems_capture_cli_task_load_thread, 0); |
| 494 | |
| 495 | if (sc != RTEMS_SUCCESSFUL) |
| 496 | { |
| 497 | fprintf (stdoutstdout, "error: cannot start helper thread: %s\n", |
| 498 | rtems_status_text (sc)); |
| 499 | rtems_task_delete (id); |
| 500 | return; |
| 501 | } |
| 502 | |
| 503 | for (;;) |
| 504 | { |
| 505 | int c = getchar (); |
| 506 | |
| 507 | if ((c == '\r') || (c == '\n')) |
| 508 | { |
| 509 | int loops = 20; |
| 510 | |
| 511 | while (loops && cli_load_thread_active) |
| 512 | rtems_task_wake_after (RTEMS_MICROSECONDS_TO_TICKS (100000)((100000) / (Configuration.microseconds_per_tick))); |
| 513 | |
| 514 | rtems_task_delete (id); |
| 515 | |
| 516 | fprintf (stdoutstdout, "load monitoring stopped.\n"); |
| 517 | |
| 518 | return; |
| 519 | } |
| 520 | } |
| 521 | } |
| 522 | |
| 523 | |
| 524 | |
| 525 | |
| 526 | |
| 527 | |
| 528 | |
| 529 | |
| 530 | |
| 531 | |
| 532 | static void |
| 533 | rtems_capture_cli_watch_list (int argc __attribute__((unused)), |
| 534 | char** argv __attribute__((unused)), |
| 535 | const rtems_monitor_command_arg_t* command_arg __attribute__((unused)), |
| 536 | bool_Bool verbose __attribute__((unused))) |
| 537 | { |
| 538 | rtems_capture_control_t* control = rtems_capture_get_control_list (); |
| 539 | rtems_task_priority ceiling = rtems_capture_watch_get_ceiling (); |
| 540 | rtems_task_priority floor = rtems_capture_watch_get_floor (); |
| 541 | |
| 542 | fprintf (stdoutstdout, "watch priority ceiling is %" PRId32"d" "\n", ceiling); |
| 543 | fprintf (stdoutstdout, "watch priority floor is %" PRId32"d" "\n", floor); |
| 544 | fprintf (stdoutstdout, "global watch is %s\n", |
| 545 | rtems_capture_watch_global_on () ? "enabled" : "disabled"); |
| 546 | fprintf (stdoutstdout, "total %" PRId32"d" "\n", rtems_capture_control_count ()); |
| 547 | |
| 548 | while (control) |
| 549 | { |
| 550 | uint32_t flags; |
| 551 | int f; |
| 552 | int fshowed; |
| 553 | int lf; |
| 554 | |
| 555 | fprintf (stdoutstdout, " "); |
| 556 | rtems_monitor_dump_id (rtems_capture_control_id (control)); |
| 557 | fprintf (stdoutstdout, " "); |
| 558 | rtems_monitor_dump_name (rtems_capture_control_name (control)); |
| 559 | flags = rtems_capture_control_flags (control); |
| 560 | fprintf (stdoutstdout, " %c%c ", |
| 561 | rtems_capture_watch_global_on () ? 'g' : '-', |
| 562 | flags & RTEMS_CAPTURE_WATCH(1 << 0) ? 'w' : '-'); |
| 563 | flags = rtems_capture_control_to_triggers (control); |
| 564 | fprintf (stdoutstdout, " T:%c%c%c%c%c%c%c", |
| 565 | flags & RTEMS_CAPTURE_SWITCH(1 << 0) ? 'S' : '-', |
| 566 | flags & RTEMS_CAPTURE_CREATE(1 << 1) ? 'C' : '-', |
| 567 | flags & RTEMS_CAPTURE_START(1 << 2) ? 'S' : '-', |
| 568 | flags & RTEMS_CAPTURE_RESTART(1 << 3) ? 'R' : '-', |
| 569 | flags & RTEMS_CAPTURE_DELETE(1 << 4) ? 'D' : '-', |
| 570 | flags & RTEMS_CAPTURE_BEGIN(1 << 5) ? 'B' : '-', |
| 571 | flags & RTEMS_CAPTURE_EXITTED(1 << 6) ? 'E' : '-'); |
| 572 | flags = rtems_capture_control_from_triggers (control); |
| 573 | fprintf (stdoutstdout, " F:%c%c%c%c%c", |
| 574 | flags & RTEMS_CAPTURE_SWITCH(1 << 0) ? 'S' : '-', |
| 575 | flags & RTEMS_CAPTURE_CREATE(1 << 1) ? 'C' : '-', |
| 576 | flags & RTEMS_CAPTURE_START(1 << 2) ? 'S' : '-', |
| 577 | flags & RTEMS_CAPTURE_RESTART(1 << 3) ? 'R' : '-', |
| 578 | flags & RTEMS_CAPTURE_DELETE(1 << 4) ? 'D' : '-'); |
| 579 | |
| 580 | for (f = 0, fshowed = 0, lf = 1; f < RTEMS_CAPTURE_TRIGGER_TASKS(32); f++) |
| 581 | { |
| 582 | if (rtems_capture_control_by_valid (control, f)) |
| 583 | { |
| 584 | if (lf && ((fshowed % 3) == 0)) |
| 585 | { |
| 586 | fprintf (stdoutstdout, "\n"); |
| 587 | lf = 0; |
| 588 | } |
| 589 | |
| 590 | fprintf (stdoutstdout, " %2i:", f); |
| 591 | rtems_monitor_dump_name (rtems_capture_control_by_name (control, f)); |
| 592 | fprintf (stdoutstdout, "/"); |
| 593 | rtems_monitor_dump_id (rtems_capture_control_by_id (control, f)); |
| 594 | flags = rtems_capture_control_by_triggers (control, f); |
| 595 | fprintf (stdoutstdout, ":%c%c%c%c%c", |
| 596 | flags & RTEMS_CAPTURE_SWITCH(1 << 0) ? 'S' : '-', |
| 597 | flags & RTEMS_CAPTURE_CREATE(1 << 1) ? 'C' : '-', |
| 598 | flags & RTEMS_CAPTURE_START(1 << 2) ? 'S' : '-', |
| 599 | flags & RTEMS_CAPTURE_RESTART(1 << 3) ? 'R' : '-', |
| 600 | flags & RTEMS_CAPTURE_DELETE(1 << 4) ? 'D' : '-'); |
| 601 | fshowed++; |
| 602 | lf = 1; |
| 603 | } |
| 604 | } |
| 605 | |
| 606 | if (lf) |
| 607 | fprintf (stdoutstdout, "\n"); |
| 608 | |
| 609 | control = rtems_capture_next_control (control); |
| 610 | } |
| 611 | } |
| 612 | |
| 613 | |
| 614 | |
| 615 | |
| 616 | |
| 617 | |
| 618 | |
| 619 | |
| 620 | |
| 621 | |
| 622 | static bool_Bool |
| 623 | rtems_capture_cli_get_name_id (char* arg, |
| 624 | bool_Bool* valid_name, |
| 625 | bool_Bool* valid_id, |
| 626 | rtems_name* name, |
| 627 | rtems_id* id) |
| 628 | { |
| 629 | size_t l; |
| 630 | size_t i; |
| 631 | |
| 632 | if (*valid_name && *valid_id) |
| 633 | { |
| 634 | fprintf (stdoutstdout, "error: too many arguments\n"); |
| 635 | return 0; |
| 636 | } |
| 637 | |
| 638 | |
| 639 | |
| 640 | |
| 641 | |
| 642 | l = strlen (arg); |
| 643 | |
| 644 | for (i = 0; i < l; i++) |
| 645 | if (!isxdigit ((unsigned char)arg[i])((*__ctype_b_loc ())[(int) (((unsigned char)arg[i]))] & ( unsigned short int) _ISxdigit)) |
| 646 | break; |
| 647 | |
| 648 | if (i == l) |
| 649 | { |
| 650 | *id = strtoul (arg, 0, 16); |
| 651 | *valid_id = true1; |
| 652 | } |
| 653 | else |
| 654 | { |
| 655 | |
| 656 | |
| 657 | |
| 658 | |
| 659 | |
| 660 | |
| 661 | |
| 662 | rtems_name rname; |
| 663 | |
| 664 | rname = rtems_build_name(arg[0], arg[1], arg[2], arg[3])( (uint32_t)(arg[0]) << 24 | (uint32_t)(arg[1]) << 16 | (uint32_t)(arg[2]) << 8 | (uint32_t)(arg[3]) ); |
| 665 | *name = rname; |
| 666 | *valid_name = true1; |
| 667 | } |
| 668 | |
| 669 | return 1; |
| 670 | } |
| 671 | |
| 672 | |
| 673 | |
| 674 | |
| 675 | |
| 676 | |
| 677 | |
| 678 | |
| 679 | |
| 680 | |
| 681 | |
| 682 | static char const * watch_add_usage = "usage: cwadd [task name] [id]\n"; |
| 683 | |
| 684 | static void |
| 685 | rtems_capture_cli_watch_add (int argc, |
| 686 | char** argv, |
| 687 | const rtems_monitor_command_arg_t* command_arg __attribute__((unused)), |
| 688 | bool_Bool verbose __attribute__((unused))) |
| 689 | { |
| 690 | rtems_status_code sc; |
| 691 | int arg; |
| 692 | rtems_name name = 0; |
| 693 | rtems_id id = 0; |
| 694 | bool_Bool valid_name = false0; |
| 695 | bool_Bool valid_id = false0; |
| 696 | |
| 697 | if (argc <= 1) |
| 698 | { |
| 699 | fprintf (stdoutstdout, watch_add_usage); |
| 700 | return; |
| 701 | } |
| 702 | |
| 703 | for (arg = 1; arg < argc; arg++) |
| 704 | { |
| 705 | if (argv[arg][0] == '-') |
| 706 | { |
| 707 | fprintf (stdoutstdout, "warning: option -%c ignored\n", argv[arg][1]); |
| 708 | } |
| 709 | else |
| 710 | { |
| 711 | if (!rtems_capture_cli_get_name_id (argv[arg], &valid_name, &valid_id, |
| 712 | &name, &id)) |
| 713 | return; |
| 714 | } |
| 715 | } |
| 716 | |
| 717 | if (!valid_name && !valid_id) |
| 718 | { |
| 719 | fprintf (stdoutstdout, "error: no valid name or task id located\n"); |
| 720 | return; |
| 721 | } |
| 722 | |
| 723 | sc = rtems_capture_watch_add (name, id); |
| 724 | |
| 725 | if (sc != RTEMS_SUCCESSFUL) |
| 726 | { |
| 727 | fprintf (stdoutstdout, |
| 728 | "error: watch add failed: %s\n", rtems_status_text (sc)); |
| 729 | return; |
| 730 | } |
| 731 | |
| 732 | fprintf (stdoutstdout, "watch added.\n"); |
| 733 | } |
| 734 | |
| 735 | |
| 736 | |
| 737 | |
| 738 | |
| 739 | |
| 740 | |
| 741 | |
| 742 | |
| 743 | |
| 744 | |
| 745 | static char const * watch_del_usage = "usage: cwdel [task name] [id]\n"; |
| 746 | |
| 747 | static void |
| 748 | rtems_capture_cli_watch_del (int argc, |
| 749 | char** argv, |
| 750 | const rtems_monitor_command_arg_t* command_arg __attribute__((unused)), |
| 751 | bool_Bool verbose __attribute__((unused))) |
| 752 | { |
| 753 | rtems_status_code sc; |
| 754 | int arg; |
| 755 | rtems_name name = 0; |
| 756 | rtems_id id = 0; |
| 757 | bool_Bool valid_name = false0; |
| 758 | bool_Bool valid_id = false0; |
| 759 | |
| 760 | if (argc <= 1) |
| 761 | { |
| 762 | fprintf (stdoutstdout, watch_del_usage); |
| 763 | return; |
| 764 | } |
| 765 | |
| 766 | for (arg = 1; arg < argc; arg++) |
| 767 | { |
| 768 | if (argv[arg][0] == '-') |
| 769 | { |
| 770 | fprintf (stdoutstdout, "warning: option -%c ignored\n", argv[arg][1]); |
| 771 | } |
| 772 | else |
| 773 | { |
| 774 | if (!rtems_capture_cli_get_name_id (argv[arg], &valid_name, &valid_id, |
| 775 | &name, &id)) |
| 776 | return; |
| 777 | } |
| 778 | } |
| 779 | |
| 780 | if (!valid_name && !valid_id) |
| 781 | { |
| 782 | fprintf (stdoutstdout, "error: no valid name or task id located\n"); |
| 783 | return; |
| 784 | } |
| 785 | |
| 786 | sc = rtems_capture_watch_del (name, id); |
| 787 | |
| 788 | if (sc != RTEMS_SUCCESSFUL) |
| 789 | { |
| 790 | fprintf (stdoutstdout, "error: watch delete failed: %s\n", |
| 791 | rtems_status_text (sc)); |
| 792 | return; |
| 793 | } |
| 794 | |
| 795 | fprintf (stdoutstdout, "watch delete.\n"); |
| 796 | } |
| 797 | |
| 798 | |
| 799 | |
| 800 | |
| 801 | |
| 802 | |
| 803 | |
| 804 | |
| 805 | |
| 806 | |
| 807 | static char const * watch_control_usage = "usage: cwctl [task name] [id] on/off\n"; |
| 808 | |
| 809 | static void |
| 810 | rtems_capture_cli_watch_control (int argc, |
| 811 | char** argv, |
| 812 | const rtems_monitor_command_arg_t* command_arg __attribute__((unused)), |
| 813 | bool_Bool verbose __attribute__((unused))) |
| 814 | { |
| 815 | rtems_status_code sc; |
| 816 | int arg; |
| 817 | rtems_name name = 0; |
| 818 | rtems_id id = 0; |
| 819 | bool_Bool valid_name = false0; |
| 820 | bool_Bool valid_id = false0; |
| 821 | bool_Bool enable = false0; |
| 822 | |
| 823 | if (argc <= 2) |
| 824 | { |
| 825 | fprintf (stdoutstdout, watch_control_usage); |
| 826 | return; |
| 827 | } |
| 828 | |
| 829 | for (arg = 1; arg < argc; arg++) |
| 830 | { |
| 831 | if (argv[arg][0] == '-') |
| 832 | { |
| 833 | fprintf (stdoutstdout, "warning: option -%c ignored\n", argv[arg][1]); |
| 834 | } |
| 835 | else |
| 836 | { |
| 837 | if (strcmp (argv[arg], "on") == 0) |
| 838 | enable = true1; |
| 839 | else if (strcmp (argv[arg], "off") == 0) |
| 840 | enable = false0; |
| 841 | else if (!rtems_capture_cli_get_name_id (argv[arg], &valid_name, |
| 842 | &valid_id, &name, &id)) |
| 843 | return; |
| 844 | } |
| 845 | } |
| 846 | |
| 847 | if (!valid_name && !valid_id) |
| 848 | { |
| 849 | fprintf (stdoutstdout, "error: no valid name or task id located\n"); |
| 850 | return; |
| 851 | } |
| 852 | |
| 853 | sc = rtems_capture_watch_ctrl (name, id, enable); |
| 854 | |
| 855 | if (sc != RTEMS_SUCCESSFUL) |
| 856 | { |
| 857 | fprintf (stdoutstdout, "error: watch control failed: %s\n", |
| 858 | rtems_status_text (sc)); |
| 859 | return; |
| 860 | } |
| 861 | |
| 862 | fprintf (stdoutstdout, "watch %s.\n", enable ? "enabled" : "disabled"); |
| 863 | } |
| 864 | |
| 865 | |
| 866 | |
| 867 | |
| 868 | |
| 869 | |
| 870 | |
| 871 | |
| 872 | |
| 873 | |
| 874 | static char const * watch_global_usage = "usage: cwglob on/off\n"; |
| 875 | |
| 876 | static void |
| 877 | rtems_capture_cli_watch_global (int argc, |
| 878 | char** argv, |
| 879 | const rtems_monitor_command_arg_t* command_arg __attribute__((unused)), |
| 880 | bool_Bool verbose __attribute__((unused))) |
| 881 | { |
| 882 | rtems_status_code sc; |
| 883 | int arg; |
| 884 | bool_Bool enable = false0; |
| 885 | |
| 886 | if (argc <= 1) |
| 887 | { |
| 888 | fprintf (stdoutstdout, watch_global_usage); |
| 889 | return; |
| 890 | } |
| 891 | |
| 892 | for (arg = 1; arg < argc; arg++) |
| 893 | { |
| 894 | if (argv[arg][0] == '-') |
| 895 | { |
| 896 | fprintf (stdoutstdout, "warning: option -%c ignored\n", argv[arg][1]); |
| 897 | } |
| 898 | else |
| 899 | { |
| 900 | if (strcmp (argv[arg], "on") == 0) |
| 901 | enable = true1; |
| 902 | else if (strcmp (argv[arg], "off") == 0) |
| 903 | enable = false0; |
| 904 | } |
| 905 | } |
| 906 | |
| 907 | sc = rtems_capture_watch_global (enable); |
| 908 | |
| 909 | if (sc != RTEMS_SUCCESSFUL) |
| 910 | { |
| 911 | fprintf (stdoutstdout, "error: global watch failed: %s\n", |
| 912 | rtems_status_text (sc)); |
| 913 | return; |
| 914 | } |
| 915 | |
| 916 | fprintf (stdoutstdout, "global watch %s.\n", enable ? "enabled" : "disabled"); |
| 917 | } |
| 918 | |
| 919 | |
| 920 | |
| 921 | |
| 922 | |
| 923 | |
| 924 | |
| 925 | |
| 926 | |
| 927 | |
| 928 | static char const * watch_ceiling_usage = "usage: cwceil priority\n"; |
| 929 | |
| 930 | static void |
| 931 | rtems_capture_cli_watch_ceiling (int argc, |
| 932 | char** argv, |
| 933 | const rtems_monitor_command_arg_t* command_arg __attribute__((unused)), |
| 934 | bool_Bool verbose __attribute__((unused))) |
| 935 | { |
| 936 | rtems_status_code sc; |
| 937 | int arg; |
| 938 | rtems_task_priority priority = 0; |
| 939 | |
| 940 | if (argc <= 1) |
| 941 | { |
| 942 | fprintf (stdoutstdout, watch_ceiling_usage); |
| 943 | return; |
| 944 | } |
| 945 | |
| 946 | for (arg = 1; arg < argc; arg++) |
| 947 | { |
| 948 | if (argv[arg][0] == '-') |
| 949 | { |
| 950 | fprintf (stdoutstdout, "warning: option -%c ignored\n", argv[arg][1]); |
| 951 | } |
| 952 | else |
| 953 | { |
| 954 | priority = strtoul (argv[arg], 0, 0); |
| 955 | } |
| 956 | } |
| 957 | |
| 958 | sc = rtems_capture_watch_ceiling (priority); |
| 959 | |
| 960 | if (sc != RTEMS_SUCCESSFUL) |
| 961 | { |
| 962 | fprintf (stdoutstdout, "error: watch ceiling failed: %s\n", |
| 963 | rtems_status_text (sc)); |
| 964 | return; |
| 965 | } |
| 966 | |
| 967 | fprintf (stdoutstdout, "watch ceiling is %" PRId32"d" ".\n", priority); |
| 968 | } |
| 969 | |
| 970 | |
| 971 | |
| 972 | |
| 973 | |
| 974 | |
| 975 | |
| 976 | |
| 977 | |
| 978 | |
| 979 | static char const * watch_floor_usage = "usage: cwfloor priority\n"; |
| 980 | |
| 981 | static void |
| 982 | rtems_capture_cli_watch_floor (int argc, |
| 983 | char** argv, |
| 984 | const rtems_monitor_command_arg_t* command_arg __attribute__((unused)), |
| 985 | bool_Bool verbose __attribute__((unused))) |
| 986 | { |
| 987 | rtems_status_code sc; |
| 988 | int arg; |
| 989 | rtems_task_priority priority = 0; |
| 990 | |
| 991 | if (argc <= 1) |
| 992 | { |
| 993 | fprintf (stdoutstdout, watch_floor_usage); |
| 994 | return; |
| 995 | } |
| 996 | |
| 997 | for (arg = 1; arg < argc; arg++) |
| 998 | { |
| 999 | if (argv[arg][0] == '-') |
| 1000 | { |
| 1001 | fprintf (stdoutstdout, "warning: option -%c ignored\n", argv[arg][1]); |
| 1002 | } |
| 1003 | else |
| 1004 | { |
| 1005 | priority = strtoul (argv[arg], 0, 0); |
| 1006 | } |
| 1007 | } |
| 1008 | |
| 1009 | sc = rtems_capture_watch_floor (priority); |
| 1010 | |
| 1011 | if (sc != RTEMS_SUCCESSFUL) |
| 1012 | { |
| 1013 | fprintf (stdoutstdout, "error: watch floor failed: %s\n", |
| 1014 | rtems_status_text (sc)); |
| 1015 | return; |
| 1016 | } |
| 1017 | |
| 1018 | fprintf (stdoutstdout, "watch floor is %" PRId32"d" ".\n", priority); |
| 1019 | } |
| 1020 | |
| 1021 | |
| 1022 | |
| 1023 | |
| 1024 | |
| 1025 | |
| 1026 | |
| 1027 | |
| 1028 | |
| 1029 | |
| 1030 | static char const *trigger_set_usage = |
| 1031 | "usage: %s [-?] type [to name/id] [from] [from name/id]\n"; |
| 1032 | |
| 1033 | static char const *trigger_set_types = |
| 1034 | " You can say 'type TASK' or 'type TO from FROM'\n" \ |
| 1035 | " where TASK is the task the event is happening to\n" \ |
| 1036 | " or you can say the event TO this task FROM this task.\n" \ |
| 1037 | " No type defaults to 'switch'.\n" \ |
| 1038 | " switch : context switch TASK or FROM or FROM->TO\n" \ |
| 1039 | " create : create TASK, or create TO from FROM\n" \ |
| 1040 | " start : start TASK, or start TO from FROM\n" \ |
| 1041 | " restart : restart TASK, or restart TO from FROM\n" \ |
| 1042 | " delete : delete TASK or delete TO from FROM\n" \ |
| 1043 | " begin : begin TASK\n" \ |
| 1044 | " exitted : exitted TASK\n"; |
| 1045 | |
| 1046 | |
| 1047 | |
| 1048 | |
| 1049 | typedef struct rtems_capture_cli_triggers_s |
| 1050 | { |
| 1051 | char const * name; |
| 1052 | rtems_capture_trigger_t type; |
| 1053 | int to_only; |
| 1054 | } rtems_capture_cli_triggers_t; |
| 1055 | |
| 1056 | static rtems_capture_cli_triggers_t rtems_capture_cli_triggers[] = |
| 1057 | { |
| 1058 | { "switch", rtems_capture_switch, 0 }, |
| 1059 | { "create", rtems_capture_create, 0 }, |
| 1060 | { "start", rtems_capture_start, 0 }, |
| 1061 | { "restart", rtems_capture_restart, 0 }, |
| 1062 | { "delete", rtems_capture_delete, 0 }, |
| 1063 | { "begin", rtems_capture_begin, 1 }, |
| 1064 | { "exitted", rtems_capture_exitted, 1 } |
| 1065 | }; |
| 1066 | |
| 1067 | typedef enum rtems_capture_cli_trig_state_e |
| 1068 | { |
| 1069 | trig_type, |
| 1070 | trig_to, |
| 1071 | trig_from_from, |
| 1072 | trig_from |
| 1073 | } rtems_capture_cli_trig_state_t; |
| 1074 | |
| 1075 | #define RTEMS_CAPTURE_CLI_TRIGGERS_NUM(sizeof (rtems_capture_cli_triggers) / sizeof (rtems_capture_cli_triggers_t )) \ |
| 1076 | (sizeof (rtems_capture_cli_triggers) / sizeof (rtems_capture_cli_triggers_t)) |
| 1077 | |
| 1078 | static void |
| 1079 | rtems_capture_cli_trigger_worker (int set, int argc, char** argv) |
| 1080 | { |
| 1081 | rtems_status_code sc; |
| 1082 | int arg; |
| 1083 | int trigger = 0; |
| 1084 | rtems_capture_trigger_mode_t trigger_mode = rtems_capture_from_any; |
| 1085 | bool_Bool trigger_set = false0; |
| 1086 | bool_Bool is_from = false0; |
| 1087 | rtems_name name = 0; |
| 1088 | rtems_id id = 0; |
| 1089 | bool_Bool valid_name = false0; |
| 1090 | bool_Bool valid_id = false0; |
| 1091 | rtems_name from_name = 0; |
| 1092 | rtems_id from_id = 0; |
| 1093 | bool_Bool from_valid_name = false0; |
| 1094 | bool_Bool from_valid_id = false0; |
| 1095 | rtems_name to_name = 0; |
| 1096 | rtems_id to_id = 0; |
| 1097 | bool_Bool to_valid_name = false0; |
| 1098 | bool_Bool to_valid_id = false0; |
| 1099 | |
| 1100 | for (arg = 1; arg < argc; arg++) |
| 1101 | { |
| 1102 | if (argv[arg][0] == '-') |
| 1103 | { |
| 1104 | switch (argv[arg][1]) |
| 1105 | { |
| 1106 | case '?': |
| 1107 | fprintf (stdoutstdout, trigger_set_usage, set ? "ctset" : "ctclear"); |
| 1108 | fprintf (stdoutstdout, trigger_set_types); |
| 1109 | return; |
| 1110 | default: |
| 1111 | fprintf (stdoutstdout, "warning: option -%c ignored\n", argv[arg][1]); |
| 1112 | break; |
| 1113 | } |
| 1114 | } |
| 1115 | else |
| 1116 | { |
| 1117 | if (!trigger_set) |
| 1118 | { |
| 1119 | bool_Bool found = false0; |
| 1120 | int t; |
| 1121 | |
| 1122 | for (t = 0; t < RTEMS_CAPTURE_CLI_TRIGGERS_NUM(sizeof (rtems_capture_cli_triggers) / sizeof (rtems_capture_cli_triggers_t )); t++) |
| 1123 | if (strcmp (argv[arg], rtems_capture_cli_triggers[t].name) == 0) |
| 1124 | { |
| 1125 | trigger = t; |
| 1126 | found = true1; |
| 1127 | break; |
| 1128 | } |
| 1129 | |
| 1130 | trigger_set = true1; |
| 1131 | |
| 1132 | |
| 1133 | |
| 1134 | |
| 1135 | |
| 1136 | if (found) |
| 1137 | continue; |
| 1138 | } |
| 1139 | |
| 1140 | if (strcmp (arg[argv], "from") == 0) |
| 1141 | { |
| 1142 | if (is_from) |
| 1143 | fprintf (stdoutstdout, "warning: extra 'from' ignored\n"); |
| 1144 | |
| 1145 | is_from = 1; |
| 1146 | continue; |
| 1147 | } |
| 1148 | |
| 1149 | if (!rtems_capture_cli_get_name_id (argv[arg], &valid_name, &valid_id, |
| 1150 | &name, &id)) |
| 1151 | return; |
| 1152 | |
| 1153 | if (valid_name) |
| 1154 | { |
| 1155 | if (is_from) |
| 1156 | { |
| 1157 | if (!from_valid_name && !from_valid_id) |
| 1158 | { |
| 1159 | from_valid_name = true1; |
| 1160 | from_name = name; |
| 1161 | } |
| 1162 | else |
| 1163 | fprintf (stdoutstdout, "warning: extra arguments ignored\n"); |
| 1164 | } |
| 1165 | else if (!to_valid_name && !to_valid_id) |
| 1166 | { |
| 1167 | to_valid_name = true1; |
| 1168 | to_name = name; |
| 1169 | } |
| 1170 | else |
| 1171 | fprintf (stdoutstdout, "warning: extra arguments ignored\n"); |
| 1172 | } |
| 1173 | |
| 1174 | if (valid_id) |
| 1175 | { |
| 1176 | if (is_from) |
| 1177 | { |
| 1178 | if (!from_valid_name && !from_valid_id) |
| 1179 | { |
| 1180 | from_valid_id = true1; |
| 1181 | from_id = id; |
| 1182 | } |
| 1183 | else |
| 1184 | fprintf (stdoutstdout, "warning: extra arguments ignored\n"); |
| 1185 | } |
| 1186 | else if (!to_valid_name && !to_valid_id) |
| 1187 | { |
| 1188 | to_valid_id = true1; |
| 1189 | to_id = id; |
| 1190 | } |
| 1191 | else |
| 1192 | fprintf (stdoutstdout, "warning: extra arguments ignored\n"); |
| 1193 | } |
| 1194 | } |
| 1195 | } |
| 1196 | |
| 1197 | if (is_from && rtems_capture_cli_triggers[trigger].to_only) |
| 1198 | { |
| 1199 | fprintf (stdoutstdout, "error: a %s trigger can be a TO trigger\n", |
| 1200 | rtems_capture_cli_triggers[trigger].name); |
| 1201 | return; |
| 1202 | } |
| 1203 | |
| 1204 | if (!to_valid_name && !to_valid_id && !from_valid_name && !from_valid_id) |
| 1205 | { |
| 1206 | fprintf (stdoutstdout, trigger_set_usage); |
| 1207 | return; |
| 1208 | } |
| 1209 | |
| 1210 | if (!is_from && !to_valid_name && !to_valid_id) |
| 1211 | { |
| 1212 | fprintf (stdoutstdout, "error: a %s trigger needs a TO name or id\n", |
| 1213 | rtems_capture_cli_triggers[trigger].name); |
| 1214 | return; |
| 1215 | } |
| 1216 | |
| 1217 | if (is_from && !from_valid_name && !from_valid_id) |
| 1218 | { |
| 1219 | fprintf (stdoutstdout, "error: a %s trigger needs a FROM name or id\n", |
| 1220 | rtems_capture_cli_triggers[trigger].name); |
| 1221 | return; |
| 1222 | } |
| 1223 | |
| 1224 | if ((from_valid_name || from_valid_id) && (to_valid_name || to_valid_id)) |
| 1225 | trigger_mode = rtems_capture_from_to; |
| 1226 | else if (from_valid_name || from_valid_id) |
| 1227 | trigger_mode = rtems_capture_to_any; |
| 1228 | else if (to_valid_name || to_valid_id) |
| 1229 | trigger_mode = rtems_capture_from_any; |
| 1230 | |
| 1231 | if (set) |
| 1232 | sc = rtems_capture_set_trigger (from_name, from_id, to_name, to_id, |
| 1233 | trigger_mode, |
| 1234 | rtems_capture_cli_triggers[trigger].type); |
| 1235 | else |
| 1236 | sc = rtems_capture_clear_trigger (from_name, from_id, to_name, to_id, |
| 1237 | trigger_mode, |
| 1238 | rtems_capture_cli_triggers[trigger].type); |
| 1239 | |
| 1240 | if (sc != RTEMS_SUCCESSFUL) |
| 1241 | { |
| 1242 | fprintf (stdoutstdout, "error: %sing the trigger failed: %s\n", |
| 1243 | set ? "sett" : "clear", rtems_status_text (sc)); |
| 1244 | return; |
| 1245 | } |
| 1246 | |
| 1247 | fprintf (stdoutstdout, "trigger %s.\n", set ? "set" : "cleared"); |
| 1248 | } |
| 1249 | |
| 1250 | |
| 1251 | |
| 1252 | |
| 1253 | |
| 1254 | |
| 1255 | |
| 1256 | |
| 1257 | |
| 1258 | |
| 1259 | static void |
| 1260 | rtems_capture_cli_trigger_set (int argc, |
| 1261 | char** argv, |
| 1262 | const rtems_monitor_command_arg_t* command_arg __attribute__((unused)), |
| 1263 | bool_Bool verbose __attribute__((unused))) |
| 1264 | { |
| 1265 | rtems_capture_cli_trigger_worker (1, argc, argv); |
| 1266 | } |
| 1267 | |
| 1268 | |
| 1269 | |
| 1270 | |
| 1271 | |
| 1272 | |
| 1273 | |
| 1274 | |
| 1275 | |
| 1276 | |
| 1277 | static void |
| 1278 | rtems_capture_cli_trigger_clear (int argc, |
| 1279 | char** argv, |
| 1280 | const rtems_monitor_command_arg_t* command_arg __attribute__((unused)), |
| 1281 | bool_Bool verbose __attribute__((unused))) |
| 1282 | { |
| 1283 | rtems_capture_cli_trigger_worker (0, argc, argv); |
| 1284 | } |
| 1285 | |
| 1286 | |
| 1287 | |
| 1288 | |
| 1289 | |
| 1290 | |
| 1291 | |
| 1292 | |
| 1293 | |
| 1294 | |
| 1295 | static void |
| 1296 | rtems_capture_cli_trace_records (int argc, |
| 1297 | char** argv, |
| 1298 | const rtems_monitor_command_arg_t* command_arg __attribute__((unused)), |
| 1299 | bool_Bool verbose __attribute__((unused))) |
| 1300 | { |
| 1301 | rtems_status_code sc; |
| 1302 | bool_Bool csv = false0; |
| 1303 | static int dump_total = 22; |
| 1304 | int total; |
| 1305 | int count; |
| 1306 | uint32_t read; |
| 1307 | rtems_capture_record_t* rec; |
| 1308 | int arg; |
| 1309 | |
| 1310 | for (arg = 1; arg < argc; arg++) |
| 1311 | { |
| 1312 | if (argv[arg][0] == '-') |
| 1313 | { |
| 1314 | if (argv[arg][1] == 'c') |
| 1315 | csv = true1; |
| 1316 | else |
| 1317 | fprintf (stdoutstdout, "warning: option -%c ignored\n", argv[arg][1]); |
| 1318 | } |
| 1319 | else |
| 1320 | { |
| 1321 | size_t i; |
| 1322 | size_t l; |
| 1323 | |
| 1324 | l = strlen (argv[arg]); |
| 1325 | |
| 1326 | for (i = 0; i < l; i++) |
| 1327 | if (!isdigit ((unsigned char)argv[arg][i])((*__ctype_b_loc ())[(int) (((unsigned char)argv[arg][i]))] & (unsigned short int) _ISdigit)) |
| 1328 | { |
| 1329 | fprintf (stdoutstdout, "error: not a number\n"); |
| 1330 | return; |
| 1331 | } |
| 1332 | |
| 1333 | dump_total = strtoul (argv[arg], 0, 0); |
| 1334 | } |
| 1335 | } |
| 1336 | |
| 1337 | total = dump_total; |
| 1338 | |
| 1339 | while (total) |
| 1340 | { |
| 1341 | sc = rtems_capture_read (0, 0, &read, &rec); |
| 1342 | |
| 1343 | if (sc != RTEMS_SUCCESSFUL) |
| 1344 | { |
| 1345 | fprintf (stdoutstdout, "error: trace read failed: %s\n", rtems_status_text (sc)); |
| 1346 | rtems_capture_flush (0); |
| 1347 | return; |
| 1348 | } |
| 1349 | |
| 1350 | |
| 1351 | |
| 1352 | |
| 1353 | |
| 1354 | |
| 1355 | if (read == 0) |
| 1356 | { |
| 1357 | rtems_capture_release (read); |
| 1358 | break; |
| 1359 | } |
| 1360 | |
| 1361 | count = total < read ? total : read; |
| 1362 | |
| 1363 | while (count--) |
| 1364 | { |
| 1365 | if (csv) |
| 1366 | fprintf (stdoutstdout, "%08" PRIxPTR"x" ",%03" PRIu32"u" |
| 1367 | ",%03" PRIu32"u" ",%04" PRIx32"x" ",%" PRId32"d" ",%" PRId32"d" "\n", |
| 1368 | (uintptr_t) rec->task, |
| 1369 | (rec->events >> RTEMS_CAPTURE_REAL_PRIORITY_EVENT(0)) & 0xff, |
| 1370 | (rec->events >> RTEMS_CAPTURE_CURR_PRIORITY_EVENT(8)) & 0xff, |
| 1371 | (rec->events >> RTEMS_CAPTURE_EVENT_START(16)), |
| 1372 | rec->ticks, rec->tick_offset); |
| 1373 | else |
| 1374 | { |
| 1375 | unsigned long long t; |
| 1376 | uint32_t event; |
| 1377 | int e; |
| 1378 | |
| 1379 | event = rec->events >> RTEMS_CAPTURE_EVENT_START(16); |
| 1380 | |
| 1381 | t = rec->ticks; |
| 1382 | t *= rtems_capture_tick_time (); |
| 1383 | t += rec->tick_offset; |
| 1384 | |
| 1385 | for (e = RTEMS_CAPTURE_EVENT_START(16); e < RTEMS_CAPTURE_EVENT_END(28); e++) |
| 1386 | { |
| 1387 | if (event & 1) |
| 1388 | { |
| 1389 | fprintf (stdoutstdout, "%9li.%06li ", (unsigned long) (t / 1000000), |
| 1390 | (unsigned long) (t % 1000000)); |
| 1391 | rtems_monitor_dump_id (rtems_capture_task_id (rec->task)); |
| 1392 | fprintf (stdoutstdout, " "); |
| 1393 | rtems_monitor_dump_name (rtems_capture_task_name (rec->task)); |
| 1394 | fprintf (stdoutstdout, " %3" PRId32"d" " %3" PRId32"d" " %s\n", |
| 1395 | (rec->events >> RTEMS_CAPTURE_REAL_PRIORITY_EVENT(0)) & 0xff, |
| 1396 | (rec->events >> RTEMS_CAPTURE_CURR_PRIORITY_EVENT(8)) & 0xff, |
| 1397 | rtems_capture_event_text (e)); |
| 1398 | } |
| 1399 | event >>= 1; |
| 1400 | } |
| 1401 | } |
| 1402 | rec++; |
| 1403 | } |
| 1404 | |
| 1405 | count = total < read ? total : read; |
| 1406 | |
| 1407 | if (count < total) |
| 1408 | total -= count; |
| 1409 | else |
| 1410 | total = 0; |
| 1411 | |
| 1412 | rtems_capture_release (count); |
| 1413 | } |
| 1414 | } |
| 1415 | |
| 1416 | |
| 1417 | |
| 1418 | |
| 1419 | |
| 1420 | |
| 1421 | |
| 1422 | |
| 1423 | |
| 1424 | |
| 1425 | |
| 1426 | static void |
| 1427 | rtems_capture_cli_flush (int argc, |
| 1428 | char** argv, |
| 1429 | const rtems_monitor_command_arg_t* command_arg __attribute__((unused)), |
| 1430 | bool_Bool verbose __attribute__((unused))) |
| 1431 | { |
| 1432 | rtems_status_code sc; |
| 1433 | bool_Bool prime = true1; |
| 1434 | int arg; |
| 1435 | |
| 1436 | for (arg = 1; arg < argc; arg++) |
| 1437 | { |
| 1438 | if (argv[arg][0] == '-') |
| 1439 | { |
| 1440 | if (argv[arg][1] == 'n') |
| 1441 | prime = false0; |
| 1442 | else |
| 1443 | fprintf (stdoutstdout, "warning: option -%c ignored\n", argv[arg][1]); |
| 1444 | } |
| 1445 | } |
| 1446 | |
| 1447 | sc = rtems_capture_flush (prime); |
| 1448 | |
| 1449 | if (sc != RTEMS_SUCCESSFUL) |
| 1450 | { |
| 1451 | fprintf (stdoutstdout, "error: flush failed: %s\n", rtems_status_text (sc)); |
| 1452 | return; |
| 1453 | } |
| 1454 | |
| 1455 | fprintf (stdoutstdout, "trace buffer flushed and %s.\n", |
| 1456 | prime ? "primed" : "not primed"); |
| 1457 | } |
| 1458 | |
| 1459 | static rtems_monitor_command_entry_t rtems_capture_cli_cmds[] = |
| 1460 | { |
| 1461 | { |
| 1462 | "copen", |
| 1463 | "usage: copen [-i] size\n", |
| 1464 | 0, |
| 1465 | rtems_capture_cli_open, |
| 1466 | { 0 }, |
| 1467 | 0 |
| 1468 | }, |
| 1469 | { |
| 1470 | "cclose", |
| 1471 | "usage: cclose\n", |
| 1472 | 0, |
| 1473 | rtems_capture_cli_close, |
| 1474 | { 0 }, |
| 1475 | 0 |
| 1476 | }, |
| 1477 | { |
| 1478 | "cenable", |
| 1479 | "usage: cenable\n", |
| 1480 | 0, |
| 1481 | rtems_capture_cli_enable, |
| 1482 | { 0 }, |
| 1483 | 0 |
| 1484 | }, |
| 1485 | { |
| 1486 | "cdisable", |
| 1487 | "usage: cdisable\n", |
| 1488 | 0, |
| 1489 | rtems_capture_cli_disable, |
| 1490 | { 0 }, |
| 1491 | 0 |
| 1492 | }, |
| 1493 | { |
| 1494 | "ctlist", |
| 1495 | "usage: ctlist \n", |
| 1496 | 0, |
| 1497 | rtems_capture_cli_task_list, |
| 1498 | { 0 }, |
| 1499 | 0 |
| 1500 | }, |
| 1501 | { |
| 1502 | "ctload", |
| 1503 | "usage: ctload \n", |
| 1504 | 0, |
| 1505 | rtems_capture_cli_task_load, |
| 1506 | { 0 }, |
| 1507 | 0 |
| 1508 | }, |
| 1509 | { |
| 1510 | "cwlist", |
| 1511 | "usage: cwlist\n", |
| 1512 | 0, |
| 1513 | rtems_capture_cli_watch_list, |
| 1514 | { 0 }, |
| 1515 | 0 |
| 1516 | }, |
| 1517 | { |
| 1518 | "cwadd", |
| 1519 | "usage: cwadd [task name] [id]\n", |
| 1520 | 0, |
| 1521 | rtems_capture_cli_watch_add, |
| 1522 | { 0 }, |
| 1523 | 0 |
| 1524 | }, |
| 1525 | { |
| 1526 | "cwdel", |
| 1527 | "usage: cwdel [task name] [id]\n", |
| 1528 | 0, |
| 1529 | rtems_capture_cli_watch_del, |
| 1530 | { 0 }, |
| 1531 | 0 |
| 1532 | }, |
| 1533 | { |
| 1534 | "cwctl", |
| 1535 | "usage: cwctl [task name] [id] on/off\n", |
| 1536 | 0, |
| 1537 | rtems_capture_cli_watch_control, |
| 1538 | { 0 }, |
| 1539 | 0 |
| 1540 | }, |
| 1541 | { |
| 1542 | "cwglob", |
| 1543 | "usage: cwglob on/off\n", |
| 1544 | 0, |
| 1545 | rtems_capture_cli_watch_global, |
| 1546 | { 0 }, |
| 1547 | 0 |
| 1548 | }, |
| 1549 | { |
| 1550 | "cwceil", |
| 1551 | "usage: cwceil priority\n", |
| 1552 | 0, |
| 1553 | rtems_capture_cli_watch_ceiling, |
| 1554 | { 0 }, |
| 1555 | 0 |
| 1556 | }, |
| 1557 | { |
| 1558 | "cwfloor", |
| 1559 | "usage: cwfloor priority\n", |
| 1560 | 0, |
| 1561 | rtems_capture_cli_watch_floor, |
| 1562 | { 0 }, |
| 1563 | 0 |
| 1564 | }, |
| 1565 | { |
| 1566 | "ctrace", |
| 1567 | "usage: ctrace [-c] [-r records]\n", |
| 1568 | 0, |
| 1569 | rtems_capture_cli_trace_records, |
| 1570 | { 0 }, |
| 1571 | 0 |
| 1572 | }, |
| 1573 | { |
| 1574 | "ctset", |
| 1575 | "usage: ctset -h\n", |
| 1576 | 0, |
| 1577 | rtems_capture_cli_trigger_set, |
| 1578 | { 0 }, |
| 1579 | 0 |
| 1580 | }, |
| 1581 | { |
| 1582 | "ctclear", |
| 1583 | "usage: ctclear -?\n", |
| 1584 | 0, |
| 1585 | rtems_capture_cli_trigger_clear, |
| 1586 | { 0 }, |
| 1587 | 0 |
| 1588 | }, |
| 1589 | { |
| 1590 | "cflush", |
| 1591 | "usage: cflush [-n]\n", |
| 1592 | 0, |
| 1593 | rtems_capture_cli_flush, |
| 1594 | { 0 }, |
| 1595 | 0 |
| 1596 | } |
| 1597 | }; |
| 1598 | |
| 1599 | |
| 1600 | |
| 1601 | |
| 1602 | |
| 1603 | |
| 1604 | |
| 1605 | |
| 1606 | |
| 1607 | |
| 1608 | |
| 1609 | rtems_status_code |
| 1610 | rtems_capture_cli_init (rtems_capture_timestamp timestamp) |
| 1611 | { |
| 1612 | size_t cmd; |
| 1613 | |
| 1614 | capture_timestamp = timestamp; |
| 1615 | |
| 1616 | for (cmd = 0; |
| 1617 | cmd < sizeof (rtems_capture_cli_cmds) / sizeof (rtems_monitor_command_entry_t); |
| 1618 | cmd++) |
| 1619 | rtems_monitor_insert_cmd (&rtems_capture_cli_cmds[cmd]); |
| 1620 | |
| 1621 | return RTEMS_SUCCESSFUL; |
| 1622 | } |
